Results 1 to 10 of 12
Thread: New to VCDS. Getting "No response from controller"
    Oct 2015
    Hey all, I'm new to the audi VCDS world. I bought a legitimate HEX wifi device and on many modules I receive a "No repsonse from controller" message. If someone could help me remedy this situation, it would be greatly appreciated. Thanks in advance!
    2003 Allroad 2.7TT 6Spd
    VR
    Sean Halpin
    US Army (Ret.)
    Near Philadelphia, PA, USA
    Please help us by telling us how you have connected the HEX-NET. Are you using the HEX-NET with VCDS on Windows PC or are you using the HEX-NET with VCDS-Mobile on a smart device?
    Also, are you aware that your Allroad may not have all diagnostic capable modules listed installed? When this happens and you query a non-installed module, the error report you have given is the response from a module that is not present. The VCDS software is reporting that a request was made but nothing was returned from the controller.
    Again, please tell us more about what you are trying to do and with which modules you are trying to do this.
  3. Likes DocHalpin liked this post
    Oct 2015
    Hey Bruce, thanks for the response.
    I went ahead about bought a Lenovo Thinkpad with windows 7 that I will use predominantly for diagnostics and learning how to tune.
    A couple modules I know that give me trouble are trying to access both rear doors. I can gain access to see that error codes that the rear doors "cant unlock", but I can't access the doors individually.
    Also, trying to change settings so that there's an audible "beep" when the car is locked with the fob. I saw online that it can be accessed through "central convenience", but I get the "no response from controller" error when trying to get in.
    Let's see an autoscan with engine running or battery charger connected. Then we'll be able to see if there are modules that are definitely diagnostic-capable and installed, that don't answer. Rear doors and central convenience are not one of those, but it's entirely possible we have issues with other addresses.
  6. Likes Dana liked this post
    United States
    Right, the 4B chassis (Audi A6/S6/RS6/allroad (4B) does not use diagnostic capable door modules or #46 but the Auto-Scan will show us if #35-Central Locking in addition to all of the other addresses are behaving normally.
    P.S. If the beep can be modified that would be located in #35 rather than #46
    Oct 2015
    Hey Eric, how do I go about screenshotting or copy/pasting an autoscan?
    Please see: How To Post an Auto-Scan.
  10. Likes Eric liked this post
  11. #8
    Oct 2015
    VCDS Version: Release 15.7.1 (x64) Running on Windows 7 x64
    Data version: 20150904
    Wednesday,21,October,2015,15:55:27:30060
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2006))
              75 76 77
    VIN: WA1YD54B03N003403
    Address 01: Engine        Labels: 078-907-551-AZA.lbl
       Part No: 4Z7 907 551 S
       Component: 2.7L V6/5VT     G   0020
       Coding: 07712
       Shop #: WSC 26097
       VCID: 53E6AFB5A38024A6B0-5184
       WA1YD54B03N003403     AUZ7Z0B2162462
    17861 - Exhaust Gas Temp Sensor 1 (G235)
                P1453 - 35-00 - Open or Short to Plus
    17865 - Exhaust Gas Temp Sensor 2 (G236)
                P1457 - 35-00 - Open or Short to Plus
    Readiness: 0010 0101
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389 A
       Component: ABS/ESP allrad      D55
       Coding: 06495
       VCID: 4AD8B2D174CA656EC3-5184
    01422 - Hydraulic Pump for Electronic Stability Program (V156)
                35-00 -  -
    01310 - Level Control System Control Module (J197)
                49-00 - No Communications
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AD
       Component: A6-Klimavollautomat 0105
       Coding: 00010
       Shop #: WSC 02325
       VCID: 5CF44489CD5EEBDE61-2596
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 J
       Component: Airbag 8.4EP        2000
       Coding: 0000707
       Shop #: WSC 02325 785 00200
       VCID: 56E056A1E072318E57-5184
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 F
       Component: Lenkradelektronik   D01
       Coding: 01005
       Shop #: WSC 02325
       VCID: 2F2EC345EC682046F4-5216
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 P
       Component: KOMBI+WEGFAHRS. VDO D11
       Coding: 06264
       Shop #: WSC 19378
       VCID: 3326CF35034004A690-5184
    Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
       Part No: 4B0 962 258 M
       Component: Central Lock/Alarm  D37
       Coding: 14921
       Shop #: WSC 02325
       VCID: 3326CF35004004A690-4F0C
    00947 - Trunk Lid remote Control Switch (E188)
                29-10 - Short to Ground - Intermittent
    01561 - Rear left door
                59-00 - Can't Unlock
    01562 - Rear right door
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0102
       Coding: 00001
       VCID: 2C14D449DD7E5B5ED1-4B3C
    01445 - Sensor for Driver Seat Fore/Aft (G227)
    01446 - Sensor for Driver Seat; Seatback Adjust (G230)
                36-00 - Open Circuit
    01447 - Sensor for Driver Seat; Height Adjust (G231)
                20-00 - Malfunction in Basic Setting
    Address 37: Navigation        Labels: 4B0-919-887-BNS4.lbl
       Part No: 4B0 919 887 E
       Component: BNS 4.2 H05    BNO 0008
       VCID: 3522F12D0E341A96BE-4B1E
       Part No: 4B0 035 195 L
       Component: symphony II NP2    0009
       Coding: 00235
       Shop #: WSC 26097
       VCID: 291A2D5DD28C4E762A-4EEA
    Address 65: Tire Pressure        Labels: 4D0-907-273.lbl
       Part No: 4D0 907 273 A
       Component: Reifendruckueberw.  D110
       Coding: 20329
       Shop #: WSC 19378
       VCID: 2502216DBE946A160E-5184
    Address 75: Telematics        Labels: 8E0-035-616.lbl
       Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
       Component: Telematik USA1
       Coding: 0002333
       Shop #: WSC 26107 444 00039
       VCID: 23063F75E3A0942660-5184
    01531 - Emergency Battery
    End-------------------------(Elapsed Time: 07:01)--------------------------
  12. Likes Uwe, Eric, Dana liked this post
  13. #9
    Assuming this car has a manual transmission, I don't see any modules that are obviously missing, except for 34-Level Control. However based on the fault codes in other modules which indicate they can't talk to it either, it seems to be off-line.
    No car has a module at every address. This car is too old to have a gateway with a list of addresses that can be read out showing what modules are actually installed in the car, so VCDS gives you a list of addresses scans a list of addresses that MIGHT be in the car. When you go to select an individual control module, it gives you a list of addresses that might be an ANY car..
  14. Likes Eric liked this post
  15. #10
    Oct 2015
    The previous owner did the coil conversion. I'm in the process of sourcing air bags to switch back. I would assume the level control has to do with the air suspension.
    Uwe, so are you saying that everything appears to be good to go?
