Results 1 to 10 of 11
Thread: 2013 GTI Lots of codes
    Verified VCDS User tehfalcon's Avatar
    Oct 2015
    VCDS Version: Release 15.7.1 (x64) Running on Windows 10 x64
    Data version: 20150904
    Thursday,29,October,2015,09:38:35:15363
    Chassis Type: AJ (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWHD7AJ6DW081984   Mileage: 52810km-32814miles
    04-Steering Angle -- Status: Sporadic communication error 1000
    Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
       Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
       Revision: E3H26---    Serial number:
       Coding: 040301081C070160
       Shop #: WSC 78384 155 427622
       VCID: 78D11B040BEF48FE65-802C
    049446 - No Communications with Steering Angle Sender (G85)
                   U0126 - 000 -  - Intermittent
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal
    Readiness: 1110 1101
    Address 02: Auto Trans        Labels: 02E-927-770.lbl
       Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 3513
       Revision: 05653104    Serial number: 00001504092318
       Shop #: WSC 04940 001 00001
       VCID: 2773087896D117063C-8072
    18036 - Powertrain Data Bus
                P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
       Revision: 00H31001
       Coding: 114B600C492A80FB881406EC921D0141B70800
       VCID: 7DDF0A10E4CD6DD636-8028
    00003 - Control Module
                013 - Check DTC Memory
    Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010001002
       VCID: 7BDB0408F2D963E608-802E
       Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
       Component: BCM PQ35  M   111 0709
       Revision: AB111709
       Coding: 67190AB880772EC4C00A41C1640081EC4FB103EE435D8D60648860A40040
       VCID: 41A7B6E0D8B5C93612-8014
       Component: Wischer 27071  26  0512
       Coding: 009FB5
    10 Faults Found:
                010 - Open or Short to Plus
    00984 - Left Tail Light (M4)
    00985 - Right Tail Light (M2)
    02661 - Wire for Speed Signal
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R00HGAC
       Coding: 00004737
       VCID: 3C59C714B757A4DE41-8068
       Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
       Component: BF-Gewichtss.  006 0001
       Serial number: ---0000R--00005J3A00
       Serial number: 3572MSME4E1A6674ZZZ2
       Serial number: 3582MSME4F332472ZZZY
       Serial number: 3512QSME48231B7AZZZ.
       Serial number: 3522QSME482D1F6CZZZA
       Serial number: 35527SME135D3A2EZZZR
       Serial number: 35627SME0448372EZZZJ
       Part No SW: 5K0 953 507 AJ    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90440LGM001B4
       Coding: 589A140000
       ROD: EV_SMLSNGKUDS_SE36.rod
       VCID: 78D11B04C3EF48FE65-802C
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0032
       Serial number: 0054388
       Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
       Component: KOMBI         H05 0705
       Coding: 270F01
       VCID: 3753D8388E718786AC-8062
       Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
       Component: J533  Gateway H42 1632
       Revision:   H42       Serial number: 090812F2002532
       Coding: 350002
       VCID: 3FA3B018AE41BFC664-806A
                000 -  -  - Intermittent
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RKEYE07
       VCID: 7EDD0D1C29CB76CE2F-802A
       Component: IMMO          H05 0705
       VCID: 6AF5314C8D43EA6EE3-803E
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663253386
       Coding: 010100
       VCID: 2A75F14C45C32A6E23-807E
       Coding: 0001204
       VCID: 3147E620A81559B6E2-8064
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 74     3305
       Revision: 00H22000
       VCID: 3753D83846718786AC-8062
       Coding: 0001204
       VCID: 3245E92CAD1362AE9B-8066
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L3212222
       Coding: 01000400040007
       Shop #: WSC 00066 000 00000
       VCID: 63EB5C686269BB2620-8036
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 354FD2305C7D7596BE-8060
       Coding: 0001168
       VCID: 364DD53C417B7E8EB7-8062
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007663247582
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA.rod
       VCID: 3A55C10CBD639AEE53-806E
    End-------------------------(Elapsed Time: 01:53)--------------------------
    I'm not worried about the bulb or MAF codes.
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by tehfalcon View Post
    What specific concerns do you have then? There's more than one thing happening in your scan. What's the history?
    Also, there are some indications that you or someone else has been messing around with VCDS or otherwise doing retrofits:
    Please describe any work or modifications you've done to the car, and any settings changes you've made with VCDS. Include everything, even stuff you think can't possibly be related, like lighting mods. Also, please post the contents of the AdpLog.txt and CodingLog.txt in your C:\Ross-Tech\VCDS\Debug folder. We're not trying to bust you for anything here; this is a mod-friendly forum. But, it's much easier to steer you toward a solution if we know how you got into trouble.
    Jason
  3. Likes Uwe liked this post
    (waiting on verification)
    Done -- and moved to Car Repair Support.
    Oct 2015
    The car has been tuned to Stage 2, and other then that nothing retro fitted, I installed LED bulbs and that's why the bulb warnings are on.
    The car was aligned, and now there are steering wheel angle faults and the TPMS faults.
    So I tried to calibrate the steering wheel angle sensor, then did the steering wheel lock calibration and both were successful, but now the ABS and Traction light is on. Not worried about being busted haha, car's not under warranty anymore, that's why I invested in VCDS.
    It also as a ESP Function Test test code now after I had someone look at it. I really need help because there's no ABS or traction control right now, and winter is right over the mountains (im in colorado).
    HQ
    Clear codes out of the ECM first. Then see if you can clear out the ABS code of 01314 - Engine Control Module: 013 - Check DTC Memory.
    Hope you didn't skip leg day at the gym:
    http://wiki.ross-tech.com/wiki/index..._Intake_Valves
    Is there a button for TPMS in the upper left corner of your glove box? If yes, press it for 10 seconds while the engine is at idle.
    Jef
  7. Likes Uwe, jyoung8607 liked this post
    Oct 2015
    Great, also yes I do have the button, holding it did get the light to turn off, but the code is still there even after clearing it.
    HQ
    Do your leg exercises first. Odds are the TPMS will sort itself out on a test drive.
    Jef
  10. Likes Uwe, jyoung8607 liked this post
  11. #8
    Oct 2015
    Tried doing the exercises, I enter the security access, then go to the basic settings and it shows up initially, then when I activate the basic settings it turns red and says not group not available, what am I doing wrong?
  12. #9
    HQ
    Was the engine warm? IE, can you safely touch the exhaust header right before you did the test? If not, the engine is too hot, which in turn heats up the ABS module.
    Jef
  13. Likes Uwe liked this post
  14. #10
    Oct 2015
    Probably too hot, it was after a short drive I tried.
