Results 1 to 7 of 7
Thread: Mirrors no longer fold when car locked
    My A5 has just had a second hand CAN gateway fitted, with an extended CAN, during which my battery was disconnected and all my VAGCOM changes were reverted back to factory settings. I've recoded all the modules and everything works, except for some of the keyfob functionality:
    1) the mirrors no longer fold when the car is locked. Strangely they close when I turn on the ignition, then fold out again.
    The door controllers and central electric module long codes, before and after, are identical
    There are no module errors
    Module 46 (central electric) adaptation channel 01 has "folding mirrors installed and active" set
    I retrofitted the mirrors about 8 months ago and both worked perfectly prior to the new gateway being installed. They fold with the driver door switch and the MMI option under central locking is selected. If I de-select the MMI option the mirrors no longer fold in and out when when the ignition is turned on (after the car is unlocked).
    Has anyone come across this before?
    I'm at a loss what to try next.
    16.4905° S, 151.7375° W
    If I am not mistaken, these features you speak of are programed by the user and the instructions I believe were located in the owners manual.
    - A similar feature/function for example.
    drpeter
    The mirrors should fold/retract when I lock the car and did before I installed the new CAN gateway.
    They now fold/retract after I unlock the car and turn on the ignition! They then fold out again.
    Its not a "setting the option in MMI" problem.
    The door controller is processing the instruction to retract the mirrors to late. Could power to the door mirrors now be being switched off earlier than before?
    Perhaps you could provide us with an Auto-Scan of the vehicle so we can see a bit more. Thank you.
    Sure ... (I've removed some of the modules to fit in the 5000 character limit)
    Tuesday,22,January,2013,17:46:46:15913
    VCDS Version: 12.12.0.0
    Data version: 20130910
    Chassis Type: 8T (8T0)
    Scan: 01 03 05 06 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
              77
    08-Auto HVAC -- Status: Status: OK 0000
       Part No SW: 8K0 907 289 C    HW: 8K0 907 289 C
       Component: BCM2.01       H38 0253
       Coding: 031000
       Shop #: WSC 06435 000 00000
       VCID: 397F137AB067BBD693D-806C
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H34 0050
       Subsystem 2 - Part No SW: 8K0 905 852 A    HW: 8K0 905 852 A
       Component: ELVAUDIB8  H33 0039
    Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
       Part No SW: 8T0 959 760 B    HW: 8T0 959 760 B
       Component: MEM-BFS       H09 0042
       Revision: AA000000    Serial number: 00001001032680
       Coding: 08217025002444111000
       Shop #: WSC 06325 000 00000
       VCID: 428D7496DDB1F80EC27-8017
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Component: BCM1 1.0      H21 0253
       Revision: 04021001    Serial number: 00000000037141
       Coding: 260050910014AF210709000000005D5D439D038800010141000000
       Shop #: WSC 39578 001 104857
       VCID: 2F6B2D227E2365663D9-807A
       Subsystem 1 - Part No SW: 8T2 955 119 B    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 190907  H11 0040
       Coding: 00FD11
       Component: RLS  H04 0002
       Coding: 02532C
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8T0 920 981 B    HW: 8T0 920 981 B
       Component: KOMBIINSTR.   H26 0212
       Revision: 00100000    Serial number: 71Y31G2A7
       Coding: 2F05010003002600010000
       VCID: 3B730972BA5B89C6811-806E
       Part No SW: 8T0 907 468 S    HW: 8T0 907 468 J
       Component: GW-BEM 6CAN   H06 0105
       Revision: HB600050    Serial number: 5000H09B1281DE
       Coding: 000003
       Shop #: WSC 06745 128 28888
       VCID: 51AF4BDA08D713964BD-8004
       Subsystem 1 - Part No SW: 8K0 915 181     HW: 8K0 915 181
       Component: J367-BDM  H06 0150
    Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
       Component: MEM-FS        H09 0042
       Revision: AA000000    Serial number: 00001001033362
       Coding: 08297325002444111000
       Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
       Component: TSG FA        H07 1301
       Coding: 011D02225201220102
       VCID: 50A94EDE03DD1A9E443-8005
       Revision: 00002001    Serial number: 0106082436
       Coding: 011F0680003904C0002000
       Component: DWA-Sensor  H02 0030
       Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
       Component: TSG BF        H07 1301
       Coding: 011D02225E01220100
       VCID: 4FAB4DA21EE305665D9-801A
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T2 035 186 C    HW: 8T2 035 186 C
       Component: Concert3      H01 0210
       Revision: 00000003    Serial number: AUZ5Z6H1073986
       Coding: 000200820104CD00C7FBA70102
       Shop #: WSC 06325 123 12345
       VCID: 3879167E8B6DA2DE6C3-806D
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
    Last edited by Uwe; 04-23-2014 at 01:20 PM. Reason: Warpped CODE tags around Auto-Scan
    Quote Originally Posted by d*n View Post
    What 5000 character limit? I just checked the setting where such a limit could be imposed and it's set to 0 which means there is no maximum number of characters per post here.
    It appears the 5000 character limit applies only to PM's
