Results 1 to 3 of 3
Thread: Carbon Fiber R8 upgrade
    I have a friend that recently upgraded the front and rear brakes to factory carbon fiber rotors and the applicable calipers. He also changed the Brake booster and master cylinder.
    It is my understanding that the car needs to be recoded to function correctly. I believe the ABS and airbag have to be recoded. Attached is a full scan. Any help would be greatly appreciated.
    VCDS Version: Release 15.7.1 Running on Windows 7 x86
    Data version: 20150904
    Chassis Type: FG (8P0)
    Scan: 01 02 03 08 09 0F 10 11 31 14 15 16 17 19 25 2E 37 42 46 47
              52 56 61 65 6C 77 A6
    VIN: WUAENAFG5BN002076   Mileage: 47580km-29564miles
    11-Engine II -- Status: OK 0000
    31-Engine other -- Status: OK 0000
    A6-Microphone -- Status: Malfunction 0010
    Address 01: Engine (BUJ)       Labels: None
       Part No SW: 424 910 552 M    HW: 420 907 552 B
       Component: 5.2L V10HDZ/4V F   ¬0010
       Revision: F5H07---    Serial number: AUX7Z0K0FND0G7
       Coding: 011000091B0F0120
       Shop #: WSC 42772 001 1048576
       VCID: 1D3BD635C48E72D656-8048
    Address 02: Auto Trans        Labels: 420-910-156-V2.clb
       Part No SW: 420 910 156 M    HW: 420 927 156
       Component: SL600 5.2L FSI HDZ  0030
       Revision: SBH03001    Serial number: 8+4NCW3CK
       Coding: 0000001
       Shop #: WSC 02197 785 00200
       VCID: 1933C225D0A60EF6BA-804C
       Subsystem 1 - Part No: 420 713 041 C
       Component: A11 C02  26.06.12   0A11
    049478 - No Communication with Diagnostic Gateway
                   U0146 - 000 -  - Intermittent
                        Mileage: 47567 km
                        Torque: 0.0 Nm
                        Temperature: 28.0░C
                            0.00 %
       Part No SW: 420 907 379     HW: 420 614 517 D
       Component: ESP8 quattro    H01 0200
       Coding: 0000267
       VCID: 59B382259026CEF67A-800C
       Part No SW: 420 820 043 G    HW: 420 820 043 G
       Component: J255  Klima 1 Zone  0090
       Revision: 00H06007    Serial number: 00000001171161
       Coding: 1572906
       VCID: 0E19A1791968D94EDF-805A
    Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
       Part No SW: 8P0 907 063 S    HW: 8P0 907 063 L
       Component: BCM PQ35  H   106 0667
       Revision: 00106 AD
       Coding: 6E000A00A0933624207444E009200009507068001120C92ADC08061C0045
       Shop #: WSC 25166 444 84618
       VCID: 448D4351C7A4631E39-8010
       Subsystem 1 - Part No SW: 423 955 113     HW: 423 955 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiR  H23 0040
       Coding: 005912
       Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 025B32
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
                        Fault Status: 00101010
                        Fault Frequency: 6
                        Reset counter: 129
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 21:22:29
                            Term 15 On
                        Voltage: 11.80 V
                            Term 50 On
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
                        Fault Frequency: 6
                        Reset counter: 129
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 21:22:29
                            Term 15 On
                        Voltage: 11.80 V
                            Term 50 On
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7L0595096
       Coding: 0000100
       VCID: 366929994178C18EB7-8062
                000 -  -
                        Reset counter: 87
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 21:05:33
    Address 10: Park/Steer Assist (J446)       Labels: 8P0-919-475-7X2.clb
       Part No SW: 8P0 919 475 N    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0140
       Revision: 11001001    Serial number: 12591035647928
       Coding: 30010C
       Shop #: WSC 02391 823 56573
       VCID: 49935265E086BE76CA-801C
    Address 11: Engine II        Labels: None
    Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
       Part No SW: 420 910 376 A    HW: 420 907 376 A
       Component: J250 Raddaempfung   0170
       Revision: --H16---    Serial number: 190DPH 0350035
       Coding: 0000052
       VCID: 1123BA050856C6B6C2-8044
    Address 15: Airbags        Labels: 420-959-655.lbl
       Part No SW: 420 959 655     HW: 420 959 655
       Component: SN Airbag 9.43  H02 0020
       Revision: 93H02002    Serial number: 003B8000DMS%
       Coding: 0021326
       VCID: 5DBB9635840E32D616-8008
       Subsystem 1 - Part No: 8J0 910 339 A
       Component: BF-Gewichtsens. H02 0030
       Subsystem 2 - Serial number: 05ENK
       Subsystem 3 - Serial number: 0001.01.0000H0200000000000 †63
       Subsystem 4 - Serial number: 000000 †63328RB405E8FEEEJ †63
       Subsystem 5 - Serial number: 8FEEEJ †63428RB405E8FE822 †63
       Subsystem 6 - Serial number: 8FE822 †63747RB405F2AABD6 †63
       Subsystem 7 - Serial number: 2AABD6 †63847RB405F2AAE52
       Subsystem 8 - Serial number: 2AAE52
    02512 - Pressure Sensor for Seat Occupied Recognition (G452)
                014 - Defective - MIL ON
                        Fault Status: 11101110
                        Fault Frequency: 15
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 20:55:54
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H37 0070
       Coding: 0004141
       VCID: 41834A4518B6763612-8014
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 420-920-xxx-17.clb
       Part No SW: 420 920 981 X    HW: 420 920 981 X
       Component: KOMBIINSTR. VDO H01 0591
       Revision: D0H01004    Serial number: 224NL004000014
       Coding: 0081263
       Shop #: WSC 40214 001 1048576
       VCID: 2B5F08ED8A3A8C66D8-807E
       Part No SW: 8P0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H43 0311
       Revision:   H43       Serial number: 081210F1000694
       Coding: 354100
       VCID: 336F108D920AD4A690-8066
       Revision: D0H01004    Serial number: AUX7Z0K0FND0G7
    Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
       Part No SW: 420 035 785     HW: 420 035 785
       Component: SG ext.Player H08 0100
       Revision: 00000000
       Coding: 020302
       VCID: 52A175090DD0FDAEBB-8006
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
       Part No SW: 423 035 192 H    HW: 423 035 192 H
       Component: RNS-E PU US     H06 0200
       Revision: 0000012S    Serial number: AUZBZ7L7200022
       Coding: 0730645
       VCID: 152BCE153CBE2A969E-8040
    Address 42: Door Elect, Driver        Labels: None
       Part No SW: 420 959 801 H    HW: 420 959 801 H
       Component: Tuer-SG         H04 0103
       Coding: 0005245
       VCID: 1E39D139C98869CE4F-804A
    Address 47: Sound System        Labels: 420-035-223.lbl
       Part No SW: 420 035 223 D    HW: 420 035 223 A
       Component: J525 Amp High   H14 0230
       Revision: 00H14001    Serial number: 34844000925703
       Coding: 0246111
       VCID: 091392656006FE760A-805C
    Address 52: Door Elect, Pass.        Labels: None
       Part No SW: 420 959 802 H    HW: 420 959 802 H
       Coding: 0005245
       VCID: 1F47EC3DCE8260C644-804A
    Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
       Coding: 0730645
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 8P0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H43 0311
       Coding: F32001FE
       VCID: 74EDD391D784939E49-8020
       Subsystem 1 - Part No SW: 420 915 181     HW: 420 915 181
       Component: J367-BDM  H07 0140
    Address 65: Tire Pressure        Labels: None
       Part No SW: 420 910 273 A    HW: 4F0 907 273 A
       Component: Reifendruck 3   H05 0040
       Revision: 00050040    Serial number: 00000700006850
       Coding: 0462426
       Shop #: WSC 04272 001 1048576
       VCID: 0D1BA675146EE25626-8058
    Address 6C: Back-up Cam.        Labels: 420-910-441.clb
       Part No SW: 420 910 441 A    HW: 7L6 907 441 C
       Component: J772__Rearview      0010
       Revision: --H13---    Serial number: 525PA8-J0Z6042
       Coding: 1020412
       VCID: 0A11AD696500F56E03-805E
       Part No SW: 8P1 862 336     HW: 8P1 862 336
       Component: FSE_256x BT     H41 0650
       Revision: 00000000    Serial number: 00000005044711
       Coding: 0011477
       Shop #: WSC 02556 785 00200
       VCID: 75EBEE951CFE8A967E-8020
    Address A6: Microphone (J886)       Labels: 420-907-394.clb
       Part No SW: 420 907 394     HW: 420 907 394
       Component: BELTMICBOX    H09 0060
       Coding: 0100010202
       Shop #: WSC 02197 785 00000
       ASAM Dataset: EV_BeltMicAU715 002011
       ROD: EV_BeltMicAU715.rod
       VCID: 56A989192938E18E57-8002
    0032 - Microphone 1 for Passenver Side
              B1206 13 [009] - Open Circuit
                        Reset counter: 87
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 21:29:04
    0048 - Microphone 2 for Passenver Side
              B1207 13 [009] - Open Circuit
                        Reset counter: 87
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 21:29:04
    0064 - Microphone 3 for Passenver Side
              B1208 13 [009] - Open Circuit
                        Reset counter: 87
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 21:29:04
    0080 - Microphone 1 for Drivers Side
              B1203 13 [009] - Open Circuit
                        Reset counter: 87
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 21:29:04
    0096 - Microphone 2 for Drivers Side
              B1204 13 [009] - Open Circuit
                        Reset counter: 87
                        Mileage: 47536 km
                        Date: 2015.09.16
                        Time: 21:29:04
    0112 - Microphone 3 for Drivers Side
              B1205 13 [009] - Open Circuit
                        Reset counter: 87
    End
    I'm confident the airbag module in this car will not accept any coding except the one it already has. I'm not sure why the airbag module would care what kind of brakes the car has anyway.
    As for the ABS, I'd consider that far more likely but haven't come up with a coding chart for that module.
    Magdeburg, Germany
    We can do these ESP codings on a case by case basis, please email us directly via Support@Ross-Tech.com
    ╗Nichts erweitert das eigene Wissen mehr,
    als die Meinung eines Andersdenkenden.ź
