Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: MQB (Mk7 Golf) Steering Angle Sensor (G85) Calibration in 44 - Steering Assist
  1. #21
    Mar 2015
    Australia
    Hi Jef,
    No, the basic settings status never changed to finished like it would with regular G85 calibration on a PQ car for example.
    But following the process you described resulted in the fault being cleared.
    I have run the procedure in O..S in the past and that gives a successful message, though I was not watching the measuring block for basic settings status, just do as it says.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
  2. Likes Dana, Uwe liked this post
  3. #22
    Nov 2016
    says something about running....then unknown when trying basic setting.
    does not say finished correctly .
    but cant check car till friday.
  4. #23
    Nov 2016
    had to do this in abs...would not work in 44-steering assist plus the security access baloon popped up a different number in 44-steering assist,i tried the procedure in abs and it worked.....thankyou guys.
  5. Likes Uwe liked this post
  6. #24
    Apr 2019
    Will this procedure work on NAR MQB Tiguan? I had to disconnect car's battery for easy open retrofit. I'm pretty sure I got these errors because I disconnected the battery and not because of easy open retrofit(keep reading)
    There are multiple errors in few modules but I think not calibrated steering angle is the root cause. Here is a scan of my 44 - Steering Assist:
       Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
       Component: EPS_MQB_ZFLS  173 1081
       Coding: 011F0000
       Shop #: WSC 00066 790 00273
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50F973409A675ED71A9-8004
    16272 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 23
                        Time: 00:00:00
                        Motor status: 00
                        System status: Reset
                        Supply voltage: 12.50 V
                        Temperature: 34.0 °C
                        KFC: 3F
                        KFA: 00 90
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 12.56 V
                        uAdSensI_SwitchedKl30_xdu16: 12.54 V
                        NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                        NoInitCause_RackPos_Rohwert: 00 C0
                        RP_VALCNTSAV: not activated
                        RP_DIAGJOB: not activated
                        RP_RPS: not activated
                        RP_KMN_RACKPOS_SET: not activated
                        RP_STARTUP: not activated
                        RP_L2PLAUSI: not activated
                        RP_INDEXPLAUSI: not activated
                        RP_WHLSPDPLAUSI: not activated
                        RP_RUKUCNTR: not activated
                        RP_UNDERVOLT: activated
                        RP_CNTERR: activated
    Here is rest of my scan . Ignore calibration error in 05 module, I think that is because of the new sensor but Ill deal with that after I get steering angle calibration resolved(more important)
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 83A 907 115     HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H31 0004
       Revision: 1DH31000
       Coding: 012A00122464012FB4000000000000000000000000000000
       Shop #: WSC 25016 444 00000
       ASAM Dataset: EV_ECM20TFS01183A907115 001006
       ROD: EV_ECM20TFS01183A907115.rod
       VCID: 6393AC8CFBD1D54FB7B-8036
    17158 - Implausible Data Received from ESP Control Module
              U0416 00 [036] - -
                        Mileage: 8126 km
                        Date: 2019.09.07
                        Time: 00:02:22
                        Coolant temperature: 32 °C
                        Intake air temperature: 33 °C
                        Voltage terminal 30: 12.060 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
                        Acceleration: 0.000 m/s²
       Part No SW: 09G 927 158 DS    HW: 09G 927 158
       Component: AISIN AQ8     206 3550
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00442
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 074B981C2FA9596F8B3-8052
       Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
       Component: ESC           H25 0524
       Revision: 00000000    Serial number: 52518000000966
       Coding: 0BFA6BA454231B6CC57F0208A2C449D0D62AD8A34045927038415058C282420B002764121A1C230A35351919323200
       Shop #: WSC 01383 790 50316
       VCID: 77ABE8DC5F4929EFFB3-8022
    0297 - Steering Angle Sensor
                        Reset counter: 58
                        Mileage: 8126 km
                        Date: 2019.09.07
                        Time: 00:02:22
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0490283687
       Coding: 132C0C0723
       VCID: 43D34C0C5B11B54F97B-8016
       Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11055514
    221445 - Sensor for Rear Lid/Hatch Opening
              B1303 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 18
                        Mileage: 8126 km
                        Date: 2019.09.07
                        Time: 00:18:52
                        Terminal_15_Kessy_specified_value: On
                        Terminal_15_Kessy_actual_value: On
                        Terminal_15_central electric_actual_value: On
                        Terminal_15red_Kessy_specified_value: On
                        Terminal_15red_Kessy_actual_value: On
                        Terminal_S_Kessy_specified_value: On
                        Terminal_S_Kessy_actual_value: On
                        Terminal_S_central electric_actual_value: On
                        ZAT_pressed: OFF
                        Park selector lever position: Engaged and locked
                        Enabling immobilizer: Condition not met
                        Control Module Voltage: 12.191 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Status of vehicle locking: Vehicle unlocked
                        Coding information: coded
                        Coding information: Not coded
                        Driver door: closed
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        ID sensor 1 authentication: status: No response
                        ID sensor 2 authentication: status: No response
                        ID sensor 3 authentication: status: No response
                        ID sensor 4 authentication: status: No response
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
       Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
       Component: AC Automat    H35 4401
       Revision: 20K03000    Serial number: 00000D00238665
       Coding: 00020024200118001005010012111406
       ASAM Dataset: EV_ACClimaPrehVW37X 002025
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 4FFB703C8759412F033-801A
       Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
       Revision: --------    Serial number: C86421091803FA
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7CA1F7F0666F0AB7961-8028
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 180917  034 0373
       Serial number: 18091421039560
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0300151020180C202288
       Part No SW: 5QA 919 294 C    HW: 5QA 919 294
       Component: PDC 8 KanalH07 0050
       Serial number: 000137088R18289
       Coding: 0471155811
       ASAM Dataset: EV_EPHVA18AU3700000 009039
       VCID: 4CC16730764F7A37661-8018
    13637426 - Databus
                        Reset counter: 58
                        Mileage: 8126 km
                        Date: 2019.09.07
                        Time: 00:02:23
       Coding: 3200000158FF8728749C8145304097
       VCID: 3E253DF830F3D8A7F85-806A
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                        Reset counter: 58
                        Mileage: 8126 km
                        Date: 2019.09.07
                        Time: 00:02:23
                        Voltage terminal 15: 12.2 V
                        Control Module temperature: 30 °C
                        Longitudinal_acceleration_vehicle_reference: -0.06 m/s²
                        Status_ACC_System: ACC_Off_MainSwitch_Off
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                        Reset counter: 58
                        Mileage: 8126 km
                        Date: 2019.09.07
                        Time: 00:02:23
                        Voltage terminal 15: 12.1 V
    2055 - Databus
              [FAULT_ALP_STEERINGWHEEL_INIT]
                        Reset counter: 58
                        Mileage: 8126 km
                        Date: 2019.09.07
                        Time: 00:02:24
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    005 0338
       Serial number: 003NUM0BHRZ$
       Coding: 8CCCFC00000000005000001AC20800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 0557921415A54B7FF9F-8050
       Occupant Detection:
       Serial number: IBH00000000000ABQA7O
       Coding: 303351
       Subsystem 2 - Part No SW: -----------    HW: 480 002 407 18
       Serial number: 3570000000055C85933M
       Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
       Serial number: 358000000002B2843339
       Subsystem 4 - Part No SW: -----------    HW: 480 400 507 18
       Component: SideSensor_Dr  004 6149
       Serial number: 3510001142B6FB4485D8
       Subsystem 5 - Part No SW: -----------    HW: 480 400 507 18
       Component: SideSensor_Pr  004 6149
       Serial number: 3520001102B6FB4544A+
       Subsystem 6 - Part No SW: -----------    HW: 480 400 609 18
       Component: FrontSensor_D  004 6149
       Serial number: 3550001142B70FA244B%
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 609 18
       Component: FrontSensor_P  003 6149
       Serial number: 3560001A32BD5EC2E59T
       Part No SW: 5NA 920 891 C    HW: 5NA 920 891 C
       Component: KOMBI         403 4191
       Coding: 0BA4011A2788CF0502886A0954010000A0000000
       VCID: 44D14F105E1FB277AE1-8010
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5344
       Serial number: 16091800840285
       Coding: 030100347F085900FA000258180F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 3D273AF43DF5C3BFE1F-8068
       Component: 1-00-0d-00-04
       Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
       Component: E221__MFL-TAT  H06 0025
       Serial number: 2561814221201572FJ2B
       Coding: 2C0000
       Serial number: 8137026100
       Serial number: 18000277352016
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 33331CCC0BB105CF07B-8066
       Component: HRE_Master    H12 0081
       Serial number: 0489763985
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       Component: HRE_Slave  H12 0081
       Serial number: 0490546230
       Coding: 020111
       Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
       Component: TSG FS        006 0247
       Serial number: 50038828100576
       Coding: 00341B200000048000000000
       VCID: 4DC76A348D55733F71F-8018
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Serial number: 00000000000000933052
       Coding: 011000
    196660 - Motor for Window Regulator
              B1487 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 18
                        Mileage: 8126 km
                        Date: 2019.09.07
                        Time: 00:00:05
       Coding: 011F0000
                        Reset counter: 23
                        Time: 00:00:00
                        Motor status: 00
                        KFC: 3F
                        KFA: 00 90
       Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
       Component: TSG BFS       006 0247
       Serial number: 54038827902458
       Coding: 003413200000048000000000
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Serial number: 00000000000000951853
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    853 0890
       Coding: 02730602BE00000051220001001808001F0500E401200405C6
       Shop #: WSC 00066 790 00326
       ROD: EV_MUStd4CDELP_VW37.rod
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  252 8130
       Serial number: VWZ6ZMV2535287
       Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
       Component: NAR 2018/19  --- 0810
       Coding: 0123060122002017300040
       VCID: 392F2EE429DDFF9FCD7-806C
       Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0266
       Revision: --------    Serial number: A2-C758-8680-2
       Coding: 0A08
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       VCID: 45D7521455258B7FB9F-8010
       Component: OCULowMQBUS   009 0570
       Coding: 02230602C2823A017F1E06000000
       ROD: EV_OCULowMQB.rod
       Coding: 00804073260C
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.8V/12.7V)-----------
  7. #25
    Apr 2018
    ITALY
    just drive the car for a minute, making sure you fully turn the sterring wheel both ways for a couple of times each. cycle ignition and you'll be able to clear the errors.
    it is standard procedure everytime the battery is disconnected.
  8. Likes Uwe, PetrolDave liked this post
  9. #26
    Apr 2019
    O man I feel silly. You know I did that when I first connected the battery but forgot that I need to also do one full key on/off cycle. I just cleared all errors and the only one that remained is my 05-module "easy open sensor", but that is expected.
    I will now go figure that thing out.
    Thanks!
  10. Likes darkchina811, PetrolDave liked this post
