2010 Jetta Servotronic Steering - NO POWER ASSIST
El Polaco
Central FL
C?ID=148074
2010 Jetta 2.5 Auto. Owner said the battery was dead so they jumped the car. After jump starting, power steering no longer worked. See below 02614 Steering Box Failure. Fuses appear to be good. Before diagnosing the problem as a defective power steering module/rack I want to rule out all possibilities of a simpler fix. I noticed that in Group 2 the relay voltage is only .75v, I think it was in block #1. I have another Jetta at the shop and the group 2 shows something like 13.7v. Is there a relay associated with the power steering? Also my group #4 shows no values only an error and I'm not getting a reading from the G269 torque sensor. The steering angle sensor works but that's about it. How common are steering rack failures? Any advice appreciated.
J.
Tuesday,01,September,2015,08:57:08:29109
VCDS Version: 15.7.0.2
Data version: 20150820
Dealer/Shop Name: IGA
VIN: 3VWAZ7AJ8AM111272   License Plate:
Mileage: 87650km-54463mi   Repair Order: mike2010jetta
Chassis Type: AJ (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72 77
VIN: 3VWAZ7AJ8AM111272   Mileage: 87650km-54463miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 AG    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9209
   Revision: G6H03---    Serial number:
   Coding: 0000075
   VCID: 73000B49D9FF78EABBBCA2-8026
   Part No SW: 09G 927 750 HG    HW: 09G 927 750 HG
   Component: AQ 250 6F           1631
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 7D142D71EFBB3E9ADDD834-8028
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 114B400C492300FB880D02EB921B0041300000
   VCID: 781A3C65C099DBB28E8E7D-802C
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00146
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75043551D78BAEDA95A85C-8020
   Part No SW: 5K0 937 085 G    HW: 5K0 937 085 G
   Component: BCM PQ35 B++  111 0128
   Revision: BI111001
   Coding: 2D200B1A902F3EE480000085400000040100008641008D605C8020000000
   VCID: 3798FF598D0714CA471436-8062
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 08031  21  0512
   Coding: 009795
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 04 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM02DGCR
   Coding: 0012340
   VCID: 6E361A3DB2DD55025472EB-803A
   Subsystem 2 - Serial number: 6332MSME511353593
   Subsystem 3 - Serial number: 6342MSME4E426F40L
   Subsystem 4 - Serial number: 6351HSME1E43610D9
   Subsystem 5 - Serial number: 6361HSME1F446D71J
   Subsystem 6 - Serial number: 63727SME20145E38/
   Subsystem 7 - Serial number: 63827SME20146835X
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001031
   VCID: 02EE5E8D96454162A02A4F-8056
   Part No SW: 5M0 920 960 E    HW: 5M0 920 960 E
   Component: KOMBI         H14 0112
   Revision: X0014004    Serial number:
   Coding: 270700
   ASAM Dataset: EV_KombiUDSMM9RM10 A04102
   ROD: EV_KombiUDSMM9RM10_VW36.rod
   VCID: 318CC1416363C2FA09D048-8064
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 260110F1002332
   Coding: ED807F07000602001002
   VCID: 693C69218B33B23A0120D0-803C
   Part No SW: 5K0 953 234     HW: 5M0 920 960 E
   Component: IMMO          H14 0112
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
   ROD: EV_ImmoUDSMM9RM10_SE25.rod
   VCID: 6A3E162D8E357122081AC7-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0000520720
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 27B82F195DA78C4AD7B4E6-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004701009
   Coding: 000490
          B11EC 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 61
                    Mileage: 86330 km
                    Date: 2015.08.21
                    Time: 00:26:02
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   VCID: 318CC14163630AFA09D048-8064
02614 - Steering Box
            014 - Defective - MIL ON
                    Fault Status: 11101110
                    Voltage: 12.25 V
                        DD
                    Temperature: 28.0°C
                    Torque: -0.0 Nm
                    Torque: 0.000 Nm
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0000511929
   Coding: 0004B4
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 28BA2C2550B98332DEAEED-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000004678768
   Coding: 000490
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 102
                    Mileage: 86330 km
                    Date: 2015.08.21
                    Time: 00:26:02
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       020 0022
   Revision: 00020000    Serial number: VWZ4Z7K6473382
   Coding: 0042402
   VCID: 20AA34053889B372967E35-8074
Address 65: Tire Pressure (J502)       Labels: 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018705
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000329390786
   Coding: 401100
   VCID: 2ABED62D4EB5B922C89A87-807E
End-------------------------(Elapsed Time: 02:57)--------------------------
Millers Motors
Launceston, Cornwall, UK
C?ID=167727
check the large fuse on the front of the engine bay fuse board, but the last time i had a low voltage reading it was the a replacement rack that sorted it
El Polaco
Central FL
C?ID=148074
All fuses tested out fine. I have a new rack and an updated harness waiting to go in once I get my lift clear. I feel confident that the rack has failed more specifically the J500 module which is part of the rack and according to VW there is no "repair kit" for the Servotronic steering rack. They do have a new harness that goes with the rack and an install kit that looks like a couple of hose clamps and some fancy grease for approximately $40 extra. I got the harness, I'll pass on the install kit. In case anyone wants to read up on the Servotronic steering system, I found this online. http://tos.pp.fi/koukku/892403.pdf It's official VWoA service/training info. It's a good basic overview of what Servotronic does and how it works.
El Polaco
Central FL
C?ID=148074
I installed a new rack last night but ran into an issue. The adaptation channels are correct (I believe) at 01, the steering sensor basic settings was performed, and the steering limit stop adaptation was performed. I was initially having problems getting the basic settings to take place in steering assist but I have since got that straightened out and the steering wheel light is out. The rack is working just fine but it appears to be running a linear curve as the new rack came without a characteristic curve programmed into it. The traction control light is illuminated in amber. I made an appointment to have the new rack flashed at the dealer on Monday. I've attached another scan that shows codes that are currently present. It seems like the steering angle sensor is not being recognized by the ABS but when I go to #44 Steering Assist, group 07, block 1 it shows a good signal that looks accurate to its relationship to the steering wheel. The adaption channel for steering assist should be 01 since this car uses a sensor behind the wheel correct? After speaking with Jef at Rosstech today I thought it was due to the Characteristic map of the J500 but now I'm suspecting something else. Any ideas?
VIN: 3VWAZ7AJ8AM111272   Mileage: 87660km-54469miles
04-Steering Angle -- Status: Cannot be reached 1100
   Coding: 0000075
   VCID: 73000EC9D9FF78EABBBCA2-8026
   Coding: 0000840
   VCID: 7D1428F1EFBB3E9ADDD834-8028
   Revision: 00H30001
   VCID: 781A39E5C099DBB28E8E7D-802C
                    Reset counter: 77
                    Mileage: 87661 km
                    Date: 2015.09.04
                    Time: 09:19:57
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 166
                    Count: 47616
                    Count: 1
                    Count: 256
                    Reset counter: 77
                    Mileage: 87661 km
                    Date: 2015.09.04
                    Time: 09:19:57
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 8212
                    Count: 47616
                    Count: 1
                    Count: 256
   Revision: 00009001
   Coding: 0000001002
   VCID: 750430D1D78BAEDA95A85C-8020
Address 09: Cent. Elect.        Labels: None
   VCID: 55445051374B46DAB568FC-FFFE
No Faults Found
   Coding: 0012340
   VCID: 6E361FBDB2DD55025472EB-803A
   Coding: 0001031
   VCID: 02EE5B0D96454162A02A4F-8056
   Coding: 270700
   VCID: 318CC4C16363C2FA09D048-8064
   VCID: 693C6CA18B33B23A0120D0-803C
                    Reset counter: 77
                    Mileage: 87661 km
                    Date: 2015.09.04
                    Time: 09:11:32
   VCID: 6A3E13AD8E357122081AC7-803E
   Coding: 0004B5
   VCID: 27B82A995DA78C4AD7B4E6-8072
   Slave Driver:
   Coding: 000490
                    Reset counter: 116
                    Mileage: 86330 km
                    Date: 2015.08.21
                    Time: 00:26:02
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 000    3501
   Revision: 00H22000
   VCID: 399CFCE1BB13C2BAB10020-806C
Address 46: Central Conv.
   Coding: 0004B4
   VCID: 28BA29A550B98332DEAEED-807C
   Slave Passenger:
   Coding: 000490
   Coding: 0042402
   VCID: 20AA31853889B372967E35-8074
   Coding: 018705
   VCID: 3798FAD98D0714CA471436-8062
   Coding: 401100
   VCID: 2ABED3AD4EB5B922C89A87-807E
Jef
HQ
From another thread:
01309 - Power Steering Control Module (J500) - Implausible Signal is usually the end result incorrect Adaptation Channel 003 and/or 009 settings in the 44-Steering Assist controller. In other cases that can be due to the wrong steering rack or a used one with incorrect Characteristic Curves. The info on this page should be helpful: VW Golf (1K) Steering Assist
So if the VW dealer says that VIN uses the "MX" rack, lets let them have the final say in the matter and go with this rack, which need to be flashed:
Kl. 000, so hopefully the flash will get some things sorted out.
In the Steering Assist, what are the stored values for Adaptation channels 003 and 009?
El Polaco
Central FL
C?ID=148074
That was it Jef!!!! Adaptation channels 009 was 1-inactive, and needed to be active, the lights are now out and there are no codes on Steering Assist, CAN gateway, or ABS. Car drives really nice and steering feels spot on. I was under the impression that the 09 Adaptation needed to be inactive because the car was using the G85 behind the steering wheel. Thanks for all the help. Rosstech saves the day once again.
