Gear DSG 02E basic settings
caliche1275
Columbia
C?ID=160533
good mornig, now like to ask for help on some noises ajustment clutches change when i return the lever from D to N,
initially had a breakdown unit, replaced it turned out ok.
but when I perform the same procedure nowit makes me crack this one will be normal?
VCDS Version: Release 15.7.1 Running on Windows 7 x86
Data version: 20150904
Sunday,15,March,2015,10:20:41:49232
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 55 56 62
          72
VIN: 3VWFD71KX9M042996   Mileage: 101220km-62895miles
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0H53NR8CD
   Coding: 040300101C070160
   VCID: 3561004F5C812696BE-8060
Readiness: 0010 0000
   Part No SW: 02E 300 051 C    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1817
   Revision: 05144002    Serial number: 00001002121612
   Shop #: WSC 04940 001 00001
   VCID: 13259ED732B5D8A6F0-8046
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Revision: 00H45001
   Coding: 143B600D492600FC281406ED921F0041B100
   Shop #: WSC 35664 000 1048576
   VCID: 000FA19B93C3533E5D-8054
   Part No SW: 1K0 907 044 DE    HW: 1K0 907 044 DE
   Component: ClimatronicPQ35 130 1213
   Revision: 00130023    Serial number: 00000000000000
   VCID: 6DD1E82F7451AE5686-8038
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000001049194
   Coding: 07058E234004150007140000001400000029770B5C000120000000000000
   VCID: 33653E5752F538A690-8066
   Component: Wischer 010908 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Revision: 00000000    Serial number: AUZ4Z7H0400926
   Coding: 0000000
                    Reset counter: 133
                    Mileage: 101217 km
                    Time: 17:59:01
   Revision: 05034000    Serial number: 003B6M06JZU3
   Coding: 0013889
   VCID: 6CD7E52B4F4BA75E91-8038
   Subsystem 2 - Serial number: 6332MSME38716429B
   Subsystem 3 - Serial number: 6342MSME3F252860D
   Subsystem 4 - Serial number: 6351HSME17495B34B
   Subsystem 5 - Serial number: 6361HSME174A0E0AE
   Subsystem 6 - Serial number: 63727SME17246B1C4
   Subsystem 7 - Serial number: 63827SME17345C5DB
   Part No SW: 1K0 953 549 BS    HW: 1K0 953 549 BS
   Coding: 0012121
   VCID: 0407AD8B47DB4F1E79-8050
   Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0003000    Serial number: VWX7Z0H53NR8CD
   Coding: 0022203
   Shop #: WSC 01115 636 55642
   VCID: 39790C7F7099C2F65A-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 080708F1001180
   Coding: ED817F061013021002
   Component: Kompass         005 0004
   Revision: 00005000    Serial number: 1293324T35D604
   Coding: 0000003
   Component: IMMO            VDD 2416
   Revision: 72009005    Serial number: 00000000288821
   Coding: 0001205
   VCID: 6FEDF2277E5D5C46B4-803A
00109 - Left Mirror Turn Signal Lamp (L131)
                    Fault Status: 00101100
                    Reset counter: 173
                    Mileage: 101222 km
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 74     2301
   Revision: 00H15000
   VCID: 2A5B2333853F796E23-807E
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 13900F880106281B0904048FB0880F0688FC00
   VCID: 71E9F45F68694AB6A2-8024
Address 47: Sound System (R12)       Labels: None
   Part No SW: 1K8 035 456     HW: 1K8 035 456
   Component: KonzernAmp 8K H01 0316
   Revision: --------    Serial number: BP218681606843
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 6BD5E6378245A06698-803E
   Revision: 72009005    Serial number: 08080407361901
   Coding: 0001204
   VCID: 70EFF15B636343BEAD-8024
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74E7FD4B177B7F9E49-8020
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2229004
   Coding: 0010400
   VCID: 2959DC3F803972762A-807C
00003 - Control Module
            014 - Defective
   Revision: 12006001    Serial number: 00000003425121
   Coding: 0001168
   VCID: 76E3C74301076D8E77-8022
   Revision: 12006001    Serial number: 00000003413134
   Coding: 0001168
   VCID: 77FDCA47060D14866C-8022
End-------------------------(Elapsed Time: 02:10)--------------------------
caliche1275
Columbia
C?ID=160533
If ofcourse, step by step, as the auto-scan says if adapt well.
caliche1275
Columbia
C?ID=160533
Hi
Please have any idea, I see that when performing the basic setting on channel o60 do not coincide whit the values showing the link.
thanks.
In what way does it not coincide?
caliche1275
Columbia
C?ID=160533
Friday,20,March,2015,16:27:34:49232
VCDS Version: 15.7.1.0
VIN: License Plate: MPG000
Address 02: Auto Trans (02E 300 051 C)
16:27:09 Group 061
141
128
4
Friday,20,March,2015,16:28:42:49232
16:28:32 Group 060
13
caliche1275
Columbia
C?ID=160533
I'm sorry, I was just looking baseline,
have any idea that I can do to make this function do not drive in neutral?
caliche1275
Columbia
C?ID=160533
You know if there are any updates to the software mechatronics unit which spoke in this fórum?
Dana
Western PA, USA
Hi Carlos,
Was the Mechatronic unit replaced -or- was the entire transmission replaced?
Were the replacement parts brand new and ordered by VIN or used?
Was the filter changed and fluid level checked at the time of the repairs?
Does the transmission shift in all 6 forward gears and reverse at this point or is it stuck in neutral?
ivan-zgb
New Member
Croatia
Hi Everyone.. My first post here in Forums.. I will fill up proper introduction as soon as i reply to this since i don't want to miss this thread while i have quite similar situation..
Audi A3 2004 3.2 Quattro (BUB + DQ250) EU edition
A short introduction to problem;
- Purchased a car with “engine failure”
- Engine collant was contaminated with oil
- After inspection i have found out that engine was just fine and that transmission heat exchange have leaked oil in coolant
- E02 was contaminated with coolant
- did repair on heat exchange module and flush the trany several times
- now i have clean oil with new filter and proper level ( just about 0,5L over the tip on control drain @ 45 celsius)
- only error i have in trany is “wrong/none basic settings”
- tried to do basic settings with bosch kts ending with failure. (unknown just after cluch adaptation)
- borrowed Vcds from friend and tried the basic setting procedure
- offtopc -> was thrilled about interface and sw so i ordered mine same day and waiting for it now
- all ok within procedure up to group where tiptronic buttons should be initialized .. here it stays on “off” forever.
- group 69 is not accessible (ever)
- group 60 shows results in mm after going to ON
- tried to “decode” flappers on wheel and repeat with no success
- only error in 02 is still about basic settings
- tried to drive a car around it shifts all 6 gears ok up and down also with wheel flappers.
I know i should post auto scan and i will as soon as i get my interface.
I was wondering if someone head a similar problem (stuck in group 63 and 69 not available) to help me out.
Sorry for my poor English and spell errors. I am from Croatia/Europe and i am trying my best.
ivan-zgb
New Member
Croatia
oh.. i forgot .. group 61 shows 136 132 1 1 with basic settings OFF
and 141 128 4 1 with ON
group 60 -3.3mm -3.5mm -0.3mm -4mm when On or Off group 62 shows 3.0 17.0 0.000A and 0.000A when OFF and 67.0 5.0 0.000A 0.000A when ON 63 shows 0 and stays OFF
TomJigsaw
New York, USA
C?ID=501108
was there a resolution to this issue ?
