Results 1 to 6 of 6
Thread: 28823 No communications with airbag control module (U0151)
    Feb 2015
    Peterborough, UK
    Red face 28823 No communications with airbag control module (U0151)
    Hi, guys this is my first post here on the forum, I am looking for some advice on an issue with an intermittent fault 28823 No communications with airbag control module (U0151) code that has appeared ever since my local VW dealership changed my complete engine, cat converter, pre-cat down pipe, fuel injectors, pre & post cat lambda sensors, fuel filter (these were changed because the dealer used the wrong oil grade in my engine and seriously ?#?#?# it up!). The fault code has appeared under the engine module and no other fault codes in any other module are present. It appears to be intermittent and my initial thoughts are a connection issue?
    First the auto-scan data:-
    Tuesday,13,October,2015,14:17:12:64326
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    VIN: WVWZZZ1KZ8Wxxxxxx License Plate:
    Mileage: 54950km-34144mi Repair Order:
    Chassis Type: 1K (1K0)
    VIN: WVWZZZ1KZ8W169542 Mileage: 54950km-34144miles
    Address 01: Engine Labels: 03C-906-024-BXW.lbl
       Part No SW: 03C 906 024 AS HW: 03C 906 024 AS
       Component: MARELLI 4HV 0917
       Revision: --H06--- Serial number: VWX7Z0GN3N68QU
       Coding: 0004071
       Shop #: WSC 00000 028 00001
       VCID: 6FC3201D7E664A46B4-803A
    28823 - No Communications with Airbag Control Module
                U0151 - 000 - - Intermittent
                        Fault Status: 00110000
                        Reset counter: 23
                        Mileage: 54501 km
                        Date: 2000.01.01
                        Time: 15:14:48
       Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
       Revision: 00H11001
       Coding: 0019073
       Shop #: WSC 01279 785 00200
       VCID: 73CB2C6D124E6EA650-8026
       Part No SW: 1K0 820 047 HB HW: 1K0 820 047 HB
       Component: Climatic PQ35 141 1010
       Revision: 00141028 Serial number: 00000000000000
       VCID: 6BFB340D4A7EB66698-803E
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
       Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
       Revision: 00H54000 Serial number: 01000007667786
       Coding: 008D0F2700041500471400001400000000087B075C000100000000000000
       Shop #: WSC 00000 785 00200
       Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
       Component: Wischer 081107 021 0501
       Coding: 00038805
       Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
       Component: 38 AIRBAG VW8 020 2300
       Revision: 05020000 Serial number: 0038PD1KT2Y6
       Coding: 0013112
       Shop #: WSC 01269 785 00200
       VCID: 3D5FCA55648AE8D676-8068
       Subsystem 1 - Serial number: 6332MSME297438127
       Subsystem 2 - Serial number: 6342MSME333577459
       Subsystem 3 - Serial number: 6352QSME44797733L
       Subsystem 4 - Serial number: 6362QSME3D731617J
       Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
       Component: Lenksäulenmodul 636 0070
       Part No SW: 1K0 920 954 K HW: 1K0 920 954 K
       Component: KOMBIINSTRUMENT VDD 1212
       Revision: V0002000 Serial number: VWX7Z0GN3N68QU
       Coding: 0003403
       Shop #: WSC 00225 210 99164
       VCID: 3449EF7157C0299E89-8060
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
       Part No SW: 1K0 907 530 L HW: 1K0 907 951
       Component: J533__Gateway H15 0180
       Revision: H15 Serial number: 1400K077258301
       Coding: E9801F060002020003
       VCID: 3041E361A3D815BEED-8064
       Component: IMMO VDD 1212
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
       Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
       Component: Tuer-SG 006 1204
       Coding: 0000564
       VCID: 3851DB414BA8CDFEA5-806C
       Part No: 1K2 909 144 M
       Component: EPS_ZFLS Kl.067 H08 1901
       VCID: 364DD57941BC3B8EB7-8062
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Component: KSG 0401
       Coding: 80C802087F2D8405485B038010CC
       Shop #: WSC 00225 210 91070
       VCID: 002173A153F8453E5D-8054
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
       Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
       Coding: 0000564
       VCID: 3957DE4570A2D4F65A-806C
       Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
       Component: Radio BVX 037 0048
       Revision: 00037000 Serial number: VWZ1Z2G6326202
       Coding: 0020400
       VCID: 68F14B015B889D7EF5-803C
    End-------------------------(Elapsed Time: 00:59)--------------------------
    Feb 2015
    Peterborough, UK
    Following on from my initial email to RossTech support, thank you Jef for your initial email and pointers to this forum.
    As suggested, I have had a look at measuring block 126 and the values are:= Airbag 1, Cent. Elec 1. these values remain at 1. I have also noticed that the reset counter has risen to 32. I am assuming that this figure will continue to rise until reaching 255? Am I right in assuming that if it reaches that point without any further fault condition, this would archive this fault and return the log to no fault found?
    What my thought process is, that when the dealership changed the engine, they I assume would have had to disconnect this engines ECU to facilitate the engine change and perhaps some dampness has got into the connection causing this fault, or like I suggested previously perhaps have not connected the harness properly. As this workmanship is under my VW dealerships' 2 year warranty, I might get them to rectify this. But any feedback would still be greatly received, as I am still sceptical of the dealership, after all, they did put the wrong grade of oil in my car to begin with eh?
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello John,
    i would delete the fault, look into MWB 126 in "01" for BUS communication while moving the wiring.
    -Wolfgang
    Drive more talk less
  4. Likes Uwe liked this post
    Feb 2015
    Peterborough, UK
    Hi, AIB Wolfgang
    Thanks for your reply. I shall give that a try. I'm assuming that the wiring goes through to the ECU in the engine bay from the airbag control unit inside the vehicle?
    Kind regards
    John
    Sep 2014
    Hi John,
    no. All connected to Gateway "19". Try to read the power train bus also in "19".
    -Wolfgang
    Feb 2015
    Peterborough, UK
    Hi AIB Wolfgang,
    Just a quick update, tried various 'cable wriggling' whilst monitoring measuring block 126, could not get the fault to re appear and the measuring block status remained at 1. Just had my local Volkswgen dealership service the car and run it through its MOT - passed no problems. They looked into the CAN Bus error and couldn't find a fault, so just reset the error code. I will need to keep a close eye on it myself, as not even the VW dealer could find what was throwing up this intermittent error code! I explained to the dealer that I could reset the fault easily myself, what I wanted was an explanation! after collecting my car from the dealership, I have checked it again, they have deleted the fault. Will keep you posted if it returns, which I am sure it will.
  8. Likes Uwe, AIB Wolfgang liked this post
