Golf MK7 Gearbox Launch Counter.
Adam.
C?ID=136075
Hi guys,
I know this was available on previous platforms but can't seem to find it on the MK7/MQB platform.
Can you advise if this is the case or am I looking in the wrong place?
Cheers
Adam.
C?ID=136075
All Mk.7 Golfs use the same gearbox, right? :banghead:
Please post an Auto-Scan so we can see what your car is made of. ;)
Attached auto-scan below.
VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
Data version: 20151216
Wednesday,13,January,2016,18:13:32:54276
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZFW2XXXXX
Address 01: Engine (J623-CJXC)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 E    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 091D00322466050B2004
   ASAM Dataset: EV_ECM20TFS0205G0906259E 001005
   ROD: EV_ECM20TFS0205G0906259E_VW37.rod
   VCID: 306504706BF757BEC1-8064
Readiness: 1110 0001
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4522
   Revision: 05853104    Serial number: TFK01502210840
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 1F47F7CC0669D8C668-804A
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60525000000018
   Coding: 01FA93A1542829710777070141C96980C92A94E0E08296F718425078C208
   VCID: 49934994E86D0676E6-801C
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Revision: 00001K08
   Coding: 00120004200100011005000000101000
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 69D3A91488ADE676C6-803C
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011505703476
   Coding: 03001A42C20122F30B244080B10807281000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 000594B09BD7073E71-8054
   Slave 1:
   Component: WWS    150216  042 0551
   Serial number:         150220075327
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S5Y15M03D04H20M33S24
   Coding: 00A8DD
   Serial number: 000000000ZY1502800UZ
   Serial number: 00000000000031111455
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391505502941
   Coding: 0071051011
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 3D7B2D44ACA5AAD65A-8068
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 30011503272001
   Coding: 001C1300FE0739
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 38753C5083878FFE89-806C
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0CWL9I
   VCID: 7F07174CE62978C608-802A
   Seat belt tensioner; left:
   Component: BeltPretRevFL  H36 0350
   Serial number: 34169661C10021540767
   Coding: 333135
   Seat belt tensioner; right:
   Component: BeltPretRevFR  H36 0350
   Serial number: 34169662C10021540967
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 502 15
   Serial number: 3576700000035858731P
   Subsystem 4 - Part No SW: -----------    HW: 480 002 302 15
   Serial number: 35867000000A030D431K
   Subsystem 5 - Part No SW: -----------    HW: 480 401 102 15
   Serial number: 3516502B31993FC33229
   Subsystem 6 - Part No SW: -----------    HW: 480 401 102 15
   Serial number: 3526502B31993FC631DN
   Subsystem 7 - Part No SW: -----------    HW: 480 401 602 15
   Serial number: 35565029B1993FC1411G
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 23021508490325
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 7BFFE35CF23164E624-802E
   Part No SW: 5G1 920 958     HW: 5G1 920 958
   Component: KOMBI         304 4310
   Coding: 27AD00082F80260001882A011400000000000000
   VCID: 6ED9DA08B143014E93-803A
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003164222
   Coding: 030100042F085900EF00027E1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear.rod
   VCID: 72E1CE78A57B25AE77-8026
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N
   Component: E221__MFL-DC1  H10 0040
   Serial number: 27150000373060015093
   Coding: 2DFFFF
   Serial number: 3441565703
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Serial number: HA1-00030.01.15
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 468942A8F973E90E0B-8012
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 160215BBF13462
   Coding: 003F0220D001048100001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 42815EB8D55BD52E27-8016
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 37773F6C8E99808680-8062
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 200215BBJ10454
   Coding: 003F0020DE01048100801000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   VCID: 418351B4D05DCE363E-8014
   Coding: 02AE00000B000200
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 408554B0DB57C73E31-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Coding: 2E0000
   Part No SW: 5G0 035 820 A    HW: 5G0 035 820 A
   Component: MU-S-D-ER     041 0421
   Serial number: V5C02801153200
   Coding: 02730000FF00000021111201000800001F0207060100010001
   ROD: EV_MUStd4CPASE_SK37.rod
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9RS207KWY
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 150129200279
   VCID: 2D5B1D047CC53A56EA-8078
End-------------------------(Elapsed Time: 04:27)--------------------------
OK, I've looked at everything known about that transmission and don't see it in there, sorry.
DV52
C?ID=194404
Uwe,
I'm aware of at least two DSG versions in the mk7s:
The 6 speed version: 0D9 DQ250-6F (as in Adam's auto scan)
The 7 speed version: DQ200-7F 0CW (as in my TSI my13 car - see section of auto-scan below)
Part No SW: 0CW 300 045 HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5240
Revision: 00043014 Serial number: CU501212296246
I also believe that the hybrid mk7 has a gearbox with the designation ODD- I think it's 6 speed, but I
don't know much more about it
Regardless of the car, the country of sale, or the version of DSG installed, all the vehicles that I have seen ALWAYS have the coding string 0014 and there appear to be no adaptation channels in the control module. In short, like you, I don't beleive that the mk7s have a launch counter.
Adam.
C?ID=136075
I guess that's a good thing...
Cheers guys.
