Results 11 to 20 of 27
Thread: Ross Tech USB cable doesn't fit Porsche
    Aug 2015
    Quote Originally Posted by jjd View Post
    Thanks, @Zenerdiode. I'll give it a try with more effort, but I already pushed so hard I was worried I was going to break something. You've given me the confidence to try again.
    No go with the added pressure. I pushed so hard that the ODBII socket moved inward half an inch, but still the connector wouldn't connect more than a couple mm.
    I suspect maybe my 1997 (only one year after ODBII was made mandatory) might be different than your 2002.
  2. #12
    Administrator Andy's Avatar
    Sector 7G
    Well, on the plus side, you're not missing out on much. I don't think you'd be able to do anything with VCDS that you couldn't do with a generic scanner on a '97 Boxster anyway. I highly doubt it's anything related to the pins or the shape of the port itself. Did you try removing the port from the car, let it dangle, and try plugging it in?
  3. Likes Uwe liked this post
  4. #13
    Yup, I think that's the next thing to do. Based on its color and appearance, I'm reasonably confident the socket from the same supplier that made/makes them for VW/Audi. That means the socket itself is certainly compatible with our plugs, and the most likely cause of the "incompatibility" is related to the way the way it's mounted.
    Another possibility is that there's something blocking one of the individual pin sockets or (ostensibly "blank") holes. If you'd like, we'll snail-mail you a loose pin that you can try inserting into each of them one at a time to see if any of them is blocked.
  5. #14
    Aug 2015
    It is clear that it is not getting hung up on anything surrounding the socket -- there is nothing nearby that might cause problems and it feels as if it is being blocked in the middle. (Also, it feels like if you rock the cable side-to-side, each side can move down while something in the middle is blocking it.)
    I wouldn't mind getting a loose pin for this idea: I tried this already using a toothpick, but the shape wouldn't let it go in far enough on any pin socket. DM me and I'll send my US mail address, if you don't already have it. Thanks!
    --Jim--
  6. #15
    Are you still in the same place we shipped your interface to 5 years ago?
  7. #16
    Aug 2015
    Does the car have a tracker fitted? I have fitted many OBD2 style trackers that have a Y cable which replaces the oem socket. Porsches use exactly the same Y cable as VAG. It may be worth checking that there is not 1 on these (with a badly copied socket) tucked up above the panel.
  8. Likes Dana liked this post
  9. #17
    Aug 2015
    Yes, my address is the same. Thank you. 01719
  10. #18
    Aug 2015
    Quote Originally Posted by smokey08 View Post
    I'm not sure what a "tracker" is, but I've owned this car since new 18 1/2 years ago. There has never been anything in the ODBII socket other than for temporary diagnosis.
  11. #19
    Stoke on Trent, England
    In the UK the post office have a tracker system where you can check expected delivery date. Track and Trace - Track your Item
    This tracker number is normally on the receipt/email. I assume the US has a similar system.
    New User Keith
  12. #20
    Magdeburg, Germany
  13. Likes smokey08 liked this post
