The explanation provided to us-
The vehicle speed(engine RPM) staying held for 2-3 seconds after throttle pedal is released.
The Phenomenon being experienced is part of the vehicles Torque Controlled engine management system. The system generates a specific torque according to external (gearbox shift point, traction control system, engine braking control, the air conditioning system and the cruise control system)and internal (start-up, catalytic convertor heating, idle speed control, power limitation, speed limitation and lambda control) torque demands. The control of the throttle valve angle, charge pressure, ignition timing and emission (Lambda) control are what are keeping the engine RPM at the noted figure for the two to three second period. This is of a series standard with no fault in the sense of vehicle functionality.
