MQB (Mk7 Golf) Steering Angle Sensor (G85) Calibration in 44 - Steering Assist
   #21
kamold
Australia
C?ID=241363
Hi Jef,
No, the basic settings status never changed to finished like it would with regular G85 calibration on a PQ car for example.
But following the process you described resulted in the fault being cleared.
I have run the procedure in O..S in the past and that gives a successful message, though I was not watching the measuring block for basic settings status, just do as it says.
vw754
C?ID=52227
says something about running....then unknown when trying basic setting.
does not say finished correctly .
but cant check car till friday.
   #23
vw754
C?ID=52227
had to do this in abs...would not work in 44-steering assist plus the security access baloon popped up a different number in 44-steering assist,i tried the procedure in abs and it worked.....thankyou guys.
   #24
OEMplusCC
C?ID=160054
Will this procedure work on NAR MQB Tiguan? I had to disconnect car's battery for easy open retrofit. I'm pretty sure I got these errors because I disconnected the battery and not because of easy open retrofit(keep reading)
There are multiple errors in few modules but I think not calibrated steering angle is the root cause. Here is a scan of my 44 - Steering Assist:
   Part No SW: 5QM 909 144 B    HW: 5QM 909 144 B
   Component: EPS_MQB_ZFLS  173 1081
   Coding: 011F0000
   Shop #: WSC 00066 790 00273
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F973409A675ED71A9-8004
16272 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 23
                    Time: 00:00:00
                    Motor status: 00
                    System status: Reset
                    Supply voltage: 12.50 V
                    Temperature: 34.0 °C
                    KFC: 3F
                    KFA: 00 90
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.56 V
                    uAdSensI_SwitchedKl30_xdu16: 12.54 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 00 C0
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_KMN_RACKPOS_SET: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_WHLSPDPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
Here is rest of my scan . Ignore calibration error in 05 module, I think that is because of the new sensor but Ill deal with that after I get steering angle calibration resolved(more important)
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 83A 907 115     HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0004
   Revision: 1DH31000
   Coding: 012A00122464012FB4000000000000000000000000000000
   Shop #: WSC 25016 444 00000
   ASAM Dataset: EV_ECM20TFS01183A907115 001006
   ROD: EV_ECM20TFS01183A907115.rod
   VCID: 6393AC8CFBD1D54FB7B-8036
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [036] - -
                    Mileage: 8126 km
                    Date: 2019.09.07
                    Time: 00:02:22
                    Coolant temperature: 32 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 12.060 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
   Part No SW: 09G 927 158 DS    HW: 09G 927 158
   Component: AISIN AQ8     206 3550
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00442
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 074B981C2FA9596F8B3-8052
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 52518000000966
   Coding: 0BFA6BA454231B6CC57F0208A2C449D0D62AD8A34045927038415058C282420B002764121A1C230A35351919323200
   Shop #: WSC 01383 790 50316
   VCID: 77ABE8DC5F4929EFFB3-8022
0297 - Steering Angle Sensor
                    Reset counter: 58
                    Mileage: 8126 km
                    Date: 2019.09.07
                    Time: 00:02:22
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0490283687
   Coding: 132C0C0723
   VCID: 43D34C0C5B11B54F97B-8016
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11055514
221445 - Sensor for Rear Lid/Hatch Opening
          B1303 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 18
                    Mileage: 8126 km
                    Date: 2019.09.07
                    Time: 00:18:52
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    ZAT_pressed: OFF
                    Park selector lever position: Engaged and locked
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.191 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
   Component: AC Automat    H35 4401
   Revision: 20K03000    Serial number: 00000D00238665
   Coding: 00020024200118001005010012111406
   ASAM Dataset: EV_ACClimaPrehVW37X 002025
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 4FFB703C8759412F033-801A
   Part No SW: 5Q0 937 087 BB    HW: 5Q0 937 087 BB
   Revision: --------    Serial number: C86421091803FA
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7CA1F7F0666F0AB7961-8028
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 180917  034 0373
   Serial number: 18091421039560
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300151020180C202288
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000137088R18289
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC16730764F7A37661-8018
13637426 - Databus
                    Reset counter: 58
                    Mileage: 8126 km
                    Date: 2019.09.07
                    Time: 00:02:23
   Coding: 3200000158FF8728749C8145304097
   VCID: 3E253DF830F3D8A7F85-806A
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 58
                    Mileage: 8126 km
                    Date: 2019.09.07
                    Time: 00:02:23
                    Voltage terminal 15: 12.2 V
                    Control Module temperature: 30 °C
                    Longitudinal_acceleration_vehicle_reference: -0.06 m/s²
                    Status_ACC_System: ACC_Off_MainSwitch_Off
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 58
                    Mileage: 8126 km
                    Date: 2019.09.07
                    Time: 00:02:23
                    Voltage terminal 15: 12.1 V
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 58
                    Mileage: 8126 km
                    Date: 2019.09.07
                    Time: 00:02:24
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    005 0338
   Serial number: 003NUM0BHRZ$
   Coding: 8CCCFC00000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 0557921415A54B7FF9F-8050
   Occupant Detection:
   Serial number: IBH00000000000ABQA7O
   Coding: 303351
   Subsystem 2 - Part No SW: -----------    HW: 480 002 407 18
   Serial number: 3570000000055C85933M
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Serial number: 358000000002B2843339
   Subsystem 4 - Part No SW: -----------    HW: 480 400 507 18
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001142B6FB4485D8
   Subsystem 5 - Part No SW: -----------    HW: 480 400 507 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001102B6FB4544A+
   Subsystem 6 - Part No SW: -----------    HW: 480 400 609 18
   Component: FrontSensor_D  004 6149
   Serial number: 3550001142B70FA244B%
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 609 18
   Component: FrontSensor_P  003 6149
   Serial number: 3560001A32BD5EC2E59T
   Part No SW: 5NA 920 891 C    HW: 5NA 920 891 C
   Component: KOMBI         403 4191
   Coding: 0BA4011A2788CF0502886A0954010000A0000000
   VCID: 44D14F105E1FB277AE1-8010
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 16091800840285
   Coding: 030100347F085900FA000258180F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3D273AF43DF5C3BFE1F-8068
   Component: 1-00-0d-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 2561814221201572FJ2B
   Coding: 2C0000
   Serial number: 8137026100
   Serial number: 18000277352016
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331CCC0BB105CF07B-8066
   Component: HRE_Master    H12 0081
   Serial number: 0489763985
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   Component: HRE_Slave  H12 0081
   Serial number: 0490546230
   Coding: 020111
   Part No SW: 5Q4 959 393 M    HW: 5Q4 959 393 F
   Component: TSG FS        006 0247
   Serial number: 50038828100576
   Coding: 00341B200000048000000000
   VCID: 4DC76A348D55733F71F-8018
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Serial number: 00000000000000933052
   Coding: 011000
196660 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 18
                    Mileage: 8126 km
                    Date: 2019.09.07
                    Time: 00:00:05
   Coding: 011F0000
                    Reset counter: 23
                    Time: 00:00:00
                    Motor status: 00
                    KFC: 3F
                    KFA: 00 90
   Part No SW: 5Q4 959 392 M    HW: 5Q4 959 392 F
   Component: TSG BFS       006 0247
   Serial number: 54038827902458
   Coding: 003413200000048000000000
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Serial number: 00000000000000951853
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    853 0890
   Coding: 02730602BE00000051220001001808001F0500E401200405C6
   Shop #: WSC 00066 790 00326
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  252 8130
   Serial number: VWZ6ZMV2535287
   Subsystem 2 - Part No SW: 5NA 919 866 E    HW: -----------
   Component: NAR 2018/19  --- 0810
   Coding: 0123060122002017300040
   VCID: 392F2EE429DDFF9FCD7-806C
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: A2-C758-8680-2
   Coding: 0A08
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   VCID: 45D7521455258B7FB9F-8010
   Component: OCULowMQBUS   009 0570
   Coding: 02230602C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Coding: 00804073260C
End----------(Elapsed Time: 01:36, VBatt start/end: 12.8V/12.7V)-----------
   #25
darkchina811
ITALY
C?ID=333184
just drive the car for a minute, making sure you fully turn the sterring wheel both ways for a couple of times each. cycle ignition and you'll be able to clear the errors.
it is standard procedure everytime the battery is disconnected.
   #26
OEMplusCC
C?ID=160054
O man I feel silly. You know I did that when I first connected the battery but forgot that I need to also do one full key on/off cycle. I just cleared all errors and the only one that remained is my 05-module "easy open sensor", but that is expected.
I will now go figure that thing out.
Thanks!
AudiA32016
C?ID=386038
I don't know when or if you will read this message, but I was wondering if you could give me some additional information on how you did this in 03 ABS. More specifically, what Security Access code did you use in your 03ABS? And what code did it tell you when you were trying to use steering 44? And it would also help if you told us if the procedure is the same as the one outlined here. Thanks hope to hear from you soon.
Oh yea for the others who got stuck at the "Running" part, just make sure both say permitted after turning lock to lock and centering(there is also a tab for degree value of the steering sensor for when you are re-centering the wheel, located near the steering angle basic setting start tabs), and then press DONE, not stop.....there is no confirmation for our cars, open up steering angle sensor status tab where you opened the basic settings start tabs and make sure it says "initialized" or "calibrated" it can even take a minute or so after calibrating it so wait a minute or two after pressing done. If it never says calibrated you did it wrong it might say Not Calibrated. When it says calibrated, all your dash lights and warnings should disappear. You may need to do an additional lock to lock and center AFTER pressing done with "Running" in order for the status to switch to Calibrated.
Dmaxison
Cleveland, OH, USA
C?ID=419549
I've been digging through many posts on 44-steering assist module trying to resolve end stops failing to adapt. It all started with resetting the module to factory settings because i have VCDS, a VW Alltrack, a lift, and imagination, SMH! Corrected the coding back to 8102 and went through the procedure several times but could not resolve the error in the module for end stops not learned. (16387 - Steering End Stops Not Learned). I could calibrate and clear dash lights.
Unrelated...The scan below also shows an over pressure fault due to some bad fuel (hope) and tuning (stage2 IS20), however, proof of calibration without end stops adapting is there.
To get to the point I figured out a way to get this issue resolved. #1 Using this procedure. This would allow me to clear the dash lights in turn reaching initialized and calibrated.
So to add to the process...
END STOP ADAPTATION
Prerequisites: Steering Calibrated
  1. Power Cycle upon successful calibration and no DTC's
  2. Key On Engine Running
  3. Login in to Module 44-SA as "CODING"
  4. >"28183" enter
  5. Select Basic Settings >> End Stop Reset
  6. >Do it!
  7. Even though it says completed successfully, DO NOT "GO BACK" or "STOP"
  8. Monitor IDE05162-IDE03723; IDE05162-MAS01849; IDE05162-MAS01850
  9. Perform full lock to lock rolling test. ...03723 will report adapted upon completion!
I suspect that "coding" is needed as login method in order to write the values into the module's memory.
Hopefully this helps round out the 5K steering module wiki. Please add!
Vehicle Scan
Tuesday,06,April,2021,17:06:57:16304
VCDS Version: 21.3.0.0 (x64)  HEX-V2 CB: 0.4543.4
VIN: 3VWH17AU6HM510868   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 5F 75
VIN: 3VWH17AU6HM510868   Mileage: 77678km-48266miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 L    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 311D00122426002F1000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
   ROD: EV_ECM18TFS0208V0906264L.rod
   VCID: 45D755DDB5221D23FC5-8010
15074 - Cylinder Disabling
          P130A 00 [101] - -
                    Mileage: 77650 km
                    Date: 2021.04.06
                    Time: 16:46:47
                    Engine RPM: 3391.25 /min
                    Normed load value: 47.8 %
                    Vehicle speed: 101 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 13.574 V
                    Engine: operating status: PL
                    N_TOOTH: 3369 /min
                    T_AST_SAE: 1281 s
                    Engine oil temperature: 110.0 °C
                    STATE_LS_SAE[1]: OL_INTR
                    FUP_H_SAE: 20140.0 kPa
                    FUP_EFP_MES: 11000.8 hPa
15131 - Cylinder 3
          P0303 00 [096] - Misfire Detected
                    Mileage: 77539 km
                    Date: 2021.04.05
                    Time: 18:46:41
                    Engine RPM: 2977.75 /min
                    Normed load value: 6.3 %
                    Vehicle speed: 62 km/h
                    Coolant temperature: 101 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.160 V
                    Unlearning counter according OBD: 38
                    N_TOOTH: 2969 /min
                    T_AST_SAE: 531 s
                    Engine oil temperature: 94.0 °C
                    STATE_LS_SAE[1]: CL
                    FUP_H_SAE: 7540.0 kPa
15128 - Cylinder 2
          P0302 00 [096] - Misfire Detected
                    Mileage: 77539 km
                    Date: 2021.04.05
                    Time: 18:46:41
                    N_TOOTH: 2969 /min
                    T_AST_SAE: 531 s
                    STATE_LS_SAE[1]: CL
15137 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 77539 km
                    Date: 2021.04.05
                    Time: 18:46:41
                    N_TOOTH: 2969 /min
                    T_AST_SAE: 531 s
                    STATE_LS_SAE[1]: CL
15180 - Cylinder 4 Pressure too High
          P03B9 00 [101] - -
                    Mileage: 77650 km
                    Date: 2021.04.06
                    Time: 16:46:46
                    Engine RPM: 3339.00 /min
                    Normed load value: 50.6 %
                    Vehicle speed: 99 km/h
                    Coolant temperature: 93 °C
                    Voltage terminal 30: 13.535 V
                    IGA_IGC_SAE: 0.0 °
                    Charge air pressure control valve position: actual value: 9.06 %
                    Charge air pressure control valve position: target value: 8.59 %
                    CAM_VCP[IN_1]: 27.633 °
                    CAM_SP_IND_VCP[IN_1]: 26.500 °
                    Lambda probes actual: bank1: 0.8496
                    MAP_MES_SAE: 255 kPa
Readiness: 0010 0001
   Part No SW: 0D9 300 012 F    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4932
   Revision: 06354004    Serial number: TFK01607271775
   Shop #: WSC 00066 790 00064
   ROD: EV_TCMDQ250021.rod
   VCID: 196FC9AD691A49C368D-804C
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 52146000001881
   Coding: 43FA6AA13421096C807F130681CB29C2562C9001C881943C00430050E00903
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035.rod
   VCID: 75B7E51DA542CDA3AC5-8020
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 90
                    Mileage: 77513 km
                    Date: 2021.04.05
                    Time: 12:55:16
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0414091710
   Coding: 032C0C
   VCID: 3B233325C3E65BD39A1-806E
   Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
   Component: AC Manuell    H03 1601
   Revision: 00001K03
   Coding: 02020004200100000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   ROD: EV_ACManueBHBVW37X_004.rod
   VCID: 48C95CE98230004B073-801C
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865826081602DU
   Coding: 005118464041826969E44000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00228
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AADF6218C5CA2DBC17-802E
   Wiper motor control module:
   Component: WWS    160911  043 0581
   Serial number:         160920114914
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  042 0105
   Serial number: S3Y16M07D26H11M26S32
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000XJ9VK00000
   Coding: 191800
   Roof shade control module:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000XJHYV00000
   Coding: 191800
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [009] - Open or Short to Plus
                    Reset counter: 92
                    Mileage: 77535 km
                    Date: 2021.04.05
                    Time: 18:41:45
17930 - Bulb for Front Right Side Marker Lamp
          B12BB 15 [009] - Open or Short to Plus
                    Reset counter: 92
                    Mileage: 77535 km
                    Date: 2021.04.05
                    Time: 18:41:45
   Serial number: 003GCR0ARBCW
   VCID: 47CB5FD58F2E0F330E9-8012
   Serial number: IBH000000000005T89U+
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 003 007 16
   Serial number: 35700000000E3B6C3D1Z
   Subsystem 3 - Part No SW: -----------    HW: 480 002 507 16
   Serial number: 358000000002B0F4EC1W
   Subsystem 4 - Part No SW: -----------    HW: 480 402 607 16
   Serial number: 3510002A72095075334N
   Subsystem 5 - Part No SW: -----------    HW: 480 402 607 16
   Serial number: 3520002AB2095074110J
   Subsystem 6 - Part No SW: -----------    HW: 480 400 808 16
   Serial number: 3550002B121FBE8200A4
   Subsystem 7 - Part No SW: -----------    HW: 480 400 907 16
   Serial number: 3560002AF20F1954E218
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160718500197
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045188D9FE98E42BABB-8050
   Part No SW: 5G1 920 840 B    HW: 5G1 920 840 B
   Component: KOMBI         244 8311
   Coding: 0BA4101DA180CF0502086A001000000000000000
   VCID: 2615F2512864F63BD5F-8072
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Reset counter: 134
                    Mileage: 77620 km
                    Date: 2021.04.06
                    Time: 12:30:26
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2265
   Revision: --------    Serial number: 02081610800603
   Coding: 0901000830085900FB0020081E0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_013.rod
   VCID: 7BA3F32583669BD3DA1-802E
   Generator:
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160001357670126282
   Coding: 31FFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0115708
   Serial number: HA1-00025.06.16
   Coding: 0001
   VCID: 4ACD66E19C3CF25B117-801E
   Revision: 00000000    Serial number: 16000123847007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311819EEB894AB5BB-8060
   Serial number: 0909160605025B
   Coding: 003A13200000020000000000
   VCID: 43D34BC5BB162313D21-8016
   Serial number: 00000000000013792997
   Coding: 011000
   Part No SW: 5Q0 909 144 T    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0002
   ROD: EV_SteerAssisMQB_013.rod
          C10AC F0 [009] - Unknown Error Elaboration
          [Endanschläge nicht korrekt eingelernt Beide Endanschläge nicht eingelernt]
                    Reset counter: 95
                    Mileage: 77678 km
                    Date: 2021.04.06
                    Time: 17:07:10
                    Motor status: 00
                    Supply voltage: 12.75 V
                    Temperature: 66.0 °C
                    KFC: 40
                    KFA: 00 03
                    Freeze frame conditions: 5F
                    Rotorlagesensorspannung AMR Sinus: 0.522 V
                    Rotorlagesensorspannung AMR Kosinus: 3.317 V
                    Rotorlagesensorspannung AMR Sinus 2: 0.518 V
                    Rotorlagesensorspannung AMR Cosinus 2: 2.434 V
                    Rotorlagesensorspannung Hall 1: 0.0 V
                    Rotorlagesensorspannung Hall 2: 0.0 V
                    Aktueller Sinus-Offset für ASIC: -0.0 mV
                    Aktueller Cosinus-Offset für ASIC: -0.2 mV
                    aktuelle Sinusverstärkung für ASIC: 0.194
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H30 0150
   Revision: 00000001    Serial number: VWZ8Z1HBA03GDEB
   VCID: 6D87CD7DCD120563545-8038
   Serial number: 0209160605046E
   VCID: 42DD4EC1A40C2A1BD97-8016
   Serial number: 00000000000004287492
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 027302000000000051220002001808009F0108F40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 2D070D7D0D92C563145-8078
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJW00ZT8
   Component: OCULowMQBUS   007 0568
   Coding: 02730202C2823A017F1E06020000
End----------(Elapsed Time: 01:30, VBatt start/end: 12.6V/12.6V)-----------
Module 44 Steering Assist Block
;SW:5Q0-909-144-T   HW:5Q0-909-144-R ---  Steering Assist
;Component:EPS_MQB_ZFLS  129 1072, Coding:8102
;EV_SteerAssisMQB,013144,EV_SteerAssisMQB_013.rod
;Tuesday,06,April,2021,18:55:32:16304
;VCDS Version: Release 21.3.0 (x64)  Data version: 20210226 DS325.0
;VCID: 45D755DDB5221D23FC5-8010
Group,Description,Actual
IDE00018,Voltage terminal 15,12.64, V
IDE00019,Voltage terminal 30,12.74, V
IDE00020,Terminal 15 status,Terminal 15 on,
IDE00021,Engine RPM,0, /min
IDE00075,Vehicle speed,0.00, km/h
IDE00102,Control Module temperature,47.0, °C
IDE00322,Status of basic setting,was not yet started,
IDE00323,Security Access: Number of invalid keys,0,
IDE00550-IDE03737,Identification of parameterization-Index characteristic curve,0B,
IDE00550-MAS01078,Identification of parameterization-Vehicle model,A2,
IDE00550-MAS05566,Identification of parameterization-Version of system parameters,21,
IDE00550-MAS05567,Identification of parameterization-Version of characteristic curves,03,
IDE00550-MAS05568,Identification of parameterization-Version of memory map,A1,
IDE02006-IDE02955,Lane assist-System status,Function cannot be performed,
IDE02006-IDE04227,Lane assist-Directional stab. asst w/ pwr steering asst: steering status,31.999, Nm
IDE02006-MAS03095,Lane assist-Function status,not activated,
IDE02006-MAS03368,Lane assist-Steering wheel vibration,not active,
IDE02202,End stage temperature,42.0, °C
IDE02216-IDE05795,Steering angle sensor: basic setting-End basic setting,Not permitted,
IDE02216-IDE06673,Steering angle sensor: basic setting-Initialization status,initialized,
IDE02216-MAS01632,Steering angle sensor: basic setting-Status,calibrated,
IDE02216-MAS03161,Steering angle sensor: basic setting-Start,Not permitted,
IDE02486,Data logger triggering,not active,
IDE02955,System status,Waiting for start request,
IDE03682-IDE04457,motor position sensor-Electric motor speed,0, /min
IDE03682-MAS02961,motor position sensor-Engine angle,115.4, °
IDE03682-MAS03083,motor position sensor-Cosine signal,0.638, V
IDE03682-MAS03211,motor position sensor-Sine signal,2.099, V
IDE03682-MAS05053,motor position sensor-Reference value,Condition met,
IDE03725-IDE03734,Steering Assistance-Support power,0, %
IDE03725-MAS03001,Steering Assistance-Mode,Dynamic,
IDE03725-MAS03095,Steering Assistance-Function status,not activated,
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,4095.9, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,-4074.0, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not activated,
IDE03735,Steering torque,0.317, Nm
IDE03735-MAS01632,Steering torque-Status,OK,
IDE03736,Steering torque 2,0.317, Nm
IDE03736-MAS01632,Steering torque 2-Status,OK,
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,-4.0, °
IDE04118-MAS03095,Straight line running correction-Function status,activated,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,-4.0, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03738,Active default-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,0.000, Nm
IDE04184,Steering assistance: engine output,0.000, %
IDE04185,Terminal 30 voltage filtered,12.64, V
IDE04186,Battery terminal recognition,connected,
IDE04187,Steering torque: raw value 1,26.758, %
IDE04187-MAS01632,Steering torque: raw value 1-Status,OK,
IDE04188,Steering torque: raw value 2,-79.883, %
IDE04188-MAS01632,Steering torque: raw value 2-Status,OK,
IDE04189,Steering torque: raw value 3,26.758, %
IDE04189-MAS01632,Steering torque: raw value 3-Status,OK,
IDE04190,Steering torque: raw value 4,-79.883, %
IDE04190-MAS01632,Steering torque: raw value 4-Status,OK,
IDE04191-MAS03084,Steering assistance: PWM signal for motor-Phase 1,2.39, %
IDE04191-MAS03085,Steering assistance: PWM signal for motor-Phase 2,2.39, %
IDE04191-MAS03086,Steering assistance: PWM signal for motor-Phase 3,2.39, %
IDE04192-MAS03084,Steering assistance: motor current-Phase 1,0.0, A
IDE04192-MAS03085,Steering assistance: motor current-Phase 2,-0.1, A
IDE04192-MAS03086,Steering assistance: motor current-Phase 3,0.1, A
IDE04194,Steering assistance: electromotor power,-0.79, W
IDE04448-IDE00924,Steering angle sensor: angle-Steering angle,-17.7, °
IDE04448-MAS01632,Steering angle sensor: angle-Status,valid,
IDE04454-MAS01632,Steering angle sensor: angle speed-Status,valid,
IDE04454-MAS02984,Steering angle sensor: angle speed-Steering angle speed,-1.3, °
IDE04458-MAS02996,Steering angle sensor: mechanical steering stroke-Steering stroke measured,160.90, mm
IDE04458-MAS03731,Steering angle sensor: mechanical steering stroke-Mechanical center position determined,No,
IDE04459,Steering angle sensor: offset index mark mechanical middle,0.17, mm
IDE04460,Steering angle sensor: offset straight line running,-3.1, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,0,
IDE04511,Steering angle sensor external via CAN: angle,Measuring value not available,
IDE04512,Steering angle sensor external via CAN: angular velocity,Measuring value not available,
IDE04513,Steering angle sensor external via CAN: status,not active,
IDE04514,Steering angle sensor external via CAN: basic setting,Calibration not possible,
IDE04765-IDE02955,Counter steer support-System status,not activated,
IDE04765-MAS03095,Counter steer support-Function status,not activated,
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,0.000, Nm
IDE04766-IDE04116,Replacement values-Vehicle speed replacement value,No,
IDE04766-MAS00371,Replacement values-Engine RPM,No,
IDE04787,Hybrid status,not active,
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,no request,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05155,Power steering current consumption,-0.06, A
IDE05162-IDE03723,Software end stop-End stops for steering,Not adapted,
IDE05162-MAS01849,Software end stop-Left,80.57, mm
IDE05162-MAS01850,Software end stop-Right,-80.23, mm
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS00102,Network diagnosis-valid,Yes,
IDE05713-MAS02447,Network diagnosis-Release,Yes,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,529431,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,0,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,0,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,0,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,0,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,0,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,0,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,0,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,0,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,0,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,0,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,0,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,0,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,0,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,0,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,0,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,0,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,524515,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,0,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,0,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,0,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,0,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,0,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,0,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,91,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,22997,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,1,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,0,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,80,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,0,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,0,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,0,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,0,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,0,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,0,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,0,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,0,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,0,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,0,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,0,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,0,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,0,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,0,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,0,
IDE05994-ENG120739,Engine specified torque load-above_10_kilo_newton,3,
IDE05994-ENG120718,Engine specified torque load-below_-10_kilo_newton,0,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,0,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,6086682,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,0,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,0,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,0,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,0,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,278,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,0,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,8,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,0,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,11,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,0,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,0,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,0,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,0,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,0,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,0,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,0,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,291,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,578,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,159,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,7238,
IDE06678-IDE03458,Pull compensation-Steering torque offset,0.000, Nm
IDE06678-MAS03000,Pull compensation-Adaptation value,0.120, Nm
IDE06678-MAS03095,Pull compensation-Function status,not activated,
IDE07399,Engine type,1,
IDE07400-MAS03084,Phase disconnect: status-Phase 1,closed,
IDE07400-MAS03085,Phase disconnect: status-Phase 2,closed,
IDE07400-MAS03086,Phase disconnect: status-Phase 3,closed,
IDE07542-MAS00370,Prerequisites: basic setting-Vehicle speed,Condition met,
IDE07542-MAS01468,Prerequisites: basic setting-Terminal 15,Condition met,
IDE07542-MAS01634,Prerequisites: basic setting-Supply voltage,Condition met,
IDE07542-MAS01746,Prerequisites: basic setting-Control active,Condition not met,
IDE07542-MAS02980,Prerequisites: basic setting-Manual steering torque,Condition met,
MAS00464-MAS00106,Standard - ambient data 1-Year,2021,
MAS00464-MAS00107,Standard - ambient data 1-Month,4,
MAS00464-MAS00108,Standard - ambient data 1-Day,6,
MAS00464-MAS00109,Standard - ambient data 1-Hours,18,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,57,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,52,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,95,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,77699, km
MAS00976-IDE80003,Counter-Analysis 3,3244786757,
MAS00976-IDE80004,Counter-Analysis 4,108,
MAS01172-MAS01156,Development messages-Communication status,active,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,valid,
ENG120769-MAS00973,identification_add-on_parts_steering_assistance-Construction version,Series,
ENG120769-ENG120622,identification_add-on_parts_steering_assistance-moment_sensor,magnetoresistiv,
ENG120769-ENG120621,identification_add-on_parts_steering_assistance-system_supplier,ZFO,
Elapsed Time: 00:07
   #29
fastlane
Australia
C?ID=302768
We've had some customer inquiries about this so I was able to induce a fault in my 2015 GTI in 44-Steering Assist and was able to clear it using the following steps.
First, here is the fault in question:
So first with the engine running, I went into Adv Meas Values and made sure that the steering wheel was pointed straight and the front wheels were pointed straight, close enough:
Edit to show identifier for use use with recent versions of VCDS:
[IDE04448-IDE00924],Steering angle sensor: angle - Steering angle
Next, I went into Security Access -16 and entered the code that shows up in the little helper balloon and it was accepted.
Next, I went into Basic Settings - 04 and chose "Steering angle sensor" and clicked [Go!]
Edit to show identifier for recent versions of VCDS:
[MAS00815] Steering angle sensor
Here's the weird part, it showed "Running" but never changed from that. I left it in this mode for 60 seconds then clicked on [Stop] and [Done, Go Back] and [Close Controller, Go Back].
Next, I cycled the ignition off and back on again. At this point, the TPMS, steering wheel, and ESP lights were still lit up on the dash but a brief drive through a parking lot made them all go away.
I had this same problem with a vehicle today, but the code was 0288, carried out the procedure above and it was rectified. Many Thanks
   #30
khaledabdulaziz
Israel
C?ID=394371
When doing the Basic Settings [MAS00815] Steering angle sensor, did it ever go to "Finished Correctly"?
We have been testing this test plan last night and this morning on different vehicles within the Ross-Tech fleet, but these have all been vehicles in proper working order.
The Cliff Notes version of what we are doing:
Engine at idle.
[44-Steering Assist]
Rotate steering wheel 90deg left then center, 90deg right then center so steering wheel is level, front wheels pointed straight ahead.
[Security Access - 16]
Enter 19249
[Basic Settings - 04]
In Basic Settings, pick [MAS00815] Steering angle sensor
[Go!]
Rotate steering wheel all the way to the left, hold firmly against end stop for 5 seconds.
Rotate steering wheel all the way to the right, hold firmly against end stop for 5 seconds.
Center steering wheel, front wheel straight ahead.
Note: our testing of this would still be "Running", never got a message of "Finished Correctly"
[Stop]
Now a bunch of error messages and warnings will appear on the cluster, what messages you get can vary based on how the vehicles is equipped.
[Done, Go Back]
Now most warning messaged in instrument cluster should be removed.
[Close Controller, Go Back - 06]
Cycle the ignition off for 10 seconds.
Several other control modules will flag DTCs, "Databus" type codes that can now be cleared out.
Again, we are doing this on vehicles that had no fault codes to begin with.
--------------------EDIT--------------------
We have a Finished Correctly!
Atlas that actually had hard codes for the G85.
after spending two hours trying to do basic settings for g85 for skoda octavia 2015 (mqb) and failing
finally found this method and it worked !!
thanks for help
   #31
Mista Tee
England
C?ID=120729
This calibration procedure also worked for me with ROW MQB Tiguan. After calibration I was left with the 16387 - Steering End Stops Not Learned code.
Before I could carry out the End Stop Adaption procedure as described by Dmaxison further up, I found the car automatically learned the end stops and removed the fault code following a short 1 mile journey with a few full locks.
   #32
Not terribly surprising. I would think the full locks are the key.
Tyneside autohaus
C?ID=87025
Engine at idle.
Enter 19249
[Go!]
[Stop]
[Done, Go Back]
This worked for us on a 2021 Skoda Fabia
