I originally posted on the new member forum, but as I am a fully fledged owner (2 days) of a VCDS Hex-CAN, I can post my problem here in details.
I own a 2012 VW Tiguan 2.0 TDS. As it is the basic S model I decided to fit an multi function steering wheel. After research, I realised that I must upgrade my steering wheel module (clock spring) as well as harness. So, I went from 5K0953569F to 5K0953569T.
However, when I install the new module, nothing happens. The car is completely dead. When I put in the key and turn the ignition on, the dashboard lights are dead and the car will not start. Completely dead. I cannot communicate to the VCDS, the communication link is dead. If I quickly swap back, all is OK again and again, so I know there is nothing wrong with the connectors. I believe the module is DOA but the seller says it is me.
It was suggested that the CANBus is faulty. I have a full scan which is shown below. Hopefully someone can advise if I am doing something wrong, the car modules are wrong/faulty or the new module is indeed dead on arrival.
Grateful for help. The old module is back on, but I left the new steering wheel in place, hence the airbag errors.
I would appreciate some .... steer
Friday,25,September,2015,15:28:38:26712
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVGAV7AX6CW566283 License Plate:
Chassis Type: AX (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 4C 52 53 56 62 72
77
VIN: WVGAV7AX6CW566283 Mileage: 74290km-46161miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 997 027 M HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 0396
Revision: P3H07--- Serial number:
Coding: 0423010A19070160
Shop #: WSC 08308 002 1048576
VCID: 3F8D17676E15E4C664-806A
Part No SW: 09G 927 750 LR HW: 09G 927 750 LR
Component: AQ 250 6F 1971
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 0C17F0AB6F230F5E31-8058
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AP HW: 5N0 614 109 AP
Component: J104 C6 450M VD74 0005
Revision: --H07--- Serial number: 00000005254183
Coding: 0005158
VCID: 79F9B97F30B10AF61A-802C
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0404
Revision: 00001016
Coding: 0000001002
VCID: 7F0D5767E69524C624-802A
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 0064
Revision: BG021001
Coding: 6F180ABB80232EC4008800C11400044448010086524D8960648000000040
VCID: 3979797FB031CAF65A-806C
Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 16011 013 0203
Coding: 009795
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 47
Mileage: 56859 km
Date: 2014.10.03
Time: 00:00:04
Term 15 Off
Voltage: 12.60 V
Part No SW: 5N0 959 655 P HW: 5N0 959 655 P
Component: J234__204 VW10 HI 1918
Revision: 23016000 Serial number: 003GJP0FSDF5
Coding: 0012340
VCID: 4A9B36B325D7516EC3-801E
Subsystem 1 - Part No: 5N0 959 339 B
Component: BF-Gewichtsens. 003 0001
Subsystem 2 - Serial number: 00000000005YR6
Subsystem 3 - Serial number: 0008.12.110000300000630046ÿ†63
Subsystem 4 - Serial number: 630046ÿ†6332MTS605193521 ÿ†63
Subsystem 5 - Serial number: 93521 ÿ†6342MTS637160092 ÿ†63
Subsystem 6 - Serial number: 60092 ÿ†6351HTS62UDF1AKJ ÿ†63
Subsystem 7 - Serial number: F1AKJ ÿ†6361HTS6GKI21AKJ ÿ†63
Subsystem 8 - Serial number: 21AKJ ÿ†63727TS66GIRV9KR ÿ†63
Subsystem 9 - Serial number: RV9KR ÿ†63827TS6FUJI0AKJ ÿ
Subsystem 10 - Serial number: I0AKJ ÿ
Fault Status: 10100001
Mileage: 70983 km
Date: 2015.07.27
Time: 00:00:35
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 AQ HW: 5K0 953 569 F
Revision: FF010040 Serial number: 20120120101657
Coding: 5980140000
VCID: 79F9B97FF8B10AF61A-802C
Part No SW: 5N0 920 972 E HW: 5N0 920 972 E
Component: KOMBI H04 0617
Coding: 211F01
VCID: 3561754F94292E96BE-8060
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 201211F1002953
Coding: 356002
VCID: 3A7B6673B537C1EE53-806E
Mileage: 70996 km
Date: 2015.07.27
Time: 21:46:14
Component: IMMO H04 0617
VCID: 6ADB96338D17B16EE3-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684 A
Component: RNS-MID H01 1140
Revision: AB001001 Serial number: VWZ6Z7J6044063
Coding: 040500000100000600
VCID: 2345BB1722BDA02660-8076
02633 - Antenna for Satellite Tuner
Fault Status: 01101011
Reset counter: 116
Mileage: 70992 km
03181 - Internal Error SDARS Module
Fault Frequency: 214
Reset counter: 116
Mileage: 70992 km
Fault Status: 00101011
Fault Frequency: 28
Reset counter: 156
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0503
Revision: 13110009 Serial number: 0004185680
Coding: 0004B4
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 387F7C7B833BD3FEA5-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D
Component: J388__TSG-HL 007 1504
Serial number: 00000006419672
Coding: 000490
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.285 1002
Revision: 1AH03836 Serial number: 00120170223101
Coding: 0000258
Shop #: WSC 01324 020 00200
VCID: 3C77606B7F03FFDE41-8068
Address 4C: Tire Pressure II
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0503
Revision: 15110009 Serial number: 0004182937
Coding: 0004B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 3979797FB831CAF65A-806C
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D
Component: J389__TSG-HR 007 1504
Serial number: 00000006420478
Coding: 000490
132866 - Switch for Rear Central Locking
B122E 29 [008] - Signal Implausible
Reset counter: 125
Mileage: 73384 km
Date: 2015.09.12
Time: 19:55:09
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000602813
Coding: 0026156
VCID: 3561754F5C292E96BE-8060
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Reset counter: 116
Mileage: 70992 km
Reset counter: 116
Mileage: 70992 km
Fault Frequency: 28
Reset counter: 156
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H12 2902
Revision: 1B001001 Serial number: 00007661729307
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: 275DAF075E854C063C-8072
End-------------------------(Elapsed Time: 02:55)--------------------------
