Results 1 to 10 of 10
Thread: 2005 A6 Steering column replacement
    Apr 2015
    2005 A6 Quattro BKH.
    Car has been having starting issues. No crank, no start. Has been starting since it has been at our shop. However, does have a steering lock message with steering wheel and key symbol in display. Found code 00288 - Steering Column Lock Actuator (N360) 014 - Defective, in Address 5 Acc/start auth module.
    Steering lock actuator only appears to be available with complete, steering column. My understanding is column has to be matched with kessy/immo. and this cannot be done with VCDS and must be performed by dealer. Is this true?
    Thanks in advance,
    Tuesday,22,September,2015,09:26:09:37823
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(Parallels)
    VCDS Version 15.7.1.0
    Data version: 20150904
    VIN: WAUDT74F25N046727   License Plate:
    Mileage: 184760km-114804mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 42 46 47 4F 52
              53 55 56 61 62 72 76 77
    VIN: WAUDT74F25N046727   Mileage: 184760km-114804miles
    77-Telephone -- Status: Sporadic communication error 1000
    Address 01: Engine (AUK)       Labels: 06E-910-559-BKH.lbl
       Part No SW: 4F2 910 559 B    HW: 4F1 907 559 E
       Component: 3.2l V6 FSI         0020
       Revision: --H21---    Serial number:
       Coding: 01050109190F0120
       Shop #: WSC 02136 444 84361
       VCID: 2B16CD518A968F66D8-807F
    006449 - Coolant Fan Control Module (J293)
                   P1931 - 009 - Malfunction - Intermittent
                        Reset counter: 26
                        Mileage: 182497 km
                        Date: 2015.08.30
                        Time: 18:41:49
                        RPM: 1120 /min
                        Mass Air / Rev.: 130.8 mg/str
                        Temperature: 97.5∞C
                            Idle
                        Load: 20.4 %
                        Speed: 28.0 km/h
    000838 - Camshaft Position Sensor (G163)
                   P0346 - 006 - Implausible Signal - Intermittent
                        Reset counter: 25
                        Mileage: 182603 km
                        Date: 2015.09.02
                        Time: 10:55:17
                        RPM: 192 /min
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 28.5∞C
                            Start
                        Bin. Bits: 00001000
       Part No SW: 4F1 910 156 H    HW: 09L 927 156
       Component: AG6 09L 3.2 FSI USA 0020
       Revision: --H01---    Serial number:        0050219
       Coding: 0001002
       Shop #: WSC 02335 785 00200
       VCID: 291A3759806A9D762A-807D
       Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
       Component: ESP8 quattro    H03 0010
       Coding: 0004511
       VCID: 26003C659174B20E07-8073
                        Reset counter: 107
                        Mileage: 182057 km
                        Date: 2015.08.28
                        Time: 10:14:08
                        Hex Value: 0x0240
                        Hex Value: 0x4026
                        Hex Value: 0x1202
                        Hex Value: 0x00A8
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Component: FBSAUDIC6 ELV   H30 0130
       Revision: 30040401    Serial number: 10600300057465
       Coding: 0000011
       VCID: 63866571A2C6072620-8037
       Subsystem 1 - Part No: 4F0 910 131 J
       Component: FBSAUDIC6 EZS   H43 0070
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H35 0040
    00955 - Key 1
                        Fault Frequency: 23
                        Reset counter: 144
                        Mileage: 181919 km
                        Date: 2015.08.27
                        Time: 15:59:23
                014 - Defective
                        Fault Status: 01111110
                        Reset counter: 96
                        Mileage: 183632 km
                        Date: 2015.09.07
                        Time: 10:27:48
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 729 B    HW: 4E0 035 729
       Component: Interfacebox    H43 0750
       Revision: 00000000    Serial number: 360IS047503874
       Coding: 0000003
       VCID: 281C325D9B60A47E35-807D
       Subsystem 1 - Part No: 4F0 910 609
       Component: Bedienteil MMIC6H07 0870
       Subsystem 2 - Serial number: 00000000048305
       Subsystem 3 - Serial number: 0130.08.040000000100010250ˇ
       Subsystem 4 - Serial number: 010250ˇ
                        Reset counter: 136
                        Mileage: 182110 km
                        Date: 2015.08.28
                        Time: 12:24:50
                        Bin. Bits:       10
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F1 820 043 J
       Component: KLIMABETAETIGUNGH11 0110
       Revision: 00000023    Serial number: 00000000056537
       Coding: 0524326
       VCID: 5BF65D919AB63FE668-800F
       Part No SW: 4F0 910 279     HW: 4F0 907 279
       Component: ILM Fahrer      H14 0080
       Coding: 0013123
       VCID: 66807C6551F4720EC7-8033
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7155868
       VCID: 1B761D91DA367FE6A8-804F
    Address 0F: Digital Radio        Labels: None
       VCID: 55E24BA9BC92E9965E-8001
    No Faults Found
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
       Component: 56 AIRBAG AUDI8RH28 0310
       Revision: 09H28000    Serial number: 00359D0710NI
       Coding: 0013622
       Shop #: WSC 02136 444 64600
       Subsystem 1 - Part No: 4F0 910 339
       Component: BF-Gewichtsens. 002 0040
       Subsystem 2 - Serial number: 6332CSME040C223B
       Subsystem 3 - Serial number: 6342CSME05245F7BB
       Subsystem 4 - Serial number: 6351HSME037941786
       Subsystem 5 - Serial number: 6361HSME040A4A3ED
       Subsystem 6 - Serial number: 6371VSME03734C4EU
       Subsystem 7 - Serial number: 6381VSME03754635H
       Component: Lenks‰ulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026042480032
       Coding: 0002041
       Component: Lenkradmodul    H05 0080
       Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
       Component: KOMBIINSTR. M73 H09 0460
       Revision: 00100000    Serial number: 4I215W794
       Coding: 0065263
       Shop #: WSC 03419 067 57207
       VCID: 1E701485C9246ACE4F-804B
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
       Component: Gateway         H09 0030
       Revision: 09          Serial number: 08008048180113
       Coding: ECFE73CC1B3904
       Shop #: WSC 02136 444 53521
       VCID: 271E3161967EAB063C-8073
                        Reset counter: 144
                        Mileage: 184710 km
                        Date: 2015.09.11
                        Time: 16:46:25
       Coding: 0082946
       VCID: 618A6F79B8DA153632-8035
       Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
       Component: MNS US          H43 0570
       Revision: 00000000    Serial number: 378HR047501282
       VCID: 3522EB295CD2C996BE-8061
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Fault Frequency: 7
                        Reset counter: 0
                        Mileage: 157515 km
                        Date: 2014.06.18
                        Time: 18:09:42
                        Bin. Bits:     0100
       Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
       Component: TSG FA          H10 0020
       Revision: 00000000    Serial number: Së
       Coding: 0035563
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
       Component: Komfortgeraet   H14 0090
       Revision: 00900014    Serial number: 01000795340000
       Coding: 0423997
       VCID: 2C14CE4D8F98885ED1-8079
       Component: LIN BACKUP HORN H02 1301
       Part No SW: 4F5 910 223 B    HW: 4F5 035 223 C
       Component: DSP-High C6     H14 0220
       Revision: PROD_01     Serial number: 00000000001708
       Coding: 0000016
       VCID: 22082075FD5C4E2E6B-8077
       Component: ILM Beifahrer   H07 0040
       Revision:             Serial number: 00000000030243
       Coding: 0001114
       VCID: 5EF0548589A42ACE0F-800B
       Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
       Component: TSG BF          H10 0020
       Revision: 00000000    Serial number: 9i!
       Coding: 0035563
       Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
       Component: EPB  CEFC0090   H05 0090
       Revision: --H05---
       Coding: 0005022
       Shop #: WSC 02136 444 53345
       VCID: 210A2F79F85A553672-8075
    02432 - Supply Voltage for Left Parking Brake Motor (V282)
                011 - Open Circuit - MIL ON
                        Fault Status: 11101011
                        Fault Frequency: 175
                        Reset counter: 29
                        Mileage: 154672 km
                        Date: 2014.04.04
                        Time: 12:16:53
                        Voltage: 12.32 V
                        Count: 84
       Part No SW: 4F0 910 357 A    HW: 4F0 907 357 A
       Component: AFS 1           H03 0010
       Coding: 0000016
       Shop #: WSC 02327 785 00200
       VCID: 2404266DE748401E19-8071
       Subsystem 1 - Part No: 4F0 941 329 A
       Component: AFS-Modul links H05 0010
       Subsystem 2 - Part No: 4F0 941 329 A
       Component: AFS-Modul rechtsH05 0010
       Part No SW: 4E0 910 541 C    HW: 4F0 035 541
       Component: TUNER EU/US/RDW H41 0290
       Revision: 00000000    Serial number: 352IP047557321
       VCID: 200C2A7DF3505C3E7D-8075
       Component: ENERGIEMANAGER  H11 0400
       Revision: 00000000    Serial number: 00000000051816
       Shop #: WSC 02136 444 53669
       VCID: 23062571E246472660-8077
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  4408310368
       Coding: 344630393135313035432056413034343038333130333638
       Shop #: WSC 00000 384 00290
                000 -  -  - Intermittent
                        Fault Frequency: 46
                        Mileage: 163453 km
                        Date: 2014.10.09
                        Time: 09:33:35
    02276 - Quiescent Current Stage 5
                        Fault Frequency: 41
                        Mileage: 163453 km
                        Date: 2014.10.09
                        Time: 09:33:45
    02274 - Quiescent Current Stage 3
                        Fault Frequency: 40
                        Mileage: 163453 km
                        Date: 2014.10.09
                        Time: 09:33:55
                        Fault Frequency: 40
                        Mileage: 163453 km
                        Date: 2014.10.09
                        Time: 09:34:05
    02272 - Quiescent Current Stage 1
                        Mileage: 170675 km
                        Date: 2015.01.08
                        Time: 01:51:00
       Part No SW: 4F0 910 795     HW: 4F0 959 795
       Component: TSG HL          H09 0010
       Coding: 0035370
       VCID: 699A775940EA5D76EA-803D
       Part No SW: 4F0 910 795     HW: 4F0 959 794
       Component: TSG HR          H09 0010
       Coding: 0035370
       Part No SW: 4F0 910 283     HW: 4F0 919 283
       Component: Parkhilfe 4-Kan H09 0020
       Revision: --.--.--    Serial number: 11730424300971
       Coding: 0001206
       Part No SW: 4F0 910 336     HW: 4E0 862 335
       Component: Handyvorb2      H10 0080
       Revision: 00000000    Serial number: 00000007501672
       Coding: 0010900
       VCID: 608C6A7DB3D01C3E3D-8035
    End-------------------------(Elapsed Time: 03:36)--------------------------
    I don't think we have a way of doing that with VCDS.
    The question is whether the steering column lock being defective would prevent the car from starting. I've seen an 05 much like that one that wouldn't start and the problem turned out to be the starter itself. However that car did not have any immo/steering column faults or messages in the cluster.
    Sep 2015
    If it like passat B6 the ignition will not come on if the steering lock has not moved position from locked > unlocked.
  4. Likes Uwe liked this post
    Tartu, Estonia
    As for steering column lock....Yes whole column needs to replaced and costs $$$.
    I have a friend who works with parts(And yes i get good % ) Customer came in to check price....went backwards when heard it :P
    The world is my oyster...
  6. Likes Uwe, Jetta ,97 liked this post
    Sep 2015
    I don't know the Audi design but on a B6 passat the steering lock is held on by two shear bolts. You can get these off and remove the lock. If the Audi is the same you can open the lock, energize the motor and unlock it. Then the ignition etc will work. Engine may not start though.
    Verified VCDS User bobbik's Avatar
    Oct 2015
    Poland
    On B6 Passat the easiest way to replace lock(when u don't have new one) , is to read eeprom and put dump into another (used) lock . But Passat lock is cheap, and i don't know Audi lock solution.
    Dallas (McKinney) ,TX ,USA
    UWE this is very common problem on 4F Audi A6. And yes whole Steering column needs to be replace bacuse Steering lock module and Immobilizer is part of it.
    Look at address 05 for faulty codes.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  10. #8
    I disassemble the lock and discard it.......someone wants the car that bad they are gonna tow it anyway......
    I have been successful with this..........and bypassing the commands for the security feature.
  11. Likes Jetta ,97 liked this post
  12. #9
    New User
    Jan 2016
    Albania
    How did you do?
    How did you do?
  13. #10
    Verified VCDS User Other_Erik's Avatar
    Oct 2015
    Northern VA (DC Area)
    This on a 4F A6? I'd be willing to lose the actuator and/or lock so long as I don't lose the ignition cylinder (since that's, you know... necessary. How else would I be able to use the VCDS?). How do you completely bypass the Immo system, though? We went back and forth a couple months ago about my wife's '05 A6 3.2Q that gives the same stupid "defective actuator" message - as soon as I clear code in module 05, no problem starts right up. No chance in hell I'm paying ~$3k to replace a perfectly working COLUMN on a $5k car just because the column lock should've been recalled...
    O_E
    Daily: 2003 Audi RS6 (VIN 905530) - RNS-E, Hotchkis, KWV3's, Ebony on Ebony
    Wife/Weekend: 2013 Jeep Wrangler Unlimited - lifted, locked, ready to rock
  14. Likes Jetta ,97 liked this post
