2016 Golf 110TSI Highline CZDA
Sorry, thread title should be 2016 Golf 110TSI Highline CZDA
Monday,24,August,2015,17:04:38:61863
VCDS Version: 15.7.0.2 (x64)
Data version: 20150820
VIN: WVWZZZAUZGW019700 License Plate: XXXXXXX
Mileage: 21km-13mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 55 5F
VIN: WVWZZZAUZGW019700 Mileage: 21km-13miles
Address 01: Engine (J623-CZDA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 027 HD HW: 04E 907 309 BH
Component: R4 1.4l TFS H22 2325
Revision: R7H22---
Coding: 0125003224641D083000
ASAM Dataset: EV_ECM14TFS01104E906027HD 001004
ROD: EV_ECM14TFS01104E906027HD_VW37.rod
VCID: 6DDA0E84BC6059568E-8038
Readiness: 0110 0001
Part No SW: 0CW 300 048 L HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 0610
Revision: 00005005 Serial number: CU501505046034
ROD: EV_TCMDQ200021_AU37.rod
VCID: 458A9624C450411626-8010
Part No SW: 3Q0 907 379 L HW: 3Q0 907 379 G
Component: ESC H42 0722
Revision: 00000000 Serial number: 61395000001777
Coding: 01FA8AA124211175077E060041C32980512488E0608294F31822503AC282
VCID: 438E883CCA647F2608-8016
Revision: 00021000 Serial number: 0370156626
Coding: 030C0C
VCID: 3A70F5D8BDAE3EEE5B-806E
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120014200100001005000012101402
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6AD005988D8E4E6EEB-803E
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0173
Serial number: 01061514701570
Coding: 03111A46C24122FB4BE44000000C07281800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 09125A14A8C8E57602-805C
Slave 1:
Component: WWS 150514 042 0551
Serial number: 150522061308
Slave 2:
Component: RLHS 037 0059
Serial number: S5Y15M06D06H03M00S41
Coding: 90A8DD
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.403 H03 0004
Serial number: 0000CGQ000416IB00000
Coding: 181901
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431511000118
Coding: 0131165051
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_VW37.rod
VCID: 47969C2CFE5C5306D4-8012
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 08051503212617
Coding: 001C1300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001015
ROD: EV_ACCMRRBoschVW372_AU37.rod
VCID: 3874EFD083A22CFEAD-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR0ERXN+
Coding: 98CCC000000000005C00000000C800000065
VCID: 7F06C4CCE60CDBC62C-802A
Seat belt tensioner; left:
Component: BeltPretRevFL H36 0350
Serial number: 34169677B02061541189
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H36 0350
Serial number: 34169676B03061580914
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 905 15
Serial number: 3576700000098835749
Subsystem 4 - Part No SW: ----------- HW: 480 002 905 15
Serial number: 35867000000F8899749C
Subsystem 5 - Part No SW: ----------- HW: 480 402 005 15
Serial number: 3516502BB1B0CB34C2FT
Subsystem 6 - Part No SW: ----------- HW: 480 402 605 15
Serial number: 3526502B91A91E0442AC
Subsystem 7 - Part No SW: ----------- HW: 480 402 605 15
Serial number: 3556502AD1A91E04D23K
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 26051504401299
Coding: 0C10
ROD: EV_SMLSKLOMQB_SE37.rod
Part No SW: 5G1 920 740 A HW: 5G1 920 740 A
Component: KOMBI 207 7640
Coding: 27A419182F98000800886A095400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005
ROD: EV_DashBoardJCIMQBAB_SK37.rod
VCID: 244C2BA02F2A581E11-8070
16777024 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
Fault Frequency: 15
Reset counter: 44
Mileage: 18 km
Date: 2015.08.21
Time: 08:59:40
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003566162
Coding: 030100343F085700FB00025E1C0F00010001050000000000000000000000
ROD: EV_GatewLear.rod
VCID: 75EA26E4D430919676-8020
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K
Component: E221__MFL-DC1 H16 0040
Serial number: 38150000025120095222
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 2667786803
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Reset counter: 43
Mileage: 20 km
Date: 2015.08.24
Time: 16:41:55
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000137168001
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346CDBE09FCAC89E81-8060
Address 3C: Lane Change (J1086) Labels: None
Component: HRE_Master H11 0071
Serial number: 0368940143
Coding: 02011203
ROD: EV_HREntryHella_SK37.rod
VCID: 3C7CF3C0B79A00DE49-8068
Component: TSG FS 020 0041
Serial number: 190515BEJ01869
Coding: 003A13208001048000001000
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000006280499
Coding: 0D0000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8303
ROD: EV_SteerAssisMQB.rod
Component: TSG BFS 020 0041
Serial number: 130515BED10417
Coding: 003A11208E01048000801000
VCID: 42808D38D57E762E03-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000006330032
Coding: 150000
Component: AFS-ECU H07 0090
Coding: 029E00000B000200
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 40848730DB72643E15-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 846 HW: 3Q0 035 846
Component: MU-S-N-ER 820 0611
Coding: 02730008FF00000051510001000828001F0100D601200102C7
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 6ED80988B166A24EB7-803A
Media Player Position 1:
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4060
Serial number: VWZ6Z9R1560840
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 K HW: -----------
Component: MRM2 2015/16 --- 0420
6691 - Local Data Bus
U10BA 00 [008] - No Communication
Reset counter: 43
Mileage: 19 km
Date: 2015.08.21
Time: 13:23:59
End-------------------------(Elapsed Time: 04:43)--------------------------
