TPMS or not TPMS, that is the question!
Tacit
Canada
C?ID=233267
Hello everyone,
I started this thread because I have a 2010 A6 Quattro Avant and I thought it had the Tire Pressure Monitoring System (TPMS), however, I now notice that all four of my tires are about 15psi low, so now I'm doubting if I have TPMS or if the system is malfunctioning. When I start the car, I never see a TPMS or tire with the "!" symbol and when I press the "check" button on the dashboard, there is no reference to TPMS. I also checked the manual and it says with a footnote "if installed".
???????? When you turn key on, do you get a TPMS lite on dash for a second during bulb check or can you see the lamp during outputs?
I did not notice any dash warning/idiot lights that show the TPMS icon or text, but I will check the next time I start the car.
So I posted my auto-scan (which I will repost below) to see if the car has TPMS but it's broken or if TPMS was never installed. From the reviews there is no mention of TPMS in my autoscan, so it is possible (at least for a Canadian Audi) that TPMS is/was an option for 2010. Here's the auto-scan:
VCDS Version: Release 15.7.1 (x64) Running on Windows 7 x64
Data version: 20150904
Sunday,01,November,2015,16:24:40:54225
Chassis Type: FB (4F0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 36 42 46 4F 52 53 55 56 5F
          62 6C 6D 72 76
VIN: WAU8GCFB8AN065799   Mileage: 124200km-77174miles
Address 01: Engine (CCA)       Labels: None
   Part No SW: 4F1 910 551 D    HW: 4F1 907 551
   Component: 3.0l V6 TFSI        0050
   Revision: --H06---    Serial number:
   Coding: 010D000A190F0120
   Shop #: WSC 38655 001 1048576
   VCID: 2447F77DE7082E1E19-8070
   Part No SW: 4F9 910 156 A    HW: 09L 927 156 C
   Component: AG6 09L 3,0TFSI USA 0020
   Revision: --H05---    Serial number:        4556695
   Shop #: WSC 02325 785 00200
   VCID: 2A5B1945852CF86E23-807E
   Part No SW: 4F0 910 517 AL    HW: 4F0 614 517 BA
   Component: ESP8 quattro    H03 0060
   Coding: 0020921
   VCID: 6ED3D5557944D44EBF-803A
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602501505762
   Coding: 0000135
   Shop #: WSC 02323 785 00200
   VCID: 2541EA79EC32D7160E-8070
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000075    Serial number: 00000030519136
   Coding: 0524582
   VCID: 1D31C299C4621FD656-8048
   Part No SW: 4F0 910 279 M    HW: 4F0 907 279 A
   Component: ILM Fahrer      H22 0320
   Coding: 0113114
   Shop #: WSC 02156 785 00200
   VCID: 3365042152E6B9A690-8066
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02156
   Coding: 00146221
   Shop #: WSC 02156
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 1521DAB9FC5247969E-8040
Address 15: Airbags (J234)       Labels: 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 R    HW: 4F0 959 655 H
   Component: Airbag AU1042 H06 0160
   Revision: --------    Serial number: 003FA00174NK
   Coding: 30314237303430303033554A304C34463053
   ROD: EV_Airba10AURB4.rod
   VCID: 36633D358994AC8EB7-8062
   Serial number: 3574SRB400009AC4C2EN
   Serial number: 3584SRB40000AB3871AB
   Serial number: 3516HRB401V9E0SOR3B7
   Serial number: 3526HRB40239OPR7ABQ4
   Serial number: 3554NRB40000571723CX
   Serial number: 3564NRB400005720CE71
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Component: J0527               0530
   Revision: 00H06000    Serial number: 90025100200149
   Coding: 0012342
   VCID: 275DE071963EC5063C-8072
   Component: E0221           H02 0100
00886 - Turn Signal Switch (E2)
                    Fault Status: 00101110
                    Reset counter: 49
                    Mileage: 124079 km
                    Date: 2015.10.11
                    Time: 23:22:13
Address 17: Instruments (J285)       Labels: 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 901 M    HW: 4F0 920 901 M
   Component: KOMBIINSTR.   H08 0147
   Revision: 00200000    Serial number: DGZ04DH2A
   Coding: 8BD6120502000008020300
   Shop #: WSC 02391 823 56573
   VCID: 2C571F5D4FD8E65ED1-8078
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 M    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0035
   Revision: LB100029    Serial number: 2900L102190223
   Coding: 000303
   VCID: 39793609B08A43F65A-806C
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Part No SW: 4F0 959 760 C    HW: 4F0 959 760 C
   Component: MEM-FS        H08 0062
   Revision: AA000000    Serial number: 00001010068793
   Coding: 00581B00004011110000
   VCID: 31690E2968FA8BB6E2-8064
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000102964986
   Coding: 011F57205E40410001
   VCID: 46834DF5F1743C0E27-8012
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 K    HW: 4F0 907 289 K
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01271347550000
   Coding: 7764509
   VCID: 326B0125ADFCB0AE9B-8066
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000629299
   Coding: 0002014
   VCID: 5EB3859589E444CE0F-800A
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000102969936
   VCID: 45814AF9CC7237162E-8010
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000222
   Shop #: WSC 02145 785 00200
   VCID: 2149FE69F81A3B3672-8074
   Part No: 8P0 907 357 H
   Coding: 0000003
   VCID: 3F8D58116EAE6DC664-806A
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335BS0A7555215
   Coding: 020000020100000000
   VCID: 1D31C29904621FD656-8048
   Part No SW: 4E0 035 648 A    HW: 4E0 035 648
   Component: B-B-NA        H60 0117
   Revision: --------    Serial number: 322BB0BB000203
   Coding: 010000010102C1EF41000305EF6300030200
   Shop #: WSC 01676 002 1048576
   VCID: 2447F77D27082E1E19-8070
   Subsystem 1 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Subsystem 2 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 N
   Component: Bedienteil MM  H01 0060
            000 -  -  - Intermittent
                    Reset counter: 24
                    Mileage: 122582 km
                    Date: 2015.08.12
                    Time: 12:47:44
                    Voltage: 13.00 V
                    Bin. Bits: 10000000 00000000
                    Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000010173389
   Coding: 010E57204040220001
   VCID: 438554E1C246092600-8016
   Part No SW: 4F0 910 441 D    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J02211W
   Coding: 1000205
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 G
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7DF5D4F58265E91-8038
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD20.02.10--H29001001C0023ÿ
   Subsystem 4 - Serial number: 1C0023ÿ
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Revision:             Serial number: 0000010177477
   Part No SW: 4L0 910 283 B    HW: 4L0 919 283 B
   Component: Parkhilfe 4-Kan H02 0500
   Revision: 00H02000    Serial number: 12331004201887
   Coding: 0021216
   VCID: 2959E649802AF3762A-807C
End-------------------------(Elapsed Time: 03:21)--------------------------
AIB Wolfgang
Hello
This car was ordered without Tire Pressure Control. PR 7K0 !
How about call Audi dealer with VIN # or customer advocate at Audi headquarters customer care?
Post Picture of white tag in trunk area with assembly build data?
Keithuk
Stoke on Trent, England
C?ID=122432
Depend on which system is fitted IF. If you have the direct system you will have different tyre pressure sensors in the wheel noted by a threaded tyre valve.
Volkswagen Tyre Pressure Monitoring System (TPMS)
It appear that Canada have the obligatory TMPS the same a USA. http://www.tc.gc.ca/eng/motorvehiclesafety/roadsafety-1158.htm
Even if your tyres are all 15psi the indirect system won't be alerted as the rotational speed will all be the same.
I have 8 error codes for Tyre Pressure Monitoring System (TPMS):
VAG 03159
VAG 8392961, EOBD II C104C
VAG 8397058, EOBD II C1050
VAG 8397314, EOBD II C1051
VAG 8397570, EOBD II C1052
VAG 8397826, EOBD II C1053
VAG 8400898, EOBD II C1054
VAG 8400901, 8400904, EOBD II C1056
Can I come out f the corner now for Milk time and take off this DUNCE hat?
:p
GTIspirit
C?ID=245724
I'm not so sure this is true for all systems. Case in point, installed snow tires with 17" rims on my 2015 GTI. About 12miles later, on second ignition key cycle, TPMS light came on. Huh, I double checked and all were set to the same pressure when installed. Drove home a little nervously, then read the owners manual.
Owners manual specifically states that the indirect TPMS system must be reset when changing wheels and tires. Did that and all is good. So at least on this car, North American (USA) model, the indirect system is more sophisticated that just rotational speed discrepancies.
Correct, the FMVSS that apply are a performance-based standard and they demand that the system be able to identify a situation where all four tires are equally (but grossly) under-inflated. Exactly how an indirect system accomplishes this, I do not know, but the car manufacturers have to prove that it can in order to get these systems certified.
vu2gte
India
C?ID=262838
Could it be that there is a speed sensor on the transmission and this reading combined with wheel speed sensors and engine rpm for a given speed /gear ratio triggers it?
Adrian E
C?ID=258567
Indirect TPMS can't detect gross underinflation, which I believe is why markets with that requirement or another performance based test will fit direct for that market. Audi in Europe have used both systems, but the last I can think of that had direct were the D3 A8. Cheaper models were generally first to move to indirect (which is what BMW have also used in Europe with run on flat tyres for many years) as no sensor costs.
Indirect is basically useless except where 1 tyre gets a puncture.
That's not correct. The US performance based standard requires a TPMS system to detect when all four tires are grossly (but equally) under-inflated, and there are lots of cars sold here now that use indirect systems. I'm not sure exactly how they accomplish this, but they do.
