bought a used Audi A3 8P (2005). And when trying to scan module 09 there is some issues. Have a look at the two autoscans below. The FIRST is scanned with my HEX-CAN interface (serial interface with the white USB - Serial adapter bought from RT). The second one is with HEX-NET interface WITH USB cable (same result with WiFi scan, but there is still some bugs with scan of some modules, on this car the autoscan stops on module 09 with WiFi connection).
Friday,18,September,2015,22:32:31:62006
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WAUZZZ8P54A165042 License Plate:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 47 52 55 56 76 7D
VIN: WAUZZZ8P54A165042 Mileage: 162070km-100705miles
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0D3FN70K1
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 275754BD961F22063C-8072
Readiness: 0 0 1 1 1
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
VCID: 3A719DC975ADAFEE53-806E
Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
Component: KlimavollautomatH12 0150
Revision: 015231 Serial number: 8P0820043E
VCID: 2E59A199B9E5734EFF-807A
01207 - Control Module for Auxiliary Heater (J364)
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 35
Mileage: 150278 km
Date: 2015.03.31
Time: 17:26:18
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000690970
Coding: 0B8ACF0083141000000000000000000000
VCID: 3B7F98CD7A9796E648-806E
Subsystem 1 - Part No: 8P1 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 12345
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0010602
VCID: 438FE02D0267EE2600-8016
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenks‰ulenmodul 012 0030
Coding: 0000012
VCID: 3065BFE1A3D165BEED-8064
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0140
Revision: D09 Serial number: 2243DD09053438
Coding: 0004003
Shop #: WSC 80093 222 69422
VCID: 356B8EF55CB34096BE-8060
Address 18: Aux. Heat Labels: 1K0-815-005.clb
Part No: 1K0 815 005 EF
Component: Heizgeraet H08 0040
Revision: A Serial number: 09011596
Coding: 0001112
Shop #: WSC 38059 136 84162
VCID: 6AD16D89458DDF6EE3-803E
00003 - Control Module
Fault Frequency: 7
Reset counter: 253
Mileage: 155675 km
Date: 2015.07.07
Time: 26:45:11
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500104325011F
Coding: 7D0F1F42070100
VCID: 285557819B012D7E35-807C
Revision: D09 Serial number: AUX7Z0D3FN70K1
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000048
VCID: 397382C570ABA4F65A-806C
Part No: 1K1 909 144 F
Component: EPS_ZFLS Kl.10 1301
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 188800186D288505484A016000
Shop #: WSC 06435 123 12345
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001119925
VCID: 70E57FE1635125BEAD-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
00106 - Signal Central Locking SAVE/LOCK Passenger Side
Part No: 8P0 907 357 A
Revision: 00000000 Serial number:
VCID: 387587C14BA1BDFEA5-806C
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 08S Serial number: AUZ2Z3D2056623
Coding: 0001001
VCID: 6FE77C9D7E6F3A46B4-803A
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 HW: 8P0 919 283
Component: Parkhilfe 4-Kan H06 0020
Coding: 0000003
VCID: 78F547C10B217DFE65-802C
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C5DAB918FF9015ED1-8078
End-------------------------(Elapsed Time: 01:43)--------------------------
Friday,18,September,2015,22:36:59:41099
Coding: 0000072
VCID: 271E3103964D9F063C-8072
Coding: 0023174
VCID: 3A38F87775FF12EE53-806E
VCID: 2E10C427B9B7CE4EFF-807A
Reset counter: 35
Mileage: 150278 km
Date: 2015.03.31
Time: 17:26:18
Address 09: Cent. Elect. Labels: None
VCID: 55E24BCBBCA1DD965E-8000
No Faults Found
Coding: 0010602
VCID: 43C685930235532600-8016
Coding: 0000012
VCID: 302CDA5FA383D8BEED-8064
Coding: 0004003
VCID: 3522EB4B5CE1FD96BE-8060
Coding: 0001112
VCID: 6A98083745DF626EE3-803E
Fault Frequency: 7
Reset counter: 253
Mileage: 155675 km
Date: 2015.07.07
Time: 26:45:11
VCID: 281C323F9B53907E35-807C
Coding: 0000048
VCID: 393AE77B70F919F65A-806C
VCID: 3B36FD737AC52BE648-806E
VCID: 70AC1A5F630398BEAD-8024
Coding: 0000048
VCID: 383CE27F4BF300FEA5-806C
Coding: 0001001
VCID: 6FAE19237E3D8746B4-803A
Coding: 0000003
VCID: 78BC227F0B73C0FE65-802C
VCID: 2C14CE2F8FABBC5ED1-8078
End-------------------------(Elapsed Time: 01:32)--------------------------
