Page 1 of 5 123 ... LastLast
Results 1 to 10 of 48
Thread: Modules missing, failure in comm, ASAM update issues
    NC USA
    My alarm went off last night for no apparent reason, so I scanned to see if I could figure out what tripped it.
    No dice, but several other things I did notice:
    • Hung on 09 the first try
    • 09 is consistently missing - see below about several lost scans
    • 62 failed to respond the second time
    • 72 failed to respond the 4th or 5th time
    Several times the ASAM data attempted to update and failed.
    When it does this, you either get kicked out of VCDS-Mobile and have to log back in, or it goes back to the main menu.
    Ultimately this ends up with a 'lost' scan and you have to start from square one.
    Is it possible to have HEX-NET auto-save Autoscans ?
    The modules that failed comms are accessible individually as per screenshots below.
    Looking at a previous version scan, it also missed 09.
    Unfortunately I forgot the Winders tablet so I couldn't get a USB attached scan.
    What do you guys think, and what else do you need from me? THanks-Jake
    Versions / Info
    2012 A8L
    CodeBlock V0.41
    FW version: 0.176
    Dataset: 00000026
    Infra mode tethered to iPhone 5s on T-Mobile
    Version 0.41.0.4
    #hndoc:?docid=00000312&xt=hnh:B78F1B8A8EA3DBC96B0A408C3338E796B2FD70156AB09432F7529F072DA08FAA
    VCDS Mobile 0.41.0.4
    Gateway Installation list:
    48-Seat, Rear, DS -- Status: OK 0000
    5B-Seat,Rear,PS -- Status: OK 0000
    8A-Multicont. Seat Rear,DS -- Status: OK 0000
    8D-Multicont. Seat Rear,PS -- Status: OK 0000
    8F-Pretension. Front Left -- Status: OK 0000
    90-Pretension. Front Right -- Status: OK 0000
    Address 01: Engine  (CDRA
     -----)	Labels:4H-01.lbl
    	Part Number SW: 4H0-907-560-C	HW: 4H0-907-560
    	Component: 4.2l V8/4V    H07 0004
    	Revision: N5H07---
    	Coding: 0106000A290F0268
    	Shop #: WSC 02313 785 00200
    	ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
    	ROD: EV_ECM42FSI0114H0907560C.rod
    	VCID: 2A1791ABD54FA1429D8E-807F
    No fault codes found.
    Address 02: Auto Trans  (J217)	Labels:None
    	Part Number SW: 4H1-927-158-BR	HW: 0BK-927-156-K
    	Component: 0BK 42 FSIUSA H08 1001
    	Revision: --H08---
    	Coding: 000002
    	ASAM Dataset: EV_TCMALX51011 002018
    	ROD: EV_TCMALX51011_AU64.rod
    	VCID: 8145960788B9021A6C24-80D4
    Address 03: ABS Brakes  (J104)	Labels:4H0-907-379.clb
    	Part Number SW: 4H0-907-379-C	HW: 4H0-907-379-C
    	Component: ESP PREMIUM   H10 0273
    	Revision: --------
    	Shop #: WSC 02311 785 00200
    	ASAM Dataset: EV_ESPPremi 005006
    	ROD: EV_ESPPremi_AU64.rod
    	VCID: 322789CBFD9FE98225DE-8067
    Address 05: Acc/Start Auth.  (J393)	Labels:8K0-907-064-05.clb
    	Part Number SW: 4H0-907-064-BD	HW: 4H0-907-064-BD
    	Component: BCM2 2.0      H31 0330
    	Coding: 0D872000000000000000
    	VCID: 6C9B57B31F3B67722F12-8039
    	Subsystem 1 -
    	Subsystem 2 - 	Part Number: 4H0-905-852-C
    	Component: J764 ELV MLB H39 0046
    Address 06: Seat Mem. Pass  (J521)	Labels:None
    	Part Number SW: 4H0-959-760-E	HW: 4H0-959-760-E
    	Revision: AA000000
    	Coding: C018B60085043201010001010101112131313333283333
    	VCID: 352DB2D70CF1E6BA003C-8060
    Address 08: Auto HVAC  (J255)	Labels:None
    	Part Number SW: 4H0-820-043-H	HW: 4H0-820-043-H
    	Component: Klima 4 Zonen H20 0072
    	ROD: EV_AirCondiFront_AU64.rod
    	VCID: 250D6297BC518E3AB05C-8070
    Address 0E: Media Player 1  (R161)	Labels:None
    	Part Number SW: 4H0-035-108-E	HW: 4H0-035-108
    	Component: DVDCAlpine    H42 0190
    	Revision: AA001001
    	VCID: 2207798BAD7F6102D57E-8077
    Address 10: Park/Steer Assist  (J446)	Labels:4H0-919-475-7X2.clb
    	Part Number SW: 4H0-919-475-L	HW: 4H0-919-475-C
    	Component: PARKHILFE ACC H07 0043
    	Revision: 11001001
    	Coding: 280902
    	ROD: EV_EPHVA18AU57X0000.rod
    	VCID: 3B39A4EF2AD528CAF678-806E
    Address 13: Auto Dist. Reg  (J428)	Labels:None
    	Part Number SW: 4H0-907-561-A	HW: 4H0-907-561
    	Component: ACC3          H15 0160
    	Coding: 3601020201
    	ASAM Dataset: EV_AdaptCruisContrAU64X 001012
    	ROD: EV_AdaptCruisContrAU64X.rod
    	VCID: 29156EA7D049AA5A94B4-807C
    Address 15: Airbags  (J234)	Labels:None
    	Part Number SW: 4H0-959-655-D	HW: 4H0-959-655-D
    	Component: Airbag10.43   H41 0041
    	Revision: --------
    	Coding: 303143303230303030314A55304C34483053
    	VCID: 3731B8DF16FD0CAA1200-8062
    	Subsystem 1 - 	Part Number: 4H0-959-339
    	Component: BF-Gewichtss.H02 0040
    	Serial Number: 5850000R1190801Y2Nªª
    	Subsystem 2 - 	Serial Number: 3575HRB405D0NI366PV.
    	Subsystem 3 - 	Serial Number: 3585HRB40550Q3SK39JQ
    	Subsystem 4 - 	Serial Number: 3515JRB404R0Q8K4FOSG
    	Subsystem 5 - 	Serial Number: 3525JRB404R0Q8K46G6L
    	Subsystem 6 - 	Serial Number: 3554VRB40610M5SO0H1M
    	Subsystem 7 - 	Serial Number: 3564VRB40610M5SO493L
    Address 16: Steering wheel  (J527)	Labels:None
    	Part Number SW: 4H0-953-568-G	HW: 4H0-953-568-G
    	Revision: --------
    	Coding: 0000BC
    	VCID: 3731B8DF16FD14AA1200-8062
    	Subsystem 1 - 	Part Number: 4H0-951-528-L
    	Component: E221 - MFL   H04 0009
    Address 17: Instruments  (J285)	Labels:4H0-920-xxx-17.clb
    	Part Number SW: 4H0-920-980-H	HW: 4H0-920-980-H
    	Component: TBenUSAACC--- H38 0373
    	Revision: 32480030
    	Coding: 0B4F08015700D705020000
    	ASAM Dataset: EV_RBD4K 004040
    	ROD: EV_RBD4K.rod
    	VCID: 302383C3F393DB9253CA-8065
    Address 19: CAN Gateway  (J533)	Labels:None
    	Part Number SW: 4H0-907-468-F	HW: 4H0-907-468-C
    	Component: J533--Gateway H08 0213
    	Revision: --------
    	Coding: 00C1034A00
    	ROD: EV_GatewUDS_AU57.rod
    	VCID: 342B8FD3078BE7B23722-8061
    	Subsystem 1 - 	Part Number: 4H0-915-181
    	Component: J367-BDM     H07 0140
    	Serial Number: 00000000005650628220
    Address 28: HVAC, Rear  (E265)	Labels:None
    	Part Number SW: 4H0-919-158-D	HW: 4H0-919-158-D
    	Component: Klima Fond    H15 0062
    	ROD: EV_AirCondiHeck_AU64.rod
    	VCID: 312586C7F899D29A5CC4-8064
    Address 34: Level Control  (J197)	Labels:None
    	Part Number SW: 4H0-907-553-C	HW: 4H0-907-553
    	Component: LUFE-DAEMPFER H17 0096
    	Coding: 008002
    	ASAM Dataset: EV_AirSuspe 003022
    	VCID: 2C1B97B3DFBBBF726F92-8079
    Address 36: Seat Mem. Drvr  (J136)	Labels:None
    	Revision: AA000000
    	Coding: C018BF8085853201030001010101112131313333203333
    Address 3B: Sensor Elect.  (J849)	Labels:None
    	Part Number SW: 4H0-907-637	HW: 4H0-907-637
    	Component: SARA 6D       H02 0015
    	Revision: --------
    	ASAM Dataset: EV_SARA 006014
    	VCID: EC9BD7B39F3BFF72AF12-80B9
    3801346 - ROD - Unknown faultcode
    Address 3C: Lane Change	Labels:None
    	Part Number SW: 4H0-907-566-A	HW: 4G0907568
    	Component: J769  SWA MasterH01  0030
    	Revision: 00H01000	Serial Number: 6PZ 010 287-07
    	VCID: 2E1F9DBBE9A7556241E6-807B
    	Subsystem 1 - 	Part Number: 4H0-907-568-A
    	Component: J770  SWA Slave H02  0030
    	Serial Number: 6PZ 010 287-27
    Address 42: Door Elect, Driver  (J386)	Labels:None
    	Part Number SW: 4H0-959-793-M	HW: 4H0-959-793-E
    	Component: TSG FA        H02 0166
    	Revision: --------
    	Coding: 011F1F205E0062C202000017
    	Shop #: WSC 02312 785 00200
    	VCID: 43C9DC0F5225480ABE88-8016
    Address 46: Central Conv.  (J393)	Labels:4H0-907-064-46.clb
    	Coding: 0106023A00FA759FB0B0C780020100000000000000000000000000000000
    	Subsystem 1 - 	Part Number: 4H0-959-719
    	Component: GTO BF       H01 0070
    	Subsystem 2 - 	Part Number: 1K0-951-605-C
    	Component: LIN BACKUP HOH05 1501
    	Subsystem 3 - 	Part Number: 4H4-959-591
    	Component: J245  007C   H06 0005
    	Coding: 020200
    	Subsystem 4 - 	Part Number: 4H0-947-135-BR‘>8
    	Component: DachelektroniH11 0080
    	Coding: 070000
    	Subsystem 5 - 	Part Number: 4H4-959-591
    	Component: J394  0014   H06 0005
    	Coding: 020200
    	Subsystem 6 - 	Part Number: 4H4-959-591
    	Component: J392  006A   H06 0005
    	Coding: 020200
    	Subsystem 7 - 	Part Number: 4H4-959-591
    	Component: J867  00E0   H06 0005
    	Coding: 020200
    Address 47: Sound System	Labels:None
    	Part Number SW: 4G0-035-223-B	HW: 4G0-035-223-A
    	Component: 0130H07
    	Revision: CJ007000
    	Coding: 030000
    	VCID: 1C7B47738F1B57F21F32-8049
    Address 48: Seat, Rear, DS  (J876)	Labels:None
    	Part Number SW: 4H0-959-860	HW: 4H0-959-860
    	Component: MEM-FS-Fond   H06 0153
    	Revision: AA000000
    	Coding: 001892800000300D0A00392038193A2039203B3B202020
    	VCID: F1A5C6C7B8190A9A9C44-80A4
    Address 52: Door Elect, Pass.  (J387)	Labels:None
    	Part Number SW: 4H0-959-792-E	HW: 4H0-959-792-E
    	Component: TSG BF        H02 0166
    	Revision: --------
    	Coding: 011F1F205E0062C202000007
    	VCID: 3A37A1EB25EF09C2ED6E-806F
    Address 53: Parking Brake  (----)	Labels:4H0-907-801.clb
    	Part Number SW: 4H0-907-801-E	HW: 4H0-907-801-A
    	Revision: --------
    	Shop #: WSC 00000 000
    Address 56: Radio  (R)	Labels:None
    	Part Number SW: 4H0-035-082-B	HW: 4H0-035-082
    	Component: Radio U SIRIU H52 0076
    	Revision: AB001007
    	Coding: 020007010000000001
    	VCID: 20037383A3737312C36A-8075
    Address 5B: Seat,Rear,PS  (J877)	Labels:None
    	Component: MEM-BFS-Fond  H06 0153
    	Revision: AA000000
    	Coding: 001896800000300D0A00392038193A2039203B3B382020
    Address 5F: Information Electr.  (J794)	Labels:4E0-035-6xx-5F.clb
    	Part Number SW: 4H0-035-746-D	HW: 4H0-035-746
    	Component: H-BNT-NA      H48 0423
    	Revision: --------
    	Coding: 020200000001F9EF7D128B0E00000003140001000000000000
    	VCID: 29156EA7D049B25A94B4-807C
    	Subsystem 1 - 	Part Number: 8R0-060-884-AD‘>8
    	Component: NAR 2011     0505
    	Subsystem 2 - 	Part Number: 4H0-919-604-D
    	Component: DU8 D4 SV NB H47 0021
    	Subsystem 3 - 	Part Number: 4H1-919-600-F
    	Component: E380 BDT D4  H09 0064
    	Subsystem 4 - 	Part Number: 8R0-060-961-B
    	Component: CD-Database
    Address 62: Door, Rear Left  (J388)	Labels:None
    	Part Number SW: 4H0-959-795-A	HW: 4H0-959-795-A
    	Component: TSG HL        H04 0167
    	Revision: --------
    	Coding: 010F1F20420062C202000007
    	VCID: 3935BEE720E902DAE414-806C
    Address 6C: Back-up Cam.	Labels:4H0-907-441.clb
    	Part Number SW: 4H0-907-441-A	HW: 4H0907441
    	Component: SG Rueckfahrkamera   0061
    	Revision: --H04---	Serial Number: 525 PA8J17D1M2
    	Coding: 1080003
    	VCID: 260F659BC1571D22B956-8073
    Address 6D: Trunk Elect.  (----)	Labels:None
    	Part Number SW: 4H0-959-107-R	HW: 4H0-959-107-M
    	Component: HDSG-Modul    H11 0039
    	Revision: 10011001
    	Coding: 0210044100
    	VCID: 3D3DAAF734C126FAC84C-8068
    Address 6F: Centr. Conv. II  (J773)	Labels:None
    	Part Number SW: 4H0-907-412	HW: 4H0-907-412
    	Revision: --------
    	ASAM Dataset: EV_Ambie 001008
    	ROD: EV_Ambie.rod
    	VCID: E389BC8F72E5B00A1EC8-80B6
    Address 72: Failed to respond
    Address 81: Gear Shift  (J587)	Labels:None
    	Part Number SW: 4H1-927-731-A	HW: 4H1-927-731-A
    	Component: GSM-LL        H07 0083
    	Revision: 0L0D5012
    	ROD: EV_GSM2x3Mono.rod
    	VCID: 2B1994AFDAB5B84A6698-807E
    Address 85: On Board Cam.  (J852)	Labels:None
    	Part Number SW: 4G0-907-217	HW: 4H0-907-217-A
    	Component: DPC-SG        H24 0036
    	Revision: --------
    	ROD: EV_OnBoardCamerDPC.rod
    	VCID: E58DA2977CD1CE3AF0DC-80B0
    Address 88: Multicont. Seat Driver  (J873)	Labels:None
    	Part Number SW: 4H0-907-182-H	HW: 4H0-907-182-H
    	ROD: EV_IVBDriveSideFrnt.rod
    	VCID: 2F2180BFEEADC46A4AF0-807A
    Address 89: Multicont. Seat Pass.  (J872)	Labels:None
    Address 8A: Multicont. Seat Rear,DS  (J875)	Labels:None
    	Part Number SW: 4H0-907-182-G	HW: 4H0-907-182-G
    	Component: IVB           H08 0042
    	ASAM Dataset: EV_IVBDriveSideRear 001003
    	VCID: 2E1F9DBBE9A7CD6241E6-807B
    Address 8B: Adaptive Cruise 2  (J428)	Labels:None
    	Part Number SW: 4H0-907-541-A	HW: 4H0-907-541
    	Coding: 3601020201
    	ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
    	ROD: EV_AdaptCruisContr2AU57X.rod
    	VCID: 2711689FC65D9C2A82A0-8072
    Address 8D: Multicont. Seat Rear,PS  (J874)	Labels:None
    	ASAM Dataset: EV_IVBPasseSideRear 001003
    Address 8E: Image Processing  (J851)	Labels:4G0-907-107.clb
    	Part Number SW: 4G0-907-107-C	HW: 4H0-907-107
    	Component: BV-SG         H29 0036
    	ASAM Dataset: EV_BC7 001001
    	VCID: 260F659BC1578522B956-8073
    Address 8F: Pretension. Front Left  (J854)	Labels:4H0-980-94x-RGS.clb
    	Part Number SW: 4H0-980-945-B	HW: 4H0-980-945-B
    	ASAM Dataset: EV_RGS_L 002004
    Address 90: Pretension. Front Right  (J855)	Labels:4H0-980-94x-RGS.clb
    	Part Number SW: 4H0-980-946-B	HW: 4H0-980-946-B
    	ASAM Dataset: EV_RGS_R 002004
    	ROD: EV_RGS_R.rod
    Version 0.4009.0.4
    #hndoc:?docid=00000143&xt=hnh:E9C81AC9DC7CB65E2DD768F480A86F66024B43276FD134208489DBCCAB086361
    VCDS Mobile 0.4009.0.4
    VIN: WAURVAFD6CN014370
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    	Revision: N5H07---
    	VCID: 2A1791ABD5B2A1427A5D8
    	Revision: --H08---
    	Coding: 000002
    	VCID: 814596078844021A8BF77
    	Revision: --------
    	Coding:
    	VCID: 322789CBFD62E982C20D0
    	VCID: 6C9B57B31FC66772C8C1E
    	Subsystem 1 - 	Shop #: WSC 02313 785
    	Revision: AA000000
    	VCID: 352DB2D70C0CE6BAE7EF3
    	Coding:
    	VCID: 250D6297BCAC8E3A578F3
    Address 0e: Media Player 1  (R161)
    	Revision: AA001001
    	VCID: 2207798BAD82610232AD0
    	Revision: 11001001
    	Coding: 280902
    	VCID: 3B39A4EF2A2828CA11AB5
    	Coding: 3601020201
    	VCID: 29156EA7D0B4AA5A7367F
    16896 - Function Restricted due to Exessive Voltage
    	U1401 00 [008] -
    		Fault Status: 01000010
    		Reset Counter: 1
    		Mileage: 66215 km
    		Time: 00:00:00
    140288 - Function Restriction due to Received Malfunction Value
    	U1113 00 [008] -
    		Reset Counter: 1
    		Mileage: 66215 km
    		Time: 00:00:00
    	Revision: --------
    	VCID: 3731B8DF16000CAAF5D39
    	Revision: --------
    	Coding: 0000BC
    	VCID: 3731B8DF160014AAF5D39
    	Revision: 32480030
    	VCID: 302383C3F36EDB92B419A
    	Revision: --------
    	Coding: 00C1034A00
    	VCID: 342B8FD30776E7B2D0F16
    	Coding:
    	VCID: 312586C7F864D29ABB177
    	Coding: 008002
    	VCID: 2C1B97B3DF46BF728841E
    	Revision: AA000000
    Address 3b: Sensor Elect.  (J849)
    	Revision: --------
    	Coding:
    	VCID: EC9BD7B39FC6FF7248C1E
    Address 3c: Lane Change
    	VCID: 2E1F9DBBE95A5562A6354
    	Revision: --------
    	VCID: 43C9DC0F52D8480A595BD
    	Coding: 020200
    	Subsystem 4 - 	Part Number: 4H0-947-135-BR5;Ô
    	Coding: 070000
    	Coding: 020200
    	Coding: 020200
    	Coding: 020200
    	Component: 0130H07
    	Revision: CJ007000
    	Coding: 030000
    	VCID: 1C7B47738FE657F2F8E1E
    	Revision: AA000000
    	VCID: F1A5C6C7B8E40A9A7B977
    	Revision: --------
    	VCID: 3A37A1EB251209C20ABD8
    	Revision: --------
    	Coding:
    	Revision: AB001007
    	VCID: 20037383A38E731224B9A
    Address 5b: Seat,Rear,PS  (J877)
    	Revision: AA000000
    Address 5f: Information Electr.  (J794)	Labels:4E0-035-6xx-5F.clb
    	Revision: --------
    	VCID: 29156EA7D0B4B25A7367F
    	Subsystem 1 - 	Part Number: 8R0-060-884-AD5;Ô
    	Component: CD-Database  3371
    	Revision: --------
    	VCID: 3935BEE7201402DA03C7F
    02111 - Motor for Window Regulator
    		Fault Status: 00100101
    		Reset Counter: 154
    		Mileage: 13138 km
    		Date: 2014.01.19
    		Time: 13:08:53
    Address 6c: Back-up Cam.	Labels:4H0-907-441.clb
    	Coding: 1080003
    	VCID: 260F659BC1AA1D225E85C
    Address 6d: Trunk Elect.  (----)
    	Revision: 10011001
    	Coding: 0210044100
    	VCID: 3D3DAAF7343C26FA2F9FB
    Address 6f: Centr. Conv. II  (J773)
    	Revision: --------
    	Coding:
    	VCID: E389BC8F7218B00AF91BD
    Address 72: Door, Rear Right  (J389)
    	Component: TSG HR        H04 0167
    	Revision: --------
    	Revision: 0L0D5012
    	Coding:
    	VCID: 2B1994AFDA48B84A814B5
    	Revision: --------
    	Coding:
    	VCID: E58DA2977C2CCE3A170F3
    	Coding:
    	VCID: 2F2180BFEE50C46AAD231
    	Coding:
    Address 8a: Multicont. Seat Rear,DS  (J875)
    	Coding:
    	VCID: 2E1F9DBBE95ACD62A6354
    Address 8b: Adaptive Cruise 2  (J428)
    	Coding: 3601020201
    	VCID: 2711689FC6A09C2A65739
    016896 - ROD - Unknown faultcode
    		Reset Counter: 1
    		Mileage: 66215 km
    		Time: 00:00:00
    Address 8d: Multicont. Seat Rear,PS  (J874)
    	Coding:
    Address 8e: Image Processing  (J851)	Labels:4G0-907-107.clb
    	Coding:
    	VCID: 260F659BC1AA85225E85C
    Address 8f: Pretension. Front Left  (J854)	Labels:4H0-980-94x-RGS.clb
    	Coding:
    	Coding:
    Jake, at your convenience, can you please make a Measuring Block Map of your 46 module please? (You'll need the Windows PC for that). Somewhere in there we're going to find reason your alarm went off, but we don't have it documented yet.
    [Applications]
    [Controller Channels Map]
    Address: 46
    Function: Meas. Blocks
    Output: Pre-Label File
    [Start]
    Please e-mail us the resulting file.
    Thanks!
    NC USA
    Will do.
    Good reason to finally try the Dell Venue 8.1 cabled to HEX-NET.
    Edit:
    PLB emailed to Support
    Scan with USB cable worked like a champ, see below.
    Switched to AP mode and scanned again using tablet.
    Scan hung on module 09, 46. and 62.
    After several minutes, hit [Done, Go Back] on 09 and 46 and the scan continued.
    On 62 when I did that it locked up VCDS and put Not Responding in the titlebar.
    Waited.... waited.... waited... hit X to close dimmed window and VCDS crashed.
    Cabled HEX-NET scan
    Wednesday,30,April,2014,18:31:28:28071
    VCDS Version: 14.4.2.0
    Data version: 20140411
    VIN: WAURVAFD6CN014370   License Plate:
    Mileage: 13611km-8457mi   Repair Order:
    Chassis Type: FD (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 34 36 3B 3C 42
              46 47 48 52 53 56 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8B 8D
              8E 8F 90
    VIN: WAURVAFD6CN014370   Mileage: 13611km-8457miles
    Address 01: Engine (------CDRA)       Labels: None
       Part No SW: 4H0 907 560 C    HW: 4H0 907 560
       Revision: N5H07---
       VCID: 2A18C35B4D928E6B29-807F
    Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
       Part No SW: 4H1 927 158 BR    HW: 0BK 927 156 K
       Revision: --H08---
       Coding: 000002
       VCID: 014A44F79064AD3358-8054
       Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
       Coding: 44E6F20022674F00E200
       VCID: 3228DB3B6542C6AB91-8067
       Part No SW: 4H0 907 064 BD    HW: 4H0 907 064 BD
       VCID: 6C9405438FE6505B9B-8039
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000014753132
       VCID: 3522E0279C2CD193B4-8060
       Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
       Coding: 480122BECC
       VCID: 25023067248CA11304-8070
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
       Part No SW: 4H0 907 063 BG    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0100
       Revision: 11012002    Serial number: 00000001073731
       Coding: 09072091073C9FE18B000804A0003800009CD308820001218001085C3B00
       VCID: 6E900F4BB9FAA24BB5-803B
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 110724  H35 0040
       Coding: 0045F7
       Component: RLS  H04 0003
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Component: USHL4.2  H30 0030
       Coding: 100000
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0280
       Coding: 020300
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 E    HW: 4H0 035 108
       Revision: AA001001
       VCID: 22082B7B3DA2562B61-8077
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Revision: 11001001    Serial number: 55901126901403
       Coding: 280902
       VCID: 3B36F61FB20807E342-806E
    Address 13: Auto Dist. Reg (J428)       Labels: 4H0-907-561.clb
       Part No SW: 4H0 907 561 A    HW: 4H0 907 561
       Coding: 3601020201
       VCID: 291A3C574894857320-807C
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Revision: --------    Serial number: 003JS0016EK5
       VCID: 373EEA2F8E202383A6-8062
       Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
       Serial number: 5850000R1190801Y2N
       Serial number: 3575HRB405D0NI366PV.
       Serial number: 3585HRB40550Q3SK39JQ
       Serial number: 3515JRB404R0Q8K4FOSG
       Serial number: 3525JRB404R0Q8K46G6L
       Serial number: 3554VRB40610M5SO0H1M
       Crash sensor for front airbag; passenger side:
       Serial number: 3564VRB40610M5SO493L
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90815KIN0002H
       Coding: 0000BC
       VCID: 373EEA2F86202383A6-8062
       Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4H0 920 980 H    HW: 4H0 920 980 H
       Revision: 32480030    Serial number: 658270911593012
       ROD: EV_RBD4K.rod
       VCID: 302CD1336B4EF4BBE7-8065
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1110824000963
       Part No SW: 4H0 907 468 F    HW: 4H0 907 468 C
       Revision: --------    Serial number: 00000000254143
       Coding: 00C1034A00
       VCID: 3424DD239F56C89B83-8061
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Serial number: 00000000005650628220
    Address 28: HVAC, Rear (E265)       Labels: None
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Coding: 0000000000
       VCID: 312AD4376044FDB3E8-8064
    Address 34: Level Control (J197)       Labels: Redir Fail!
       Part No SW: 4H0 907 553 C    HW: 4H0 907 553
       Coding: 008002
       ROD: EV_AirSuspe_AU64.rod
       VCID: 2C14C5434766905BDB-8079
       Revision: AA000000    Serial number: 00000014727766
       Part No SW: 4H0 907 637     HW: 4H0 907 637
       Revision: --------    Serial number: EJ1BPA3100XW8S0
       ROD: EV_SARA.rod
       VCID: 6C94054387E6505B9B-8039
    3801346 - Function Restricted due to Missing Message(s)
              U1111 00 [032] - -
       Part No SW: 4H0 907 566 A    HW: 4G0 907 566
       Revision: 00H01000    Serial number: 6PZ 010 287-07
       VCID: 2E10CF4BB97AE24BF5-807B
       Subsystem 1 - Part No: 4H0 907 568 A
       Subsystem 2 - Serial number: 6PZ 010 287-27
       Subsystem 3 - Serial number: 5F22.09.1100H020003CX22488ˇ
       Subsystem 4 - Serial number: X22488ˇ
       Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
       Revision: --------    Serial number: 0000120547259
       VCID: 43C68EFFC2F87F230A-8016
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0159921986
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Subsystem 3 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BR    HW: 4H0 947 135 BR
       Component: Dachelektroni  H11 0080
       Coding: 070000
       Subsystem 5 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Coding: 020200
       Subsystem 6 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Coding: 020200
       Subsystem 7 - Part No SW: 4H4 959 591     HW: 4H4 959 591
       Coding: 020200
       Part No SW: 4G0 035 223 B    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0130
       Revision: CJ007000    Serial number: 00000000025817
       Coding: 030000
       VCID: 1C7415831FC660DBAB-8049
    Address 48: Seat, Rear, DS (J876)       Labels: None
       Part No SW: 4H0 959 860     HW: 4H0 959 860
       Revision: AA000000    Serial number: 00000014816977
       VCID: 71AA1437A8C4BDB3A8-8024
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Revision: --------    Serial number: 0000120382709
       VCID: 3A38F31BB5323EEB59-806F
       Revision: --------    Serial number: 00000000147982
       ROD: EV_ParkiBrake_AU48.rod
    Address 56: Radio (R)       Labels: None
       Part No SW: 4H0 035 082 B    HW: 4H0 035 082
       Revision: AB001007    Serial number: 155HY0B7511356
       VCID: 200C217333AE443B77-8075
    Address 5B: Seat,Rear,PS (J877)       Labels: None
       Revision: AA000000    Serial number: 00000014816966
       Part No SW: 4H0 035 746 D    HW: 4H0 035 746
       Revision: --------    Serial number: 035JZ0B7504356
       VCID: 291A3C574094857320-807C
       Subsystem 2 - Part No SW: 4H0 919 604 D    HW: 4H0 919 604 D
       Subsystem 3 - Part No SW: 4H1 919 600 F    HW: 4H1 919 600
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Revision: --------    Serial number: 0000120482526
       VCID: 393AEC17B03435F350-806C
       Part No SW: 4H0 907 441 A    HW: 4H0 907 441
       Revision: --H04---    Serial number: 525 PA8J17D1M2
       Coding: 1080003
       VCID: 2600376B918AAA0B0D-8073
    Address 6D: Trunk Elect. (----)       Labels: None
       Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
       Revision: 10011001    Serial number: 256100203
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3D32F807AC1C09D37C-8068
    Address 6F: Centr. Conv. II (J773)       Labels: None
       Revision: --------    Serial number: 000000046400
       ROD: EV_Ambie.rod
       VCID: 63866E7F6A381F232A-8036
       Revision: --------    Serial number: 0000120482529
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Revision: 0L0D5012    Serial number: SN110727  0507
       VCID: 2B16C65F42689763D2-807E
    Address 85: On Board Cam. (J852)       Labels: None
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Coding: E9060000
       VCID: 65827067640C6113C4-8030
    Address 88: Multicont. Seat Driver (J873)       Labels: None
       Serial number: 00001638159702
       Coding: 764FF2
       VCID: 2F2ED24F7670EB43FE-807A
    Address 89: Multicont. Seat Pass. (J872)       Labels: None
       Serial number: 00001638160002
       Coding: 364FF2
    Address 8A: Multicont. Seat Rear,DS (J875)       Labels: None
       Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
       Serial number: 00001637035802
       Coding: 200F00
       VCID: 2E10CF4B717AE24BF5-807B
    Address 8B: Adaptive Cruise 2 (J428)       Labels: 4H0-907-561.clb
       Part No SW: 4H0 907 541 A    HW: 4H0 907 541
       Coding: 3601020201
       VCID: 271E3A6F5E80B30336-8072
    Address 8D: Multicont. Seat Rear,PS (J874)       Labels: None
       Serial number: 00001637038001
       Coding: 200F00
    Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
       Part No SW: 4G0 907 107 C    HW: 4H0 907 107
       Serial number: 000040220709117
       Coding: 02A19A000111
       ROD: EV_BC7.rod
       VCID: 2600376B598AAA0B0D-8073
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       Coding: 0066F609031F037E070308014240C2010000
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    Last edited by jakematic; 04-30-2014 at 06:11 PM. Reason: additional information, observations
  4. Likes Uwe, Sebastian liked this post
    NC USA
    ps - Noticed some missing label files. Let me know if you want more maps done.
  6. Likes Santos liked this post
    United States
    Quote Originally Posted by jakematic View Post
    Hi Jake,
    It looks like MVB group 021 is the most recent alarm source (followed by 022, 023 and 024). Per your map:
    21,0,,
    21,1,,,
    ;12,,
    21,2,,,
    ;2014:04:26,,
    21,3,,,
    ;23:04 h,,
    21,4,,,
    Pretty cool. Looks like the alarm went off @ 23:04 h on 4/26/2014 for alarm code #12. If the date and time aren't adding up we can check the 17-Instrument cluster or simply set the alarm off by opening a door and see if the stamps are accurate. #12 should be "Intelligent siren" so I would need to dig through the SSP or repair manual to see what's what but you have a whooping list of subsystem slave modules in this car and I believe one of those would quality as Intelligent siren.
    On that note MVB 018 is a Siren value and the last siren alarm code was 2 which is communication break.
    If that alarm system needs to be diagnosed we can dig into this and move all of it to a repair thread but I suspect a LIN Bus/Intelligent siren of some sort failed to communicate momentarily and set the alarm off.
    NC USA
    Hi Dana-
    Firstly, you guys freaking rock!
    I looked at the file and couldn't make heads nor tails of it, and in retrospect didn't think to search on the time.
    Timestamp confirmed:
    No kidding, this one has the most modules I've ever seen.
    No need to dig into it further - am due for my two year time based service this month.
    Time based... note the mileage in the scan
    Any thoughts on the Auto-Scan autosave, or is that just me not having the ASAM data fully updated at that point ?
    Will scan in infra mode tomorrow now that CB 0.4102 is on the HEX-NET and see if it improves the module comms.
    Thanks again!
  9. Likes Dana liked this post
  10. #7
    Don't forget to update your VCDS too.
    NC USA
    You see, this is what happens when I go sneak away from the desk for a glass of wine.... Updating now
  12. #9
    NC USA
    Apologies for the delay on this - allergies turned into a cold, turned into bronchitis, and work is trying their very best to kill me anyway....
    This new version is much, much faster than previous ones
    VCDS-Mobile: 62 and 72 are back in the scan, 09 is still missing.
    Did leave the doors unlocked - not sure that matters after this test.
    USB attach: This was interesting...
    VCDS could not find the CAN gateway, so I disconnected USB and pulled the HEX-NET from the DLC, waited, restarted everything, same result.
    Same procedure again, same result - could not access any modules.
    Pulled HEX-NET, shut down vehicle, waited 60 seconds and it was working again.
    Did not get a Network scan from VCDS Beta as time was running thin.
    Let me know what you need next. THanks!
    #hndoc:?docid=00000347&xt=hnh:3DBC21060B2E13A9A643BA455BB5CDCD113ADC21A379F3AA160B9948910FE235
    VCDS Mobile 0.4102.0.4
    	Revision: N5H07---
    	VCID: 2A1791ABD5B2A1427AB7D7-807F
    	Revision: --H08---
    	Coding: 000002
    	VCID: 814596078844021A8B1D88-80D4
    	Revision: --------
    	VCID: 322789CBFD62E982C2E72F-8067
    	VCID: 6C9B57B31FC66772C82BA1-8039
    	Subsystem 1 -
    	Revision: AA000000
    	VCID: 352DB2D70C0CE6BAE7054C-8060
    	VCID: 250D6297BCAC8E3A57659C-8070
    	Revision: AA001001
    	VCID: 2207798BAD82610232477F-8077
    	Revision: 11001001
    	Coding: 280902
    	VCID: 3B39A4EF2A2828CA11418A-806E
    	Coding: 3601020201
    	VCID: 29156EA7D0B4AA5A738DC0-807C
    	Revision: --------
    	VCID: 3731B8DF16000CAAF53966-8062
    	Revision: --------
    	Coding: 0000BC
    	VCID: 3731B8DF160014AAF53966-8062
    	Revision: 32480030
    	ROD: EV_RBD4K.rod
    	VCID: 302383C3F36EDB92B4F315-8065
    	Revision: --------
    	Coding: 00C1034A00
    	VCID: 342B8FD30776E7B2D01B39-8061
    	VCID: 312586C7F864D29ABBFD18-8064
    	Coding: 008002
    	VCID: 2C1B97B3DF46BF7288ABE1-8079
    	Revision: AA000000
    	Revision: --------
    	ROD: EV_SARA.rod
    	VCID: EC9BD7B39FC6FF72482B21-80B9
    	U1111 00 [032] -
    	VCID: 2E1F9DBBE95A5562A6DFFB-807B
    	Revision: --------
    	VCID: 43C9DC0F52D8480A59B1E2-8016
    	Coding: 020200
    	Subsystem 4 - 	Part Number: 4H0-947-135-BRí>8
    	Coding: 070000
    	Coding: 020200
    	Coding: 020200
    	Coding: 020200
    	Component: 0130H07
    	Revision: CJ007000
    	Coding: 030000
    	VCID: 1C7B47738FE657F2F80B31-8049
    	Revision: AA000000
    	VCID: F1A5C6C7B8E40A9A7B7D58-80A4
    	Revision: --------
    	VCID: 3A37A1EB251209C20A5787-806F
    	Revision: --------
    	Revision: AB001007
    	VCID: 20037383A38E7312245365-8075
    	Revision: AA000000
    	Revision: --------
    	VCID: 29156EA7D0B4B25A738DC0-807C
    	Subsystem 1 - 	Part Number: 8R0-060-884-ADí>8
    	Revision: --------
    	VCID: 3935BEE7201402DA032D70-806C
    	Coding: 1080003
    	VCID: 260F659BC1AA1D225E6FA3-8073
    	Revision: 10011001
    	Coding: 0210044100
    	VCID: 3D3DAAF7343C26FA2F75A4-8068
    	Revision: --------
    	ROD: EV_Ambie.rod
    	VCID: E389BC8F7218B00AF9F1C2-80B6
    Address 72: Door, Rear Right  (J389)	Labels:None
    	Revision: --------
    	Revision: 0L0D5012
    	VCID: 2B1994AFDA48B84A81A1DA-807E
    	Revision: --------
    	VCID: E58DA2977C2CCE3A17E5DC-80B0
    	VCID: 2F2180BFEE50C46AADC90E-807A
    	VCID: 2E1F9DBBE95ACD62A6DFFB-807B
    	Coding: 3601020201
    	VCID: 2711689FC6A09C2A6599B6-8072
    	ROD: EV_BC7.rod
    	VCID: 260F659BC1AA85225E6FA3-8073
    	ROD: EV_RGS_L.rod
    	ROD: EV_RGS_R.rod
    Scan with USB cable using VCDS classic.
    Sunday,11,May,2014,11:56:46:62017
    VCDS Version: 14.5.0.0
    Data version: 20140501
    Mileage: 13640km-8475mi   Repair Order:
              8E 8F 90
    VIN: WAURVAFD6CN014370   Mileage: 13640km-8475miles
       Revision: N5H07---
       VCID: 2A18C3264D0D686BD9-807F
       Revision: --H08---
       Coding: 000002
       VCID: 014A448A90FB4B33A8-8054
       VCID: 3228DB4665DD20AB61-8067
       VCID: 6C94053E8F79B65B6B-8039
       VCID: 3522E05A9CB3379344-8060
       Coding: 480122BECC
       VCID: 2502301A24134713F4-8070
       VCID: 6E900F36B965444B45-803B
       Coding: 0045F7
       Coding: 025523
       Coding: 100000
       Coding: 100000
       Coding: 020300
       Revision: AA001001
       VCID: 22082B063D3DB02B91-8077
       Coding: 280902
       VCID: 3B36F662B297E1E3B2-806E
       Coding: 3601020201
       VCID: 291A3C2A480B6373D0-807C
       VCID: 373EEA528EBFC58356-8062
       Coding: 0000BC
       VCID: 373EEA5286BFC58356-8062
       ROD: EV_RBD4K.rod
       VCID: 302CD14E6BD112BB17-8065
       Analog_clock:
       Coding: 00C1034A00
       VCID: 3424DD5E9FC92E9B73-8061
       Coding: 0000000000
       VCID: 312AD44A60DB1BB318-8064
       Coding: 008002
       VCID: 2C14C53E47F9765B2B-8079
       ROD: EV_SARA.rod
       VCID: 6C94053E8779B65B6B-8039
              U1111 00 [032] - -
       VCID: 2E10CF36B9E5044B05-807B
       VCID: 43C68E82C2679923FA-8016
       Coding: 020200
       Coding: 070000
       Coding: 020200
       Coding: 020200
       Coding: 020200
       Coding: 030000
       VCID: 1C7415FE1F5986DB5B-8049
       VCID: 71AA144AA85B5BB358-8024
       VCID: 3A38F366B5ADD8EBA9-806F
       VCID: 200C210E3331A23B87-8075
       VCID: 291A3C2A400B6373D0-807C
       VCID: 393AEC6AB0ABD3F3A0-806C
       Coding: 1080003
       VCID: 2600371691154C0BFD-8073
       Coding: 0210044100
       VCID: 3D32F87AAC83EFD38C-8068
       ROD: EV_Ambie.rod
       VCID: 63866E026AA7F923DA-8036
       VCID: 2B16C62242F7716322-807E
       Coding: E9060000
       VCID: 6582701A6493871334-8030
       Coding: 764FF2
       VCID: 2F2ED23276EF0D430E-807A
       Coding: 364FF2
       Coding: 200F00
       VCID: 2E10CF3671E5044B05-807B
       Coding: 3601020201
       VCID: 271E3A125E1F5503C6-8072
       Coding: 200F00
       ROD: EV_BC7.rod
       VCID: 2600371659154C0BFD-8073
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    Edit: As an FYI
    bureau:Desktop jake$ grep None mob.txt
    bureau:Desktop jake$ grep None Log-WAURVAFD6CN014370-13640km-8475mi.txt
    bureau:Desktop jake$ grep -i fail Log-WAURVAFD6CN014370-13640km-8475mi.txt
    bureau:Desktop jake$ grep None mob.txt Log-WAURVAFD6CN014370-13640km-8475mi.txt  | awk -F: '{print $2}' | sort -u
    Address 01
    Address 02
    Address 06
    Address 08
    Address 0E
    Address 13
    Address 15
    Address 16
    Address 19
    Address 28
    Address 34
    Address 36
    Address 3B
    Address 3C
    Address 42
    Address 47
    Address 48
    Address 52
    Address 56
    Address 5B
    Address 62
    Address 6D
    Address 6F
    Address 72
    Address 81
    Address 85
    Address 88
    Address 89
    Address 8A
    Address 8B
    Address 8D
    Last edited by jakematic; 05-11-2014 at 01:46 PM. Reason: additional label information
  13. Likes Uwe liked this post
  14. #10
    NC USA
    Latest test:
    APP Id (1) CodeBlock V0.4104 API V4
    FW version: 0.184.
    Dataset: 00000026
    VCDS 14.5.1
    The elapsed time is insanely long because I ran in Debug Level 2, smoked a lot of cigarettes, and wished I'd had a beer
    Maps emailed to support to go in the queue.
    Observations:
    - every time I change modes (cable/net/mobile) the HEX-NET needs to be unplugged and the vehicle shut down or it will not get access to 19, at all
    -- typically reports "Function Not Supported in Gateway"
    -- choosing the chassis does not help
    - in cabled mode module 62 did not reply - noticed it said K-Line Init in VCDS
    - several unplug/shutdown iterations require to switch to net mode
    -- tested fine in options every time
    - net mode hangs on 09, had to force quit/restart everything multiple times
    - never got anywhere in mobile mode after restarting multiple times
    -- could never get access to 19
    - gave up after idling for 2 hours
    Let me know if you need anything additional. THanks!
    Tuesday,20,May,2014,15:55:06:62017
    VCDS Version: 14.5.1.0
    Data version: 20140515
    Mileage: 13686km-8504mi   Repair Order:
              8E 8F 90
    VIN: WAURVAFD6CN014370   Mileage: 13686km-8504miles
       Revision: N5H07---
       VCID: 2A18C3264D0D686BD3-807F
       Revision: --H08---
       Coding: 000002
       VCID: 014A448A90FB4B33A2-8054
       VCID: 3228DB4665DD20AB6B-8067
    Address 05: Acc/Start Auth. (J393)       Labels: 8K0-907-064-05.CLB
       VCID: 6C94053E8F79B65B61-8039
    Address 06: Seat Mem. Pass (J521)       Labels: NONE
       VCID: 3522E05A9CB337934E-8060
       Coding: 480122BECC
       VCID: 2502301A24134713FE-8070
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.CLB
       VCID: 6E900F36B965444B4F-803B
       Coding: 0045F7
       Coding: 025523
       Coding: 100000
       Coding: 100000
       Coding: 020300
    Address 0E: Media Player 1 (R161)       Labels: NONE
       Revision: AA001001
       VCID: 22082B063D3DB02B9B-8077
       Coding: 280902
       VCID: 3B36F662B297E1E3B8-806E
       Coding: 3601020201
       VCID: 291A3C2A480B6373DA-807C
       VCID: 373EEA528EBFC5835C-8062
    Address 16: Steering wheel (J527)       Labels: NONE
       Coding: 0000BC
       VCID: 373EEA5286BFC5835C-8062
       ROD: EV_RBD4K.rod
       VCID: 302CD14E6BD112BB1D-8065
       Analog_clock:
       Coding: 00C1034A00
       VCID: 3424DD5E9FC92E9B79-8061
       Coding: 0000000000
       VCID: 312AD44A60DB1BB312-8064
       Coding: 008002
       VCID: 2C14C53E47F9765B21-8079
    Address 36: Seat Mem. Drvr (J136)       Labels: NONE
       ROD: EV_SARA.rod
       VCID: 6C94053E8779B65B61-8039
              U1111 00 [032] - -
    Address 3C: Lane Change        Labels: NONE
       VCID: 2E10CF36B9E5044B0F-807B
    Address 42: Door Elect, Driver (J386)       Labels: NONE
       VCID: 43C68E82C2679923F0-8016
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.CLB
       Coding: 020200
       Coding: 070000
       Coding: 020200
       Coding: 020200
       Coding: 020200
    Address 47: Sound System (J525)       Labels: NONE
       Coding: 030000
       VCID: 1C7415FE1F5986DB51-8049
    Address 48: Seat, Rear, DS (J876)       Labels: NONE
       VCID: 71AA144AA85B5BB352-8024
    Address 52: Door Elect, Pass. (J387)       Labels: NONE
       VCID: 3A38F366B5ADD8EBA3-806F
    Address 56: Radio (R)       Labels: NONE
       VCID: 200C210E3331A23B8D-8075
    Address 5B: Seat,Rear,PS (J877)       Labels: NONE
    Address 5F: Information Electr. (J794)       Labels: 4E0-035-6XX-5F.CLB
       VCID: 291A3C2A400B6373DA-807C
    Address 6C: Back-up Cam.        Labels: 4H0-907-441.CLB
       Coding: 1080003
       VCID: 2600371691154C0BF7-8073
       Coding: 0210044100
       VCID: 3D32F87AAC83EFD386-8068
       ROD: EV_Ambie.rod
       VCID: 63866E026AA7F923D0-8036
    Address 72: Door, Rear Right (J389)       Labels: NONE
       VCID: 393AEC6AB0ABD3F3AA-806C
       VCID: 2B16C62242F7716328-807E
       Coding: E9060000
       VCID: 6582701A649387133E-8030
       Coding: 764FF2
       VCID: 2F2ED23276EF0D4304-807A
       Coding: 364FF2
       Coding: 200F00
       VCID: 2E10CF3671E5044B0F-807B
       Coding: 3601020201
       VCID: 271E3A125E1F5503CC-8072
       Coding: 200F00
       ROD: EV_BC7.rod
       VCID: 2600371659154C0BF7-8073
       ROD: EV_RGS_L.rod
       ROD: EV_RGS_R.rod
    End-------------------------(Elapsed Time: 90:35)--------------------------
    Edit:
    Much improved labels list in this version.
    Edit II:
    I stand corrected, I did not grep ignoring case...
    bureau:Desktop jake$ grep -i none j.txt
  15. Likes jyoung8607, Uwe liked this post
