Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: A8 led matrix
    Aug 2015
    Romania
    A8 led matrix
    Hi. I've done this retrofit and have issue with matrix basic setting. Anyone know how to make this basic settings with VCDS? I send car to dealer but they couldn't do it also. Also I have dtc about no comunication between gateway and adress 55. I connect module to can extended as in Elsa wiring. Any help is welcome. Thank you.
    Tuesday,04,August,2015,16:31:57:42648
    VCDS Version: 15.7.0.1
    Data version: 20150729
    VIN: WAUZZZ4H5DN027234   License Plate:
    Mileage: 92339km-57376mi   Repair Order:
    Chassis Type: 4H (4H0)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 28 34 36 3B 42 46 47
              48 52 53 55 56 57 5B 5F 62 6C 6D 6F 72 81 85 88 89 8A 8D 8E
              8F 90
    VIN: WAUZZZ4H5DN027234   Mileage: 92339km-57376miles
    48-Seat, Rear, DS -- Status: OK 0000
    55-Headlight Range -- Status: Cannot be reached 0100
    5B-Seat,Rear,PS -- Status: OK 0000
    8A-Multicont. Seat Rear,DS -- Status: OK 0000
    8D-Multicont. Seat Rear,PS -- Status: OK 0000
    Address 01: Engine (J623-CDTA)       Labels: 059-907-401-V2.clb
       Part No SW: 4H0 907 401     HW: 4G0 907 401
       Component: 3.0TDI EDC17  H40 0006
       Revision: 53H40---
       Coding: 0A2A4012052601020000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TDI0114H0907401 001012
       ROD: EV_ECM30TDI0114H0907401.rod
       VCID: E1C3BA52F0EFB236B9-80B4
    Address 02: Auto Trans (J217)       Labels: 0BK-927-156.clb
       Part No SW: 4H1 927 158 BG    HW: 0BK 927 156 AG
       Component: 0BK 30 TDIRdW H16 1005
       Revision: --H16---
       Coding: 000001
       ASAM Dataset: EV_TCMALX51011 002018
       ROD: EV_TCMALX51011_AU64.rod
       VCID: F6E9F90E4961258EFC-80A2
       Part No SW: 4H0 907 379 D    HW: 4H0 907 379 D
       Component: ESP PREMIUM   H10 0352
       Coding: 60E5E30006A7C700E300
       ASAM Dataset: EV_ESPPremi 005013
       ROD: EV_ESPPremi_AU64.rod
       VCID: B36F001A1A9370A61B-80E6
       Part No SW: 4H0 907 064 CB    HW: 4H0 907 064 CB
       Component: BCM2 2.0      H33 0433
       Coding: 01A73046000000000000
       Shop #: WSC 02313 785 00200
       VCID: EBDFD87A0A23E86613-80BE
       Revision: AA000000    Serial number: 00000051862550
       Coding: 0018B60000047201000001010101112131313333283333
       VCID: B46D0306179D779E02-80E0
    Address 08: Auto HVAC (J255)       Labels: 4H0-820-043.clb
       Part No SW: 4H0 820 043 K    HW: 4H0 820 043 K
       Component: Klima 4 Zonen H20 0130
       Coding: 360102BE3C
       ROD: EV_AirCondiFront_AU64.rod
       VCID: A855E776D355037EBE-80FC
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063-V1.clb
       Revision: 11012002    Serial number: 00000001521967
       Coding: 0105001440349FE18B810007A0001800009CC3080E000101800008546F01
       Shop #: WSC 17000 111 123456
       VCID: EFE7CC6A3E3B14463F-80BA
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 130120  H35 0080
       Coding: 0045F7
       Component: RLS  H04 0003
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Coding: 020300
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
    01771 - Control Module for Headlight Range (J431)
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 15:43:00
    Address 10: Park/Steer Assist (J446)       Labels: 4H0-919-475-7X2.clb
       Revision: 11001001    Serial number: 61061306000814
       Coding: A8030E
       ROD: EV_EPHVA18AU57X0000.rod
       VCID: F1E3CA12200F02B629-80A4
    Address 15: Airbags (J234)       Labels: 4H0-959-655.clb
       Revision: --------    Serial number: 003JG00C4N5$
       Coding: 30314246323430303032554A304C34483053
       ROD: EV_AirbaAU10BPAAU64X_AU64.rod
       VCID: B669390E09E1658E3C-80E2
       Serial number: 3575HRB400K50EV48A32
       Serial number: 3585HRB401650E6E7PVH
       Serial number: 3515JRB401050ET871IT
       Serial number: 3525JRB401050ET8PHQT
       Serial number: 3554VRB400C50DEOA9LQ
       Serial number: 3564VRB401A50DEOOPUM
    Address 16: Steering wheel (J527)       Labels: 4H0-953-568.clb
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90815MB10000P
       Coding: 0000B4
       VCID: B777340A06EB9C8627-80E2
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Component: E221 - MFL  H08 0009
    02795 - Steering Wheel Vibration Motor (V331)
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 15:43:34
    Address 17: Instruments (J285)       Labels: 4H0-920-xxx-17.clb
       Part No SW: 4H0 920 900 M    HW: 4H0 920 900 M
       Component: TDieRDW------ H50 0515
       Revision: 34081076    Serial number: 658230213592002
       Coding: 13A60800534400080D0000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K.rod
       VCID: AD5B1662FCB726564D-80F8
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0225
       Serial number: 2130221005358
       Part No SW: 4H0 907 468 AC    HW: 4H0 907 468 AC
       Component: J533--Gateway H12 0037
       Revision: --------    Serial number: 00000000839508
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001018
       ROD: EV_GatewPkoUDS.rod
       VCID: F2E1C51E250939AED0-80A6
       Subsystem 1 - Part No SW: 4H0 915 181 F    HW: 4H0 915 181 F
       Component: J367-BDM  H08 0181
       Serial number: 00000000004971005640
       Voltage stabilizer:
    5013 - Headlight Range Control Module
              U101E 00 [009] - No Communication
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 15:43:39
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Part No SW: 8K0 857 511 F    HW: 8K0 857 511 A
       Component: FLA           H04 0020
       Revision: AA001002
       Coding: 04018B6B74745D545420363E00
    Address 28: HVAC, Rear (E265)       Labels: None
       Part No SW: 4H0 919 158 K    HW: 4H0 919 158 K
       Component: Klima Fond    H16 0121
       Coding: 2000000000
       ROD: EV_AirCondiHeck_AU64.rod
       VCID: B875373603F593FE2E-80EC
    Address 34: Level Control (J197)       Labels: 4G0-907-553.clb
       Part No SW: 4H0 907 553 E    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0099
       Coding: 008000
       ROD: EV_AirSuspe_AU64.rod
       VCID: AE59116EF1B15D4E74-80FA
       Revision: AA000000    Serial number: 00000051862551
       Coding: 0018B78000857201020001010101112131313333203333
       Part No SW: 4H0 907 637 K    HW: 4H0 907 637 F
       Component: SARA 6D       H02 0056
       Revision: --------    Serial number: EJ1BPA7700KWCT
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2_AU57.rod
       VCID: B777340A0EEB9C8627-80E2
       Part No SW: 4H0 959 793 R    HW: 4H0 959 793 G
       Component: TSG FA        H06 0273
       Revision: --------    Serial number: 0000053461567
       Coding: 011F12005E0062C202083006
       Shop #: WSC 02312 785 00200
       VCID: C89547F67B15E37E5E-809C
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0300722738
       Coding: 011A062000B93584B320C7C40A01010F0000000000000000000000000000
       Subsystem 1 - Part No: 4H0 951 177
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.030  H07 0006
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 G    HW: 4H0 947 135 G
       Component: Dachelektroni  H13 0080
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS010  H05 0005
       Revision: CJ007001    Serial number: 00000000036215
       Coding: 030000
       VCID: 9D3BC6A28417D6D6DD-80C8
    Address 48: Seat, Rear, DS (J876)       Labels: None
       Part No SW: 4H0 959 860     HW: 4H0 959 860
       Component: MEM-FS-Fond   H06 0155
       Revision: AA000000    Serial number: 00000049984493
       Coding: 001892800000700D0A00392038193A2039203B3B202020
       VCID: F1E3CA12280F02B629-80A4
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H06 0273
       Revision: --------    Serial number: 0000051657748
       VCID: BC7D2B263FCDBFDECA-80E8
       Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
       Component: EPB-4         H03 0013
       Revision: --------    Serial number: 00000000605748
       ROD: EV_ParkiBrake_AU48.rod
       VCID: AB5F187AC2A3286653-80FE
    Address 55: Headlight Range (J745)       Labels: 4H4-907-357.clb
       Part No SW: 4H4 907 357 B    HW: 7P6 907 357 B
       Component: MxB-ECU       H01 0049
       Coding: 02F2022022130200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 004002
       ROD: EV_HeadlRegulAUDIMXBAU64X_AU57.rod
       VCID: B1630A12E08F42B669-80E4
       Subsystem 1 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 7540
       Coding: E00300
       Subsystem 2 - Part No SW: 7PP 941 472 G    HW: 7PP 941 472 G  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 7540
       Coding: E00300
       Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo li.  H03 0021
       Coding: E00300
       Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
       Component: MxB LeiMo re.  H03 0021
       Coding: E00300
    13706045 - Databus
              U1121 00 [137] - Missing Message
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 16:00:42
    13705479 - Databus
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 16:00:43
    5350720 - Left Matrix High Beam
              C1175 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 16:00:44
    5350976 - Right Matrix High Beam
              C1176 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 16:00:44
    Address 56: Radio (R)       Labels: None
       Part No SW: 4H0 035 053 G    HW: 4H0 035 053
       Component: Radio U Basic H60 0121
       Revision: AB001007    Serial number: 228B%0D7517739
       Coding: 010003010000000001
       VCID: A34FF05AA273E026EB-80F6
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4G0 919 129 C    HW: 4G0 919 129
       Component: NGTV-DVB      H04 0690
       Revision: R0043000    Serial number: 06801300290401
       Coding: 01000000
       VCID: AD5B1662F4B726564D-80F8
    Address 5B: Seat,Rear,PS (J877)       Labels: None
       Component: MEM-BFS-Fond  H06 0155
       Revision: AA000000    Serial number: 00000049984635
       Coding: 001896800000700D0A00392038193A2039203B3B382020
       Part No SW: 4H0 035 666 L    HW: 4H0 035 666 N
       Component: H-BN-EU       H45 0637
       Revision: --------    Serial number: 178B.0D7503573
       Coding: 020100000001F1EF4DB08B1E00000003E80101020000000000
       VCID: B261051EED8979AE10-80E6
       Subsystem 1 - Part No: 8R0 060 884 AR
       Component: ECE 2013  1505
       Subsystem 2 - Part No SW: 4H0 919 604 G    HW: 4H0 919 604 G
       Component: DU8 D4 SV NB  H48 0021
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Component: CD-Database  4949
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0273
       Revision: --------    Serial number: 0000053533987
       Coding: 010F1200420062C202083006
       Part No SW: 4H0 907 441 A    HW: 4H0 907 441
       Revision: --H06---    Serial number: 525 PA8J31D0PO
       Coding: 1080003
       VCID: A649E94E1141150E8C-80F2
    Address 6D: Trunk Elect. (----)       Labels: None
       Part No SW: 4H0 959 107 AB    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0043
       Revision: 10011001    Serial number: 047300072
       Coding: 0210044000
       ASAM Dataset: EV_DeckLidContrUnit 001032
       ROD: EV_DeckLidContrUnit.rod
       VCID: EED9D16E31311D4E34-80BA
    Address 6F: Centr. Conv. II (J773)       Labels: None
       Revision: --------    Serial number: 000000099047
       Coding: 200000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: E3CFB05AEAF3A026AB-80B6
    0006 - Front Left Footwell Lighting  Color 2
              B111D 01 [009] - Electrical Failure
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 15:43:39
       Component: TSG HR        H06 0273
       Revision: --------    Serial number: 0000053533835
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5015    Serial number: SN130131  1406
       ROD: EV_GSM2x3Mono.rod
    Address 85: On Board Cam. (J852)       Labels: None
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H25 0038
       Coding: E1040000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: A649E94ED941150E8C-80F2
    0721 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 143
                        Mileage: 92339 km
                        Date: 2015.08.04
                        Time: 15:43:33
    Address 88: Multicont. Seat Driver (J873)       Labels: None
       Serial number: 00010370250602
       Coding: 662FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: AF670C6AF6BB54467F-80FA
    Address 89: Multicont. Seat Pass. (J872)       Labels: None
       Serial number: 00010370185302
       Coding: 262FF2
    Address 8A: Multicont. Seat Rear,DS (J875)       Labels: None
       Part No SW: 4H0 907 182 G    HW: 4H0 907 182 G
       Component: IVB           H08 0042
       Serial number: 00010050298201
       Coding: 202F00
       ASAM Dataset: EV_IVBDriveSideRear 001003
    Address 8D: Multicont. Seat Rear,PS (J874)       Labels: None
       Serial number: 00010050299901
       Coding: 202F00
       ASAM Dataset: EV_IVBPasseSideRear 001003
    Address 8E: Image Processing (J851)       Labels: 4G0-907-107.clb
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H31 0041
       Serial number: 005000122802137
       Coding: 0220AB001111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: B261051EE58979AE10-80E6
    End-------------------------(Elapsed Time: 07:39)--------------------------
    Jan 2015
    Lithuania
    hello.what kind of headlights you had before?
    Aug 2015
    Romania
    Full led headlights.
    Jan 2015
    Lithuania
    ok so:full led headlight are without can,you have conected pin 1 and 2(can low,can high)from headlights to j745 range control unit to pin t26a/4 and t26a/5,when you must connect external can, from range control unit j745 t26a/2 ant t26a/3 to connection 3 in main wiring harness or to TV1/TV2(wiring junciotn for can).i think you have done this already yes? know problems can be in gateway wiring,have you check it?gateway j533 must be conected to tv1/tv2.so from j533(gateway) t32f/2 and t32f/18 must be conected to tv1/tv2 t46/19L and t46/19h,have you check it?
    Jan 2015
    Lithuania
    olso check convience can from 09 bcm (j519) to Wiring junction for convenience CAN and from Wiring junction for convenience CAN to gateway
    Aug 2015
    Romania
    Hi. Wiring is ok, I dont know why gateway and 09 bcm say that can't comunicate with adress 55, even if I can make diag on adress 55.
    Do you know procedure for making basic setting for matrix module? VCDS ask for 1 to 3 digit number in matrix basic setting menu.
    Thank you.
  7. #7
    Verified VCDS User Mrclopec's Avatar
    May 2015
    Nipomo, CA
    There was a changeover in 2013 on how the A8 headlights were wired. The changeover was between August and September of 2013. I have a question about the range control module (J745) you have in your vehicle. The module for the LED matrix is different than the one for standard LED headlights, however LED headlights on an A8 manufactured up to August 2013 did not use one. Did you have a range and cornering control module in your car before your retrofit?
    You need to clear up the communication issue with 55 before you can do the basic settings. Work on fixing the communication error first.
    I retrofit not because I settled for a car that didn't have everything. I retrofit for the challenge!
  8. #8
    Jan 2015
    Lithuania
    check pins 32f2 and 32f18 in gateway,maybe yours gateway not suporting external can and and this pins is not existing.
  9. #9
    Aug 2015
    Romania
    Mrclopec you are right, original headlight were drivin by BCM on LIN-bus. Control unit 55 I installed is from a working car, do you know other way to register in gateway except in instalation list? Maybe I need to change gateway?
    maniken Wiring is ok, can extended exist on car because other control unit are connected to that bus and they comunicate with gteway, only my control unit on adress 55 is not able to comunicate with gateway.But as before, I can make diag on adress 55 with no problem, so wiring and gateway should be ok.
    Thank you.
  10. #10
    May 2015
    Nipomo, CA
    Look in your 09-Central Elec...The error code there is it cant communicate with 55-Headlight Range (J431). You have a J745 now. I suspect your 09-Central Elec. Needs to be coded differently as it is looking for a headlight range module for Non-Matrix headlights.
