Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Does VAG recognize VCDS as diagnostics tool?
    New User
    Jun 2015
    Macedonia
    first,apologies for the double thread. I realised too late, I was in the wrong section.I do not know how to delete a thread. please delete the other thread in 'pre sales' section.cheers
    is the VCDS recognized by VAG as a diagnostics tool?
    if a VDCS finds a fault,but the VAG dealer does not find it
    which is correct?
    I get this fault every time I do a scan. I delete it every time and it shows up again on every following scan.
    I went to the offical VW dealer where I bought the car,he said his diagonstics tools did not find any faults like this one.
    B201A 00 [009] - -
    Reset counter: 107
    Mileage: 8378 km
    Date: 2015.08.05
    Time: 22:25:36
    and here is the last full scan of the car,passat MQB 2.0 TDI
    Saturday,22,August,2015,02:45:43:25280
    VCDS Version: 15.7.0.1 (x64)
    Data version: 20150729
    VIN: WVWZZZ3CZFE445322   License Plate:
    Mileage: 10370km-6443mi   Repair Order:
    Chassis Type: 3C (5Q0)
    Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F
    VIN: WVWZZZ3CZFE445322   Mileage: 10370km-6443miles
    Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 026 AS    HW: 04L 907 309 R
       Component: R4 2,0L TDI   H21 0887
       Revision: B5H21---
       Coding: 0119003203441D083000
       Shop #: WSC 05311 115 00300
       ASAM Dataset: EV_ECM20TDI01104L906026AS 001005
       ROD: EV_ECM20TDI01104L906026AS.rod
       VCID: 7BFFC647F287A0E603-802E
    20359 - Internal Control Module
              P0606 00 [101] - Processor Fault
                        Mileage: 9511 km
                        Date: 2015.08.13
                        Time: 13:16:51
       Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
       Component: ESC           H42 0609
       Revision: 00000000    Serial number: 63514000002738
       Coding: 0EEC6A8F34240B71077A060241C54970562CD0E0608292F13460F078C002
       Shop #: WSC 00015 115 00001
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
       VCID: 3D7B085FAC136ED67D-8068
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0356005419
       Coding: 000F1F0603
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       ROD: EV_KessyHellaMQBAB_SK48.rod
       VCID: 77F7DA77CEAF848667-8022
       Part No SW: 5G0 907 044 AH    HW: 5G0 907 044 AH
       Revision: 00001K10
       Coding: 11020104202100012015504000101802
       ROD: EV_ACClimaBHBVW37X_SK37.rod
       VCID: 6DDBF81FBCF33E568D-8038
       Slave 1:
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86580501150888
       Coding: 00010A46C24102FF03A04084B11007081880000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 7DFBC85FEC93AED63D-8028
       Slave 1:
       Component: WWS    141123  042 0607
       Serial number:         141201031904
       Slave 2:
       Component: RLHS  037 0059
       Serial number: S5Y15M01D08H10M04S24
       Coding: 06A8DD
       Slave 3:
       Serial number: 16 11 2014  00000603
       Serial number: 000000000ZY143210NWY
       Serial number: 00000000000061016863
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
       Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
       Component: PLA 3.0 12KH08 0013
       Serial number: ATW-00111.01.15
       Coding: 0071061041
       Shop #: WSC 05311 115 00093
       ASAM Dataset: EV_EPHVA2CAU3700000 008017
       ROD: EV_EPHVA2CAU3700000_VW48.rod
       VCID: 3F877257A61F7CC66F-806A
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0126
       Coding: 2A40600310FFC428949C804C
       ASAM Dataset: EV_ACCBOSCHVW48X 001007
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 336F2E679A57A8A69B-8066
    0862 - Databus
                        Reset counter: 175
                        Mileage: 8432 km
                        Date: 2015.08.06
                        Time: 14:06:57
       Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R2PSHT9S$
       Coding: 88CCC000000000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X_VW48.rod
       VCID: 0201BBA3956DD12E40-8056
       Subsystem 1 - Part No SW: -----------    HW: 454 001 912 14
       Serial number: 3576U00000079944E11E
       Subsystem 2 - Part No SW: -----------    HW: 454 002 112 14
       Serial number: 3586U00000040330021M
       Subsystem 3 - Part No SW: -----------    HW: 454 801 712 14
       Serial number: 3516R7CB566050000008
       Subsystem 4 - Part No SW: -----------    HW: 454 801 712 14
       Serial number: 3526RFA546B05000000D
       Subsystem 5 - Part No SW: -----------    HW: 454 801 512 14
       Serial number: 3556V0C5748050000005
    9682162 - Multiple collision brake
              B13BC F2 [008] - No function
                        Mileage: 9021 km
                        Date: 2015.08.10
                        Time: 16:29:24
    Address 16: Steering wheel (J524)       Labels: None
       Part No SW: 3Q0 953 521     HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150107400025
       Coding: 0000
       ROD: EV_SMLSVALEOMQB.rod
       Part No SW: 3G0 920 741     HW: 3G0 920 741
       Component: KOMBI         209 4311
       Coding: 07A401102F80000800883A001001000000000000
       ROD: EV_DashBoardVDDMQBAB_SK25.rod
       VCID: 61C3942F702B6A3639-8034
       Revision: --------    Serial number: 13121410803090
       Coding: 030300044F087300EF000258080F00010001070000000000000000000000
       ROD: EV_GatewConti.rod
       VCID: 72E1EB63A5CDE1AE50-8026
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
       Component: E221__MFL-DC1  H16 0040
       Serial number: 27140003140050104513
       Coding: 2CFFFF
       Serial number: 2833385303
       Component: Analoguhr  209 2002
    8531970 - Quiescent Current
              U1406 00 [009] - Too High
                        Fault Frequency: 12
                        Reset counter: 159
                        Mileage: 9017 km
                        Date: 2015.08.10
                        Time: 03:18:01
       Serial number: 14000315541013
       Coding: 0000000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71E3E46FA0CBDAB6A9-8024
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 111214BLA0672A
       Coding: 00350A20DC00020000001000
       ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
       VCID: 42817BA3D5ED112E00-8016
       Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E
       Serial number: 00000000000000643701
    Address 44: Steering Assist (J500)       Labels: None
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    203 2033
       Revision: 00000000    Serial number: 0000115696
       Coding: 01010010005000
       Shop #: WSC 00015 115 00300
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_SK48.rod
       VCID: 3B7F0647B20760E643-806E
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 171214BLG19605
       Coding: 00350020DC00020000001000
       ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
       VCID: 418374AFD0EB0A3619-8014
       Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E
       Serial number: 00000000000000639417
       Coding: 090000
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       Coding: 03DA000009000000
       Shop #: WSC 05311 000 00001
       ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
       VCID: 75EBD07FD4A3F69675-8020
       Part No SW: 3Q0 035 819     HW: 3Q0 035 819
       Component: MU-S--ER      H11 0135
       Serial number: VWZAZ2P4672212
       Coding: 02840100FF00000011110001000808001F0100840120010001
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_VW26.rod
       VCID: 6ED9FF13B1F5C54EB4-803A
       Media Player Position 1:
       Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
       Component: ABT_Std-2  H42 1015
       Serial number: VWZ8Z9PD500879
              B201A 00 [009] -  -
                        Reset counter: 107
                        Mileage: 8378 km
                        Date: 2015.08.05
                        Time: 22:25:36
    7203 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 163
                        Mileage: 9351 km
                        Date: 2015.08.12
                        Time: 17:47:24
    End-------------------------(Elapsed Time: 04:16)--------------------------
  2. Likes Uwe liked this post
  3. #2
    Jun 2014
    VCDS ofcourse ;-) you only have to convince your dealer that there is something wrong with your car!
    That will be a problem, because if they cannot detect the failure with their own devices, there is no problem. That why I never go to a dealer, allway visit a company that is specialized in VAG-cars, they use VCDS and dealer-tools.
    To delete a post, click the "edit"-button, then there is an option to delete your post!
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
    New User
    Jun 2015
    Macedonia
    Quote Originally Posted by Mari View Post
    that is what happened. vcds finds the fault. I go to the official vw dealer in my country,they use their diagnostics tools.they say there is no such fault. I tell them how I found that fault, VW dealer says, VCDS is not recognized by VW therfore...there is no 1555 fault.
    simple way of solving the fault by not admiting there is one.
    "VAG" is not a monolithic entity. Some people within VAG certainly do recognize VCDS as a very useful tool. Others take a "Not Invented Here" attitude toward it.
    Since this all the faults are in modules that use the UDS protocol, please try the following: Go to the Auto-Scan screen and un-check
    "UDS aggressive mode", then run another scan.
    There are some nuances to the query for fault codes in the UDS protocol. When just doing a quick-check, the dealer's tools do not look very deeply; they only dig as deeply as VCDS does by default when running various "guided" things. So it is entirely plausible that VCDS turns up faults that a quick check with the dealers' tools would not reveal. Note: This is only the case on modules that use UDS.
    Quote Originally Posted by lans View Post
    Do they let you watch them perform the scan, or even show you the print-out from their tool?
    New User
    Jun 2015
    Macedonia
    cheers for the reply
    first chance to go back is in 2 weeks.
    till then,any advice on the presistent fault?
    B201A 00 [009] - -
    Reset counter: 107
    Mileage: 8378 km
    Date: 2015.08.05
    Time: 22:25:36
    all I could find on the net,related to this kind of fault was equipment being retrofitted and not coded propperly?
    I have asked the vw dealer,did they retrofitted some equipment(mine is a comfortline with nearly 90% of the gear of highline-it was on a promotion)
    i.e. ACC,selfparking system,heated seats,full LED lights etc...
    they never replied to that question.
    edit
    no,they took the car in the garage.10mins later they took it out and said 'no fault'
    thats when I showed them my scan and the fault,and they said 'yeah,and?'
    Nope, "Check SVM" is something that the dealer has to do on-line.
  9. #8
    New User
    Jun 2015
    Macedonia
    hello
    here is the non agressive scan
    Wednesday,16,September,2015,23:37:54:25280
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    Mileage: 10603km-6588mi   Repair Order: dtuk
    VIN: WVWZZZ3CZFE445322   Mileage: 10603km-6588miles
       Revision: B5H21---
       VCID: 7BFFC647F287A0E608-802E
       VCID: 3D7B085FAC136ED676-8068
    16401 - Tire Pressure Warning
              C102D 00 [009] -  -
                        Reset counter: 206
                        Mileage: 10492 km
                        Date: 2015.08.23
                        Time: 16:31:03
       Coding: 000F1F0603
       VCID: 77F7DA77CEAF84866C-8022
       Revision: 00001K10
       VCID: 6DDBF81FBCF33E5686-8038
       Slave 1:
       VCID: 7DFBC85FEC93AED636-8028
       Slave 1:
       Slave 2:
       Coding: 06A8DD
       Slave 3:
       Coding: 0071061041
       VCID: 3F877257A61F7CC664-806A
       VCID: 336F2E679A57A8A690-8066
       VCID: 0201BBA3956DD12E4B-8056
       Coding: 0000
       VCID: 61C3942F702B6A3632-8034
       VCID: 72E1EB63A5CDE1AE5B-8026
       Coding: 2CFFFF
              U1406 00 [008] - Too High
                        Reset counter: 205
                        Mileage: 10380 km
                        Date: 2015.08.22
                        Time: 08:00:01
       VCID: 71E3E46FA0CBDAB6A2-8024
       VCID: 42817BA3D5ED112E0B-8016
    Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
       VCID: 3B7F0647B20760E648-806E
       VCID: 418374AFD0EB0A3612-8014
       Coding: 090000
       VCID: 75EBD07FD4A3F6967E-8020
       VCID: 6ED9FF13B1F5C54EBF-803A
              B201A 00 [009] -  -
                        Reset counter: 159
                        Mileage: 10370 km
                        Date: 2015.08.22
                        Time: 02:45:30
    End-------------------------(Elapsed Time: 04:19)--------------------------
    and here is the agressive scan
    Wednesday,16,September,2015,23:43:53:25280
    Address 01: Engine (J623-CRLB)       Labels: None
       Part No HW: 04L 907 309 R
       Revision: B5H21---
       VCID: 55ABB0FF346396965E-8000
    5169 - Manifold Pressure / Boost Sensor (G31)
              P0238 00 [032] - Signal too High
                        Mileage: 10576 km
                        Time: 00:00:00
              C102D 00 [009] -  -
                        Reset counter: 206
                        Mileage: 10492 km
                        Date: 2015.08.23
                        Time: 16:31:03
       Coding: 000F1F0603
       Revision: 00001K10
       Slave 1:
       Slave 1:
       Slave 2:
       Coding: 06A8DD
       Slave 3:
       Coding: 0071061041
       Coding: 0000
       Coding: 2CFFFF
                        Reset counter: 205
                        Mileage: 10380 km
                        Date: 2015.08.22
                        Time: 08:00:01
       Coding: 090000
              B201A 00 [009] -  -
                        Reset counter: 159
                        Mileage: 10370 km
                        Date: 2015.08.22
                        Time: 02:45:30
    End-------------------------(Elapsed Time: 04:15)--------------------------
    when i delete all the codes, the 1555 code comes up right away again. strange.
  10. #9
    Sep 2015
    Does it have HDD based navigation? Could be someone has updated the map database using 'unofficial' sources. That (on a B8 platform Audi anyway) will flag an SVM fault until you clear it by reading a value, doing a quick calculation, and updating the value. This then removes the SVM error.
    Info and an SVM calculator are here, although the calculation is nothing fancy
    http://audienthusiasts.com/Application_SVMError.html
  11. Likes Uwe liked this post
  12. #10
    New User
    Jun 2015
    Macedonia
    Quote Originally Posted by Adrian E View Post
    no navigation of any kind in this car.
