Results 1 to 8 of 8
Thread: 2001 Passat HVAC coding
    Verified VCDS User hans j's Avatar
    Mar 2014
    Utah
    Had this car come in from another shop, noticed the control head loose and coding says it's definitely not coded correctly. Out of all my old autoscans, I don't have one that uses the same part number and can't verify the coding.
    Tuesday,08,September,2015,17:03:27:05734
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    Dealer/Shop Name: Utah Imports hj
    VIN: WVWRH63B41P280188   License Plate:
    Mileage: 269060km-167186mi   Repair Order:
    Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWRH63B41P280188   Mileage: 269060km-167186miles
    Address 01: Engine        Labels: 078-907-551-ATQ.lbl
       Part No: 3B0 907 551 BS
       Component: 2.8L V6/5V      G   0001
       Coding: 07501
       Shop #: WSC 00028
       VCID: F5A2A14ACDD7D096FE-5184
       WVWRH63B41P280188     VWZ7Z0A3593376
    16814 - Catalyst System; Bank 2
                P0430 - 35-00 - Efficiency Below Threshold
    16804 - Catalyst System; Bank 1
                P0420 - 35-10 - Efficiency Below Threshold - Intermittent
    18010 - Power Supply Terminal 30
                P1602 - 35-10 - Voltage too Low - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1
                P0130 - 35-10 - Malfunction in Circuit - Intermittent
    Readiness: 0000 1000
    Address 03: ABS Brakes        Labels: 8E0-614-111-ASR.lbl
       Part No: 3B0 614 111
       Component: ABS/ASR 5.3 FRONT   D00
       Coding: 00032
       Shop #: WSC 00028
       VCID: D3E63FD223E3AEA630-5184
    Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
       Part No: 3B1 907 044 C
       Component: CLIMATRONIC     C 0.7.0
       Coding: 01000
       Shop #: WSC 00066
       VCID: A10AA51A29DF0C36F2-523C
    00532 - Supply Voltage B+
                30-00 - Open or Short to Plus
    00281 - Vehicle Speed Sensor (G68)
                37-10 - Faulty - Intermittent
                37-00 - Faulty
       Part No: 6Q0 909 605 C
       Component: 09 AIRBAG VW6  04   0004
       Coding: 12345
       Shop #: WSC 00028
       VCID: B73E6B42975B62862C-5160
    Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
       Part No: 1J0 907 487 B
       Component: Lenkradelektronik   0002
       Coding: 00008
       Shop #: WSC 00028
       VCID: B02C505E7235B5BE6D-5216
    Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
       Part No: 3B0 920 925 B
       Component: KOMBI+WEGFAHRSP VDO V13
       Coding: 07235
       Shop #: WSC 19419
       VCID: A208AA162CD9172EEB-5160
    01176 - Key
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00028
       VCID: F0AC905EB2B5F5BE2D-5160
    Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
       Part No: 3B1 959 760 D
       Component: Sitzverstellung     0101
       VCID: AE104E263801A34E7F-5160
    01008 - Note; Emergency OFF Switch is Active!
                000 -  -  - Intermittent
       Part No: 1C0 959 799 C
       Component: 09 Komfortgerát HLO 0001
       Coding: 00258
       Shop #: WSC 00028
       VCID: B73E6B42975B62862C-4B3C
       Subsystem 1 - Part No: 1C0959801
       Component: 09 Tőrsteuer.FS     0001
       Subsystem 2 - Part No: 1C0959802A
       Component: 09 Tőrsteuer.BF     0001
       Subsystem 3 - Part No: 1C0959811
       Component: 09 Tőrsteuer.HL     0001
       Subsystem 4 - Part No: 1C0959812
       Component: 09 Tőrsteuer.HR     0001
    11 Faults Found:
                53-10 - Supply Voltage Too Low - Intermittent
    00849 - S-contact at Ignition/Starter Switch (D)
                25-10 - Unknown Switch Condition - Intermittent
                54-10 - Incorrectly Equipped - Intermittent
                37-00 - Faulty
    00913 - Window Regulator Switch; Front Right Driver (E81)
                29-10 - Short to Ground - Intermittent
    01035 - Electric Window Thermal Protection Active; Passenger
                35-10 -  -  - Intermittent
    End-------------------------(Elapsed Time: 06:44)--------------------------
    The A/C has a shut off code for no engine speed signal, but no fault in Engine for engine speed. So I'm wondering if the coding is way off (even when I change it to what I think it should be it still doesn't work).
    Can anyone suggest the proper coding for this VIN and part number?
    Northern ireland
    is it possible it's the speed signal wire into the rear of the hvac unit, maybe high resistance/open circuit? I saw this same issue before on a SEAT ibiza.
    Magdeburg, Germany
    Even with an incorrect coding of that module, you shouldn't have any electrical issues with the flaps.
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by hans j View Post
    Try coding to 17200. In the label file you'll see a reference to that being a W8-specific coding, but I can tell you my 2004 GLX with ATQ V6 was coded that way from the factory and works fine. If that doesn't work, you could try 15200.
    Ignore the faulty positioning motor DTCs for the moment. The Climatronic control head in this car is notorious for declaring flap control motors faulty when they're still working okay. I think my old Passat has declared three separate flap motors faulty and the whole system works just fine. You also don't mention if anyone tried the flap position adaptation, which could also explain the faulty code. That's absolutely necessary after swapping control heads, especially a used one.
    Recode, clear faults in 08 and 19, perform flap position adaptation so it's matched to this car, and then re-check behavior and fault codes.
    Jason
    Regardless of coding issues here, there is clear swing in voltages; based on the scan which need to be addressed ASAP.
    Check connections to battery, and alternator for proper output............
    Mar 2014
    Utah
    Thanks for the ideas! CAN gateway keeps coming up with a had fault for no communication with HVAC and block 125 in any CAN connected module doesn't include HVAC. Since the car came in with the HVAC control head loose and no identifying part number (sticker pulled off) on the module, I've warned the customer that there is more to look at and I'm not doing it for free.
    I've tried all the coding options and no change. I could only find 17200 referenced in all my old autoscans as well.
    Battery and alternator are good
    I'm never worried about the flap faults or the ambient air temp faults. I've had those many times with no effect to the air conditioning. I got in to the menu of the climatronic and it said the air temp sensor behind the bumper was the issue.
    So it could be the speed sensor wire to the HVAC module, but I'm betting the module isn't equipped to take the CAN signal (and I'm betting it gets it's speed signal from the CAN). I'll post back up if they decide on a new HVAC module!
  7. Likes Uwe liked this post
    Cincinnati, OH
    I think you may indeed have the wrong HVAC module.
    The control head we can see installed in your Auto-Scan (3B1 907 044 C) does NOT share cross-references with the one I looked up in PL24 for this specific vehicle by VIN (3B1 907 044 J). Both show as valid for a "2001" Passat but that's the only year of overlap; -C fits older cars and -J fits newer. Parts shopping for a 2001 Passat sucks because of the mid-model year platform refresh, B5 to B5.5 if you've ever seen those terms. A 2001 can be either.
    Suffix -J units are readily available for $cheap on eBay. See if your customer will try one out. I wouldn't be surprised if there are more gremlins hiding; somebody was already in there screwing with it for a reason and you're showing all sorts of other comfort-CAN comms faults. But, it should get you a lot closer.
    Jason
  9. Likes Uwe liked this post
  10. #8
    Mar 2014
    Utah
    Definitely the wrong module! Parts guy finally looked it up and told the other shop to supply a "J" version. Sure enough it works... Came coded 17200 and would not allow me to change it to 15200 so it's staying 17200. Shut off compressor code stays 0.0 and engine RPM is read just fine. Hard fault also cleared in CAN gateway.
    Interesting to note measuring block 80 would not work on the "C" version.
    Funny thing is, Chavez Auto Service did an evac/recarge, changed the pressure sensor, swapped the A/C relay, and finally changed the control valve (their words) before bringing it to us.
    Oh and the next best thing is after I installed it, the display went blank! Turns out someone used a 2 amp fuse in position 5 (for A/C and other items). Sometimes that tree with all that shade just doesn't make you a good mechanic...
    Thanks for the help guys.
    Oh and the temp sensor fault went away and the CAN for HVAC is located in block 132! It was 0 with the old module and 1 with the new module.
  11. Likes jyoung8607, Uwe liked this post
