Results 1 to 3 of 3
Thread: 2005 Touareg CCM Replacement
    Sep 2015
    Australia
    Post 2005 Touareg CCM Replacement
    Posting this up hoping someone may be able to help.
    After washing my vehicle, 2005 Touareg 2.5 TDI and I am from Australia, hence the vehicle is Right Hand Drive. I noticed that the rear left park lights were on all time and the fuel filler release mechanism, remote key fob, rear door micro switched, sunroof and a few other items failed. I was able to determine that water had made it's way down to the rear right side of the interior of the vehicle via the rear hinge after finding that the drain holes below the rear door hinge were blocked. This water was then able to make it's way into the the CCM. Upon opening the CCM, water was released and on a closer inspection it appears that this had been happening for some time prior as there was substantial water corrosion to the surface of the CCM board and it's components.
    I was able to find a replacement.... however after installing the replacement CCM and purchasing the RossTech cable I was able to identify some fault codes to which I am hoping to resolve. One other issue that is not shown below is that when I open the drivers door RHS (Australia) the Multifuction Display in the instrument cluster shows the front passengers door open and vice versa when opening the front passengers door the MDF displays the right front drivers door open. However the 2 rear doors are displaying correctly on the MFD when each one is opened. The CCM replacement part was purchased from Germany so i am hoping someone may be able to advise me where to find and edit this setting if possible, to resolve this problem
    The following issues have been found with VCDS.
    Address 03: ABS Brakes
    Address 18: Aux. Heat
    02251 - Heater Unit Locked
    Address 46: Central Conv.
    Subsystem 5 - Component: NGS No Answer
    Subsystem 6 - Component: IRUE No Answer
    00323 - Vehicle Inclination Sensor (G384)
    Original water damaged CCM
    7L0 959 933 E
    STG Heck high 5DK 008 416-24 II 30505 H92/S0200
    Replacement used CCM
    7L0 959 933 E
    STG Heck high 5DK 008 416-24 III 34403 H92/S0200
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGZZZ7LZ5D0xxxxx   Mileage: 102970km-63982miles
       Part No SW: 070 997 016 P    HW: 028 101 185 9
       Component: R5 2,5L EDC G000AG  1011
       Revision: 12345678    Serial number: VWZ3Z0E1310224
       Coding: 0001175
       Shop #: WSC 30023 959 89341
       VCID: 275DAF4C950E82063C-5140
    Readiness: 0 0 X X X
       Part No: 09D 927 750 BP
       Component: AL 750 6A           0596
       Coding: 0004136
       Shop #: WSC 31414 000 00000
       VCID: 7DF1AD242712F8D636-515E
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0006146
       VCID: 3D716D24679238D676-5140
       Part No SW: 3D0 909 135 N    HW: 5WK 470 21
       Component:    Kessy            6610
       Revision: 66105312    Serial number: VWZ3Z0E1310224
       Coding: 0000232
       VCID: 306F4410A0C0C5BEED-515E
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 H
       Component: CLIMAtronic R/L   X 3716
       VCID: 356175045FA2E096BE-515E
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 M
       Component:                     3001
       Coding: 0098428
       VCID: 468302C832447B0E27-5140
       Part No: 3D0 909 601 E
       Component: 0C Airbag 8.4E+ H10 0952
       Coding: 0012355
       VCID: 2541A544EF0290160E-515E
       Part No: 7L6 953 549 D
       Component: Lenksäulenmodul     3301
       Coding: 0000031
       VCID: 408F14D01060553E1D-5140
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 870 S
       Component: KOMBIINSTRUMENT RB8 2035
       Coding: 0007711
    Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
       Part No: 7L6 815 071 C
       Component: Standheizung E1MAC
       Coding: 0000000
       VCID: 326B4E18AECCF7AE9B-515E
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70EF8410604085BEAD-5140
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F0D572C2D1EEAC624-515E
       Part No: 7L0 959 933 E
       Component: 1N HSG              0201
       Coding: 0000085
       Shop #: WSC 23094 126 81224
       VCID: 3E736A286A9423CE6F-4AE8
       Subsystem 1 - Part No: 7L0 959 701 K
       Component: Tuersteuergeraet FS 0201
       Subsystem 2 - Part No: 7L0 959 702 K
       Component: Tuersteuergeraet BF 0201
       Subsystem 3 - Part No: 7L0 959 703 C
       Subsystem 4 - Part No: 7L0 959 704 C
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 7L6 035 195 A
       Component: Radio DE2           0012
       Coding: 0001405
       VCID: 31694114ABCACCB6E2-5140
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L0 955 119 L
       Component: Front Wiper         4027
       Coding: 0000768
       Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 005  0605
       Coding: 00217125
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
       VCID: 3979793473BA04F65A-5140
    End-------------------------(Elapsed Time: 09:23)--------------------------
    Thank you.
    Jun 2014
    Newcastle, England
    Welcome to the forum - from another RHD driver.
    Even though the original CCM is water-damaged; will it still communicate with VCDS? If so, see if you can grab the coding value and also run an adaptation map and we'll (Hopefully) be able to get everything back to normal for you.
    Have you fixed the water ingress problem?
    Sep 2015
    Australia
    Thanks for the welcome message and your suggestion.
    I was hoping to be able to retrieve some settings from the old CCM but unfortunately it does not communicate with VCDS at all. I have removed the debris and dirt from the drain holes, then thoroughly cleaned around the drain area. I have then lightly flooded the top roof area where water was entering and no further water was able to enter the rear of the car.
    Cheers
