Results 1 to 5 of 5
Thread: Long Code for 2010 JSW
    I am trying to get my LED lights on my HID conversion work as DLRs.
    I have a 2010 JSW, any help would be appreciated.
    Here is my scan...
    VCDS Version: Release 12.12.2
    Data version: 20140212
    Tuesday,22,April,2014,21:04:43:35374
    Chassis Type: AJ (1K0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
    VIN: 3VWPL7AJXAM661245
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
       Component: R4 2,0L EDC G000SG  7966
       Revision: 12H03---    Serial number:
       Coding: 0050072
       Shop #: WSC 01404 444 83851
       VCID: 77D3034006476AA6AAD-8022
    001151 - Exhaust Pressure Control Valve
                   P047F - 000 - Stuck Open - Intermittent
                        Mileage: 89777 km
                        Date: 2046.14.15
                        Time: 16:44:16
                        RPM: 989 /min
                        Speed: 20.0 km/h
                        Load: 100.0 %
                        Lambda: 100.2 %
                        Temperature: 48.0C
                        Temperature: 27.0C
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 114B600C492800FB880D06E8921E0042300000
       VCID: 78D1007CCB5965DEA37-802D
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       Shop #: WSC 00066 000 00197
       ROD: EV_ClimaBasis_SE36.rod
       VCID: 75CF0948D44B18B6B81-8020
    13701936 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 15:06:55
       Part No SW: 5K0 937 085 G    HW: 5K0 937 085 G
       Component: BCM PQ35 B++  111 0128
       Revision: BI111001
       Coding: 2D380E1A902F3EC480080081400000C401000086535D8560648020000000
       VCID: 3753C34086C7AAA66AD-8062
       Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 15021  21  0512
       Coding: 009795
    12 Faults Found:
                        Fault Status: 00101010
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 14:21:08
                        Voltage: 11.75 V
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 16:17:17
                        Voltage: 11.80 V
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 14:21:08
                        Voltage: 11.70 V
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 14:21:08
                        Voltage: 11.70 V
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 16:17:16
                        Voltage: 11.65 V
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 16:17:16
                        Voltage: 11.65 V
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                        Fault Status: 00100001
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 15:06:50
                        Voltage: 11.85 V
                        Fault Status: 00100111
                        Reset counter: 34
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 14:50:39
                            Term 15 Off
                        Voltage: 12.30 V
                        Fault Frequency: 13
                        Reset counter: 41
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 16:41:18
                        Voltage: 14.10 V
                        Fault Frequency: 16
                        Reset counter: 41
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 16:17:24
                        Voltage: 11.75 V
                        Fault Status: 01101010
                        Reset counter: 249
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 14:21:07
                        Voltage: 11.65 V
                        Reset counter: 249
                        Mileage: 89799 km
                        Date: 2046.14.20
                        Time: 16:17:16
                        Voltage: 11.80 V
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4D0ACS84
       Coding: 00003044
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3957C578B8D3BCD69C9-806C
       Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
       Component: BF-Gewichtss.  007 0001
       Serial number: ---0000R--000530M700
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME5F44334EZZZ2
       Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME4E46314EZZZ1
       Serial number: 3511HSME7703151FZZZK
       Serial number: 3521HSME2402151FZZZC
       Serial number: 35527SME211F1120ZZZ%
       Crash sensor for front airbag; passenger side:
       Serial number: 35627SME0C467F1FZZZ.
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Component: J0527           056 0111
       Coding: 0000532
       VCID: 78D1007C0B5965DEA37-802D
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0112
       Revision:   H07 01    Serial number: 171209F1002716
       Coding: E9807F07001602002002
       VCID: 69F7553840F3CC562C9-803C
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223T6X9E04
       VCID: FEDD9664A97DDBEE69B-80AB
       Component: IMMO          H03 0305
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EAF5AA340DF5474EA53-80BF
       Part No SW: 3C0 959 701 B    HW: 3C0 959 793
       Component: TUER-SG FT    002 0307
       Revision: 13101005    Serial number: 0000371623
       Coding: 0004B5
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide.rod
       VCID: 277313005E673A26FAD-8072
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000004609071
       Coding: 000490
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: 3147FD58A8A37496249-8064
       Part No SW: 3C0 959 702 B    HW: 3C0 959 792
       Component: TUER-SG BT    002 0307
       Revision: 15101005    Serial number: 0000341681
       Coding: 0004B4
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 2871103C5379355EF37-807D
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000004588934
       Coding: 000490
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H10 0035
       Revision: -----20S    Serial number: VWZ4Z7K3058511
       Coding: 0500040004
       VCID: 61E74D1878C38416F49-8034
                        Reset counter: 244
                        Mileage: 73513 km
                        Date: 2040.14.20
                        Time: 18:05:19
    Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
       Component: RDK           111 0821
       Coding: 018705
    02904 - Hard Warning 3
                        Mileage: 40627 km
                        Date: 2024.14.16
                        Time: 17:06:37
                        Text: 3445299725
                        Pressure: 1.60 bar
                        Pressure: 2.40 bar
                        Temperature: 19.2C
                        Text: E0
                        Speed: 6.0 km/h
    02801 - Hard Warning
                        Mileage: 72788 km
                        Date: 2040.14.19
                        Time: 08:57:41
                        Text: 3445299737
                        Pressure: 1.90 bar
                        Pressure: 2.40 bar
                        Temperature: 10.0C
                        Text: 00
                        Speed: 63.0 km/h
    02903 - Hard Warning 2
                        Mileage: 78982 km
                        Date: 2041.14.28
                        Time: 16:16:20
                        Text: 3454362541
                        Pressure: 2.20 bar
                        Pressure: 2.40 bar
                        Temperature: 22.0C
                        Text: A0
    Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H08 6900
       Revision: 00008000    Serial number: 00000329359718
       Coding: 412100
       Shop #: WSC 01404 444 53924
       VCID: 2A75EA344575074EE53-807F
    Last edited by Uwe; 04-23-2014 at 02:52 PM. Reason: Changed QUOTE tags to CODE tags
    check out my thread over at VW Vortex
    http://forums.vwvortex.com/showthrea...-your-location
    Hobs
    Administrator Andy's Avatar
    Sector 7G
    It looks like you don't have 55-Xenon controller installed so we won't be able to assist as explained here:
    http://wiki.ross-tech.com/wiki/index...t_Retrofitting
    P.S. Retrofits like yours have been know to damage BCM's with problems like non-working wipers, etc. so you should proceed with caution.
    Quote Originally Posted by Andy View Post
    Well so far I have gotten the HID conversion kit to work perfectly. With absolutely no help from you guys on the forums or on the phone..
    Verified VCDS User mitch's Avatar
    England, UK
    A HID kit isn't the same as a proper xenon retrofit.
  6. Likes Uwe, Sebastian, jakematic, Dana liked this post
