Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: BCM Upgrade problems - Jetta MK6 Sedan
    Hi all,
    I have a 2011 UK Jetta Sedan 2.0 TDI 140PS. 'Type' is listed in the service schedule as 162372.
    I recently fitted front fog lights, only to discover my 5K0 937 084-F BCM didn't have the pins for the left and right fog. I then purchased a brand new 1K0 937 087-AN BCM and fitted this. I also bought a rain light sensor to fit.
    I fitted the BCM and the RLS and some new wires into the new BCM as follows:
    Pin A21 - Front Fog Signal from euro switch
    Pin A25 - Power for Left Fog
    Pin C25 - Power for Right Fog
    Pin B33 - Pin 3 from RLS ***Note, there was no existing cable in this pin!
    After I fitted the BCM, I noticed a few problems with lighting etc, but I got these sorted after a while and a lot of help from a friend who knows a lot more about VCDS than me. My one major remaining issue has him stumped, so I'm looking for some help here. The RLS is registering light and rain in the measuring blocks when I experiment with water and cover the sensor with my hand, so I know its connected properly. It is now available as a dropdown subsystem of the main BCM in the VCDS coding window, so all looks ok. The rain closing feature also works, but I haven't got playing with the auto wipers yet because of my problem, which I will explain below:
    My problem is with the wipers behaving strangely. They were like this after I installed the BCM and before I installed the RLS, so don't think it's the cause. When I run an autoscan, there is a "Windshield Wiper Stop Switch (F229) Implausible Signal" fault. How this appears is, when I switch on the car with the wiper stalk in the off position, the wipers do several sweeps and stop in a random place. I have to gently jab the down (one wipe) option on the wiper stalk to try and coax the wipers home to the correct position, which can take a few minutes and is very annoying! Before I changed the BCM, in the coding window I had a dropdown menu with "DWA Sensor" and "LIN Backup" available for coding, in addition to the main BCM. Now I only have main BCM and RLS. The other two don't appear on the dropdown menu, even though they appear in the autoscan. My friend thinks there is something not right with the LINBUS system if they aren't displayed on the dropdown, so this is causing the system not to see the wiper stop switch anymore.
    Has anybody got any ideas on why my wipers are behaving like this or why the implausible signal is appearing on the autoscan?
    Any help or comments appreciated.
    Regards,
    Kieran.
    **************** AUTOSCAN BELOW ***********************
    Tuesday,22,April,2014,08:38:25:46798
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WVWZZZ16ZBM073***   License Plate:
    Mileage: 21429   Repair Order:
    Chassis Type: 16 (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 4C 52 56 62 6C 72
              77 A6
    4C-Tire Pressure II -- Status: Not registered 0001
    6C-Back-up Cam. -- Status: Cannot be reached 1100
    A6-Microphone -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
       Part No SW: 03L 906 018     HW: 03L 907 309 R
       Component: R4 2,0L EDC   H22 7453
       Revision: 42H22---    Serial number: 00000000000000
       Coding: 00190012042500080000
       Shop #: WSC 00066 000 00083
       ASAM Dataset: EV_ECM20TDI01103L906018 003010
       ROD: EV_ECM20TDI01103L906018_VW32.rod
       VCID: E7F3D0861EDB9A26BAD-80B2
       Revision: 00H31001
       Coding: A63B40F8092900FD651102E9901B0082250400
       Shop #: WSC 00066 123 12345
       VCID: 7BDB1CF6FA53AEC6CE5-802E
    Address 08: Auto HVAC (J301)       Labels: 7N0-907-426.clb
       Part No SW: 7N0 907 426 K    HW: 7N0 907 426 K
       Component: AC Manuell    H17 0202
       Revision: 00012001
       Coding: 0000000002
       Shop #: WSC 00066 000 00147
       ROD: EV_ClimaBasis_SE36.rod
       VCID: 3C59DFEAB7DD69FE87F-8069
       Part No SW: 1K0 937 087 AN    HW: 1K0 937 087 AN
       Component: BCM PQ35  H+  112 0771
       Revision: AF112771
       Coding: 08000A38E82FE1C044080080010083A047708C8850A08160DC8000000040
       VCID: 7DDF12EEE447A0F6F01-8028
       Component: RLS 080213 05  54  0403
       Coding: 0730AD
       Subsystem 2 - Part No: 1K8 951 171
       Subsystem 3 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HO  H11 9004
    00077 - Windshield Wiper Stop Switch (F229)
                        Fault Frequency: 46
                        Reset counter: 72
                        Mileage: 34342 km
                        Date: 2036.14.03
                        Time: 08:55:38
                        Voltage: 11.80 V
                            Term 50 Off
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Serial number: 003G6R016KVO
       Coding: 00003141
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3245F1D26599AF8E5D3-8067
       Serial number: 3572MSME30705359ZZZP
       Serial number: 3582MSME0B6C635AZZZ4
       Serial number: 3516KSME5A27120EZZZU
       Serial number: 3526KSME255F130EZZZZ
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101220200137
       Coding: 0082140000
       Shop #: WSC 00066 123 00158
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76CD0DC2C971F3AEB1B-8023
       Component: E221__MFL-TAS  H07 0013
       Coding: 820000
       Part No SW: 5C6 920 970 A    HW: 5C6 920 970 A
       Component: KOMBI         H20 0420
       Coding: 471B01
       Shop #: WSC 00066 123 00147
       ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
       VCID: 2A75E9B24D49E74EE53-807F
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 07021101210317
       Coding: 351003
       VCID: 3041FBDA63959D9E2B7-8065
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:58:49
                        Fault Frequency: 33
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:58:45
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:58:49
    03753 - Control Module for Microphone
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:58:49
       Component: IMMO          H20 0420
       ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
       VCID: EAF5A9B20DC9A74EA53-80BF
       Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
       Component: SG EXT.PLAYER H13 0150
       Revision: A1001003    Serial number: 7669094348
       VCID: 287113BA5B45D55EF37-807D
       Part No SW: 3C0 035 279 N    HW: 3C0 035 279 N
       Component: RNS315-EU   H52 0319
       Serial number: VWZAZ2M5960147
       Coding: 040004510400000000000000
       Shop #: WSC 01383 790 50316
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2E7DE5A271A18B6E39B-807B
       Component: EUR_W_0038  0038
    1048659 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 67
                        Mileage: 34303 km
                        Date: 2036.14.01
                        Time: 09:16:10
    1048665 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 67
                        Mileage: 34303 km
                        Date: 2036.14.01
                        Time: 09:16:10
       Revision: 13110009    Serial number: 0001966803
       Coding: 0002B5
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: DB9BFC76D293CEC62E5-808E
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R
       Component: J389__TSG-HR  006 1409
       Serial number: 00000005520408
       Coding: 000290
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 69     3201
       Revision: 00H20000
       VCID: 3449F7CA578DA1BE4FF-8061
    Last edited by km_connolly; 04-23-2014 at 01:42 PM. Reason: Wrapped CODE tags around Auto-Scan
    United States
    Did you configure that replacement PQ35 BCM by copy and pasting the original coding directly into the new module to baseline it?
    http://wiki.ross-tech.com/wiki/index...le#Replacement
    Either way, please post the scan with the original controller installed because I suspect it will show the LIN subsystem Component: Wischer
    -Dana
    Hi Dana,
    I actually went through every bit of every byte and made sure everything was the same. I then compared the two codes to make sure they were the same and they were.
    This is the original scan the evening before I removed the old BCM: (I will post the new scan immediately after installing and coding the new BCM below it):
    ********OLD BCM SCAN*********
    Friday,18,April,2014,21:22:33:46798
    Mileage: 21262   Repair Order:
              77 A6
    4635 - Engine Oil Temp. Sensor (G8)
              P0196 00 [032] - Implausible Signal
                        Mileage: 34099 km
                        Date: 2035.14.31
                        Time: 16:00:28
       Revision: 00H31001
       Revision: 00012001
       Coding: 0000000002
       Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
       Component: BCM PQ35 B    011 0046
       Revision: BA011001
       Coding: 08000A38882FE1C044080080050000E047600088508081605C8000000040
       VCID: 354FCACE9CF7B8B6781-8060
       Subsystem 1 - Part No: 1K8 951 171
       Subsystem 2 - Part No: 1K8 951 605 A
       Coding: 00003141
       Coding: 0082140000
       Coding: 820000
       Coding: 471B01
       Coding: 351003
                        Reset counter: 28
                        Mileage: 32821 km
                        Date: 2035.14.13
                        Time: 21:38:36
                        Fault Frequency: 91
                        Mileage: 32821 km
                        Date: 2035.14.13
                        Time: 21:38:32
                        Reset counter: 28
                        Mileage: 32821 km
                        Date: 2035.14.13
                        Time: 21:38:36
                        Reset counter: 28
                        Mileage: 32821 km
                        Date: 2035.14.13
                        Time: 21:38:36
              U1111 00 [009] - -
                        Reset counter: 28
                        Mileage: 32821 km
                        Date: 2035.14.13
                        Time: 21:38:58
              U1111 00 [009] - -
                        Reset counter: 28
                        Mileage: 32821 km
                        Date: 2035.14.13
                        Time: 21:38:58
       Coding: 0002B5
       Slave Driver:
       Coding: 000290
       Revision: 00H20000
       Revision: 15110009    Serial number: 0001943680
       Coding: 0002B4
       ROD: EV_TSGBPQ35BRFVW46X.rod
       VCID: DC99FF6AD79DC9FE27F-8089
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R
       Component: J388__TSG-HL  006 1409
       Serial number: 00000005475001
       Coding: 000290
    ********NEW BCM SCAN*********
    Saturday,19,April,2014,16:15:42:46798
    Mileage: 21292   Repair Order:
              77 A6
       Revision: 00H31001
       Revision: 00012001
       Coding: 0000000002
       Revision: AF112771
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:57:47
                        Voltage: 13.80 V
                            Term 50 Off
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:57:52
                        Voltage: 13.85 V
                            Term 50 Off
       Coding: 00003141
       Coding: 0082140000
       Coding: 820000
       Coding: 471B01
       Coding: 351003
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:58:49
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:58:45
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:58:49
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:58:49
              U1111 00 [009] - -
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:59:23
              U1111 00 [009] - -
                        Reset counter: 66
                        Mileage: 34268 km
                        Date: 2036.14.01
                        Time: 01:59:23
       Coding: 0002B5
       Slave Driver:
       Coding: 000290
       Revision: 00H20000
       Coding: 0002B4
       Slave Passenger:
       Coding: 000290
    Note - I have just edited a typing error in my initial post to show that my old BCM was a 5K0 937 084-F and my new BCM is a 1K0 937 087-AN. Not sure if this makes a difference?
    Thanks.
    Anything on this Dana? I don't see the Wischer component in there.....
    Dana,
    Are you able to help me on this?
    Regards,
    Kieran.
  7. #7
    Mackay Qld Australia
    The Wischer component i think is for the rear window wiper as fitted to Golfs & Tiguans. The Jetta does not have a rear wiper.
    I have attached a module 9 coding from a 2012 RHD Australian spec Jetta 6 FYI & comparison. Have alook at this in longcoder.exe and also check the coding of the RLS sensor itself.
    I have ALSO had a look at your coding in longcoder and Byte 21 Bit 5 (Rain/Light Sensor (RLS) installed) should also be ticked on ie A0
    Part No SW: 5K0 937 084 H HW: 5K0 937 084 H
    Component: BCM PQ35 B 021 0068
    Revision: BA021001
    Coding: 00000A3A982D00C040880080040000640370008850A081605C8000000040
    VCID: 3753E64286B83CA67F3
    Component: RLS 290612 05 54 0403
    Coding: 02300A
  8. #8
    Thanks for that bambazonke.
    I tried this coding, but none of it changed the wiper problem and the fact that The "LIN BACKUP" and the "DWA sensor" don't seem to be recognised properly as components.
    Has anybody else got any suggestions?
  9. #9
    United States
    Kieran Something looks goofy with the before and after slaves:
    This car did not have a Wischer, so I wouldn't expect one to communicate now, but all of the slaves are on a LIN (single wire) bus. For this reason I would unplug that RLS and scan the car to see if Coding shows up at all. It doesn't look like they were communicating properly in the original scan and all coding info is missing in the latest scan.
    The Wischer component is the front wiper module/motor but our NAR market (A3) "NMS" Passat (the NMS is basically a large Jetta rather than a real RoW B7 Passat) and the (16) Jetta do not seem so use diagnostic capable wiper motors anymore.
    My previous 2010 Gti
    Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
    Component: BCM PQ35 H+ 103 0576
    Revision: 00103 AC
    Coding: 6E180A3E80272AC48088008555008984417F1586434D8D6064 9120200000
    Shop #: WSC 06483 444 12345
    VCID: 356A218D9C5A571
    Component: Wischer 30060 21 0501
    Coding: 009795
    My Current 2012 Tiguan:
    Part No SW: 5K0 937 086 L HW: 5K0 937 086 L
    Component: BCM PQ35 M 011 0048
    Revision: BJ011001
    Coding: 6F180A1B88232EC4008800C134000D4448550006576D8DF0E4 840000A040
    Shop #: WSC 01324 020 00200
    VCID: 3D7A39ADA47A56F00A3
    Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
    Component: Wischer 20061 013 0203
    Coding: 009795
    Component: RLS 170611 05 54 0403
    Coding: 02304D
    Andy's 2012 NMS:
    Part No SW: 5K0 937 085 P HW: 5K0 937 085 P
    Component: BCM PQ35 B+ 011 0047
    Revision: BH011001
    Coding: 6F200EB8F82B28D408880001360004C84071008E50A0056064 8060000C70
    Shop #: WSC 09003 957 00200
    VCID: 40845869D3C9AB34C6-8015
    Component: RLS 080911 05 54 0403
    Coding: 06300A
    On this topic, if you happen to check out RHD vehicle scans the Wischer is usually a xx2 955 119 (2 for RHD).
  10. #10
    Hi Dana,
    I will unplug the RLS and do another scan but the "after" scan was done several days before I attached the RLS to the windscreen and plugged it in. It doesn't actually appear in the immediate after scan. If you look at the scan in my first post, this shows the RLS.
    Regards,
    Kieran.
