good mornig, now like to ask for help on some noises ajustment clutches change when i return the lever from D to N,
initially had a breakdown unit, replaced it turned out ok.
but when I perform the same procedure nowit makes me crack this one will be normal?
VCDS Version: Release 15.7.1 Running on Windows 7 x86
Data version: 20150904
Sunday,15,March,2015,10:20:41:49232
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 55 56 62
72
VIN: 3VWFD71KX9M042996 Mileage: 101220km-62895miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0H53NR8CD
Coding: 040300101C070160
VCID: 3561004F5C812696BE-8060
Readiness: 0010 0000
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 051 C HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1817
Revision: 05144002 Serial number: 00001002121612
Shop #: WSC 04940 001 00001
VCID: 13259ED732B5D8A6F0-8046
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 143B600D492600FC281406ED921F0041B100
Shop #: WSC 35664 000 1048576
VCID: 000FA19B93C3533E5D-8054
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6DD1E82F7451AE5686-8038
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 00000001049194
Coding: 07058E234004150007140000001400000029770B5C000120000000000000
VCID: 33653E5752F538A690-8066
Component: Wischer 010908 021 0501
Coding: 00038805
Shop #: WSC 00066
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0400926
Coding: 0000000
Reset counter: 133
Mileage: 101217 km
Time: 17:59:01
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M06JZU3
Coding: 0013889
VCID: 6CD7E52B4F4BA75E91-8038
Subsystem 2 - Serial number: 6332MSME38716429B
Subsystem 3 - Serial number: 6342MSME3F252860D
Subsystem 4 - Serial number: 6351HSME17495B34B
Subsystem 5 - Serial number: 6361HSME174A0E0AE
Subsystem 6 - Serial number: 63727SME17246B1C4
Subsystem 7 - Serial number: 63827SME17345C5DB
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 051 0101
Coding: 0012121
VCID: 0407AD8B47DB4F1E79-8050
Component: E0221 002 0010
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H53NR8CD
Coding: 0022203
Shop #: WSC 01115 636 55642
VCID: 39790C7F7099C2F65A-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 080708F1001180
Coding: ED817F061013021002
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T35D604
Coding: 0000003
Component: IMMO VDD 2416
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000000288821
Coding: 0001205
VCID: 6FEDF2277E5D5C46B4-803A
00109 - Left Mirror Turn Signal Lamp (L131)
Fault Status: 00101100
Reset counter: 173
Mileage: 101222 km
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 74 2301
Revision: 00H15000
VCID: 2A5B2333853F796E23-807E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 13900F880106281B0904048FB0880F0688FC00
VCID: 71E9F45F68694AB6A2-8024
Address 47: Sound System (R12) Labels: None
Part No SW: 1K8 035 456 HW: 1K8 035 456
Component: KonzernAmp 8K H01 0316
Revision: -------- Serial number: BP218681606843
ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
ROD: EV_AudioVerst10KanalBNO1.rod
VCID: 6BD5E6378245A06698-803E
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 08080407361901
Coding: 0001204
VCID: 70EFF15B636343BEAD-8024
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E7FD4B177B7F9E49-8020
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio DE2 016 0020
Revision: 00016000 Serial number: VWZ4Z7H2229004
Coding: 0010400
VCID: 2959DC3F803972762A-807C
00003 - Control Module
014 - Defective
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003425121
Coding: 0001168
VCID: 76E3C74301076D8E77-8022
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003413134
Coding: 0001168
VCID: 77FDCA47060D14866C-8022
End-------------------------(Elapsed Time: 02:10)--------------------------
