Results 1 to 4 of 4
Thread: A6 4F Memory Seat module
    Canada / Netherlands
    Hello everybody,
    I changed the dash/doors trim in my car for the S6 model without the seat memory option. I removed the module.
    Not a big deal since i changed the seats for the S7 seats too. Since the modules are completly different, I just want to disable the option so there's no more code. Here's the codes that i'm getting since i've removed the module.
    Where do i need to go to disable the module? Thanks
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    > Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    > Component: Gateway H11 0070
    > Revision: 11 Serial number: 1300805A318108
    > Coding: ECFE73CC1B7106
    > Shop #: WSC 94827 999 85536
    > VCID: 2757DEB196AEFB26FAD-8072
    > 1 Fault Found:
    > 01964 - Control Module for Seat & Steering Column Memory (J136)
    > 004 - No Signal/Communication
    > Freeze Frame:
    > Fault Status: 01100100
    > Fault Priority: 2
    > Fault Frequency: 1
    > Reset counter: 248
    > Mileage: 111665 km
    > Time Indication: 0
    > Date: 2014.03.06
    > Time: 05:37:34
    > Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    > Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    > Component: TSG FA H12 0080
    > Revision: 00000000 Serial number: 0p > Coding: 0052971
    > Shop #: WSC 02327 785 00200
    > VCID: 2C5D219D8F48D87E17F-8079
    > 1 Fault Found:
    > Freeze Frame:
    > Fault Priority: 4
    > Fault Frequency: 1
    > Reset counter: 248
    > Mileage: 111665 km
    > Time Indication: 0
    > Date: 2014.03.06
    > Time: 05:37:32
    > Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    > Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    > Component: TSG BF H12 0080
    > Revision: 00000000 Serial number: G‰ > Coding: 0052971
    > 1 Fault Found:
    > Freeze Frame:
    > Fault Priority: 4
    > Fault Frequency: 1
    > Reset counter: 248
    > Mileage: 111665 km
    > Time Indication: 0
    > Date: 2014.03.06
    > Time: 05:37:32
    United States
    I wasn't able to locate a complete Auto-Scan from you in our email history or in forum. Please post the complete scan so we can see what this vehicle is made of in addition to the current configuration of the GAN Gateway Installation List.
    -Dana
    Monday,21,April,2014,15:23:09:17391
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WAUKH94F56N104951   License Plate:
    Mileage: 111660km-69382mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 36 37 42 46 47 4F 52 53
              55 56 61 62 67 6D 72 76 77
    VIN: WAUKH94F56N104951   Mileage: 111660km/69382miles
    36-Seat Mem. Drvr -- Status: Cannot be reached 1100
    Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
       Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
       Component: 3.2l V6 FSI         0030
       Revision: --H15---    Serial number:
       Coding: 010D0109190F0120
       Shop #: WSC 66565 257 00032
       VCID: 2B5F22818A46DF461E5-807E
                   P1653 - 008 -
                        Reset counter: 40
                        Mileage: 111665 km
                        Date: 2014.03.06
                        Time: 05:37:51
                        RPM: 1312 /min
                        Mass Air / Rev.: 103.6 mg/str
                        Temperature: 49.5°C
                            Idle
                        Load: 9.0 %
    Readiness: 0110 0101
       Part No SW: 4F2 910 156 D    HW: 09L 927 156 A
       Component: AG6 09L 3,2 FSI USA 0010
       Revision: --H01---    Serial number:        4105914
       Shop #: WSC 02325 785 00200
       VCID: 2649D3B591A4E22EC1B-8073
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H04 0090
       Coding: 0020895
       VCID: 2D5B2C99B452D176001-8078
                        Reset counter: 248
                        Mileage: 111665 km
                        Date: 2014.03.06
                        Time: 05:38:44
                        Hex Value: 0x0000
                        Hex Value: 0x42A2
                        Hex Value: 0x0024
                        Hex Value: 0x0190
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0230
       Revision: 09010701    Serial number: 10601500951070
       Coding: 0000143
       Shop #: WSC 94827 999 72508
       VCID: E3CF0AA12216D706665-80B6
       Subsystem 1 - Part No: 4F0 910 131 L
       Component: FBSAUDIC6 EZS   H45 0070
       Subsystem 2 - Part No: 4F0 910 335
       Component: FBSAUDIC6 KSG   H26 0080
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 732 C    HW: 4E0 035 729
       Component: Interfacebox    H43 4140
       Revision: 00000000    Serial number: 303KJ057510714
       Coding: 0031003
       Shop #: WSC 00000 000 08192
       VCID: 234FCAA1E2961706A65-8076
       Component: Bedienteil MMIC6H08 0050
       Subsystem 2 - Serial number: 00000000266912
       Subsystem 3 - Serial number: 0128.10.050000000100010691˙
       Subsystem 4 - Serial number: 010691˙
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0160
       Revision: 00000027    Serial number: 00000030069672
       Coding: 0524582
       VCID: DBBF32411A66EFC62E5-808E
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H15 0190
       Coding: 0014114
       Shop #: WSC 02335 785 00200
       VCID: 2A51278585BCC64EE53-807F
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE7253127
       VCID: 1C3DF15DDFE828FE67F-8049
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
       Component: 65 AIRBAG AUDI8RH29 0300
       Revision: 12H29000    Serial number: 00359D0A6A9M
       Coding: 0013877
       Shop #: WSC 92602 999 83964
       Subsystem 1 - Serial number: 6332CSME0C6469086
       Subsystem 2 - Serial number: 6342CSME0C643251
       Subsystem 3 - Serial number: 6352QSME06741E31D
       Subsystem 4 - Serial number: 6362QSME06762D0BN
       Subsystem 5 - Serial number: 63734SME042B191F1
       Subsystem 6 - Serial number: 63834SME060D2101P
       Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
       Component: J0527               0310
       Revision: 00H01000    Serial number: 90026052690226
       Coding: 0002342
       Shop #: WSC 02323 785 00200
       Component: E0221           H01 0100
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 A    HW: 4F0 920 931 E
       Component: KOMBIINSTR. M73 H16 0630
       Revision: 00200000    Serial number: 4PU39TWA5
       Coding: 2113363
       Shop #: WSC 94817 999 96786
       VCID: 2143C0A9F88A0516B49-8074
                        Reset counter: 248
                        Mileage: 111665 km
                        Date: 2014.03.06
                        Time: 05:37:34
       Part No SW: 4E0 910 888 M    HW: 4E0 919 887 C
       Component: MNS US          H45 1100
       Revision: 00000000    Serial number: 355K%057556684
       VCID: 38750DCD4B1064DE637-806D
       Coding: 0052971
                        Reset counter: 248
                        Mileage: 111665 km
                        Date: 2014.03.06
                        Time: 05:37:32
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
       Component: Komfortgeraet   H18 0130
       Revision: 01300018    Serial number: 01007806180000
       Coding: 7764669
       VCID: 2953D88980BACD56EC9-807C
    01696 - Footwell Lighting; Rear Left (W45)
                        Fault Status: 01101011
                        Reset counter: 248
                        Mileage: 107813 km
                        Date: 2005.02.01
                        Time: 13:46:15
    Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
       Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
       Component: DSP-High C6     H09 0240
       Revision: PROD_01     Serial number: 00000000810786
       Coding: 0000126
       VCID: 254BD4B9ECA2E936C81-8070
    02753 - Inside Microphone (R74)
                        Reset counter: 248
                        Mileage: 111665 km
                        Date: 2014.03.06
                        Time: 05:37:39
       Part No SW: 4F0 910 280     HW: 4F0 907 280 B
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000010638
       Coding: 0002114
       VCID: DEB93B550974FAEE49B-808B
       Coding: 0052971
                        Reset counter: 248
                        Mileage: 111665 km
                        Date: 2014.03.06
                        Time: 05:37:32
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801
       Component: EPB  CDEC0080   H03 0080
       Revision: --H03---
       Coding: 0005022
       Shop #: WSC 93250 999 65003
       VCID: 2045C5ADF3800C1EBB7-8075
    Address 55: Xenon Range        Labels: 4F0-910-357.lbl
       Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
       Component: AFS 1           H01 0030
       Coding: 0000016
       Subsystem 1 - Part No: 4F0 941 329 B
       Component: AFS-Modul links H02 0020
       Subsystem 2 - Part No: 4F0 941 329 B
       Component: AFS-Modul rechtsH02 0020
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0620
       Revision: 00000000    Serial number: 394JV057630435
       VCID: 2E592B95B954AA6E39B-807B
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: J0644 BEM       H12 0590
       Revision: 00000000    Serial number: 00000000148869
       Shop #: WSC 02335 823 00000
       Subsystem 1 - Part No: 4F0 915 105 E
       Component: von VA0  1510260045
       Coding: 344630393135313035452056413031353130323630303435
       Shop #: WSC 00000 384 00290
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
       Component: TSG HL          H21 0050
       Coding: 0052778
    Address 67: Voice Control        Labels: 4E0-910-75x-67.lbl
       Part No SW: 4E0 910 754 Q    HW: 4E0 035 753 A
       Component: SDS 3501 US     H45 0630
       Revision: 00000000    Serial number: 00000510190086
       Shop #: WSC 12336 024 394758
       VCID: 346D39FD577880BE4FF-8061
    Address 6D: Trunk Elect.        Labels: Redir Fail!
       Part No SW: 4F9 910 591     HW: 4F9 827 851 B
       Component: ValeoHeckdeckel H18 0280
       Revision: --H18001    Serial number: E5030000B
       Shop #: WSC 23250 431 715754
       VCID: ECDD619DCFC8987ED7F-80B9
       Subsystem 1 - Part No: 4F9 910 592
       Subsystem 3 - Serial number: RD11.10.05--H18001001A0046˙
       Subsystem 4 - Serial number: 1A0046˙
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0050
       Coding: 0052778
       Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
       Component: Parkhilfe 4-Kan H09 0030
       Revision: 00H09000    Serial number: 11720528704259
       Coding: 0201216
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4F0 910 336 E    HW: 4E0 862 335
       Component: Handyvorb2      H11 0950
       Revision: 00000000    Serial number: 00000007521964
       Coding: 0010900
    Last edited by Uwe; 05-05-2014 at 09:07 AM. Reason: Wrapped CODE tags around Auto-Scan
    Tartu, Estonia
    Remove seat memory from can gateway coding or installation list. Or paste coding: ECFE73C41B7106
    Coding for module 42 and 52 is 0052843
