I know there is no info on the ross tech wiki regarding long coding for ABS mk60EC1 it is stated that it must be sent to Dealer for SVM.
I came across some info that saved the day for me and it may be useful to include in a future version of VCDS.
Here is the procedure to get descriptions in the bytes/bit in longcoding helper.
vcds long coding plugin for mk60ec1
gives a much better description of abs long coding than original vcds label file.
recoded my golf from 288mm fronts to 312mm fronts since its had gti carriers and rotors for over a year now.
http://www24.zippyshare.com/v/1513575/file.html
Instructions:
Start LCode.exe (found in the directory of VCDS)
copy your Original LongCoding of ABS module 03 in box 1)
then click on "READ INFO TEXT FILE" and select the file eng-mk60ec1.xpl
Credit goes to Ian(kompressed) for making this info available.
special note: my car was a 2009 mk5 golf 2.5 and to get the coding to work i had to select a Mk6 jetta for it to take.
Instructions:
