01314 - Engine Control Module - No Communication
royalslim
C?ID=255481
Hi everyone, having a problem with my 2006 Passat 3.6L, I had finished taking the kids to school, came back home all normal. I then came back to drive to work and the car would not start. It cranks, but no start, I hear 3 long beeps and the brake light is flashing on the cluster. Below is a VCDS Scan I did.
What I have done so far is charge the battery, replace the battery, check all fuses, although I'm not sure how to test or see if the grey square fuses inside engine bay are bad, based on the code, I took out the ECU, smelled it to see if I can tell if it is burned or something, looks good, I also looked are the harness going to it, looks clean and normal.
What else can I do troubleshoot these issues? I have tried to clear all codes and start the car and get nothing. I feel the issue is related to the three long beeps and brake light flashing, although the electronic brake is not engaged at all, I rarely use it. Any help is appreciated!
VCDS Version: 15.7.0.2 (x64)
Data version: 20150820
VIN: WVWEU73C56E066967   License Plate:
Mileage: 197960km-123006mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 36 42 44 46 52 53 56 62
          65 72
Address 01: Engine
   Part No SW: 09G 927 750 HK    HW: 09G 927 750 AJ
   Component: AQ 250 6F           1271
   Revision: 00H38000    Serial number:
   Coding: 0000072
   Shop #: WSC 22588 444 54284
   VCID: 0109D23358E18E365A-8054
                    Fault Frequency: 10
                    Reset counter: 0
                    Mileage: 78109 km
                    Date: 2009.04.16
                    Time: 09:54:17
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 N    HW: 3C0 614 095 N
   Component: ESP 440 C2     H015 0001
   Revision:  H015       Serial number: 0657870972
   Coding: 0112077
   Shop #: WSC 05311 000 00000
   VCID: 2D515E83B4F9BA56CE-8078
                    Reset counter: 155
                    Mileage: 197969 km
                    Date: 2015.08.27
                    Time: 21:46:50
                    Reset counter: 155
                    Mileage: 197969 km
                    Date: 2015.08.27
                    Time: 21:46:50
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 Q    HW: 3C0 907 044 Q
   Component: ClimatronicPQ46 042 0202
   Revision: 00042004    Serial number: 00000000000000
   VCID: 2F6D448BBEF5C846FC-807A
                    Reset counter: 156
                    Mileage: 197969 km
                    Date: 2015.08.27
                    Time: 21:46:50
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000001991898
   Coding: F58C8F0340041A00000A00000F00000000285D435C
   VCID: 2B55509B8AEDB466D0-807E
   Subsystem 1 - Part No: 3C1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer VW461  012  0503
   Coding: 00065493
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00208933
   Shop #: WSC 05311
                    Reset counter: 156
                    Mileage: 197969 km
                    Date: 2015.08.27
                    Time: 21:46:00
                    Voltage: 11.70 V
   Part No SW: 8E0 035 593 D    HW: 8E0 035 593 D
   Component: SDAR SIRIUS     H03 0060
   Revision: 00000000    Serial number: AUZ4Z7E4006942
   VCID: 2A5B559F8517AD6E2B-807E
                    Reset counter: 156
                    Mileage: 197969 km
                    Date: 2015.08.27
                    Time: 21:46:57
   Part No SW: 3C0 909 605 G    HW: 3C0 909 605 G
   Component: 0E AIRBAG VW8R  029 2421
   Revision: 09029000    Serial number: 0039VSFAAZV0
   Coding: 0012357
   Subsystem 1 - Part No: 3C0 959 339
   Component: BF-Gewichtsens. 006 0001
   Subsystem 2 - Serial number: 00000000034ZM3
   Subsystem 3 - Serial number: 0001.01.000000600000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332MSME0B187A42Eÿ†63
   Subsystem 5 - Serial number: 87A42Eÿ†6342MSME0B653D0DNÿ†63
   Subsystem 6 - Serial number: 53D0DNÿ†6351HTS68SD27243Xÿ†63
   Subsystem 7 - Serial number: 27243Xÿ†6361HTS68SDUQ7531ÿ†63
   Subsystem 8 - Serial number: UQ7531ÿ†63727TS68SDIONP2Eÿ†63
   Subsystem 9 - Serial number: IONP2Eÿ†63827TS604F2BL33Jÿ
   Subsystem 10 - Serial number: 2BL33Jÿ
   Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
   Revision: 00005000    Serial number: 3C5953507P
   Coding: 0002111
   VCID: 2E53598FB9FFC14EF7-807A
   Component: E0221           006 0080
   Part No SW: 3C0 920 970 H    HW: 3C0 920 970 H
   Component: KOMBIINSTRUMENT VD1 3938
   Revision: X0032000    Serial number: 00000000000000
   Coding: 0007205
   Shop #: WSC 72573 444 00001
   VCID: 2959AA938011A67622-807C
                    Reset counter: 156
                    Mileage: 197968 km
                    Date: 2015.08.27
                    Time: 07:55:26
   Coding: 0007205
                    Reset counter: 156
                    Mileage: 197969 km
                    Date: 2015.08.27
                    Time: 21:46:48
Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
   Revision: 00007000    Serial number: 0700C057160499
   Coding: 3FFD0F04D31002
   VCID: 2149B2B3F8216E367A-8074
                    Reset counter: 156
                    Mileage: 197969 km
                    Date: 2015.08.27
                    Time: 21:46:49
   Part No SW: 3C0 919 965     HW: 3C0 919 965
   Component: Kompass         005 0002
   Revision: 00005000    Serial number: 1166279TN50L04
   VCID: 6DD19E8374797A568E-8038
   Part No SW: 3C0 959 433 C    HW: 3C0 959 433 C
   Component:    IMMO         041 0364
   Revision: 00041000    Serial number: VWZCZ000000000
   Shop #: WSC 22158 444 999999
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 A    HW: 3C0 959 760 A
   Component: Sitzverstellung     0601
   Revision: 00002000    Serial number: 00000000000000
            002 - Lower Limit Exceeded
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1K0 959 701 L
   Component: Tuer-SG         024 2461
   Coding: 0001463
   VCID: 377D7CEB46A50086A4-8062
   Part No: 3C1 909 144 B
   Component: EPS_ZFLS Kl.5   D04 1607
   VCID: 2447BBA7E7337B1E11-8070
                    Mileage: 7960 km
                    Temperature: 35.0°C
                    Voltage: 11.80 V
                    Voltage: 11.60 V
                    Mileage: 7960 km
                    Temperature: 35.0°C
                    Voltage: 5.70 V
                    Voltage: 5.50 V
   Component:    KSG PQ46 RDK 041 0213
   Coding: 13910F8801862E521804141FF00A8F0E081800
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1K0 959 702 L
   Coding: 0001462
   VCID: 387F7FD74BBB0FFEAD-806C
   Revision:   013
   Coding: 0000013
                    Fault Status: 11100100
                    Fault Frequency: 29
                    Reset counter: 156
                    Mileage: 197968 km
                    Date: 2015.08.27
                    Time: 07:55:26
                    Voltage: 11.80 V
                    Count: 241
                    Fault Status: 11101101
                    Reset counter: 156
                    Mileage: 197968 km
                    Date: 2015.08.27
                    Time: 18:54:41
                    Voltage: 11.70 V
                    Count: 224
   Part No SW: 1K0 035 180     HW: 1K0 035 180
   Component: Radio ZSW       015 0037
   Revision: 00015000    Serial number: VWZ5Z7E6276082
   Coding: 0040400
   Shop #: WSC 22588 444 57832
   VCID: 5DB1CE4384D90AD61E-8008
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2432
   Coding: 0000144
   VCID: 316942F3A8C1DEB6EA-8064
   Component:    RDK              0391
   Coding: 0100101
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 326B4DFFADC7E5AE93-8066
End-------------------------(Elapsed Time: 01:59)--------------------------
ECU is clearly off-line. Question is whether this is due to an internal issue with the ECU or perhaps something like missing power to one of the pins on the ECU that requires it. ECUs tend to be expensive, so I'd suggest checking power and ground connections at the ECU's harness first.
Don't forget the fuses.........ignition switch, or terminal 15 and 30 relays.
If you need an ecu we can help with that.
http://europeanpartsemporium.com/?page_id=31
This ecu should be 03H-906-032 series.......
I see low voltage in the BCM 0x09........... so first and foremost make sure the battery isn't too weak by charging or replacement.
royalslim
C?ID=255481
The ECU was taken out of the housing, we found that the pin that controls getting power from the relay or gives power (not sure, looked very technical) was out, the technician fixed it, once plugged back in, before starting car, power to the ECU and relay was checked, looked okay, and the car started right away. Hope this helps others in the future.
Mikchel
Russia
C?ID=230435
Hello, i will continue this topic as i have similar problems. In instrumental panel i have
it is mean that this DTC is happen because of problems with Engine module? And until i won't fix problems in Engine ECU this DTC will be in instrumental panel. Am i right or not?
Thanks,
Wednesday,09,September,2015,19:38:33:54959
VCDS Version: 15.7.0.1
Data version: 20150729
VIN: WVGZZZ7LZ7D072473   License Plate: 848
Mileage: 230720km-143362mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 22 34 36 46 55 56 68 76
VIN: WVGZZZ7LZ7D072473   Mileage: 230720km-143362miles
68-Wiper Electr. -- Status: OK 0000
   Part No SW: 7L0 907 401 F    HW: 7L0 907 401 D
   Component: 3.0L V6TDI  G000AG  0040
   Revision: --H04---    Serial number: VWX3Z0G1581346
   Coding: 0011775
   Shop #: WSC 31414 790 00001
   VCID: 2E53209CBAC1EA4EF4-5140
004501 - Fuel Pressure Regulator Valve (N276)
               P1195 - 001 - Open or Short to Ground - Intermittent
                    Fault Status: 00100001
                    Mileage: 230721 km
                    Date: 2015.09.08
                    Time: 17:06:48
                    Torque: 0.0 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 11.86 V
                    Pressure: 0.0 bar
                    Duty Cycle: 7.9 %
Readiness: 0 0 0 1 1
   Part No SW: 09D 927 750 FA    HW: 09D 927 750 FA
   Component: AL 750 6A           0992
   Revision: 00H61000    Serial number:
   Coding: 0004456
   VCID: 72EBF4EC6E798EAE50-515C
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 K    HW: 7L0 907 379 K
   Component: ESP ALLRAD MK25E1   0302
   Revision: 00H53001
   Coding: 0004482
   VCID: 41896B201C5F653619-8014
   Part No SW: 3D0 909 139 B    HW: 5WK 485 04
   Component:    Kessy            6840
   Revision: 68406418    Serial number: VWX3Z0G1581346
   Coding: 0000232
   VCID: 285FD6849F25B47E3E-807C
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AD
   Component: CLIMAtronic R/L     4326
   Coding: 0001020
   Shop #: WSC 00233 935 95973
   VCID: 72EBF4EC69798EAE50-8026
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2000
   Revision: -0004---    Serial number: --------------
   Coding: 600004003B221C000000000000000000
   VCID: 000FAE2457D5AC3E56-8054
01117 - Generator Terminal DF Load Signal
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234  36 VW8T       0250
   Revision: 92011025    Serial number: 0039P000T31R
   Coding: 0013110
   VCID: 7AFBDCCC3109F6EE18-802E
00592 - Seat Belt Switch; Passenger (E25)
            008 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10101000
                    Fault Frequency: 9
                    Mileage: 208587 km
                    Date: 2015.01.29
                    Time: 13:52:18
   Part No: 7L6 953 549 G
   Component: Lenksaeulenmodul    3501
   Coding: 0010211
   VCID: 43856128064377260B-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 885 J    HW: 7L6 920 885 J
   Component: J0285 KOMBI-INST.   7018
   Revision: KHH06X62
   Coding: 0007101
   Shop #: WSC 13677 002 1048576
   VCID: 43856128024377260B-8016
                    Mileage: 230721 km
                    Date: 2015.09.08
                    Time: 19:17:37
                    Fault Status: 01101101
                    Mileage: 230721 km
                    Date: 2015.09.08
                    Time: 19:34:09
01304 - Radio
                    Mileage: 230721 km
                    Date: 2015.09.08
                    Time: 19:17:38
Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
   Part No: 7L6 815 071 G
   Component: Standheizung E1MAC  0425
   Coding: 0000000
   Shop #: WSC 12345 935 45725
   VCID: 366308FC4191D28EBC-8062
01414 - Combustion-Air Blower (V6)
            010 - Open or Short to Plus
02251 - Heater Unit Locked
Address 19: CAN Gateway        Labels: 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 885 J
   Component: J533  GW-K-CAN TP20 7018
   Coding: 7FE2EF8940056002
   VCID: 70EFFEE46375BCBEA6-8024
01304 - Radio
                    Mileage: 230721 km
                    Date: 2015.09.08
                    Time: 19:17:38
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F0D2DD82D2BD3C62F-515C
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 G
   Component: LUFTFDR.-CDC- 3C3P1 3112
   Coding: 0015521
   VCID: 377D05F8429B2B86A7-8062
   Part No: 7L0 959 760
   Component: Sitzverstellung     0702
   VCID: 77FDC5F8021BEB8667-8022
   Part No: 7L6 959 933
   Component: 12 HSG              7124
   Coding: 0000065
   VCID: 7F0D2DD82D2BD3C62F-4B1A
   Subsystem 1 - Part No: 7L0 959 701 N
   Component: Tuersteuergeraet FS 6302
   Subsystem 2 - Part No: 7L0 959 702 N
   Component: Tuersteuergeraet BF 6302
   Subsystem 3 - Part No: 7L6 959 703
   Component: Tuersteuergeraet HL 0202
   Subsystem 4 - Part No: 7L6 959 704
   Component: Tuersteuergeraet HR 0202
   Subsystem 5 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
   Subsystem 6 - Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
            009 - Open or Short to Ground
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 1288195
   VCID: 397903C0748F3DF651-806C
   Component: AFS-Lst.-Modul l    X008
   Coding: 00000019
   Component: AFS-Lst.-Modul r    X008
   Coding: 00000019
02236 - Stationary Right Cornering Lamp (Right) (M52)
            011 - Open Circuit - Intermittent - MIL ON
                    Fault Status: 10101011
                    Reset counter: 170
                    Mileage: 228750 km
                    Date: 2015.08.20
                    Time: 07:42:16
                    Voltage: 13.63 V
                    Speed: 15.6 km/h
                        ABS 1
Address 56: Radio
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119
   Component: J400__ Front Wiper  5101
   Coding: 0000004
   VCID: 77FDC5F8061BEB8667-8022
   Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
   Component: RLS     210207 020  0105
   Coding: 00208933
   Shop #: WSC 12345
   Part No: 7L0 919 283 F
   Component: 0D Einparkhilfe     1107
00432 - Supply Voltage for Display and Parking Aid Buzzer
00429 - Left Front Parking Aid Display (Y13)
00430 - Front Right Parking Aid Display (Y14)
00431 - Rear Parking Aid Display (Y15)
End-------------------------(Elapsed Time: 03:14)--------------------------
Yes, that is correct. Instrument cluster is aware that ECU is unhappy, and sets this fault code out of sympathy. :)
Mikchel
Russia
C?ID=230435
I see. Thank you. It is my colleague's car. He changed pressure valve on new one but it didn't help. I told him that first he should check wires and when he understand that it is ok change parts. Anyhow thank's again.
WBR,
Mikchel
Russia
C?ID=230435
may be it would help to someone. The reason of low pressure was pump's belt. It was corrupted and in result pump couldn't give required pressure.
webup
Auckland
C?ID=256879
pumps belt for what?
