Hi everyone,
I have a 2015 Audi S3 Sedan, Canada spec, that I'm trying to enable the indirect TPMS.
Here is my auto scan:
I have read this thread http://forums.ross-tech.com/showthread.php?355-Security-Access-ABS-Module and this thread http://forums.ross-tech.com/showthread.php?1903-8V-A3-Tweaks&highlight=audi+tpms regarding the TPMS in the 8V Audi A3/S3s but their unaltered ABS module coding is slightly different than mine and I'm hesitant to make the changes suggested in those threads.
It seems in Sebastian's suggestion to user Veeight, Byte 27's bit 4 and 5 were enabled and Byte 28's bit 7 was enabled to get activate TPMS. Can someone shed some light on whether I could emulate those bit changes to get TPMS?
To add to my confusion, I found an autoscan from user jster here: http://forums.ross-tech.com/showthread.php?3489-Auto-Scan-2015-Audi-A3 of a US spec Audi A3 sedan with standard TPMS.
His ABS long coding seems a lot more similar to mine but it doesn't match what was suggested by Sebastian in the other thread.
Can any expert users or Ross-Tech employee offer some insight or advice regarding what correct coding to use? I would appreciate it very much!
Sunday,23,August,2015,14:36:38:02955
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: License Plate:
Mileage: 5008km-3111mi Repair Order:
Chassis Type: FF (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
5F 6C A5 A9
VIN: Mileage: 5008km-3111miles
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 E HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00322466000E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259E 001003
ROD: EV_ECM20TFS0208V0906259E_AU37.rod
VCID: 42A5BA1ED5845A2E00-8016
Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4521
Revision: 05853104 Serial number: TFK01502040143
Shop #: WSC 04742 780 00200
ROD: EV_TCMDQ250021_AU37.rod
VCID: 1F63136A06B657C64F-804A
Part No SW: 3Q0 907 379 R HW: 3Q0 907 379 G
Component: ESC H42 0711
Revision: 00000000 Serial number: 60325000000111
Coding: 31FF6B9254210A700180030341C3698CD62A5080C08296B6184150880208
ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
VCID: 49B7AD32E8B28976C1-801C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0358587765
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A55C2FEBD5412EE58-806E
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H13 0060
Revision: 20027000 Serial number: 00000000565343
Coding: 03000014010000000000000000001400
VCID: 334BEFDA9A3EE3A69B-8066
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 AC HW: 5Q0 937 085 AC
Component: BCM MQBAB HNA H18 0137
Serial number: 01011503100728
Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 7AD502FEFDD4D2EE18-802E
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 150208 042 0585
Serial number: 150212145619
Coding: 0A47F7
Slave 2:
Component: G397_RLFS H06 0002
Serial number: 23703699
Coding: 00006C
Slave 3:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 09 12 2014 00001112
Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000031795966
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST0004SWWO00000
Coding: 101F00
204293 - Remote key 1
B1479 54 [008] - Missing Calibration / Basic Setting
Reset counter: 231
Mileage: 4874 km
Date: 2015.08.19
Time: 15:38:47
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0051
Revision: -------- Serial number: 39391503401199
Coding: 0070150011
ROD: EV_EPHVA18AU3700000_AU37.rod
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-567.clb
Part No SW: 5Q0 907 567 N HW: 5Q0 907 567 N
Component: ACC3 H10 0400
Serial number: 05021503031112
Coding: 01261701FE0309
ASAM Dataset: EV_ACCBoschMQB 001024
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 46ADA60EF9AC660E2C-8012
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 E HW: 8V0 907 376 E
Component: DAEMPFUNGS-SG H09 0072
Serial number: 310115015
ASAM Dataset: EV_AudiMagneRide 002003
ROD: EV_AudiMagneRide_AU37.rod
VCID: 43ABBF1ACA9E53260B-8016
Component: AirbagVW20 009 0825
Serial number: 003GCR01ED77
Coding: 9DCCFCC00000000050000000C04800000065
VCID: 47B3AB0AFEA67F06D7-8012
Seat belt tensioner; left:
Component: BeltPretRevFL H36 0350
Serial number: 34178311B09021541043
Coding: 333135
Seat belt tensioner; right:
Component: BeltPretRevFR H36 0350
Serial number: 34178312B09021541197
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 502 15
Serial number: 357000000002FA39231H
Subsystem 4 - Part No SW: ----------- HW: 480 000 502 15
Serial number: 3580000000098A39231I
Subsystem 5 - Part No SW: ----------- HW: 480 402 801 15
Serial number: 3510002B31901D9473C+
Subsystem 6 - Part No SW: ----------- HW: 480 400 302 15
Serial number: 352000299196FF55F21I
Subsystem 7 - Part No SW: ----------- HW: 480 400 801 15
Serial number: 3550002991901DA283A4
Subsystem 8 - Part No SW: ----------- HW: 480 400 801 15
Serial number: 3560002991901DA4D0ED
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 ED HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 11021508490099
Coding: E818
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 002170169B08883E56-8054
Part No SW: 8V0 920 871 D HW: 8V0 920 871 D
Component: KOMBI H02 4292
Coding: 0B8D181B7E8800080281EA001800000000000000
VCID: 3D5FC9E2AC7A25D67D-8068
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 07021510800817
Coding: 0101000830085A005B00023C980B00000001010000000000000000000000
ROD: EV_GatewConti.rod
VCID: 72C52ADEA5A4AAAE50-8026
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 28 01 2015 C0081727
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 D HW: 0CQ 525 130
Serial number: HA1-00009.01.15
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000028949002
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 3449ECC69F30E49E82-8060
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0355726899
Coding: 030211
ROD: EV_LaneChangAssis_AU37.rod
VCID: 3851D8F6835800FEAE-806C
Lane Change Assistant 2:
Part No SW: 5Q0 959 593 D HW: 5Q0 959 593 B
Component: TSG FS 020 0028
Serial number: 260115BAQ04018
Coding: 005D1F204000048000000003
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
Part No SW: 3Q0 909 144 H HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5061
Coding: 9102
ROD: EV_SteerAssisMQB.rod
VCID: 3753DBCA8E460F86A7-8062
Part No SW: 5Q0 959 592 D HW: 5Q0 959 592 B
Component: TSG BFS 020 0028
Serial number: 280115BAS00215
Coding: 005D17204C00048000000003
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 41A7B512D082413619-8014
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Coding: 0122000123200400
ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
VCID: 3FA3B3EAA67637C66F-806A
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo links H01 7050
Coding: E00100
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M
Component: LeiMo rechts H01 7050
Coding: E00100
5544753 - LED Headlamp Power Output Stage; Right
B149B 31 [008] - No Signal
Reset counter: 237
Mileage: 4959 km
Date: 2015.08.21
Time: 09:07:33
Part No SW: 8V0 035 047 B HW: 8V0 035 047 B
Component: MU-H-NS-US H43 0394
Serial number: A052B0FB005021
Coding: 017301020000000021220002041A00002F000224010001047E
ROD: EV_MUHig6C3HBAS_AU37.rod
Engine Control Module 2:
Subsystem 1 - Part No SW: V03 959 800 SS HW: -----------
Component: NAR 2015 --- 0035
Seat Adjustment Driver Side:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9EY202JL4
Sound System:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: C1000015121400040420
Door Electronics Rear Left:
Component: Gracenote --- 3006
B11CF 53 [009] - Deactivated
Reset counter: 159
Mileage: 4008 km
Date: 2015.07.23
Time: 14:25:45
Address 6C: Back-up Cam. (J772) Labels: 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_CamSysRearPANAAU914.rod
VCID: 3041E0D66B28D8BEE6-8064
Address A5: Frt Sens. Drv. Assist (R242) Labels: 5Q0-980-653.clb
Part No SW: 5Q0 980 653 F HW: 5Q0 980 653
Component: MQB_MFK H06 0052
Serial number: 00000280594
Coding: 0100000000010303000500010100000100
ROD: EV_MFKBoschAU370_AU37.rod
VCID: 3B5BC7FAB26E2BE643-806E
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 150131200042
VCID: 7DDF09E2ECFAE5D63D-8028
End-------------------------(Elapsed Time: 04:15)--------------------------
My original code: | 31FF6B9254210A700180030341C3698CD62A5080C08296B6184150880208 |
User Veeeight's original code: | 30F193A254252A75017C070641C5690CC92A5480E08296F6F84150080608 |
Code change suggested by Sebastian to enable TPMS: | 30F193A254252A75017C070641C5690CC92A5480E08296F6F84150388608 |
User jster's:
Address 03: ABS Brakes Labels: None
Revision: 00000000
Coding: 13FF6A9234280A6E0177030381CC29C8562C5080C08194B4184150588208
ROD: N/A
VCID: 49D5CE27735D8A0346CD3D-801C
Mine:
