Audi TT RS 8J ride level sensors showing wrong values in 14 Susp Elect (Has Mag Ride)
GBXRS
Australia
C?ID=240134 (NRRT)
I haven't been happy with the handling of my car at the track so I thought about checking the suspension.
I went into 14 Susp Elect and then into Meas Blocks 08 and clicked Go on each of the three buttons and the values displayed for ride height are wrong on the two RH sensors. My car is a ROW RH drive 2.5L AWD Coupe (TT RS) with Mag Ride.
I have replaced a broken RHR sensor with a used part.
VCDS has no error codes but the ride height shows RHR & RHF as about 336 (from memory) LHF & LHR show as 352mm. I measured the car on my (reasonably flat garage floor) with the door closed and no person inside and it is:
my measure is:
LHF 354mm
LHR 353mm
RHF 352mm
RHR 351mm
Now that sounds pretty normal to me.
Can I reset the sensor values to show the actual values?
I looked at (but didn't change) the coding values.
Current coding 0000072
The popup window suggests it should be 0000032 based on 0000xxx with 0 for Audi TT 8J then 3 for 2.5L RS TFSI then 2 for Coupe with AWD.
Can anyone help with the reason why it has 0000072 coding?
Do I need a security code to change the coding?
Cheers
Greg
I've never played with one of these, but it looks like it's done in adaptation channels 01-05, just like the pneumatic suspensions from the last decade. I'm thinking you have to enter all four measured heights into the first four channels and then test and save a 1 into channel 5.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Let's clear up some assumptions...
#1 The displayed values are for internal reference and do not represent the actual vehicle height.
#2 Your coding is all good, next update for VCDS will have an updated table.
...now that we're done with this, let's go back to your original issue. What exactly have you been unhappy with? Which wheel/tire combination are you running? When has the last actual alignment been done? Oh, let's not forget - PLEASE POST A COMPLETE AUTO-SCAN.
GBXRS
Australia
C?ID=240134 (NRRT)
Thanks, Uwe.
I have now had a look at that and the current stored values are zero. I can see each channel but I didn't make any changes yet.
GBXRS
Australia
C?ID=240134 (NRRT)
Thanks for your fast response, Sebastian,
#1 What concerns me is that the reported LHS figures are very accurate and the RHS figures are well out. & all figures show the car as lower than stock. I bought the car 2nd hand but the suspension looks stock. here is the screen from VCDS:
#2 That's good to know, thanks & that's the great value of this product and the support forum.
To answer your question why I am unhappy with the handling:
I currently compete in Tarmac Rallys (usually on alpine roads) in my 2009 Mitsubishi Lancer EVO X RS. This car has AWD and an active centre diff. We have had a fair degree of success with it. The TT RS has become eligible in our competition and they are clearly a faster car. So I bought this 2010 TT RS 6MT with 21,000klm.
It's a very nice road car but before I commit to a big spend to make it a competition car, I work through a testing process at a local race track. I'm not looking for ultimate race track setup. This track has a very good combination of different corner types and I can data log the laps and see the cars behaviour compared to my EVO by overlaying laps from each car, so it's real data not seat of the pants feel.
A rally car will always have a softer setup to cope with less than perfect road surfaces and changing weather conditions. What I can do at the track is drive at speeds and close to the limits that I could never do on a public road.
Wheels & tyres?
On the road it has the stock 19x9 wheels with 265/35/19 Michelin Pilot Super Sport tyres. At the track I run a set of 18x9 wheels with Yokohama Advan AO50 Medium compound semi slick tyres. I don't think these are available in many countries but they are a very good tyre for tarmac rally. Compared to a Dunlop Direzza 03G semi slick, they are somewhere between an M2 & an R2 compound. Much more grippy and well behaved than a road tyre and very short life.
Alignment:
It had an alignment 3 months ago and was supposed to be set to Front: Max negative camber -1.2 deg, zero toe-in. Rear: -1.5 neg camber, 1mm toe in (I later found the rear toe was wrong and it had 4.1mm toe in)
It's just had a new alignment and it now Front: camber -1.2 deg Negative, 7.1 deg caster, zero toe-in. Rear: -1.5 neg camber, 1mm toe in
I did my first test day on stock anti-roll bars and then fitted H&R bars that have soft & hard link positions.
Haldex:
The car had the stock Haldex and I kept on getting codes relating to controller or clutch failure. I installed a competition controller (the single mode one) from HPA and while it didn't help lap times much, the car was much nicer to drive. More composed under brakes and much more settled when I have to upshift mid-corner.
Problem:
What I never experienced on the road but did when i was driving at a higher level at the track was the very bad power-on corner exit understeer. Note that this is not corner entry understeer. i am doing what I think is the right thing, the slow in fast out method and the car has no problem turning in to the apex. it has a serious understeer problem when, having reached the apex, I try to power out of the corner. With the stock bars this was a case of back off or you will hit the wall. With the H&R bars it is much better but it's still a problem. In a rally, if I arrive at a corner too fast because I have listened to the note call properly, I might have understeer and be looking at the big tree I will hit. In the EVO, I can chuck it in and manage things with the throttle.
One further bit of info: I'm no youngster. I'll be 67 next week. :-)
My next track day in three weeks will be with a custom set of MSS stacked rear springs with height adjustment like coilovers. The overall spring rates will be harder than stock.
This has been a long reply but I appreciate your input and I wanted to tell you what I have been doing.
I'm not sure how to post the autoscan correctly but here it is:
VCDS Version Release 15.7.0 (x64) Running on Windows 7 x64(VMWare)
Data version: 20150729
Friday,04,September,2015,08:21:29:35289
Chassis Type: 8J (8P0)
Scan: 01 03 08 09 10 14 15 16 17 19 20 22 25 2E 37 42 44 46 47 4C
          52 55 56 61 77
VIN: TRUZZZ8J0B1900043   Mileage: 25550km-15876miles
Address 01: Engine (CEP)       Labels: 07K-907-404-CEP.clb
   Part No SW: 8J0 907 404 F    HW: 8J0 907 404
   Component: 2.5l R5/4V TFSI     0010
   Revision: F4H05---    Serial number: AUX7Z0J4FNH067
   Coding: 0113000C180F0160
   Shop #: WSC 01236 785 00200
   VCID: 306F2ED8A3AA8ABEE6-8065
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 910 517     HW: 8J0 614 517 C
   Component: ESP MK60E1          0010
   Revision: 00H60001
   Coding: 0618391
   VCID: 69D983BC40F03B76E1-803D
   Part No SW: 8J0 820 043 BA    HW: 8J0 820 043 BA
   Component: J255  Klima 1 Zone  0110
   Revision: 00H09006    Serial number: 00000001152826
   Coding: 1573957
   VCID: 66C3888051EE140ECC-8033
Address 09: Cent. Elect.
Address 10: Park/Steer Assist (J446)       Labels: 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93641013419135
   Coding: 00000B
   Shop #: WSC 01236 758 00200
   VCID: 428B7410DD06082E00-8017
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376 E    HW: 8J0 907 376 E
   Component: J250 Raddaempfung   0110
   Revision: --H22---    Serial number: 190DPH 0110378
   Coding: 0000072
   VCID: 31692BDCA8A083B6E9-8065
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -r Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K004FE2L
   Coding: 0011634
   VCID: 79F9D3FC30508BF611-802D
   Subsystem 1 - Serial number: 6332DRB40B6E0CB1
   Subsystem 2 - Serial number: 6342DRB40B6E0BA3$
   Subsystem 3 - Serial number: 63747RB4058B1309K
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004041
   VCID: 46836800312E340E2C-8013
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 930 S    HW: 8J0 920 930 S
   Component: KOMBIINSTR. VDO H01 0580
   Revision: D0H01002    Serial number: 2244J002000023
   Coding: 0117728
   Shop #: WSC 20460 822 999999
   VCID: 3C770AE87FE27EDE4A-8069
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 8P0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H33 0302
   Revision:   H33       Serial number: 210510F2000185
   Coding: E9BB1F0650065204004101
Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
   Part No SW: 8J0 857 511 G    HW: 8J0 857 511 G
   Component: FLA           H03 0004
   Revision: AA002001
   Coding: 02028D64747464545425363E
   VCID: 346722C897B2B69E82-8061
   Part No SW: 563 tun ere l    HW: 563 tun ere l
   Component: Haldex 4Motion      T403
   VCID: 1D31E76CC43817D65D-8049
   Revision: D0H01002    Serial number: AUX7Z0J4FNH067
Address 2E: Media Player 3 (R199)       Labels: 8T0-035-785.clb
   Part No SW: 8P0 035 785     HW: 8P0 035 785
   Component: SG ext.Player H08 0100
   Revision: 00000000
   Coding: 020202
   VCID: 74E7E2C8D732F69E42-8021
Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
   Part No SW: 8J0 035 193 D    HW: 8J0 035 193 D
   Component: RNS-E PU EU     H04 0200
   Revision: 0000010S    Serial number: AUZBZ7KD400450
   Coding: 0610725
   Shop #: WSC 20460 822 173925
   VCID: 2B5539B48A8CE966D3-807F
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8J8 959 801 J    HW: 8J8 959 801 J
   Component: Tuer-SG         H04 0101
   Coding: 0000605
   Shop #: WSC 20460 822 13273
   VCID: 448772080712061E32-8011
   Part No: 8J0 909 144 J
   Component: EPS_ZFLS Kl. 239    3001
   Revision: 00H17000
   VCID: 377D15C446C45D86A7-8063
Address 46: Central Conv.
Address 47: Sound System (J525)       Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 F    HW: 8J0 035 223 F
   Component: Audi TT Amp5K H05 0170
   Revision: --------    Serial number: BP208309190387
   Coding: 070101060002
   ASAM Dataset: EV_AudioAmpli5ChannBNO1 003011
   ROD: EV_AudioAmpli5ChannBNO1.rod
   VCID: 275DC5845E64CD0637-8073
Address 4C: Tire Pressure II        Labels: 8J0-907-274.lbl
   Part No SW: 8J0 907 274 C    HW: 4F0 907 274
   Component: J793  RKA+      H02 0190
   Revision: 00000813    Serial number: 00008130113299
   Coding: 0604100
   VCID: 326B24D0ADA6B8AE90-8067
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 8J8 959 802 H    HW: 8J8 959 802 H
   Coding: 0000605
   VCID: 43857114021C01260B-8017
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0060
   Coding: 0000025
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
   Coding: 0610725
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 8P0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H33 0302
   Coding: 0302015A
   Component: J367-BDM  H07 0140
   Part No SW: 8P1 862 335     HW: 8P1 862 335
   Component: FSE_256x BT     H41 0650
   Revision: 00000000    Serial number: 00000005205469
   Coding: 0011422
   VCID: 74E7E2C81732F69E42-8021
GBXRS
Australia
C?ID=240134 (NRRT)
Further info:
I am assuming that I have stock suspension.
The front springs are black and have a 1x brown dot & 1x white dot on them
The rear springs are black and have 3x pink dots, 1x grey dot & 1x yellow dot on them.
I uploaded some pics here and I'd appreciate confirmation that it is stock:
GBXRS
Australia
C?ID=240134 (NRRT)
OK, I decided to do my first adaptation.
It showed:
I went through to Adaptation and entered the correct values in channel 1, tested it and then saved it. Then did the same for channels 2,3 & 4. Then tested and saved a "1" in channel 5 and saved that.
After an ignition off for 30 seconds and back on, I now see:
No fault codes in 14 Susp Elect
& the heights are displayed correctly. My floor probably is not absolutely perfect but the measurements I have entered are much more accurate than the readings I was seeing before.
The Meas Blocks 08 screen now shows:
It seems like it has worked OK.
Now when I am logging what the suspension is doing, I'll see more realistic data.
Then I ran another autoscan:
Friday,04,September,2015,14:59:04:35289
          52 55 56 61 77
   Revision: 00H60001
   Coding: 0618391
   Coding: 1573957
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 H    HW: 8P0 907 063 H
   Component: BCM PQ35  H   106 0615
   Revision: 00106 AD
   Coding: 4E000B2FA0051A202070C0E82180084C507658AA3120D928DC080E440045
   VCID: 397913FCB0D04BF651-806D
   Subsystem 1 - Part No SW: 8J2 955 119 A    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H08 0070
   Coding: 00FD10
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 02492C
   Coding: 00000B
   Coding: 0000072
   Coding: 0011634
   Coding: 0004041
   Coding: 0117728
   Revision: AA002001
   Revision: 00000000
   Coding: 020202
   Coding: 0610725
   Coding: 0000605
   Revision: 00H17000
   Coding: 0604100
   Coding: 0000605
   Coding: 0000025
   Coding: 0610725
   Coding: 0302015A
   Coding: 0011422
