Results 11 to 20 of 27
Thread: MQB (Mk7 Golf) Steering Angle Sensor (G85) Calibration in 44 - Steering Assist
    Sep 2015
    I believe automech has more experience than we do on the subject (we failed to truly break Andy's 2015 GTI) but these are notes from my most recent phone ticket on a crashed 2015 A3:
    ST?ID=71374
    That may or may not help here but he didn't call or e-mail back so I believe the test drive sorted it. It was unknown if the rack was original or replaced in this case.
    I'm not quite sure if any Ross tech employees found a solution. I took it to a shop and they didn't even know how to do it with VCDS.
  2. #12
    Sep 2015
    Quote Originally Posted by Andy View Post
    We did some more testing on this in October and I don't think we've had a chance to detail a procedure yet but I will see what I can find.
    So I've been waiting for several months to see if anything was ever posted about the correct steps to take. I've taken my car to two VW specialist centers with VCDS and neither of them knew what to do to clear steering end stops fault. I still have it. Any updates Andy?
  3. #13
    Administrator Andy's Avatar
    Sector 7G
    We haven't verified this on a car yet but this should be what ODIS is doing when it runs the G85 calibration, but in VCDS terms:
    1) Test step: Edge detection
    Start the engine
    Point the front wheels straight ahead
    [44-Steering Assist]
    [Security Access - 16]
    Enter 19249
    [Do It!]
    Select these in [Adv Meas Values]:
    [IDE04510-MAS03732] Steering angle sensor: slope detection index - Steering angle speed negative dropping slope on curve
    [IDE04510-MAS03733] Steering angle sensor: slope detection index - Steering angle speed negative rising slope on curve
    [IDE04510-MAS03734] Steering angle sensor: slope detection index - Steering angle speed positive dropping slope on curve
    [IDE04510-MAS03735] Steering angle sensor: slope detection index - Steering angle speed positive rising slope on curve
    [IDE04510-MAS03736]Steering angle sensor: slope detection index - Index mark
    Slowly turn the steering wheel to the right and left, passing the index mark (approx. 45) until all 4 slope detection indexes have been recognised (detected) and the index mark is set to (1).
    [Done, Go Back]
    2) Test step: Steer. angle sens. calibration
    [Basic Settings - 04]
    [Show Measuring Data]
    Select the following items:
    [IDE02216-IDE05795] Steering angle sensor: basic setting - End basic setting
    [IDE02216-MAS03161] Steering angle sensor: basic setting - Start
    In Basic Settings, pick [MAS00815] Steering angle sensor
    [Go!]
    It should show Running
    - Turn the steering wheel slowly to the right and then to the left mechanical stop.
    - Turn the steering wheel back to the mid position, the status should be indicated as Permitted. (IDE02216-MAS03161 or IDE02216-IDE05795 ?)
    Note: in a test on the car it never showed permitted in either of those?
    (after one or both show permitted, stop moving wheel and point straight)
    Wait for it to show Finished correctly?
    [Stop]
    Note: in a test on the car there were no faults and no warning lamps.
    3) Test step: Evaluation of basic setting (no VCDS needed)
    Turn the steering wheel to the right end stop.
    Turn the steering wheel to the left end stop.
    Turn the steering back to its center position.
    Check the yellow fault lamp on the dash.
    The fault lamp on the dash must go out.
    Stop the engine.
    Check and clear DTCs
  4. Likes Uwe, Dana, NEtech, HMC, HMFIC, DrPeter, jyoung8607 liked this post
  5. #14
    Nov 2016
    We've had some customer inquiries about this so I was able to induce a fault in my 2015 GTI in 44-Steering Assist and was able to clear it using the following steps.
    First, here is the fault in question:
    So first with the engine running, I went into Adv Meas Values and made sure that the steering wheel was pointed straight and the front wheels were pointed straight, close enough:
    Edit to show identifier for use use with recent versions of VCDS:
    [IDE04448-IDE00924],Steering angle sensor: angle - Steering angle
    Next, I went into Security Access -16 and entered the code that shows up in the little helper balloon and it was accepted.
    Next, I went into Basic Settings - 04 and chose "Steering angle sensor" and clicked [Go!]
    Edit to show identifier for recent versions of VCDS:
    Here's the weird part, it showed "Running" but never changed from that. I left it in this mode for 60 seconds then clicked on [Stop] and [Done, Go Back] and [Close Controller, Go Back].
    Next, I cycled the ignition off and back on again. At this point, the TPMS, steering wheel, and ESP lights were still lit up on the dash but a brief drive through a parking lot made them all go away.
    this baloon does not show up when i hover over it in vcds,so i dont know what the security access code is???????????
  6. #15
    You click the button [Security Access -16] in which Control Module ?
  7. #16
    Nov 2016
    abs/brakes i think and steering assist
  8. #17
    Try again in Steering Assist-44, it should pop-up.
  9. Likes vw754 liked this post
  10. #18
    Nov 2016
    ok...will update,thanks
  11. #19
    Mar 2015
    Australia
    Start the engine
    Enter 19249
    [Do It!]
    [Done, Go Back]
    [Go!]
    [Stop]
    Stop the engine.
    Tried this tonight remotely with someone and it worked.
    Mk 7.5 Golf
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  12. Likes Uwe, Jef, Dana, Andy liked this post
  13. #20
    HQ
    When doing the Basic Settings [MAS00815] Steering angle sensor, did it ever go to "Finished Correctly"?
    We have been testing this test plan last night and this morning on different vehicles within the Ross-Tech fleet, but these have all been vehicles in proper working order.
    The Cliff Notes version of what we are doing:
    Engine at idle.
    Rotate steering wheel 90deg left then center, 90deg right then center so steering wheel is level, front wheels pointed straight ahead.
    Enter 19249
    [Go!]
    Rotate steering wheel all the way to the left, hold firmly against end stop for 5 seconds.
    Rotate steering wheel all the way to the right, hold firmly against end stop for 5 seconds.
    Center steering wheel, front wheel straight ahead.
    Note: our testing of this would still be "Running", never got a message of "Finished Correctly"
    [Stop]
    Now a bunch of error messages and warnings will appear on the cluster, what messages you get can vary based on how the vehicles is equipped.
    [Done, Go Back]
    Now most warning messaged in instrument cluster should be removed.
    [Close Controller, Go Back - 06]
    Cycle the ignition off for 10 seconds.
    Several other control modules will flag DTCs, "Databus" type codes that can now be cleared out.
    Again, we are doing this on vehicles that had no fault codes to begin with.
    --------------------EDIT--------------------
    We have a Finished Correctly!
    Atlas that actually had hard codes for the G85.
    Jef
  14. Likes Andy, Uwe liked this post
