- Joined
- Feb 19, 2014
- Messages
- 6
- Reaction score
- 0
- VCDS Serial number
- C?ID=208413
Hey guys,
Just got my HEX-NET last night, and played around with it a little. Here is some feedback:
- Setup was relatively easy, but I did run into an issue where the SSID name that I entered in VCDS Mobile would get garbled (extra characters added at the end) when saved. I got around it by using the Java-based setup tool.
- I did experience timeouts with the cloud functionality, but trying again worked.
- I wish that auto-scan and OBD-II codes showed freeze frames in VCDS Mobile.
Since VCDS Mobile isn't on a par with native VCDS yet, I tried connecting the native VCDS to HEX-NET via the USB cable, but couldn't get it recognized. I did this in VMWare (I'm on a Mac), so that very well might have been the problem, but I wanted to ask if this is supposed to work with the current VCDS version? I know that you're working on a beta that will provide Wi-Fi connectivity, but it's unclear whether HEX-NET would currently work in cable mode.
Finally, do you have an ETA on the Wi-Fi enabled native VCDS version?
