Does VAG recognize VCDS as diagnostics tool?
lans
Macedonia
HC438952 (2nd hand?)
first,apologies for the double thread. I realised too late, I was in the wrong section.I do not know how to delete a thread. please delete the other thread in 'pre sales' section.cheers
is the VCDS recognized by VAG as a diagnostics tool?
if a VDCS finds a fault,but the VAG dealer does not find it
which is correct?
I get this fault every time I do a scan. I delete it every time and it shows up again on every following scan.
I went to the offical VW dealer where I bought the car,he said his diagonstics tools did not find any faults like this one.
B201A 00 [009] - -
Reset counter: 107
Mileage: 8378 km
Date: 2015.08.05
Time: 22:25:36
and here is the last full scan of the car,passat MQB 2.0 TDI
Saturday,22,August,2015,02:45:43:25280
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: WVWZZZ3CZFE445322   License Plate:
Mileage: 10370km-6443mi   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F
VIN: WVWZZZ3CZFE445322   Mileage: 10370km-6443miles
Address 01: Engine (J623-CRLB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 AS    HW: 04L 907 309 R
   Component: R4 2,0L TDI   H21 0887
   Revision: B5H21---
   Coding: 0119003203441D083000
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_ECM20TDI01104L906026AS 001005
   ROD: EV_ECM20TDI01104L906026AS.rod
   VCID: 7BFFC647F287A0E603-802E
20359 - Internal Control Module
          P0606 00 [101] - Processor Fault
                    Mileage: 9511 km
                    Date: 2015.08.13
                    Time: 13:16:51
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63514000002738
   Coding: 0EEC6A8F34240B71077A060241C54970562CD0E0608292F13460F078C002
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
   VCID: 3D7B085FAC136ED67D-8068
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0356005419
   Coding: 000F1F0603
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB_SK48.rod
   VCID: 77F7DA77CEAF848667-8022
   Part No SW: 5G0 907 044 AH    HW: 5G0 907 044 AH
   Revision: 00001K10
   Coding: 11020104202100012015504000101802
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 6DDBF81FBCF33E568D-8038
   Slave 1:
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580501150888
   Coding: 00010A46C24102FF03A04084B11007081880000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: 7DFBC85FEC93AED63D-8028
   Slave 1:
   Component: WWS    141123  042 0607
   Serial number:         141201031904
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S5Y15M01D08H10M04S24
   Coding: 06A8DD
   Slave 3:
   Serial number: 16 11 2014  00000603
   Serial number: 000000000ZY143210NWY
   Serial number: 00000000000061016863
   Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0013
   Serial number: ATW-00111.01.15
   Coding: 0071061041
   Shop #: WSC 05311 115 00093
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_VW48.rod
   VCID: 3F877257A61F7CC66F-806A
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 2A40600310FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 336F2E679A57A8A69B-8066
0862 - Databus
                    Reset counter: 175
                    Mileage: 8432 km
                    Date: 2015.08.06
                    Time: 14:06:57
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2PSHT9S$
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X_VW48.rod
   VCID: 0201BBA3956DD12E40-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 001 912 14
   Serial number: 3576U00000079944E11E
   Subsystem 2 - Part No SW: -----------    HW: 454 002 112 14
   Serial number: 3586U00000040330021M
   Subsystem 3 - Part No SW: -----------    HW: 454 801 712 14
   Serial number: 3516R7CB566050000008
   Subsystem 4 - Part No SW: -----------    HW: 454 801 712 14
   Serial number: 3526RFA546B05000000D
   Subsystem 5 - Part No SW: -----------    HW: 454 801 512 14
   Serial number: 3556V0C5748050000005
          B13BC F2 [008] - No function
                    Mileage: 9021 km
                    Date: 2015.08.10
                    Time: 16:29:24
Address 16: Steering wheel (J524)       Labels: None
   Part No SW: 3Q0 953 521     HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150107400025
   Coding: 0000
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 741     HW: 3G0 920 741
   Component: KOMBI         209 4311
   Coding: 07A401102F80000800883A001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 61C3942F702B6A3639-8034
   Revision: --------    Serial number: 13121410803090
   Coding: 030300044F087300EF000258080F00010001070000000000000000000000
   ROD: EV_GatewConti.rod
   VCID: 72E1EB63A5CDE1AE50-8026
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H16 0040
   Serial number: 27140003140050104513
   Coding: 2CFFFF
   Serial number: 2833385303
8531970 - Quiescent Current
          U1406 00 [009] - Too High
                    Fault Frequency: 12
                    Reset counter: 159
                    Mileage: 9017 km
                    Date: 2015.08.10
                    Time: 03:18:01
   Serial number: 14000315541013
   Coding: 0000000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E3E46FA0CBDAB6A9-8024
   Serial number: 111214BLA0672A
   Coding: 00350A20DC00020000001000
   VCID: 42817BA3D5ED112E00-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E
   Serial number: 00000000000000643701
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000115696
   Coding: 01010010005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_SK48.rod
   VCID: 3B7F0647B20760E643-806E
   Serial number: 171214BLG19605
   Coding: 00350020DC00020000001000
   VCID: 418374AFD0EB0A3619-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E
   Serial number: 00000000000000639417
   Coding: 090000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 03DA000009000000
   Shop #: WSC 05311 000 00001
   ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
   VCID: 75EBD07FD4A3F69675-8020
   Part No SW: 3Q0 035 819     HW: 3Q0 035 819
   Component: MU-S--ER      H11 0135
   Serial number: VWZAZ2P4672212
   Coding: 02840100FF00000011110001000808001F0100840120010001
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 6ED9FF13B1F5C54EB4-803A
   Media Player Position 1:
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H42 1015
   Serial number: VWZ8Z9PD500879
          B201A 00 [009] -  -
                    Reset counter: 107
                    Mileage: 8378 km
                    Date: 2015.08.05
                    Time: 22:25:36
7203 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 163
                    Mileage: 9351 km
                    Date: 2015.08.12
                    Time: 17:47:24
End-------------------------(Elapsed Time: 04:16)--------------------------
Mari
C?ID=150535
VCDS ofcourse ;-) you only have to convince your dealer that there is something wrong with your car!
That will be a problem, because if they cannot detect the failure with their own devices, there is no problem. That why I never go to a dealer, allway visit a company that is specialized in VAG-cars, they use VCDS and dealer-tools.
To delete a post, click the "edit"-button, then there is an option to delete your post!
lans
Macedonia
that is what happened. vcds finds the fault. I go to the official vw dealer in my country,they use their diagnostics tools.they say there is no such fault. I tell them how I found that fault, VW dealer says, VCDS is not recognized by VW therfore...there is no 1555 fault.
simple way of solving the fault by not admiting there is one.
"VAG" is not a monolithic entity. Some people within VAG certainly do recognize VCDS as a very useful tool. Others take a "Not Invented Here" attitude toward it.
Since this all the faults are in modules that use the UDS protocol, please try the following: Go to the Auto-Scan screen and un-check
"UDS aggressive mode", then run another scan.
There are some nuances to the query for fault codes in the UDS protocol. When just doing a quick-check, the dealer's tools do not look very deeply; they only dig as deeply as VCDS does by default when running various "guided" things. So it is entirely plausible that VCDS turns up faults that a quick check with the dealers' tools would not reveal. Note: This is only the case on modules that use UDS.
Do they let you watch them perform the scan, or even show you the print-out from their tool?
lans
Macedonia
cheers for the reply
first chance to go back is in 2 weeks.
till then,any advice on the presistent fault?
B201A 00 [009] - -
Reset counter: 107
Mileage: 8378 km
Date: 2015.08.05
Time: 22:25:36
all I could find on the net,related to this kind of fault was equipment being retrofitted and not coded propperly?
I have asked the vw dealer,did they retrofitted some equipment(mine is a comfortline with nearly 90% of the gear of highline-it was on a promotion)
i.e. ACC,selfparking system,heated seats,full LED lights etc...
they never replied to that question.
edit
no,they took the car in the garage.10mins later they took it out and said 'no fault'
thats when I showed them my scan and the fault,and they said 'yeah,and?'
Nope, "Check SVM" is something that the dealer has to do on-line.
lans
Macedonia
hello
here is the non agressive scan
Wednesday,16,September,2015,23:37:54:25280
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
Mileage: 10603km-6588mi   Repair Order: dtuk
VIN: WVWZZZ3CZFE445322   Mileage: 10603km-6588miles
   Revision: B5H21---
   VCID: 7BFFC647F287A0E608-802E
   VCID: 3D7B085FAC136ED676-8068
16401 - Tire Pressure Warning
          C102D 00 [009] -  -
                    Reset counter: 206
                    Mileage: 10492 km
                    Date: 2015.08.23
                    Time: 16:31:03
   Coding: 000F1F0603
   VCID: 77F7DA77CEAF84866C-8022
   Revision: 00001K10
   VCID: 6DDBF81FBCF33E5686-8038
   Slave 1:
   VCID: 7DFBC85FEC93AED636-8028
   Slave 1:
   Slave 2:
   Coding: 06A8DD
   Slave 3:
   Coding: 0071061041
   VCID: 3F877257A61F7CC664-806A
   VCID: 336F2E679A57A8A690-8066
   VCID: 0201BBA3956DD12E4B-8056
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Coding: 0000
   VCID: 61C3942F702B6A3632-8034
   VCID: 72E1EB63A5CDE1AE5B-8026
   Coding: 2CFFFF
          U1406 00 [008] - Too High
                    Reset counter: 205
                    Mileage: 10380 km
                    Date: 2015.08.22
                    Time: 08:00:01
   VCID: 71E3E46FA0CBDAB6A2-8024
   VCID: 42817BA3D5ED112E0B-8016
Address 44: Steering Assist (J500)       Labels: 5Q0-909-143.clb
   VCID: 3B7F0647B20760E648-806E
   VCID: 418374AFD0EB0A3612-8014
   Coding: 090000
   VCID: 75EBD07FD4A3F6967E-8020
   VCID: 6ED9FF13B1F5C54EBF-803A
          B201A 00 [009] -  -
                    Reset counter: 159
                    Mileage: 10370 km
                    Date: 2015.08.22
                    Time: 02:45:30
End-------------------------(Elapsed Time: 04:19)--------------------------
and here is the agressive scan
Wednesday,16,September,2015,23:43:53:25280
Address 01: Engine (J623-CRLB)       Labels: None
   Part No HW: 04L 907 309 R
   Revision: B5H21---
   VCID: 55ABB0FF346396965E-8000
5169 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [032] - Signal too High
                    Mileage: 10576 km
                    Time: 00:00:00
          C102D 00 [009] -  -
                    Reset counter: 206
                    Mileage: 10492 km
                    Date: 2015.08.23
                    Time: 16:31:03
   Coding: 000F1F0603
   Revision: 00001K10
   Slave 1:
   Slave 1:
   Slave 2:
   Coding: 06A8DD
   Slave 3:
   Coding: 0071061041
   Coding: 0000
   Coding: 2CFFFF
                    Reset counter: 205
                    Mileage: 10380 km
                    Date: 2015.08.22
                    Time: 08:00:01
   Coding: 090000
          B201A 00 [009] -  -
                    Reset counter: 159
                    Mileage: 10370 km
                    Date: 2015.08.22
                    Time: 02:45:30
End-------------------------(Elapsed Time: 04:15)--------------------------
when i delete all the codes, the 1555 code comes up right away again. strange.
Adrian E
C?ID=258567
Does it have HDD based navigation? Could be someone has updated the map database using 'unofficial' sources. That (on a B8 platform Audi anyway) will flag an SVM fault until you clear it by reading a value, doing a quick calculation, and updating the value. This then removes the SVM error.
Info and an SVM calculator are here, although the calculation is nothing fancy
http://audienthusiasts.com/Application_SVMError.html
lans
Macedonia
no navigation of any kind in this car.
Adrian E
C?ID=258567
Removing SVM will likely involve the same SVM error removal process - worth a try as it doesn't cost anything to do it, and will most likely make the problem go away :)
lans
Macedonia
how does one remove SVM with VCDS?
or it has to be done by the dealer?
markusboy
Greece
C?ID=107799
Hallo.
This error is generated by the 5F device itself to let the dealer know that a newer Software for this device MAY have become available. It has practicaly no impact to the device's fuctionality and it can be left alone. The dealer's workaround of this error is to da an "SVM comparison" (using the ODIS system of course) online following the error in Guided Fault Finding and check whether it has a newer version available or not. When the comparison ends, it either updates the SW to the newer version or verifies that the version installed is the latest available and in both cases it erases the fault using some "unseen" adaptations as the fault cannot be erased with the old fashioned DTC-erase way.
I hope that was an illuminating bit of Info...
lans
Macedonia
Hallo.
cheers bud
lans
Macedonia
what was once one fault in the short term,it has now evolved into two fault on the long run
wv dealer not helpful as usual
   Coding: 02840100FF00000011110001000808001F0100840120010003
   VCID: 6ED9FF13B1F5C54E93-803A
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 67
                    Mileage: 17329 km
                    Date: 2015.12.22
                    Time: 11:11:57
          B201A 00 [009] -  -
                    Reset counter: 67
                    Mileage: 17329 km
                    Date: 2015.12.22
                    Time: 11:11:57
DV52
C?ID=194404
lans: Good evening!
I've been following your questions with interest (as a learning exercise for me), but I've noticed that the coding string in your 5F unit has changed from the value that was in your post #8 auto-scan and the post above (i.e. Post #15).
Here's a comparison of the two coding strings for address 5F for reference:
As is clear, it seems that Byte 24 has altered from Hex01 to Hex03 - or more particularly, Bit 1 has been set in the last auto-scan extract
Here's the long coding helper screen shot for Byte 24 showing the Bit functions:
The Speech Dialogue System box is the enabling facility for Voice Control (I have VC installed in my screen shot). Clearly VC wasn't in your 5F unit at the post #8 scan.
To install VC in an early mk7, an SD card is needed to load the VC software into the 5F firmware (as well as setting Byte 24, Bit 1). For later model mk7's I understand that the VC software is native to the 5F firmware, but an activation code is needed- I believe a link to FAZIT as part of the activation process is also needed for CP purposes.
Did you install/activate VC in the intervening period?
lans
Macedonia
no, I have not installed VC.
now when I think about it, I might have found something flicking trough the adaptations channels and set 'voice control active' but obviously its not good enough.
i see FAZIT is a vw thing, which means there is no way around them to enable VC,even if the software is installed and I somehow find the activation code. the car has to communicate with FAZIT?
I am offshore till 19th. I will revert the byte 24/bit 1 once I get back home
meanwhile I found some more tweaks
http://www.vcdscoding.com/#!passat/cog8
Datatekniker
New Member
Maybe this can help you , I have the excact same problem and will try this one today.
VCDS CODING:
1) 5F (Infotainment) module, Adaptations, channel: 'Confirmation of installation change'
2) Note your current coding
3) Start Windows calculator and set it to 'Programming mode' and select 'HEX' option
4) Calculation: (current coding) Xor C9D2
5) Change the adaptation channel to the new code (Don't be surprised if it changes back to the original coding, this is normal!)
6) VCDS main screen, 'Auto-Scan'
7) Check for fault codes on all modules and clear the DTCs
Note that VCDS displays your code in 'xx xx' format (small letters and a space character).
You have to remove the space before you calculate your new code.
When you enter your new (calculated) code, insert the space again and use lower cases.
EXAMPLE (don't use these values):
'1a 1a' (original coding of the adaptation channel)
1A1A Xor C9D2 equals D3C8
Enter it as 'd3 c8'
If your original code starts with zero(s) just remove them before calculating (i.e. 0A fb=AFB).
If the new (calculated) code is less than 4 characters, insert zeros in the beginning (i.e. FBB=0f bb).
/FWH
dna007
Lake Zurich, IL, USA
C?ID=214534
VCDS CODING:
Enter it as 'd3 c8'
/FWH
Wanted to confirm this works on 2015-2019 VW Golf/Tiguan/Atlas as well.
-Peter
It certainly works on a 2015-2019 Skoda Octavia, which uses the same infotainment systems as the VW Golf of the same years.
