Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
Thread: VW Transporter T5.2/T5GP Mirror Fold on Lock
    Feb 2015
    No - Im afraid not. Spent lots of time with different coding but could never work it out!
  2. #12
    I'm trying to get as many t5/6 long codes as I can to compare but it's difficult to make any sense from them
    Also included the one from the polo with it working
  3. #13
    Apr 2016
    this is my 2016 T6 Kombi Highline,i would like mine to do that along with auto lock and just the drivers door to unlock with 1 click
    Subsystem 2 - Part No SW: 7E0 959 801 L HW: 7E0 959 801 L Labels: 7E0-959-801.CLB
    Component: J386__TSG_FT 003 8654
    Coding: 1400B1
    Subsystem 3 - Part No SW: 7E0 959 802 L HW: 7E0 959 802 L Labels: 7E0-959-802.CLB
    Component: J387__TSG_BT 003 8654
    Coding: 0400A1
  4. #14
    Magdeburg, Germany
    @nickdaw, Selective Locking as well as Auto-Lock/Unlock can be found in the coding/adaptation of the BCM. Those functions are unrelated to the door control module coding.
  5. Likes Uwe liked this post
  6. #15
    Apr 2016
    Hi does any one know the access code for my 2016 Transporter T6?
    i want to try the settings from the Golf 7 for folding mirrors on lock,
    31347 code does not work
    [09] Central Electronics
    [16] Security Access - Code
  7. #16
    Magdeburg, Germany
    Feel free to try, it just won't work. The Golf 7 modules are not even close to what you got in the T6. Most T6 modules are pretty much the same as the T5GP, the BCM only got a new software and that's it.
  8. Likes Uwe, Danners74 liked this post
  9. #17
    Ive got a customer that wants the same mirror's fold on lock,
    Any one know the login for the dashpod as he wants the staging (Needle sweep) turning on? I got a scan but not had the chance to try any logins yet.
    VCDS Version: Release 15.7.4 (x64) Running on Windows 10 x64
    Data version: 20160216
    DG Motor Services
    Wednesday,27,April,2016,15:46:16:62916
    Chassis Type: 7H (7E0)
    Scan: 01 03 08 09 10 15 17 19 25 5F 61 0B
    VIN: WV1ZZZ7HZGX0****   Mileage: 2260km-1404miles
    Address 01: Engine (J623-CAAC)       Labels: 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
       Component: R4 2,0L EDC   H38 8440
       Revision: 22H38---    Serial number: 00000000000000
       Coding: 01194012232401080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
       ROD: EV_ECM20TDI01103L906019GP.rod
       VCID: 0005EF799BF6C73E7E-8054
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 42715000000115
       Coding: 517E40982563847E8A75027EA48621E6390000
       ROD: EV_Brake1ESCCONTIVN75XGP2.rod
       VCID: 3F872C85A68878C647-806A
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 7E0 907 047 T    HW: 7E0 907 047 T
       Component: Climatic-T5   H22 0607
       Revision: 00001002
       Coding: 0000000003
       ROD: EV_ClimaT5Basis_VN75.rod
       VCID: 3B7F5895B29064E66B-806E
    Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090     HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0733
       Revision: B9080001    Serial number: 0771 281150712
       Coding: A0A4393A0A61349193284F746CEB8E748FA0710F60CC6D60320400230800
       Shop #: WSC 35110 377 08192
       VCID: 68D5D7D99B861F7ED6-803C
       Subsystem 1 - Part No: 5K7 955 559 B
       Component: RLS 231015 03  37  0059
       Coding: 0228EE
       Coding: 1400B1
       Coding: 0400A1
       Subsystem 4 - Part No: 7E1 951 172
       Subsystem 5 - Part No: 1K0 951 605 C
       Subsystem 6 - Part No: 7E1 951 172
       Subsystem 7 - Part No SW: 2H0 959 442     HW: 2H0 959 442
       Component: E221__MFL-DC1  H02 0103
       Coding: A4FFFF
    Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
       Part No SW: 7E0 919 475 M    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0205
       Revision: --------    Serial number: 32961524301914
       Coding: 108008
       ASAM Dataset: EV_VW75XParkAssis4K 001008
       ROD: EV_VW75XParkAssis4K_VN75.rod
       VCID: 3C7D5B89B79E63DE62-8068
       Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
       Component: VW10Airbag00J 008 0016
       Revision: --------    Serial number: 003PH001F84U
       Coding: 00000000000000000000000000000000304A
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       ROD: EV_AirbaVW10BPAVN750_SE12.rod
       VCID: 377744A58EB840868F-8062
       Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
       Component: KOMBI         H05 1008
       Coding: 470B010100
       ROD: EV_Kombi_UDS_VDD_RM09_SE36.rod
       VCID: 336F70B59AC0ACA6B3-8066
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0733
       Revision: B9080001
       Coding: 042307
       Component: IMMO          H05 1008
       VCID: 6AD1ADD18D8A2D6EC0-803E
    Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
       Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
       Component: MU-S-ND-ER    H22 0245
       Serial number: VWZAZ2R8935701
       Coding: 065700013C00000011111101008808001F010086002001004F
       ROD: EV_MUStd4CTSAT_SE25.rod
       VCID: 21438AFD303C2E3651-8074
       Engine Control Module 2:
       Subsystem 1 - Part No SW: 3G0 919 866 M    HW: -----------
       Component: ECE 2016  --- 0521
    15360256 - Component Protection
              U1101 00 [008] - Active
                        Reset counter: 81
                        Date: 2016.04.17
                        Time: 14:35:32
    Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H80 0733
       Coding: 030B1A73
       Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
       Component: J367-BDM  H08 0223
    Apr 2016
    Thanks for that,
    so its just wait until someone figures out the folding mirrors on lock?
  11. #19
    Magdeburg, Germany
    The more pressing question at this point is IMO - is this feature actually supported by those door/window control modules?!
    P.S.: Needle sweep/staging should be not require a login.
  12. Likes Uwe liked this post
  13. #20
    Apr 2016
    How do we find out?
