Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
Thread: VW Transporter T5.2/T5GP Mirror Fold on Lock
  1. #31
    Verified VCDS User Danners74's Avatar
    Jun 2016
    Im looking to retro fit folding mirrors on a T5 GP. Has any body done this?
    Also any news on this folding mirrors on lock,as im looking to get this working on our T6 Kombi DSG highline.
    The needle sweep.....is that where the needles sweep when turning the ignition on.....done via instrument cluster?????
    Regards Danners.
  2. #32
    Jun 2016
    Bumpety bump
  3. #33
    Magdeburg, Germany
    Quote Originally Posted by Adam87 View Post
    Byte 2 Bit 1 in each door module, then redo basic settings for windows
    Adam, can you elaborate on this? I tested this and can NOT confirm it's working. What model/module did you try this on?
    FWIW: With Byte 02 Bit 1 active, the Window Regulators are blocked/off with Ignition OFF (but S-Contact ON). I did manage to find some more time to play and I believe I found the meaning of a few bits and fixed the differentiation between the individual control module variants - won't help with this problem yet, though there's gonna be a more appropriate label file included in the next update.
  4. Likes Danners74 liked this post
  5. #34
    Jun 2016
    Any news on yet Sebastian?
  6. #35
    Dec 2016
    There is an aftermarket kit available, I don't know the quality but have a read here https://www.t6forum.com/threads/powe...mote-lock.885/
    Rod
  7. #36
    Apr 2016
    Ive got my T6 mirrors to fold on the key now thanks to Adam and the T6 forum
    all I changed was the 1500B1 to 1500B3 and 0400A1 to 0400A3
    then you have to reset the one touch window switches,
    you have to hold the lock button on key for a second or so longer for the mirrors to fold, then they unfold when you turn the ignition on
    Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
    Part No SW: 7E0 937 090 HW: 7E0 937 090
    Component: BCM PQ25 Max4 H80 0733
    Revision: B9080001 Serial number: 0771 334150793
    Coding: B9F479384A63349193284F646EEB9EF48DA0718960CC6D6032 04003F0800
    Shop #: WSC 02737 534 134075
    VCID: 68DFD5C49B54270141-803C
    Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
    Component: RLS 071215 03 37 0059
    Coding: 0228EE
    Subsystem 2 - Part No SW: 7E0 959 801 L HW: 7E0 959 801 L Labels: 7E0-959-80X-V2.CLB
    Component: J386__TSG_FT 003 8654
    Serial number: KU0KU017111553216158
    Coding: 1500B1
    Subsystem 3 - Part No SW: 7E0 959 802 L HW: 7E0 959 802 L Labels: 7E0-959-80X-V2.CLB
    Component: J387__TSG_BT 003 8654
    Serial number: KU0KU018111553222604
    Coding: 0400A1
  8. Likes Uwe, Danners74 liked this post
  9. #37
    Apr 2016
    The folding on lock with the key works now!
  10. #38
    Magdeburg, Germany
    nickdaw, what position is your mirror switch in when you do this? As I wrote earlier, flipping that bit has a completely different effect on mine.
       Part No SW: 7E0 937 090 B    HW: 7E0 937 090
       Component: BCM PQ25 Max4 H81 0744
       Revision: B9081001    Serial number: 0982 14416XXXX
       Coding: A0AA393A0A69349293280F606CEB8F74C0B4738960CD79703304023F0860
       Shop #: WSC 02737 534 105168
       Subsystem 2 - Part No SW: 7E0 959 801 N    HW: 7E0 959 801 N
       Component: J386__TSG_FT  003 0653
       Serial number: KU0KU01905166140XXXX
       Coding: 0400A1
       Subsystem 3 - Part No SW: 7E0 959 802 N    HW: 7E0 959 802 N
       Component: J387__TSG_BT  003 0653
       Serial number: KU0KU01105166132XXXX
       Coding: 1400A1
  11. #39
    Apr 2016
    my mirror fold works with button switched to the left or right mirror
    I see your modules have the letter N as mine have the letter L, I wonder if that has any thing to do with it?
  12. Likes Danners74 liked this post
  13. #40
    Jun 2016
    Quote Originally Posted by nickdaw View Post
    Coding: 0228EE
    Coding: 1500B1
    Coding: 0400A1
    hmmmmmm very interesting i have part numbers with Q's on our T6. Im very intrigued if this will work on ours. How do you get into the separate control units??? I.E. J386 and J387 door control modules?
    Regards Danners.
