- Joined
- Apr 28, 2014
- Messages
- 18
- Reaction score
- 2
- VCDS Serial number
- C?ID=112475
I'm suggesting that if both are not, then you'll see that fault code. The question is whether both actually support it. I don't have an answer to that question.
Get's complicated, doesn't it?
So, there is a possibility that even though a fault code shows up in #03, ABS, the DSR may actually be active when appropriately coded for "DSR Active" in #44, Steering Assist?
Like I said, there is only one module, #44 where it is possible to activate DSR in my 2013 CC. At least as far as I can find.
I wonder if it is better to leave it activated and have the fault code or deactivate it and have no malfunction.
Or, maybe I should just forget about the whole thing and go about my life as if this subject never came up.
By the way, my 2009 Eos has DSR Active and handles noticeably better than my CC at highway speeds. This was the OEM setting.
