Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 009571 - Turbocharger Boost Control Position Sensor Circuit P2563
    Hi I'm new to the forum and relatively new to the VCDS. I've been using it to prime the fuel lines after changing the fuel filters on both of my TDI's. I've also used it to service the DSG on my mother's golf tdi but I haven't tried to do a lot of diagnostic things with it because the cars are all relatively new. Yesterday my wife had a CEL on her 2010 Jetta TDI with 60,000 miles on it. When I look up the code and google around a little bit I get a turbo actuator issue. VW makes a kit to replace the turbo actuator part number 03L198716A. The car isn't suffering from any kind of limp mode condition or lack of power the only indication that there is any kind of an issue is the CEL. Is there a way to test the actuator with the VCDS? I know I can go to select --> 01 engine --> 08 --> measuring blocks --> choose 11 and graph it but I'm not really sure what I'm looking at or what I'm looking for? Also the bently manual talks about measuring the resistance on the g851 circuit or the voltage coming out of the connector but I can't find in the manual what readings I should be getting from the meter. Below are the results from my auto scan any help would be greatly appreciated.
    Wednesday,10,October,2012,21:07:14:18333
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
    VIN: 3VWAL7AJ7AM052216
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
       Component: R4 2,0L EDC G000SG  7966
       Revision: 12H02---    Serial number:
       Coding: 0050072
       Shop #: WSC 08230 444 83945
       VCID: 77F7D54B068AD9A010F
    Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Revision: 00H45001
       Coding: 114B400C492700FC880D02E5921F00423000
       VCID: 7EF9C06FE9B0E8E8539
       Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
       Component: Climatic      H13 0203
       Revision: 00006001
       Coding: 0000000000
       Shop #: WSC 00066 000 00185
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_Climatic_VW36.rod
       VCID: 38751677831416D8D95
       Part No SW: 5K0 937 085 C    HW: 5K0 937 085 C
       Component: BCM PQ35 B++  008 0019
       Revision: BI008001
       Coding: 6D200B1A902F3EE4800800054000000401000086510085605C8020000000
       VCID: 336F215B9272F580EC7
       Component: Wischer 20100  21  0501
       Coding: 009795
                000 -  -  - Intermittent
                        Reset counter: 7
                        Mileage: 58173 km
                        Date: 2096.14.11
                        Time: 20:09:50
                            Term 15 Off
                        Voltage: 12.15 V
       Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
       Component: 04 AIRBAG VW8R  036 8900
       Revision: 06036000    Serial number: 003EVM01CA3A
       Coding: 0012340
       VCID: 6ED9F02F79D09868C39
       Part No: 1K0 959 339 H
       Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
       Component: J0527           056 0111
       Coding: 0000731
       VCID: 76E9D84F0180A0A80B9
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
       Part No SW: 5M0 920 970 C    HW: 5M0 920 970 C
       Component: KOMBI         H08 0021
       Revision: V0008011    Serial number:
       Coding: 271F00
       Shop #: WSC 00066 000 00146
       ASAM Dataset: EV_KombiUDSMM9RM10 A04010
       ROD: EV_KombiUDSMM9RM10_VW36.rod
       VCID: 30652E576B64CE98915
    13701120 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 41
                        Time: 00:00:00
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 270809F2000343
       Coding: E9807F07001602001002
       VCID: 66C9880F51205028BB9
       Part No SW: 1K5 919 965 D    HW: 1K5 919 965 D
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1293324T4FZF05
       Coding: 0000004
       VCID: 3C7D0A677F2C3AF83DD
       Component: IMMO          H08 0021
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
       ROD: EV_ImmoUDSMM9RM10_VW36.rod
       Component: J386  TUER-SG FT    1525
       Revision: 72009005    Serial number: 00000876698923
       Coding: 0001205
       VCID: 6FE7ED2B7EDA9160C8F
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 70     2901
       Revision: 00H17000
       VCID: 2F672D2BBE5AD16088F
                000 -  -  - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.4 V
                            PD
                        Temperature: 30.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
       Component: J387  TUER-SG BT    1525
       Revision: 72009005    Serial number: 09071109230803
       Coding: 0001204
       VCID: 70E5EE5763E48E98D15
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H10 0035
       Revision: -----20S    Serial number: VWZ4Z7J3033852
       Coding: 0500040004
       VCID: 61C39B13780E37104EB
       Revision: 12006001    Serial number: 00000004410039
       Coding: 0001168
    Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
       Component: RDK           008 0817
       Coding: 018705
    02904 - Hard Warning 3
                        Mileage: 39456 km
                        Date: 2023.14.30
                        Time: 07:34:21
                        Text: 3445517757
                        Pressure: 1.90 bar
                        Pressure: 2.40 bar
                        Temperature: 1.2C
                        Text: 00
                        Speed: 18.0 km/h
       Revision: 12006001    Serial number: 00000004302874
       Coding: 0001168
    Address 77: Telephone        Labels: 5P0-862-335.lbl
       Part No SW: 1Z0 035 729 C    HW: 1Z0 035 729 C
       Component: FSE_2P8x        H35 0170
       Revision: 00000000    Serial number: 00000005068440
       Coding: 0011070
       VCID: 387516774B1416D8D95
    Monday,18,February,2013,22:11:48:18333
    VCDS Version: Release 11.11.5 (x64)
    Data version: 20121222
    Chassis Type: 1K0
       Coding: 0050072
       VCID: 77F7D54B068AD9A0106
       Revision: 00H45001
       Shop #: WSC 00066 123 12345
       VCID: 7EF9C06FE9B0E8E8530
       Revision: 00006001
       Coding: 0000000000
       VCID: 38751677831416D8D9C
    9479441 - Control Circuit for Front Right Seat Heater
              B10A5 11 [008] - Short to Ground
                        Reset counter: 211
                        Mileage: 69595 km
                        Date: 2037.14.01
                        Time: 17:33:33
    9479697 - Control Circuit for Front Left Seat Heater
              B10A6 11 [008] - Short to Ground
                        Reset counter: 234
                        Mileage: 67731 km
                        Date: 2036.14.04
                        Time: 08:02:42
       Revision: BI008001
       Coding: 6F200B1A902F3EE4800800054000000401000086510085605C8020000000
       VCID: 336F215B9272F580ECE
       Coding: 009795
                        Reset counter: 239
                        Mileage: 69777 km
                        Date: 2101.14.08
                        Time: 13:19:06
                            Term 15 Off
                        Voltage: 12.15 V
       Coding: 0012340
       VCID: 6ED9F02F79D09868C30
       Coding: 0000731
       VCID: 76E9D84F0180A0A80B0
       Coding: 00000130
       Coding: 271F00
       VCID: 30652E576B64CE9891C
       VCID: 66C9880F51205028BB0
       Coding: 0000004
       VCID: 3C7D0A677F2C3AF83D4
       Coding: 0001205
       VCID: 6FE7ED2B7EDA9160C86
       Revision: 00H17000
       VCID: 2F672D2BBE5AD160886
       Coding: 0001204
       VCID: 70E5EE5763E48E98D1C
       Coding: 0500040004
       VCID: 61C39B13780E37104E2
       Coding: 0001168
       Coding: 018705
       Coding: 0001168
       Coding: 0011070
       VCID: 387516774B1416D8D9C
                        Reset counter: 211
                        Mileage: 69612 km
                        Date: 2101.14.04
                        Time: 07:57:00
    Wednesday,23,April,2014,19:55:58:18333
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: 3VWAL7AJ7AM052216   License Plate:
    Chassis Type: AJ (1K0)
       Coding: 0050072
       VCID: 77F7D54B068AD9A6AAD-8022
                   P2563 - 000 - Implausible Signal - Intermittent - MIL ON
                        Fault Status: 10100000
                        Fault Frequency: 7
                        Mileage: 96897 km
                        Date: 2051.14.05
                        Time: 18:51:11
                        RPM: 897 /min
                        Speed: 1.0 km/h
                        Voltage: 13.98 V
                        Temperature: 192.0C
                        Lambda: -29.2 %
                        Bin. Bits: 00001110
                        Voltage: 1.824 V
    Readiness: 1 1 0 0 0
       Revision: 00H45001
       VCID: 7EF9C06FE9B0E8EEE9B-802B
       Revision: 00006001
       Coding: 0000000000
       ROD: EV_ClimaBasis_SE36.rod
       VCID: 38751677831416DE637-806D
       Revision: BI008001
       VCID: 336F215B9272F586565-8066
       Coding: 009795
       Coding: 0012340
       VCID: 6ED9F02F79D0986E79B-803B
       Subsystem 2 - Serial number: 6332MSME4A044C027
       Subsystem 3 - Serial number: 6342MSME4B114D0BH
       Subsystem 4 - Serial number: 6351HSME1D3725356
       Subsystem 5 - Serial number: 6361HSME1D3F3508G
       Subsystem 6 - Serial number: 63727SME00134730L
       Subsystem 7 - Serial number: 63827SME00216A7B+
       Coding: 0000731
       VCID: 76E9D84F0180A0AEB1B-8023
       Coding: 00000130
       Coding: 271F00
       VCID: 30652E576B64CE9E2B7-8065
       VCID: 66C9880F5120502E01B-8033
       Coding: 0000004
       VCID: 3C7D0A677F2C3AFE87F-8069
       ROD: EV_ImmoUDSMM9RM10_SE36.rod
       Coding: 0001205
       VCID: 6FE7ED2B7EDA916672D-803A
       Revision: 00H17000
       VCID: 2F672D2BBE5AD16632D-807A
       Coding: 0001204
       VCID: 70E5EE5763E48E9E6B7-8025
                        Fault Status: 00101100
                        Reset counter: 68
                        Mileage: 96522 km
                        Date: 2051.14.03
                        Time: 08:54:15
       Coding: 0500040004
       VCID: 61C39B13780E3716F49-8034
       Coding: 0001168
       Coding: 018705
       Coding: 0001168
       Coding: 0011070
       VCID: 387516774B1416DE637-806D
    Thursday,24,April,2014,21:43:27:18333
       Coding: 0050072
                   P2563 - 000 - Implausible Signal - MIL ON
                        Fault Frequency: 7
                        Mileage: 96922 km
                        Date: 2051.14.06
                        Time: 08:01:47
                        RPM: 1035 /min
                        Speed: 1.0 km/h
                        Voltage: 14.21 V
                        Temperature: 294.0C
                        Lambda: -26.0 %
                        Bin. Bits: 00001110
                        Voltage: 1.748 V
       Revision: 00H45001
       Revision: 00006001
       Coding: 0000000000
       Revision: BI008001
       Coding: 009795
       Coding: 0012340
       Coding: 0000731
       Coding: 00000130
       Coding: 271F00
       Coding: 0000004
       Coding: 0001205
       Revision: 00H17000
       Coding: 0001204
                        Reset counter: 68
                        Mileage: 96522 km
                        Date: 2051.14.03
                        Time: 08:54:15
       Coding: 0500040004
       Coding: 0001168
       Coding: 018705
       Coding: 0001168
       Coding: 0011070
    Last edited by Uwe; 04-25-2014 at 05:04 PM. Reason: Wrapped CODE tags around Auto-Scans
    Its possible the WG unit is bad, sticking on, or a wire from waste-gate to ecu is damaged or ecu faulty.
    Could even be contaminated with carbon slightly in turbo charger......... causing the rod to stick, and in some cases corroded at pivot point.
    I would observe block 011 and look at requested boost by the ecu verse actual. Look for things like the actual being slightly higher than request for a sticky gate.
    If it sticks on......it may not be enough to pend a deviation but could be an indication of a problem.
    Usually anything over 150/200 MBAR deviation will cause a deviation fault boost fault.
    It is possible if the turbo charger is adapted for the linearizer function it may help.
    Maybe someone from RT will give advise since I don't see mention in the wiki.
    United States
    The 2.0L CR TDI should use a G581 Vane Position Sensor (I believe you had a typo in the initial post) and Measuring Block Group # 034.2 and .3 will show you specified and actual positions. Those two fields should mirror each other, very similar to group 011 as Jack suggested.
    It looks like Eric's 2009 TDI Jetta had the following values at idle in 034:
    828 /min | 100.00% | 99.40% | 94.70%
    .. but sticky turbo issues aren't always obvious at idle. You may need to log that while driving and if you do please wrap the log and paste it here (wrapped in code).
    Stoke on Trent, England
    02903 - Hard Warning 2
    I've seen these codes recently but Google or Ross Tech Wiki doesn't show any results, what is it referring to?
    New User Keith
    Why are you asking about TPMS codes in a thread that's about Turbocharger codes?
    I'm just asking about jimmyfrack's first VCDS log with:
    Mileage: 39456 km
    Date: 2023.14.30
    Time: 07:34:21
    Its a Priority: 1 so it must be important. Ross Tech Wiki doesn't show any results.
    New User Keith
  7. #7
    OK, perhaps I wasn't clear. Stop polluting a thread about an engine fault with generic questions about a TPMS fault. If you wish to discuss TPMS faults, start a different thread.
    finally had some time to look at the car again sorry for the delay
    I haven't had a lot of time this week to look at the issue but I managed to find some time tonight and took the car for a drive both before resetting the CEL and after. I drove the car up a pretty steep hill and back down. I monitored group 11 and graphed it and I'm going to post links to the 2 screen captures I took from my laptop. I'm not sure how to monitor Measuring Block Group # 034.2 and .3 but if someone can tell me I can go for another drive again and log it this time and do a screen recording if that's helpful. After I reset the CEL I drove around again up a hill etc. and I couldn't get the light to come back on. The car was at normal operating temperature when I did it, so I'm confused how my wife manages to get the light to turn back on, on her way to work. I'm sure when she gets home from work tomorrow the light will be on again if someone can tell me how to monitor the other 2 blocks I can go ahead and do more tests. I would take the car myself except I have a very short commute to work and it doesn't seem to come on in the 5 minutes I drive to work but my wife drives 50 miles round trip local and highway and it usually turns on somewhere during the local driving.
    Driving the car with CEL before resetting it.
    Driving car after resetting the CEL
  9. #9
    Is this car tuned?
  10. #10
    Is this car tuned?
    Nope the car isn't tuned at all dead stock I haven't modified anything with the VCDS
