Results 1 to 3 of 3
Thread: Audi A4 B8 MFSW install problem
    New User
    Aug 2015
    Hello All
    I try to install my car a multifunction steering wheel and at the same time change the slip ring.
    My problem is that VCDS announces an old slip ring information. I changed the slip ring version (8K0 953 568 E) to version (8K0 953 568 F) there is no errors after change but VCDS shows the steering wheel in further 8K0 953 568 E data.
    When i try code VCDS steering wheel buttons, it gives me an error coding rejected error 31 request out of range
    I wonder if somebody telling that what i should do for that, so I could get the ring and the steering wheel buttons to operate?
    My car is Audi A4 B8 -09 avant
    Tartu, Estonia
    Autoscan of car is needed.
    The world is my oyster...
    New User
    Aug 2015
    Here is a scan
    VCDS Version: Release 15.7.0 Running on Windows XP x86
    Chassis Type: 8K (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 55 56 62 72
    VIN: WAUZZZ8KXAA105015   Mileage: 159910km-99363miles
    Address 01: Engine (J623-CAGA)       Labels: 03L-906-019-CAG.clb
       Part No SW: 03L 906 022 RL    HW: 03L 906 019 AL
       Component: R4 2,0L EDC   H32 8435
       Revision: 25H32---
       Coding: 12194012232603080000
       Shop #: WSC 11400 205 999999
       ASAM Dataset: EV_ECM20TDI03L906022RL A02006
       ROD: EV_ECM20TDI03L906019AL.rod
       VCID: 0037C29D9B38E13E56-8054
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 AL    HW: 8K0 907 379 AL
       Component: ESP8 quattro  H04 0080
       Coding: 180504
       Shop #: WSC 06325 000 00000
       VCID: 033DCD91822EFA264B-8056
       Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
       Component: BCM2 1.1      H02 0326
       Coding: 032200
       VCID: 0131C7999832E83659-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Part No SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
       Component: KLIMA 1 ZONE  H08 0171
       Revision: A1000000    Serial number: 01071220091535
       Coding: 34200000
       VCID: 77C5A941C6F6A68667-8022
                        Reset counter: 226
                        Mileage: 159910 km
                        Date: 2009.06.26
                        Time: 00:01:28
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000410358
       Coding: 0600D09140349F010001000300001909001C070804010101000000
       VCID: 3C4F766DBF5045DE4A-8068
       Component: WWS 041209  H06 0070
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AJ    HW: 8K0 941 531 AJ
       Component: E1 - LDS  H08 0090
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
       Component: AirbagVW-AU10 H39 0560
       Serial number: 003EFD084KUL
       Coding: 30343435363030303030554A304C384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 41B10799D0B2283619-8014
       Serial number: 6334MSME4D733653H
       Serial number: 6344MSME4D454D5AW
       Serial number: 6352QSME314652244
       Serial number: 6362QSME634513145
       Serial number: 637
       Serial number: 63832SME5A471204X
       Part No SW: 8K0 953 568 E    HW: 8K0 953 568 E
       Revision: --------    Serial number: 90304IKU00080
       Coding: 000007
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
       Component: KOMBIINSTR.   H20 0255
       Revision: 00100000    Serial number: CIY67W8D9
       Coding: 0F0D110002000008010000
       Shop #: WSC 06325 123 12345
       VCID: 2E6B4C25792CA74EF4-807A
    Address 19: CAN Gateway        Labels: 8T0-907-468.clb
       Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 GW-BEM 5CAN   H06 01050105
       Coding: 00CF07
       VCID: 509732DD03D8D1BE86-8004
       Component: J367-BDM  H07 0125
       Subsystem 2 - Part No: 8K0 959 663
       Component: J532_DCDCStab
    No Faults Found
       Part No SW: 8K0 959 793 J    HW: 8K0 959 793 E
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000102433847
       Coding: 011002204000410001
       VCID: 47A51981F6961606D7-8012
       Revision: 00002001    Serial number: 0124683784
       Coding: 01000620203904400020023680000000
       Part No SW: 8K0 959 792 J    HW: 8K0 959 792 E
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000102449009
       VCID: 46BB1485F19C0F0E2C-8012
       Revision: 00000003    Serial number: 00000000523000
       VCID: 345F5E4D97008D9E82-8060
       Part No: 8K5 907 357 A
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 38476A7D4B6869FEAE-806C
    Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
       Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
       Component: Concert3      H05 0310
       Revision: 00000008    Serial number: AUZ5Z6I1320526
       Coding: 050204800402C5000159870900
       VCID: 44BF0E8DC7A03D1E32-8010
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
    03138 - Input AUX IN
                        Fault Status: 00101011
                        Reset counter: 227
                        Mileage: 159910 km
                        Date: 2009.06.26
                        Time: 01:05:40
                        Reset counter: 187
                        Mileage: 159910 km
                        Date: 2009.06.26
                        Time: 01:23:59
                        Reset counter: 187
                        Mileage: 159910 km
                        Date: 2009.06.26
                        Time: 01:28:10
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000102488244
       Coding: 010002204000210001
       VCID: 42B30895DDB4332E00-8016
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000102480983
    End-------------------------(Elapsed Time: 02:09)--------------------------
