George Smooth
New Member
Is there a specific procedure to follow when resetting the DSG adaptions on the GTI and R.
Thanks,
Thanks,
I didn't ask for an Auto-Scan to see if faults are present.
VCDS Version: Release 15.7.0 (x64) Running on Windows 7 x64
Data version: 20150820
Sunday,20,September,2015,16:21:52:30230
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZEW243160 Mileage: 8382km-5208miles
Address 01: Engine (J623-CJXB) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00322426050B3004
ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
ROD: EV_ECM20TFS0205G0906259B_VW37.rod
VCID: 2D57B12B7C672856CE-8078
Readiness: 1110 0001
Part No SW: 0D9 300 011 R HW: 02E 927 770 AQ
Component: DQ250-6A MQB H52 4311
Revision: 05852204 Serial number: TFK01312021995
ROD: EV_TCMDQ250021_AU37.rod
VCID: 2441540F2FADE91E11-8070
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 63403000000709
Coding: 01FA93A15424296F0378070641C36980C92A94C0E08296F7004200B8C208
VCID: 7BF34F73F29376E600-802E
Revision: 00021000 Serial number: 0322002274
Coding: 030C0C
VCID: 3A7D8A77BD298FEE5B-806E
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0805
Revision: 00001K06
Coding: 00120014200100001005000012101800
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 66C50E079911DB0ECF-8032
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AE HW: 5Q0 937 084 AE
Component: BCM MQBAB H H16 0124
Serial number: 00011334600228
Coding: 03111A46C24122F30BA44080B10C07281800000000000000000000000000
ASAM Dataset: EV_BCMCONTI 012001
ROD: EV_BCMBOSCH_AU37.rod
Slave 1:
Component: WWS 131207 042 0551
Serial number: 131210024235
Slave 2:
Component: RLFS 024 0042
Serial number: Y13M12D13H21M39S56S8
Coding: 00A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1331021VZ
Serial number: 00000000000058181145
Subsystem 5 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.013 H02 0007
Serial number: WOO2598516A
Coding: 181801
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 F HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0142
Revision: -------- Serial number: 39331335100849
Coding: 0031151011
ROD: EV_EPHVA18AU3700000_SK48.rod
VCID: 3E758667A101A3CE67-806A
Part No SW: 5Q0 907 376 HW: 5Q0 907 376
Component: DAEMPFUNGS-SG H15 0115
Serial number: 27111341350254
ROD: EV_DRCONTITEMIC.rod
VCID: 76E55E47C9B12B8E7F-8022
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R039PVX
VCID: 418FFD9BD0FFDC361A-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 712 13
Serial number: 35767000000173156E0M
Subsystem 2 - Part No SW: ----------- HW: 480 000 712 13
Serial number: 3586700000047335BD0W
Subsystem 3 - Part No SW: ----------- HW: 480 400 712 13
Serial number: 3516502C91220565934.
Subsystem 4 - Part No SW: ----------- HW: 480 400 712 13
Serial number: 3526502C51220765D21-
Subsystem 5 - Part No SW: ----------- HW: 480 400 612 13
Serial number: 3556502A51220565711S
Part No SW: 5Q0 953 507 EA HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 10121304221556
Coding: 0410
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 79FF557BF8AF44F612-802C
Part No SW: 5G6 920 870 B HW: 5G6 920 870 B
Component: KOMBI 314 2210
Coding: 27AD0818BB80000800086A00040000
VCID: 2E55B6277161534EF7-807A
Part No SW: 5Q0 907 530 Q HW: 5Q0 907 530 F
Component: GW MQB High 125 1164
Revision: -------- Serial number: 0001363722
Coding: 030100042B085900EF00026A9C0F00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear.rod
VCID: 3F8BFB63A60BAAC66C-806A
Subsystem 2 - Part No SW: 5G0 959 442 M HW: 5G0 959 442 M
Component: E221__MFL-DC1 H06 0101
Serial number: 27130001947850093491
Coding: 29FFFF
Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 9262102103
Part No SW: 0CQ 907 554 D HW: 0CQ 907 554 D
Serial number: HA1-00021.10.13
Coding: 0001
VCID: 4685EE87F9D1FB0E2F-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 13000278102005
Coding: DD00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3461A44F9F4D799E81-8060
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 07121302090870
Coding: 003E12208001040000001000
VCID: 4089F89FDBF5D53E15-8014
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000001339837
Coding: 1D0000
Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
Component: EPS_MQB_ZFLS 503 5043
Coding: 8103
ROD: EV_SteerAssisMQB.rod
VCID: 3567994B94376096B6-8060
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 08121304081303
Coding: 003E10208E01040000801000
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000001329009
Coding: 050000
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Coding: 02A602000B010200
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 3D77816BAC07B8D67E-8068
Subsystem 1 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 HW: 3D0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 2E0000
Part No SW: 5G0 035 045 B HW: 5G0 035 045
Component: MU-H-N-RW H42 0291
Serial number: A311K0D7502804
Coding: 02730009FF00000011110001000900001F0207D60100010057
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 1F4B5BE306CBCAC64C-804A
Media Player Position 1:
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H51 0022
Serial number: VWZ8Z9NJ6006Z4
Engine Control Module 2:
Subsystem 2 - Part No SW: V03 959 800 TJ HW: -----------
Component: ROW 2014 --- 0030
Door Electronics Rear Left:
Component: Gracenote --- 4005
Part No SW: 5G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0006
Serial number: 131113201745
End-------------------------(Elapsed Time: 04:16)--------------------------
OK, 09D / DQ250. My understanding is we do not currently have a calibration procedure for that transmission. However, we did recently get regular access to a car that has such a transmission, and will hopefully be able to develop a procedure for it.
There are no faults present. I do tuning for Burger Motorsport and we have had a few 7 R's that shudder. Some can go to the dealer for reset but it would help if I knew the VCDS procedure.
Thanks.
Prerequisites:
Transmission fluid temperature between 30°C - 100°C confirmed using Advanced Measuring Values:
** IDE00102 Control Module temperature
** IDE00024 Transmission fluid temperature
Selector lever in Park
Engine idle speed, do not press accelerator pedal
Parking brake and foot brake applied during the entire procedure. This can be confirmed using Advanced Measuring Values:
* IDE02713 Brake Light Switch
* IDE02714 Brake test switch
0D9 - DQ250 MQB - Basic Settings Procedure:
[Select]
[02- Auto Trans]
[Basic Settings-04]
Select [Basic settings of transmission]
[Show Measuring Data] and select:
* IDE00021 Engine speed
* IDE00322 Status of basic setting
[Go!]
- During the basic setting procedure, there may be some loud gear shifting noises from the transmission, this is normal.
Basic settings may not complete successfully if:
- The fluid temperature gets too hot.
- Brake is released
- Engine RPM is increased
Once complete, there should be an indication of this in the [Status of Basic Settings] Advanced Measuring Value group and Basic Settings should report Finished Correctly..
[Done, Go Back] and Check for fault codes. If you have several Intermittent fault codes stored please [Save] them before clearing so the text can be pasted here with any feedback you happen to have.
;SW:0D9-300-012-K HW:02E-927-770-AQ --- Auto Trans
;Component:DQ250-6A MQB H53 4515 Coding:0014
;EV_TCMDQ250021 1001 EV_TCMDQ250021.rod
;Thursday 20 October 2016
;VCDS Version: Release 16.8.3 (x64) Data version: 20161010 DS267.0
;VCID: 1E7F5DDD019534B2AE-804A
Group Description Actual
IDE00018 Voltage terminal 15 13.5 V
IDE00019 Voltage terminal 30 13.8 V
IDE00021-ENG99543 Engine speed-Engine RPM 695 /min
IDE00022-ENG103074 Transmission input speed-Transmission Input Speed Sensor 698 /min
IDE00024 Transmission fluid temperature 38 °C
IDE00075-ENG99967 Vehicle speed-Vehicle Speed Sensor 0 km/h
IDE00086-ENG98363 Accelerator position-Accelerator pedal position 0 %
IDE00091-ENG101172 Status of starter lock-Status Engine Starter Lock Activate
IDE00094 Kick-down status OFF
IDE00095-ENG101643 Status of selector lever lock-Status Shift Lock active
IDE00096-ENG100569 Selector lever position-Shift Position Position P Stop
IDE00102-ENG102028 Control Module temperature-Control modul temperature 45 °C
IDE00130-ENG103124 Transmission specified idle RPM-Idle Speed Commanded Value 600 /min
IDE00322-ENG100540 Status of basic setting-Basic Settings Status 0
IDE00323-ENG09093 Security Access: Number of invalid keys-Counter Value 0
IDE00451-ENG103018 Currently running routine-Current Test Routine 0
IDE00872-ENG102188 Current of main pressure valve-Oil Pressure Actual Current 819.5 mA
IDE01588-ENG101855 Driving direction-M015 SvnNAbRichtung not known
IDE02221 Engine torque: qualification valid
IDE02713 Brake Light Switch not activated
IDE02714 Brake test switch not activated
IDE02717-ENG102076 Tiptronic upshift-Tiptronic Up OFF
IDE02718-ENG101063 Tiptronic downshift-Tiptronic Down OFF
IDE02719-ENG99606 Selector lever position made plausible-Shift Position Plausible P
IDE02720-ENG103810 Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1 0 /min
IDE02721-ENG100916 Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2 0 /min
IDE02722-ENG101964 Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1 0 /min
IDE02723-ENG100382 Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2 0 /min
IDE02735-ENG100209 Display of driving mode in instrument panel-Display Driving Position P
IDE02736-ENG100252 Display of gear in instrument panel-Display Driving Gear no gear engaged
IDE02790-ENG104124 Specified torque clutch 1-Clutch 1 Commanded Torque -600 Nm
IDE02796-ENG103463 Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value 0 mA
IDE02797-ENG100730 Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value 0.5 mA
IDE02800-ENG100171 Specified torque clutch 2-Clutch 2 Commanded Torque -600 Nm
IDE02805-ENG99237 Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value 0 mA
IDE02806-ENG103118 Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value 0.1 mA
IDE02862-ENG103213 Production data transmission-Aggregatekennzeichnung (Getriebe) 6
IDE02862-ENG103083 Production data transmission-Baudatum 150326
IDE02862-ENG104019 Production data transmission-Getriebekennbuchstabe QSN
IDE02862-ENG99175 Production data transmission-Kassel K
IDE02862-ENG101707 Production data transmission-Kennung der Montagelinie 0
IDE02862-ENG103830 Production data transmission-Lfd.-Nr 863
IDE02864-ENG99505 Actual position of gear positioner A-Gearpositioner A Actual Position 0.14 mm
IDE02865-ENG104121 AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1 2088
IDE02870-ENG120871 Duty cycle of gear solenoid valve A-Gearpositioner_A_Valve_Duty_Factor 0 %
IDE02872-ENG102218 Actual position of gear adjuster B-Gearpositioner B Actual Position -8.1 mm
IDE02873-ENG101728 AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1 1058
IDE02878-ENG120875 Pulse duty factor of gear solenoid valve B-Gearpositioner_B_Valve_Duty_Factor 0 %
IDE02880-ENG103036 Actual position of gear positioner C-Gearpositioner C Actual Position -0.14 mm
IDE02881-ENG99453 AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1 2072
IDE02886-ENG120879 Pulse duty factor of gear solenoid valve C-Gearpositioner_C_Valve_Duty_Factor 0 %
IDE02888-ENG103826 Actual position of gear positioner D-Gearpositioner D Actual Position -8.21 mm
IDE02889-ENG100525 AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1 1203
IDE02894-ENG120883 Duty cycle of gear solenoid valve D-Gearpositioner_D_Valve_Duty_Factor 0 %
IDE03008-ENG122550 Stop process prevented-GE_StartStopp_Info Stop release
IDE03008-ENG122551 Stop process prevented-MO_StartStopp_Status 0
IDE03008-ENG122546 Stop process prevented-Stopp-Verbot-Grund 1 not active
IDE03008-ENG122547 Stop process prevented-Stopp-Verbot-Grund 2 not active
IDE03008-ENG122548 Stop process prevented-Stopp-Verbot-Grund 3 not active
IDE03008-ENG122549 Stop process prevented-Stopp-Verbot-Grund 4 not active
IDE03008-ENG122552 Stop process prevented-Stopp-Verbot-Grund 5 not active
IDE03008-ENG122553 Stop process prevented-Stopp-Verbot-Grund 6 not active
IDE03008-ENG122554 Stop process prevented-Stopp-Verbot-Grund 8 not active
IDE03171-ENG102987 Driving strategy transmission mileage-Q002 Total Driving Time 16679.2 km
IDE03172-ENG100789 Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological 98 %
IDE03173-ENG103567 Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty 0 %
IDE03174-ENG100415 Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual 0 %
IDE03180-ENG103176 Number of standard trips-General Denominator 554
IDE03181-ENG102823 Number of ignition cycles-Ignition Cycle Counter 2420
IDE03182-ENG120927 Lower adapted coupling point K1 from kiss point adaptation-lower_Adapted_Clutchpoint_K1_Of_Kisspoint_Adaption 0.27 A
IDE03183-ENG120930 Lower adapted coupling point K2 from kiss point adaptation-lower_Adapted_Clutchpoint_K2_Of_Kisspoint_Adaption 0.245 A
IDE03184-ENG120928 Upper adapted coupling point K1 from microslip adaptation-Upper_Adapted_Clutchpoint_K1_Of_Microslip_Adaption 0.825 A
IDE03185-ENG120929 Upper adapted coupling point K2 from microslip adaptation-Upper_Adapted_Clutchpoint_K2_Of_Microslip_Adaption 0.75 A
IDE03189-ENG110507 Number of prevented stop processes (statistics)-Anzahl Stoppverbote 0
IDE03189-ENG110509 Number of prevented stop processes (statistics)-Gründe für Stoppverbot not active
IDE03189-ENG110508 Number of prevented stop processes (statistics)-km-Stand des letzten Stoppverbots 0 km
IDE04612-ENG101246 Clutch temperature air / splash oil-Centrifugal oil temperature 38 °C
IDE04805-ENG98547 Driving profile selection-Driving program Available
IDE04805-ENG98560 Driving profile selection-Free run not_available
IDE05987-ENG110507 Engine stop prohibitions-Anzahl Stoppverbote 0
IDE05987-ENG110509 Engine stop prohibitions-Gründe für Stoppverbot not active
IDE05987-ENG110508 Engine stop prohibitions-km-Stand des letzten Stoppverbots 0 km
IDE05988-ENG110505 Pressure of clutch 2: actual value-Clutch_2_actual_value 0.07 bar
IDE05989-ENG110503 Pressure of clutch 1: actual value-Clutch_1_actual_value 0.11 bar
IDE06425 Roller test bench mode: functional not activated
IDE80001-ENG100467 Analysis 1-Snapshot 1 Failure ID 65535
IDE80002-ENG102386 Analysis 2-Snapshot 1 Mileage 0 km
IDE80003-ENG101467 Analysis 3-Snapshot 1 Counter 0
IDE80005-ENG103330 Analysis 5-Snapshot 1 Shift Position Plausible ERROR
IDE80007-ENG101090 Analysis 7-Snapshot 1 Commanded Gear GANG N
IDE80008-ENG100048 Analysis 8-Snapshot 1 Preselection Gear GANG N
IDE80009-ENG102100 Analysis 9-Snapshot 1 Transmission Input Speed 0 /min
IDE80010-ENG101565 Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1 0 /min
IDE80011-ENG100379 Analysis 11-Snapshot 1 Transmission Speed Shaft 1 0 /min
IDE80012-ENG103459 Analysis 12-Snapshot 1 Transmission Speed Shaft 2 0 /min
IDE80021-ENG102762 Analysis 21-Snapshot 1 Clutch 1 Actual Pressure 0 bar
IDE80022-ENG100347 Analysis 22-Snapshot 1 Clutch 2 Actual Pressure 0 bar
IDE80023-ENG99119 Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value 0 mA
IDE80024-ENG101123 Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value 0 mA
IDE80025-ENG103611 Analysis 25-Snapshot 1 Accelerator Pedal Position 0 %
IDE80026-ENG101503 Analysis 26-Snapshot 1 Engine torque -50 Nm
IDE80029-ENG103070 Analysis 29-Snapshot 1 Voltage Terminal 15 0 V
IDE80031-ENG102899 Analysis 31-Snapshot 1 Transmission Fluid Temperature -60 °C
IDE80033-ENG103098 Analysis 33-Snapshot 2 Failure ID 65535
IDE80034-ENG101047 Analysis 34-Snapshot 2 Mileage 0 km
IDE80035-ENG99915 Analysis 35-Snapshot 2 Counter 0
IDE80037-ENG99369 Analysis 37-Snapshot 2 Shift Position Plausible ERROR
IDE80039-ENG101369 Analysis 39-Snapshot 2 Commanded Gear GANG N
IDE80040-ENG103638 Analysis 40-Snapshot 2 Preselection Gear GANG N
IDE80041-ENG103367 Analysis 41-Snapshot 2 Transmission Input Speed 0 /min
IDE80042-ENG102476 Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1 0 /min
IDE80043-ENG102699 Analysis 43-Snapshot 2 Transmission Speed Shaft 1 0 /min
IDE80044-ENG101900 Analysis 44-Snapshot 2 Transmission Speed Shaft 2 0 /min
IDE80053-ENG102973 Analysis 53-Snapshot 2 Clutch 1 Actual Pressure 0 bar
IDE80054-ENG100122 Analysis 54-Snapshot 2 Clutch 2 Actual Pressure 0 bar
IDE80055-ENG103189 Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value 0 mA
IDE80056-ENG103616 Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value 0 mA
IDE80057-ENG102447 Analysis 57-Snapshot 2 Accelerator Pedal Position 0 %
IDE80058-ENG103198 Analysis 58-Snapshot 2 Engine torque -50 Nm
IDE80061-ENG101449 Analysis 61-Snapshot 2 Voltage Terminal 15 0 V
IDE80063-ENG104157 Analysis 63-Snapshot 2 Transmission Fluid Temperature -60 °C
IDE80065-ENG122555 Analysis 65-Snapshot 1 Weg Gangsteller 1-3 0
IDE80065-ENG122556 Analysis 65-Snapshot 1 Weg Gangsteller 2-4 0
IDE80065-ENG122557 Analysis 65-Snapshot 1 Weg Gangsteller 5-N 0
IDE80065-ENG122558 Analysis 65-Snapshot 1 Weg Gangsteller 6-R 0
IDE80066-ENG122559 Analysis 66-Snapshot 2 Weg Gangsteller 1-3 0
IDE80066-ENG122560 Analysis 66-Snapshot 2 Weg Gangsteller 2-4 0
IDE80066-ENG122561 Analysis 66-Snapshot 2 Weg Gangsteller 5-N 0
IDE80066-ENG122562 Analysis 66-Snapshot 2 Weg Gangsteller 6-R 0
IDE80071-ENG127839 Analysis 71-FID event memory entry 1 FF FF
IDE80071-ENG127848 Analysis 71-FID event memory entry 10 FF FF
IDE80071-ENG127849 Analysis 71-FID event memory entry 11 FF FF
IDE80071-ENG127850 Analysis 71-FID event memory entry 12 FF FF
IDE80071-ENG127840 Analysis 71-FID event memory entry 2 FF FF
IDE80071-ENG127841 Analysis 71-FID event memory entry 3 FF FF
IDE80071-ENG127842 Analysis 71-FID event memory entry 4 FF FF
IDE80071-ENG127843 Analysis 71-FID event memory entry 5 FF FF
IDE80071-ENG127844 Analysis 71-FID event memory entry 6 FF FF
IDE80071-ENG127845 Analysis 71-FID event memory entry 7 FF FF
IDE80071-ENG127846 Analysis 71-FID event memory entry 8 FF FF
IDE80071-ENG127847 Analysis 71-FID event memory entry 9 FF FF
IDE80296-ENG127853 Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter 1583
IDE80298-ENG127880 Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter 1306
IDE80302-ENG122492 Selector lever information-Datenstand 17
IDE80302-ENG111628 Selector lever information-Part Number 8V1713023G
IDE80302-ENG98856 Selector lever information-Programmability 0
IDE80302-ENG122491 Selector lever information-Programm-Stand VL
IDE80303-ENG127833 Overall software description-Software full name F45M
IDE80304-ENG120779 Mechatronics identification DQ250-Änderungsstand BorgWarner 58
IDE80304-ENG120778 Mechatronics identification DQ250-Mechatronik-Identifikation R12F2198
IDE80305-ENG125922 Parameter set description-Data set name 0D9300012K_4515_NlJF
IDE80312-ENG122524 CAN bus installation information-ACC_06 Unknown
IDE80312-ENG122528 CAN bus installation information-BEM_05 installed
IDE80312-ENG113024 CAN bus installation information-Charisma_01 installed
IDE80312-ENG122522 CAN bus installation information-EPB_01 installed
IDE80312-ENG122525 CAN bus installation information-GRA_ACC_01 installed
IDE80312-ENG122511 CAN bus installation information-TSK_06 installed
ENG120958 Abbruchcode GSA_ABBRUCH_CODE_OK
ENG122365-ENG104207 Abschaltpfadtest Fehlerursache aus dem SCM-Bit 0 Abschalten ENA erfolgreich
ENG122365-ENG102209 Abschaltpfadtest Fehlerursache aus dem SCM-Bit 1 Abschalten WDA erfolgreich
ENG122365-ENG99197 Abschaltpfadtest Fehlerursache aus dem SCM-Bit 2 EInschalten Endstufen erfolgreich
ENG122365-ENG102937 Abschaltpfadtest Fehlerursache aus dem SCM-Bit 3 Keine Unterspannung im Abschaltpfadtest
ENG122363 Abschaltpfadtest Maximaler AD-Wert im Off-Fall 304
ENG122364 Abschaltpfadtest Minimaler AD-Wert im On-Fall 580
ENG120920 Abtriebsdrehzahl CAN 0 /min
ENG98625-ENG103724 Accelerator position: qualification-Accelerator pedal position: qualification OK
ENG100091 Ambient temperature 23 °C
ENG120963 Anzahl der Überschreitungen der zulässigen Schleuderöltemperatur 0
ENG120964 Anzahl der Warnungen aufgrund erhöhter Schleuderöltemperatur 0
ENG122366 Anzahl der wegen Unterspannung abgebrochenen Abschaltpfadtests 5817
ENG120970 Anzahl Ereignisse auf K1 0
ENG120972 Anzahl Ereignisse auf K2 0
ENG98482-ENG99180 Checksum of flash-Calibration Checksumme A5 ED D5 3A
ENG98482-ENG100495 Checksum of flash-Cboot Checksumme 31 82 84 67
ENG98482-ENG100117 Checksum of flash-Checksumme ECU + CAL 00 00 E2 45
ENG98482-ENG102221 Checksum of flash-ECU Checksumme 5F AC DE 77
ENG110530 Clutch 1 adaption kiss point part 1 fault counter 0
ENG110536 Clutch 2 adaption kiss point part 1 fault counter 0
ENG99212 Common highside 1 specified condition Common Highside soll eingeschaltet werden
ENG99878 Common highside 2 specified condition Common Highside soll eingeschaltet werden
ENG103403 Converter Loss Torque 6.1 Nm
ENG100625 Coolant temperature 67 °C
ENG98602 Driver request torque 12 Nm
ENG100746 Driving strategy: sport factor 0 %
ENG120931 Eingelegtposition Seite A: Gangsteller 1-3 0 %
ENG120932 Eingelegtposition Seite A: Gangsteller 2-4 0 %
ENG120933 Eingelegtposition Seite A: Gangsteller 5-N 0 %
ENG120934 Eingelegtposition Seite A: Gangsteller 6-R 0 %
ENG120943 Eingelegtposition Seite B: Gangsteller 1-3 0 %
ENG120944 Eingelegtposition Seite B: Gangsteller 2-4 0 %
ENG120945 Eingelegtposition Seite B: Gangsteller 5-N 0 %
ENG120946 Eingelegtposition Seite B: Gangsteller 6-R 0 %
ENG101251 Empty Empty
ENG98756 Engine torque 12 Nm
ENG104230 Engine torque loss -21 Nm
ENG123019-ENG99024 Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission 0 km/h
ENG120799 Gangsteller A Adaption Flags 00 1F
ENG120808 Gangsteller B Adaption Flags 00 1F
ENG120817 Gangsteller C Adaption Flags 00 15
ENG120826 Gangsteller D Adaption Flags 00 1F
ENG121005 Gangsteller Synchronposition G1 (Prozent) 55.61 %
ENG121006 Gangsteller Synchronposition G2 (Prozent) 45.41 %
ENG121007 Gangsteller Synchronposition G3 (Prozent) 46.08 %
ENG121008 Gangsteller Synchronposition G4 (Prozent) 54.99 %
ENG121009 Gangsteller Synchronposition G5 (Prozent) 53.89 %
ENG121010 Gangsteller Synchronposition G6 (Prozent) 54.41 %
ENG121011 Gangsteller Synchronposition GR (Prozent) 46.65 %
ENG120961 Gangsteller_Index GS_13
ENG120962 Gangsteller_Seite Neutrallage
ENG120957 Gangstellerposition zum Zeitpunkt eines Abbruchs Neutral
ENG120969 Gefahrene km seit letztem Ereignis auf K1 30 km
ENG120971 Gefahrene km seit letztem Ereignis auf K2 30 km
ENG99720 Height info 994 mbar
ENG98604 Hill factor driving strategy 0 %
ENG99596 Indicated engine torque without external interventions 33 Nm
ENG99582 Intake air temperature 2 °C
ENG122357-ENG122524 Kommunikationsstatus Datenbus 1 MQB-ACC_06 Unknown
ENG122357-ENG122528 Kommunikationsstatus Datenbus 1 MQB-BEM_05 received
ENG122357-ENG113024 Kommunikationsstatus Datenbus 1 MQB-Charisma_01 received
ENG122357-ENG122523 Kommunikationsstatus Datenbus 1 MQB-Diagnose_01 received
ENG122357-ENG122522 Kommunikationsstatus Datenbus 1 MQB-EPB_01 received
ENG122357-ENG122513 Kommunikationsstatus Datenbus 1 MQB-ESP_02 received
ENG122357-ENG122514 Kommunikationsstatus Datenbus 1 MQB-ESP_05 received
ENG122357-ENG110808 Kommunikationsstatus Datenbus 1 MQB-ESP_07 received
ENG122357-ENG122515 Kommunikationsstatus Datenbus 1 MQB-ESP_10 Unknown
ENG122357-ENG122516 Kommunikationsstatus Datenbus 1 MQB-ESP_19 received
ENG122357-ENG122517 Kommunikationsstatus Datenbus 1 MQB-ESP_20 received
ENG122357-ENG122518 Kommunikationsstatus Datenbus 1 MQB-ESP_21 received
ENG122357-ENG122519 Kommunikationsstatus Datenbus 1 MQB-Gateway_72 received
ENG122357-ENG122520 Kommunikationsstatus Datenbus 1 MQB-Gateway_74 received
ENG122357-ENG122525 Kommunikationsstatus Datenbus 1 MQB-GRA_ACC_01 received
ENG122357-ENG00240 Kommunikationsstatus Datenbus 1 MQB-Klemmen_Status_01 received
ENG122357-ENG110802 Kommunikationsstatus Datenbus 1 MQB-Kombi_01 received
ENG122357-ENG122521 Kommunikationsstatus Datenbus 1 MQB-Kombi_02 received
ENG122357-ENG110799 Kommunikationsstatus Datenbus 1 MQB-LWI_01 received
ENG122357-ENG122512 Kommunikationsstatus Datenbus 1 MQB-Motor_04 received
ENG122357-ENG122502 Kommunikationsstatus Datenbus 1 MQB-Motor_07 received
ENG122357-ENG122503 Kommunikationsstatus Datenbus 1 MQB-Motor_11 received
ENG122357-ENG122504 Kommunikationsstatus Datenbus 1 MQB-Motor_12 received
ENG122357-ENG122505 Kommunikationsstatus Datenbus 1 MQB-Motor_14 received
ENG122357-ENG122506 Kommunikationsstatus Datenbus 1 MQB-Motor_16 received
ENG122357-ENG122507 Kommunikationsstatus Datenbus 1 MQB-Motor_17 received
ENG122357-ENG122529 Kommunikationsstatus Datenbus 1 MQB-Motor_18 received
ENG122357-ENG122508 Kommunikationsstatus Datenbus 1 MQB-Motor_20 received
ENG122357-ENG122509 Kommunikationsstatus Datenbus 1 MQB-Motor_26 Unknown
ENG122357-ENG06581 Kommunikationsstatus Datenbus 1 MQB-Motor_35 Unknown
ENG122357-ENG122510 Kommunikationsstatus Datenbus 1 MQB-Motor_Code_01 received
ENG122357-ENG122526 Kommunikationsstatus Datenbus 1 MQB-OBD_01 received
ENG122357-ENG122511 Kommunikationsstatus Datenbus 1 MQB-TSK_06 received
ENG122357-ENG122527 Kommunikationsstatus Datenbus 1 MQB-Waehlhebel_03 received
ENG121002 Korrekturwerte Hauptdruckadaption: großer Druck auf K1 0.75 bar
ENG121004 Korrekturwerte Hauptdruckadaption: großer Druck auf K2 0.85 bar
ENG121001 Korrekturwerte Hauptdruckadaption: kleiner Druck auf K1 0.8 bar
ENG121003 Korrekturwerte Hauptdruckadaption: kleiner Druck auf K2 0.75 bar
ENG99297 Kupplung 1 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl 0
ENG100826 Kupplung 2 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl 0
ENG120965 Kupplungsadaptionswerte: IKp0 fuer K1 270 mA
ENG120966 Kupplungsadaptionswerte: IKp0 fuer K2 245 mA
ENG120967 Kupplungsadaptionswerte: unterer Strompunkt Adaption K1 225 mA
ENG120968 Kupplungsadaptionswerte: unterer Strompunkt Adaption K2 225 mA
ENG110556-ENG110541 Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung 0
ENG110556-ENG110542 Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß 0
ENG110556-ENG110543 Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein 0
ENG110556-ENG120771 Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen 23945
ENG110557-ENG110545 Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung 0
ENG110557-ENG110546 Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß 0
ENG110557-ENG110547 Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein 0
ENG110557-ENG110544 Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen 15574
ENG120996 Maximale Spannung an UH1 9.2 V
ENG120998 Maximale Spannung an UH2 4.9 V
ENG120995 Minimale Spannung an UH1 0.2 V
ENG120997 Minimale Spannung an UH2 4.9 V
ENG111613-ENG101555 Motordrehmoment Begrenzung-Engine torque limitation 320 Nm
ENG120939 Neutralposition: Gangsteller 1-3 50.77 %
ENG120940 Neutralposition: Gangsteller 2-4 50.07 %
ENG120941 Neutralposition: Gangsteller 5-N 50.25 %
ENG120942 Neutralposition: Gangsteller 6-R 50.75 %
ENG120993 Oberer adaptierter Kupplungspunkt K1 aus Makroschlupfadaption 825 mA
ENG120994 Oberer adaptierter Kupplungspunkt K2 aus Makroschlupfadaption 750 mA
ENG105329-ENG101124 Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1) 489 H
ENG105329-ENG100216 Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2) 37.2 H
ENG105329-ENG103067 Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3) 0 H
ENG105329-ENG101168 Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4) 0 H
ENG105329-ENG104150 Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5) 0 H
ENG105329-ENG100130 Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6) 0 H
ENG120987 Ratio FID 256 100 %
ENG120989 Ratio FID 257 100 %
ENG120988 Ratio FID 330 100 %
ENG120990 Ratio FID 333 100 %
ENG120975 Ratio FID 52 100 %
ENG120976 Ratio FID 53 100 %
ENG120977 Ratio FID 54 100 %
ENG120978 Ratio FID 55 100 %
ENG120986 Ratio FID 56 100 %
ENG120973 Ratio FID 57 100 %
ENG120974 Ratio FID 58 100 %
ENG120979 Ratio FID 78 100 %
ENG120980 Ratio FID 79 100 %
ENG120981 Ratio FID 80 100 %
ENG120982 Ratio FID 81 100 %
ENG120983 Ratio FID 82 100 %
ENG120984 Ratio FID 83 100 %
ENG120985 Ratio FID 84 100 %
ENG100188 Reached maximum temperature control module 112 °C
ENG123020-ENG102793 Rollwiderstand-Road Resistance 0 %
ENG102748 Selector lever error flags 00 00
ENG122375-ENG122573 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag ABS-Flag nicht gesetzt
ENG122375-ENG122571 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag ASR-Flag nicht gesetzt
ENG122375-ENG122570 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag CHS1 oder CHS2 oder beide ausgeschaltet
ENG122375-ENG122574 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag EDS-Flag nicht gesetzt
ENG122375-ENG122575 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag FDR-Flag nicht gesetzt
ENG122375-ENG122563 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag GV1-Flag nicht gesetzt
ENG122375-ENG122564 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag GV2-Flag nicht gesetzt
ENG122375-ENG122565 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag GV3-Flag nicht gesetzt
ENG122375-ENG122566 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag GV4-Flag nicht gesetzt
ENG122375-ENG122569 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag MPX-Flag nicht gesetzt
ENG122375-ENG122572 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag MSR-Flag nicht gesetzt
ENG122375-ENG122567 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag SV1-Flag nicht gesetzt
ENG122375-ENG122568 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag SV2-Flag nicht gesetzt
ENG122375-ENG122576 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag Tipp-Gasse-Flag nicht gesetzt
ENG122375-ENG122578 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag Tipp-hoch-Flag nicht gesetzt
ENG122375-ENG122577 Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag Tipp-runter-Flag nicht gesetzt
ENG122369 Snapshot 1 Iststrom Hauptdruckventil 0 mA
ENG122367 Snapshot 1 Kupplungszustand New
ENG122371 Snapshot 1 unterer Strompunkt Adaption K1 0 mA
ENG122372 Snapshot 1 unterer Strompunkt Adaption K2 0 mA
ENG122376-ENG122573 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag ABS-Flag nicht gesetzt
ENG122376-ENG122571 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag ASR-Flag nicht gesetzt
ENG122376-ENG122570 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag CHS1 oder CHS2 oder beide ausgeschaltet
ENG122376-ENG122574 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag EDS-Flag nicht gesetzt
ENG122376-ENG122575 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag FDR-Flag nicht gesetzt
ENG122376-ENG122563 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag GV1-Flag nicht gesetzt
ENG122376-ENG122564 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag GV2-Flag nicht gesetzt
ENG122376-ENG122565 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag GV3-Flag nicht gesetzt
ENG122376-ENG122566 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag GV4-Flag nicht gesetzt
ENG122376-ENG122569 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag MPX-Flag nicht gesetzt
ENG122376-ENG122572 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag MSR-Flag nicht gesetzt
ENG122376-ENG122567 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag SV1-Flag nicht gesetzt
ENG122376-ENG122568 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag SV2-Flag nicht gesetzt
ENG122376-ENG122576 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag Tipp-Gasse-Flag nicht gesetzt
ENG122376-ENG122578 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag Tipp-hoch-Flag nicht gesetzt
ENG122376-ENG122577 Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag Tipp-runter-Flag nicht gesetzt
ENG122370 Snapshot 2 Iststrom Hauptdruckventil 0 mA
ENG122368 Snapshot 2 Kupplungszustand New
ENG122373 Snapshot 2 unterer Strompunkt Adaption K1 0 mA
ENG122374 Snapshot 2 unterer Strompunkt Adaption K2 0 mA
ENG120921 Sollgang der Fahrstrategie R
ENG101057 Specified idle speed 700 /min
ENG100803 Speed: output 0 /min
ENG122358 Start Stopp Statusinformationen aktuell not active
ENG122358-ENG122500 Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 1 0
ENG122358-ENG122501 Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 2 0
ENG120924 Strom oberer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption 1000 mA
ENG120926 Strom oberer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption 1000 mA
ENG120923 Strom unterer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption 225 mA
ENG120925 Strom unterer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption 225 mA
ENG120935 Synchronposition Seite A: Gangsteller 1-3 46.08 %
ENG120936 Synchronposition Seite A: Gangsteller 2-4 45.41 %
ENG120937 Synchronposition Seite A: Gangsteller 5-N 50.24 %
ENG120938 Synchronposition Seite A: Gangsteller 6-R 46.65 %
ENG120947 Synchronposition Seite B: Gangsteller 1-3 55.61 %
ENG120948 Synchronposition Seite B: Gangsteller 2-4 54.99 %
ENG120949 Synchronposition Seite B: Gangsteller 5-N 53.89 %
ENG120950 Synchronposition Seite B: Gangsteller 6-R 54.41 %
ENG120999 Tastverhältnis Sicherheitsventil 1 18 %
ENG121000 Tastverhältnis Sicherheitsventil 2 18 %
ENG120991 Unterer adaptierter Kupplungspunkt K1 aus Mikroschlupfadaption 260 mA
ENG120992 Unterer adaptierter Kupplungspunkt K2 aus Mikroschlupfadaption 220 mA
ENG120960 Unterzustand Gangstelleradaption Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
ENG120956 Unterzustand Gangstelleradaption zum Zeitpunkt eines Abbruchs Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
ENG101346 Version info driving strategy Temic
ENG109005 Voltage Common Highside 1 13.7 V
ENG99955 Voltage Common Highside 2 13.8 V
ENG120922 Vorwahlgang der Fahrstrategie 2
ENG120952 Zählerstände der Hauptdruckadaption:Abbruchzähler auf K1 0
ENG120954 Zählerstände der Hauptdruckadaption:Abbruchzähler auf K2 0
ENG120951 Zählerstände der Hauptdruckadaption:Erfolgszähler auf K1 1929
ENG120953 Zählerstände der Hauptdruckadaption:Erfolgszähler auf K2 1626
ENG120959 Zustand Gangstelleradaption Synchron_GSA_AUS
ENG120955 Zustand Gangstelleradaption zum Zeitpunkt eines Abbruchs Synchron_GSA_AUS
Elapsed Time: 00:20
IDE00021-ENG99543 Engine speed-Engine RPM 701 /min
IDE00022-ENG103074 Transmission input speed-Transmission Input Speed Sensor 701 /min
IDE00024 Transmission fluid temperature 44 °C
IDE00102-ENG102028 Control Module temperature-Control modul temperature 49 °C
IDE00872-ENG102188 Current of main pressure valve-Oil Pressure Actual Current 819.6 mA
IDE02806-ENG103118 Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value 0 mA
IDE02864-ENG99505 Actual position of gear positioner A-Gearpositioner A Actual Position 0.13 mm
IDE02865-ENG104121 AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1 2087
IDE02873-ENG101728 AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1 1057
IDE02880-ENG103036 Actual position of gear positioner C-Gearpositioner C Actual Position -0.15 mm
IDE02881-ENG99453 AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1 2075
IDE02888-ENG103826 Actual position of gear positioner D-Gearpositioner D Actual Position -8.1 mm
IDE02889-ENG100525 AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1 1222
IDE04612-ENG101246 Clutch temperature air / splash oil-Centrifugal oil temperature 44 °C
IDE05988-ENG110505 Pressure of clutch 2: actual value-Clutch_2_actual_value 0.06 bar
IDE05989-ENG110503 Pressure of clutch 1: actual value-Clutch_1_actual_value 0.08 bar
ENG103403 Converter Loss Torque 5.1 Nm
ENG100625 Coolant temperature 110 °C
ENG98602 Driver request torque 5 Nm
ENG98756 Engine torque 6 Nm
ENG104230 Engine torque loss -20 Nm
ENG99596 Indicated engine torque without external interventions 25 Nm
ENG105329-ENG101124 Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1) 489.2 H
ENG109005 Voltage Common Highside 1 13.9 V
Elapsed Time: 00:20
Address 02: Auto Trans (0D9 300 012 K)
18:40:20
IDE00021-ENG99543 Engine speed-Engine RPM 696 /min
IDE00024 Transmission fluid temperature 48 °C
IDE00102-ENG102028 Control Module temperature-Control modul temperature 53 °C
IDE00322-ENG100540 Status of basic setting-Basic Settings Status 16
IDE02713 Brake Light Switch operated
IDE02714 Brake test switch operated
Address 02: Auto Trans Labels: 0D9-927-770.CLB
Control Module Part Number: 0D9 300 012 K HW: 02E 927 770 AQ
Component and/or Version: DQ250-6A MQB H53 4515
Software Coding: 0014
Work Shop Code: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001 (AU37)
ROD: EV_TCMDQ250021.rod
10732 - Valve 3 in Transmission Part 2
P174E 00 [002] - Electrical malfunction
10909 - Cooling Oil Valve
10906 - Cooling Oil Valve
Address 02: DTCs cleared
Fault Codes have been Erased
IDE00021-ENG99543 Engine speed-Engine RPM 704 /min
IDE00022-ENG103074 Transmission input speed-Transmission Input Speed Sensor 705 /min
IDE00095-ENG101643 Status of selector lever lock-Status Shift Lock not active
IDE00102-ENG102028 Control Module temperature-Control modul temperature 55 °C
IDE00872-ENG102188 Current of main pressure valve-Oil Pressure Actual Current 819.2 mA
IDE02797-ENG100730 Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value 0.6 mA
IDE02864-ENG99505 Actual position of gear positioner A-Gearpositioner A Actual Position 0.16 mm
IDE02872-ENG102218 Actual position of gear adjuster B-Gearpositioner B Actual Position -8.47 mm
IDE02873-ENG101728 AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1 1036
IDE02881-ENG99453 AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1 2074
IDE02888-ENG103826 Actual position of gear positioner D-Gearpositioner D Actual Position -8.43 mm
IDE02889-ENG100525 AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1 1214
IDE04612-ENG101246 Clutch temperature air / splash oil-Centrifugal oil temperature 48 °C
ENG103403 Converter Loss Torque 4.4 Nm
ENG100625 Coolant temperature 111 °C
ENG98602 Driver request torque 3 Nm
ENG120931 Eingelegtposition Seite A: Gangsteller 1-3 26.12 %
ENG120932 Eingelegtposition Seite A: Gangsteller 2-4 24.7 %
ENG120934 Eingelegtposition Seite A: Gangsteller 6-R 28.96 %
ENG120943 Eingelegtposition Seite B: Gangsteller 1-3 78.38 %
ENG120944 Eingelegtposition Seite B: Gangsteller 2-4 74.27 %
ENG120945 Eingelegtposition Seite B: Gangsteller 5-N 76.45 %
ENG120946 Eingelegtposition Seite B: Gangsteller 6-R 77.4 %
ENG98756 Engine torque 4 Nm
ENG104230 Engine torque loss -23 Nm
ENG120962 Gangsteller_Seite Seite A
ENG99596 Indicated engine torque without external interventions 26 Nm
ENG111613-ENG101555 Motordrehmoment Begrenzung-Engine torque limitation 319 Nm
ENG105329-ENG101124 Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1) 489.4 H
ENG120960 Unterzustand Gangstelleradaption Eingelegt_GSA_SUB_SYNC_ADAPTION_SETZEMPX
ENG120956 Unterzustand Gangstelleradaption zum Zeitpunkt eines Abbruchs Eingelegt_GSA_SUB_EING_ADAPTION_GANG_AUSL_WARTEN
ENG120955 Zustand Gangstelleradaption zum Zeitpunkt eines Abbruchs Eingelegt_GSA_FERTIG
Elapsed Time: 00:20
I'd like to add that I did this last night and the transmission is running smoother this morning after some adaptation.
Note that once reset, there will be a bunch of intermittent codes (like stated above) that while reset-able, will reappear (in my case) until the DSG transmission has been driven for some miles.
Background is:
'17 MK7R DSG, 1800 miles
Installed JB1 @ 5.0 for 4 days. Had a slight hint at slip (4th) followed by harsh shifting (all around).
Took off JB1, RESET DSG per above. I haven't checked DSG Fluid level, but car feels right again.
I think I'll drive stock for a while.
