Hi all,
I could use some coding expertise. I've installed and wired the Chinese-made Hella LED tail lights with rear fog. Now I'm trying to achieve two things: turn off cold diagnostics for the now-defunct left reverse light and (more significantly) stop the outer rings of the tails from illuminating amber when I use the brakes. The outer rings do blink amber when the hazards or turn signals are used, but also when the brakes are used. I'd like the amber to be for blinkers only which, as I understand, is the correct, full-on "amber club" mode of operation.
Here is the CECM section of my current coding (ignore the license plate bulb warning - it needs replacing):
Let me know if there's more you need to see and if there are any questions I can answer.
Many thanks for your time & effort!
dco
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 L HW: 5K0 937 085 L
Component: BCM PQ35 B++ 111 0135
Revision: BI111001
Coding: 2D200B3F902F3EE4800A00042B00000401000086510085605C8020000000
Shop #: WSC 00066 123 12345
VCID: 3C59D568BF869DDE41-8068
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 14081 21 0512
Coding: 009795
Fault Status: 00101010
Fault Frequency: 120
Reset counter: 211
Mileage: 75777 km
Date: 2015.06.03
Time: 07:37:47
Voltage: 13.90 V
Fault Status: 01101010
Reset counter: 190
Mileage: 82099 km
Date: 2015.10.11
Time: 00:15:01
Voltage: 11.75 V
dco
