Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: MK7 GTI and R DSG Reset of Adaption procedure
    New User
    Sep 2015
    South Africa
    Is there a specific procedure to follow when resetting the DSG adaptions on the GTI and R.
    Thanks,
    Please post Auto-Scan(s) from the cars in question so we can see what they're made of.
    New User
    Sep 2015
    South Africa
    There are no faults present. I do tuning for Burger Motorsport and we have had a few 7 R's that shudder. Some can go to the dealer for reset but it would help if I knew the VCDS procedure.
    Thanks.
    I didn't ask for an Auto-Scan to see if faults are present.
  5. Likes Zenerdiode liked this post
    New User
    Sep 2015
    South Africa
    Golf 7 R
    VCDS Version: Release 15.7.0 (x64) Running on Windows 7 x64
    Data version: 20150820
    Sunday,20,September,2015,16:21:52:30230
    Chassis Type: AU (5Q0)
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
    VIN: WVWZZZAUZEW243160   Mileage: 8382km-5208miles
    Address 01: Engine (J623-CJXB)       Labels: 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 B    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D00322426050B3004
       ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
       ROD: EV_ECM20TFS0205G0906259B_VW37.rod
       VCID: 2D57B12B7C672856CE-8078
    Readiness: 1110 0001
       Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H52 4311
       Revision: 05852204    Serial number: TFK01312021995
       ROD: EV_TCMDQ250021_AU37.rod
       VCID: 2441540F2FADE91E11-8070
       Revision: 00000000    Serial number: 63403000000709
       Coding: 01FA93A15424296F0378070641C36980C92A94C0E08296F7004200B8C208
       VCID: 7BF34F73F29376E600-802E
       Revision: 00021000    Serial number: 0322002274
       Coding: 030C0C
       ROD: EV_KessyHellaMQBAB_AU37.rod
       VCID: 3A7D8A77BD298FEE5B-806E
       Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
       Component: Climatronic   H02 0805
       Revision: 00001K06
       Coding: 00120014200100001005000012101800
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 66C50E079911DB0ECF-8032
       Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
       Component: BCM MQBAB H   H16 0124
       Serial number: 00011334600228
       Coding: 03111A46C24122F30BA44080B10C07281800000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       Slave 1:
       Component: WWS    131207  042 0551
       Serial number:         131210024235
       Slave 2:
       Component: RLFS  024 0042
       Serial number: Y13M12D13H21M39S56S8
       Coding: 00A8DD
       Serial number: 000000000ZY1331021VZ
       Serial number: 00000000000058181145
       Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.013  H02 0007
       Serial number:     WOO2598516A
       Coding: 181801
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
       Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0142
       Revision: --------    Serial number: 39331335100849
       Coding: 0031151011
       ROD: EV_EPHVA18AU3700000_SK48.rod
       VCID: 3E758667A101A3CE67-806A
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H15 0115
       Serial number: 27111341350254
       ROD: EV_DRCONTITEMIC.rod
       VCID: 76E55E47C9B12B8E7F-8022
       Component: AirbagVW20    014 0385
       Serial number: 003F6R039PVX
       VCID: 418FFD9BD0FFDC361A-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 000 712 13
       Serial number: 35767000000173156E0M
       Subsystem 2 - Part No SW: -----------    HW: 480 000 712 13
       Serial number: 3586700000047335BD0W
       Subsystem 3 - Part No SW: -----------    HW: 480 400 712 13
       Serial number: 3516502C91220565934.
       Subsystem 4 - Part No SW: -----------    HW: 480 400 712 13
       Serial number: 3526502C51220765D21-
       Subsystem 5 - Part No SW: -----------    HW: 480 400 612 13
       Serial number: 3556502A51220565711S
       Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 10121304221556
       Coding: 0410
       ROD: EV_SMLSKLOMQB_SE37.rod
       VCID: 79FF557BF8AF44F612-802C
       Part No SW: 5G6 920 870 B    HW: 5G6 920 870 B
       Component: KOMBI         314 2210
       Coding: 27AD0818BB80000800086A00040000
       VCID: 2E55B6277161534EF7-807A
       Revision: --------    Serial number: 0001363722
       Coding: 030100042B085900EF00026A9C0F00010001000000000000000000000000
       ROD: EV_GatewLear.rod
       VCID: 3F8BFB63A60BAAC66C-806A
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M
       Component: E221__MFL-DC1  H06 0101
       Serial number: 27130001947850093491
       Coding: 29FFFF
       Serial number: 9262102103
    Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
       Component: Haldex4Motion H52 7076
       Serial number: HA1-00021.10.13
       Coding: 0001
       ROD: EV_AllWheelContrHA1VW37X_AU21.rod
       VCID: 4685EE87F9D1FB0E2F-8012
       Revision: 00000000    Serial number: 13000278102005
       Coding: DD00000000000000
       ROD: EV_ELVMarquMQB_AU37.rod
       VCID: 3461A44F9F4D799E81-8060
       Serial number: 07121302090870
       Coding: 003E12208001040000001000
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: 4089F89FDBF5D53E15-8014
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
       Serial number: 00000000000001339837
       Coding: 1D0000
       Coding: 8103
       ROD: EV_SteerAssisMQB.rod
       VCID: 3567994B94376096B6-8060
       Serial number: 08121304081303
       Coding: 003E10208E01040000801000
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
       Serial number: 00000000000001329009
       Coding: 050000
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Coding: 02A602000B010200
       ROD: EV_HeadlRegulVWAFS_SE26.rod
       VCID: 3D77816BAC07B8D67E-8068
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
       Part No SW: 5G0 035 045 B    HW: 5G0 035 045
       Component: MU-H-N-RW     H42 0291
       Serial number: A311K0D7502804
       Coding: 02730009FF00000011110001000900001F0207D60100010057
       ASAM Dataset: EV_MUHig4CHBAS 001040
       ROD: EV_MUHig4CHBAS_VW37.rod
       VCID: 1F4B5BE306CBCAC64C-804A
       Media Player Position 1:
       Component: ABT_High  H51 0022
       Serial number: VWZ8Z9NJ6006Z4
       Engine Control Module 2:
       Subsystem 2 - Part No SW: V03 959 800 TJ    HW: -----------
       Component: ROW 2014  --- 0030
       Door Electronics Rear Left:
       Component: Gracenote  --- 4005
       Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 131113201745
    End-------------------------(Elapsed Time: 04:16)--------------------------
  7. Likes Uwe, flygteye liked this post
    OK, 09D / DQ250. My understanding is we do not currently have a calibration procedure for that transmission. However, we did recently get regular access to a car that has such a transmission, and will hopefully be able to develop a procedure for it.
    PS: Please register your system for support by filling out this form so we can make you a Verified User here.
  9. Likes DV52 liked this post
  10. #7
    Uwe: I'm always ecstatic when I hear about RT's developments for the mk7 (purely and unashamedly for self serving reasons)! Will the calibration procedure that you mention above extend generally to the DQ200 series transmissions, or do you anticipate that it will apply solely to the DQ250 box?
  11. #8
    Don, to be honest, at this point, I do not know.
  12. #9
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by George Smooth View Post
    Thanks.
    Of topic.
    I do not think shuddering will go away with adaptation.
    You need to tune DGS, Shuddering /hard shift comes when Torque limit in DSG vs ECU is pass.
    Same thing with TDI when you tune them.
    Anyway if you think this will go away let customer drive 500-700miles and transmission will adopt it self.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  13. Likes Uwe liked this post
  14. #10
    Sep 2015
    Uwe,
    Any update on availability of 0D9 adaptation procedure?
    Bryan
