Results 11 to 20 of 24
Thread: Auto-Scan Testing: 2006 VW Phaeton W12
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Retry of the problem stuff with Beta 14.5.0/CB 4102.
    • Address 01/11/31: Engine ECUs, Turbo Mode: Mixed results.
      • Good: HEX-USB+CAN can now shift into Turbo Mode on address 11 as well as 01.
      • Bad: HEX-USB+CAN seems to have a regression with address 31; I can't hold a stable connection at all just sitting at the function menu. I'm pretty sure this was working on the last Beta. HEX-NET using Desktop/USB seems to talk to all three addresses fine.
      • Strange: Turbo Mode on HEX-NET is outright rejected. I didn't try this on my last visit so I don't know if this is a regression. Should Turbo Mode work on HEX-NET hardware?
    • Address 07: Control Head: No change at this time. None was really expected though based on Uwe's comment.
    • Address 37: Navigation: Did not test. Most likely the same as 07.
    ECU test results, for clarity:
    Device Address 01 Address 11 Address 31
    HEX-USB+CAN Basic OK OK Unstable
    HEX-USB+CAN Turbo OK OK Could not test
    HEX-NET USB Basic OK OK OK
    HEX-NET USB Turbo Rejected Rejected Rejected
    Attempting to use Turbo Mode on HEX-NET using VCDS Desktop/USB:
  2. Likes Uwe liked this post
  3. #12
    Cincinnati, OH
    Ouch. Sorry to hear about your battery. "Professionals" really should know better.
    I'm pretty laid back and understanding, but that in combination with some other small stuff kind of had me in a confidence crisis. I set up a meeting last week with the service manager and shop foreman. They are taking care of the battery; I didn't even have to ask. And, I am going to be inserting myself in the repair process more directly going forward.
    She finally gets into a service bay on Monday. I dropped this car off for repair on March 10th.
    Jason
  4. #13
    Cincinnati, OH
    Incredibly long-overdue results from earlier today.
    • Address 01/11/31: Engine ECUs: Can't connect due to a series of open-circuit faults. See pictures below for more information.
  5. Likes Uwe, Eric, PanEuropean, jakematic, Santos liked this post
  6. #14
  7. Likes jyoung8607, jakematic liked this post
  8. #15
    Cincinnati, OH
    86 days and $14,300 later, the open-circuit faults are resolved. Also my cam adjuster and some other things work better now.
    Desktop Beta 14.6.0, HEX-NET CB 4106 / FW 0184 / DS 27
    • Address 01/11/31: Engine ECUs, Turbo Mode: Improved but still mixed results.
      • Good: HEX-USB+CAN can now shift into Turbo Mode on address 01, 11 and 31. Also, I got around 30 minutes of continuous logging from address 31 via HEX-NET (non-Turbo) while verifying my cam adjusters are working right.
      • Bad: In Turbo mode only, HEX-USB+CAN has occasional reading issues on 31. I think it occasionally doesn't get a read from ECU 1 and returns only ECU 2's result on the ECU 1 line. This isn't flipping like it was before, the second line doesn't get updated at all. I will package up a sample log for support. I did not see this happen outside Turbo mode.
      • Strange: Turbo Mode on HEX-NET is still outright rejected. Uwe said he thought this should work... it's a no-go. VCDS says the interface doesn't support it, just as it did in my screenshot earlier in the thread.
    • Address 03: ABS Brakes: VCDS Mobile can't read the controller part number or any other details. I thought this was a new problem, but upon review I can see this problem was present on my very first VCDS Mobile auto-scan in this thread. It fails the same way when opening address 03 independently. It does seem to get a connection successfully, and it can read DTCs.
    • Address 07: Control Head: Unfortunately SSDD with HEX-NET. HEX-USB+CAN still fine on current Beta.
    • Address 37: Navigation: Unfortunately SSDD with HEX-NET. HEX-USB+CAN still fine on current Beta.
    • Address 65: Tire Pressure: VCDS Desktop can talk to it fine at a protocol level, but as Michael has pointed out recently, the label files 3D0-907-273.lbl and 3D0-907-273-D.lbl have silently disappeared out of recent VCDS releases. VCDS Mobile has no MVB-label knowledge of our modules either. In fact, I can't even find address 65 on the list - I have to enter the address number manually.
    I am preparing a new TPMS label and redirect file set that includes the security access procedure and the processes to disable/enable the system, disable/enable spare tire monitoring, directly set target tire pressures, and directly adapt TPMS sensor IDs to wheel positions. It should apply to 2004-2007 Phaeton as well as Touaregs and Bentleys of the same vintage.
    HEX-USB+CAN Basic OK OK OK
    HEX-USB+CAN Turbo OK OK Some Issues
    Baseline scan with HEX-USB+CAN:
    Tuesday,03,June,2014,22:56:25:05280
    VCDS Version: 14.6.0.0 (x64)
    Data version: 20140601
    VIN: WVWAK03D868005728   License Plate: PHAETON
    Mileage: 120730km-75018mi   Repair Order: BETA1460-HEXUSBCAN
    Chassis Type: 3D (JY2 - VW Phaeton (2002 > 2006))
    Scan: 01 02 03 05 06 07 08 09 11 15 16 17 19 28 29 34 36 37 38 39
              46 47 65 68 71 76
    VIN: WVWAK03D868005728   Mileage: 120730km-75018miles
    Address 01: Engine        Labels: 07C-906-018-BAP1.lbl
       Part No SW: 07C 906 018 AJ    HW: 000 000 000 00
       Component: D1-6.0L-AT-LEV2 G  ª6722
       Revision: --H01---    Serial number: VWZ3Z0F7470400
       Coding: 0000173
       Shop #: WSC 01065 000 00000
       VCID: 6DDBB2F477855E52D0-5120
    Address 02: Auto Trans        Labels: 3D0-927-156.lbl
       Part No: 3D0 927 156 AB
       Component: AG5 01L 6.0lW12 USA 1010
       VCID: 68D5C3E058677B7AA3-5120
    Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
       Part No: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H33 0047
       Coding: 0008397
       VCID: 6BDFBCEC49915062CE-5120
       Part No SW: 3D0 909 137 C    HW: 5WK 484 97
       Component: G1 Kessy            6700
       Revision: 67006015    Serial number: VWZ3Z0F7470400
       Coding: 0213228
       VCID: 275780DC95F9B4026A-5120
    Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
       Part No: 3D0 959 759 CA
       Component: Sitzmemory D1 BF    1720
       Coding: 0000003
       VCID: 77F7909C05D9E4823A-5120
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3D0 035 008 QX
       Component:    ZAB COCKPIT      0223
       Coding: 0500305
       Shop #: WSC 03207 444 84420
       VCID: 0005FB405017A33A0B-5120
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 J
       Component: Climatronic D1      2031
       VCID: 254B8AD4EFF5A61258-5120
       Subsystem 1 - Part No: 3D0 907 040 J
    No Faults Found
    Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
       Part No: 3D0 937 049 H
       Component: STG.Bordnetz        5101
       Coding: 0000003
       Shop #: WSC 02605 444 64790
       VCID: 2F6768FCBD09EC42A2-5120
    Address 11: Engine II        Labels: 07C-906-018-BAP2.lbl
       Coding: 0000173
       VCID: 6DDBB2F477855E52D0-FFFF
    No Faults Found
       Part No: 3D0 909 601 H
       Component: 04 Airbag 8.4E++H01 0554
       Revision: BB38727     Serial number: 0006635<
       Coding: 0012340
       VCID: 285583E098E7BB7A63-5120
       Subsystem 1 - Part No: 3D0 959 339
       Component: BF-Gewichtsens. 006 0005
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 E
       Component: Lenksäulenmodul     3401
       Coding: 0000232
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No: 3D0 920 982 B
       Component: KOMBIINSTRUMENT RB8 0521
       Coding: 0005221
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70E5AB8060B7B3BAFB-5120
    Address 28: HVAC, Rear        Labels: 3D0-919-158.lbl
       Part No: 3D0 919 158 F
       Component: Klima-Bedienteil D1 0117
       VCID: 2E5975F8BA03E54AA9-5120
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       VCID: 66C9CDD852736D0A91-5102
    Address 34: Level Control        Labels: 3D0-907-553-V2.clb
       Part No: 3D0 907 553 C
       Component: LUFTFDR.-CDC- 3C3V0 1122
       Coding: 0005531
       Shop #: WSC 53212 053 999999
    Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
       Part No: 3D0 959 760 CA
       Component: Sitzmemory D1 F     1720
       Coding: 0000004
       VCID: 6FE7A8FC7D89AC42E2-5120
    Address 37: Navigation        Labels: 3D0-919-887.lbl
       Part No: 3D0 919 887 F
       Component:    NAVIGATION       0188
       Coding: 0400000
       VCID: 3777509C45592482FA-5120
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 C
       Component: Dachmodul           0708
       Coding: 0000015
       VCID: 234F94CCE1C1582236-5120
    00220 - Connection to Sunroof
       Part No: 3D0 909 158
       VCID: 67D7C0DC55797402AA-5120
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component: X3 HSG              0102
       Coding: 0000040
       Shop #: WSC 03325 444 13946
       VCID: 336F648C5121C8A2C6-4AE6
       Subsystem 1 - Part No: 3D1 959 701 L
       Component: Tuersteuergeraet FS 6001
       Subsystem 2 - Part No: 3D1 959 702 L
       Component: Tuersteuergeraet BF 6001
       Subsystem 3 - Part No: 3D0 959 703 K
       Component: Tuersteuergeraet HL 6001
       Subsystem 4 - Part No: 3D0 959 704 K
       Component: Tuersteuergeraet HR 6001
       Subsystem 5 - Part No: 3D0 909 610 C
       Component: 3L HDSG             2330
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3D0 035 466 A
       Component: 12K-AUDIOVERST      0118
       VCID: 20459BC0F0D7433A2B-513C
    Address 65: Tire Pressure        Labels: None
       Part No: 3D0 907 273 G
       Component: Reifendruckueberw.  0026
       Coding: 0411224
       VCID: 2A5179E886EB896A75-5120
    01487 - System Function Test
    02757 - Learning Tire Pressures
                000 - - - MIL ON
    Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
       Part No: 3D1 955 119 A
       Component: Front Wiper         2005
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
       VCID: 244D97D0E4CF5F1A4F-5120
    Address 76: Park Assist        Labels: 3D0-919-283.lbl
       Part No: 3D0 919 283 D
       Component: 03 Einparkhilfe     0907
       VCID: 2B5F7CEC891190628E-513C
    End-------------------------(Elapsed Time: 05:10)--------------------------
    Scan with HEX-NET using VCDS Desktop/USB:
    Tuesday,03,June,2014,23:07:54:21122
    Mileage: 120730km-75018mi   Repair Order: BETA1460-HEXNET-USB
              46 47 65 68 71 76
       Coding: 0000173
       VCID: 6D9208DC75C37C52D0-5184
       VCID: 689C79C85A21597AA3-5184
       Coding: 0008397
       VCID: 6B9606C44BD77262CE-5184
       Coding: 0213228
       VCID: 271E3AF497BF96026A-5184
       Coding: 0000003
       VCID: 77BE2AB4079FC6823A-5184
    Address 07: Control Head        Labels: None
       VCID: 55E2403CBD53D49208-FFFF
       VCID: 250230FCEDB3841258-5184
       Coding: 0000003
       VCID: 2F2ED2D4BF4FCE42A2-5184
       Coding: 0000173
       Coding: 0012340
       VCID: 281C39C89AA1997A63-5184
       Coding: 0000232
       Coding: 0005221
       Coding: 0000006
       VCID: 70AC11A862F191BAFB-5184
       VCID: 2E10CFD0B845C74AA9-5184
       VCID: 668077F050354F0A91-5160
       Coding: 0005531
       Coding: 0000004
       VCID: 6FAE12D47FCF8E42E2-5184
    Address 37: Navigation        Labels: None
       VCID: 55E2403CBD53D49208-5184
    No Faults Found
       Coding: 0000015
       VCID: 23062EE4E3877A2236-5184
       VCID: 679E7AF4573F5602AA-5184
       Coding: 0000040
       VCID: 3326DEA45367EAA2C6-4B3C
       VCID: 200C21E8F291613A2B-5184
       Coding: 0411224
       VCID: 2A18C3C084ADAB6A75-5184
                000 - - - MIL ON
       VCID: 24042DF8E6897D1A4F-5184
    No Faults Found
       VCID: 2B16C6C48B57B2628E-5184
    End-------------------------(Elapsed Time: 08:18)--------------------------
    Scan with HEX-NET using VCDS Mobile - Aborted at 07:
    Tue,Jun,03,2014,23:11:08  VCDS Mobile 0.4106.0.4
    Chassis Type:3D
    Scan:
    	 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
    	 34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
    Address 01: Engine	Labels:07C-906-018-BAP1.lbl
    	Part Number SW: 07C-906-018-AJ	HW: 00000000000
    	Revision: --H01---	Serial Number: VWZ3Z0F7470400
    	Coding: 0000173
    	VCID: 6D9D5AB724BAEFBAC055B8-5184
    No fault codes found.
    Address 02: Auto Trans	Labels:3D0-927-156.lbl
    	Part Number SW: 3D0-927-156-AB
    	VCID: 68932BA30B58CA92B30371-5184
    Address 03: ABS Brakes	Labels:None
    	Part Number SW:
    	Component:
    	Shop #: WSC 00000 000
    	VCID: 55ED1257AC2AC77A1845A0-5184
    Address 05: Acc/Start Auth.	Labels:3D0-909-13x-05.lbl
    	Part Number SW: 3D0-909-137-C	HW: 5WK48497ÿ’
    	Revision: 67006015	Serial Number: VWZ3Z0F7470400
    	Coding: 0213228
    	VCID: 2711689FC6C605EA7A99BA-5184
    	Subsystem 1 - 	Part Number: XXX-XXX-XXX-XX
    	Component: ELV                  XXXX
    Address 06: Seat Mem. Pass	Labels:3D0-959-759.lbl
    	Part Number SW: 3D0-959-759-CA
    	Coding: 0000003
    	VCID: 77B178DF56E6556A2AB92A-5184
    Address 07: Control Head	Labels:None
    	Part Number SW:
    	Component:
  9. Likes Eric, Uwe liked this post
  10. #16
    Toronto, Canada
    I tried out the new software (VCDS application 14.6.0, HEX-NET Code block 4106, Firmware 0184, and Dataset 27) on my 2004 Phaeton.
    Overall, the HEX-NET device, when connected to the 'traditional' VCDS 14.6.0 application in access point mode, runs a heck of a lot faster now. Subjectively, I think it runs the autoscan at about the same speed as my HEX-USB cable, and that is a very significant and noticeable improvement.
    Controller 07 and 37 still don't scan, the application stops working when it reaches those controllers. I have to press the 'Close Controller' button to get it working again. Controller 71 (the Battery Monitoring Controller) is also sometimes troublesome, returning a "No Faults Found or DTCs not supported by controller or a communication error occurred" message. I've seen this same problem in the past with controller 71. It doesn't happen all the time, perhaps only 50% of the time.
    I note Jason's comment about difficulties with his ABS controller. The application seems to work fine with my ABS controller. My car is a 2004, Jason's is a 2006, but I think the ABS controller is either the same or very similar on the two cars.
    I encountered difficulty getting a connection between the HEX-NET device in 'infrastructure mode' and the VCDS-Mobile application, hence I have nothing to share from that. I will try again tomorrow.
    Michael
    VCDS Version: Beta 14.6.0 (x64)
    Thursday,05,June,2014,21:25:14:33162
    Chassis Type: 3D (3D - NAR Phaeton )
    Scan: 01 02 03 05 06 07 08 09 11 15 16 17 19 25 28 29 34 36 37 38
              39 46 47 57 65 66 68 71 76
    VIN: WVWAH63D648008349   Mileage: 102900km-63939miles
       Part No SW: 07C 906 018 C    HW:
       Component: D1-6.0L-AG-LEV  G  ª5211
       Coding: 0000173
       VCID: A502B7996D600C12D8-5184
       Part No: 3D0 927 156 N
       Component: AG5 01L 6.0 W12 USA 1114
       Coding: 0000102
       Shop #: WSC 02137 444 53300
       VCID: B32659C1D3B462A246-5184
       Part No: 3D0 614 517 R
       Component: ESP 5.7 allrad  H33 0043
       Coding: 0008397
       Shop #: WSC 93004 000 00000
       VCID: B12A53C929A850B234-5184
       Part No SW: 3D0 909 137 A    HW: 5WK 470 19
       Component:    Kessy            6700
       Revision: 67005614    Serial number: VWZ3Z0C7093074
       Coding: 0133356
       Shop #: WSC 91426 999 83920
       Part No: 3D0 959 759 B
       Component: Sitzmemory D1 BF    1520
       Coding: 0000003
       Shop #: WSC 93004 999 52056
       VCID: B52267D9DDC07C9268-5184
       VCID: D5E2C7593D805C9288-5184
       Part No: 3D0 907 040 H
       Component: Climatronic D1      2021
       VCID: A306A9816354F222B6-5184
    00711 - Left Footwell Flap Positioning Motor (V108)
       Part No: 3D0 937 049 G
       Component: STG.Bordnetz        5001
       Coding: 0000003
       Shop #: WSC 03004 999 58851
       VCID: AE1048B538964F4A29-5184
       Coding: 0000173
       Part No: 3D0 909 601 D
       Component: 0A Airbag 8.4E+ H07 0934
       Coding: 0012353
       VCID: A404AA9D665AF51ACF-5184
       Coding: 0000012
       VCID: AF2E55B13F9C464222-5184
       Part No: 3D0 920 882
       Component: KOMBIINSTRUMENT RB4 0421
       Coding: 0005111
       Shop #: WSC 93004 999 183250
       VCID: E484EA9D26DAB51A0F-5184
       Coding: 0000006
       VCID: F0AC96CDE22219BA7B-5184
    Address 25: Immobilizer        Labels: None
       Coding: 0133356
       XXXXXXXXXXX ELV                 XXXX
       VCID: E680F095D0E6C70A11-5184
    Address 34: Level Control        Labels: 3D0-907-553-V1.clb
       Part No: 3D0 907 553 B
       Component: LUFTFDR.-CDC- 3C1V0 1101
       Coding: 0015500
       Shop #: WSC 91426 999 52450
       VCID: A600B0951066070AD1-5184
       Part No: 3D0 959 760 B
       Component: Sitzmemory D1 F     1520
       Coding: 0000004
       VCID: AD124FB93590345210-5184
       Part No: 3D0 907 135 B
       Component: Dachmodul           0605
       Coding: 0000015
       VCID: A208AC857C4EFB2ABD-5184
       Component: EVG GDL+AutoLWR(r)  X012
       VCID: E79EFD91D7ECDE022A-5184
       Component: 1A HSG              0100
       Coding: 0000040
       VCID: B32659C1D3B462A246-4B3C
       Subsystem 1 - Part No: 3D1 959 701 E
       Component: Tuersteuergeraet FS 0104
       Subsystem 2 - Part No: 3D1 959 702 E
       Component: Tuersteuergeraet BF 0104
       Subsystem 3 - Part No: 3D0 959 703 E
       Component: Tuersteuergeraet HL 0104
       Subsystem 4 - Part No: 3D0 959 704 E
       Component: Tuersteuergeraet HR 0104
       VCID: A00CA68D7242E93AAB-5184
    Address 57: TV Tuner        Labels: 3D0-919-146.lbl
       Part No: 3D0 919 146
       Component: TV Tuner        H07 1205
       Coding: 0000060
       VCID: E582F7992DE0CC1218-5184
       Coding: 0310224
       VCID: AA1844A5047E236AF5-5184
    Address 66: Seat, Rear        Labels: None
       Part No: 3D0 959 860 C
       Component: Sitzmemory D1 H     1724
       Part No: 3D0 915 181 C
       Component: Batteriemanagement  2700
    No Faults Found
       Part No: 3D0 919 283 C
       Component: 03 Einparkhilfe     0807
       Shop #: WSC 00099 000 00000
    End-------------------------(Elapsed Time: 06:19)--------------------------
  11. Likes jyoung8607 liked this post
  12. #17
    Cincinnati, OH
    Hey, I thought you were motorcycling across Europe?
    Quote Originally Posted by PanEuropean View Post
    I think we might be stuck with that until we can arrange for a Phaeton in their parking lot for a while. I had offered to send in my nav computer for a while, but I think that might not do any good. I recently had an illuminating conversation with Uwe on K-Line stuff in the Phaeton. Unlike the ECUs we were working with earlier, I think the infotainment/nav computers may depend on the K-Line/CAN gateway (in our case, the instrument cluster) as an intermediary.
    Josh's profile (PowerDubs) says he's in New Jersey, not too far away. I wonder if he could be bribed to head over to Lansdale.
    Desktop works fine for me, it's just Mobile (embedded web-based) that had trouble.
    Jason
  13. Likes Eric liked this post
  14. #18
    Cincinnati, OH
    Desktop Beta 14.6.1, CB 4107, FW 0184.
    Desktop looks pretty damn good on Phaeton right now. I can't find anything that doesn't work. Both USB and WiFi can talk to everything consistently. WiFi performs quite well provided the WiFi signal is solid. I will say it's very easy to run into things that look like VCDS problems, but are in fact fringe WiFi range problems.
    Mobile consistently has trouble with both headlight level controllers, addresses 29 and 39, both on Auto-Scan and on direct open. It can talk to them at some level but can't return any details like part numbers, versions, etc. However, Mobile Auto-Scan doesn't stall on them and it completes the rest successfully.
    Wednesday,18,June,2014,18:03:41:21122
    VCDS Version: 14.6.1.0 (x64)
    Mileage: 121380km-75422mi   Repair Order: BETA1461-HEXNET-USB
              46 47 65 68 71 76
    VIN: WVWAK03D868005728   Mileage: 121380km-75422miles
       Coding: 0000173
       VCID: 6D9208DC75C37C52CA-5184
    Readiness: 0110 1001
       VCID: 689C79C85A21597AB9-5184
       Coding: 0008397
       VCID: 6B9606C44BD77262D4-5184
       Coding: 0213228
       VCID: 271E3AF497BF960270-5184
       Coding: 0000003
       VCID: 77BE2AB4079FC68220-5184
       Component:    ZAB COCKPIT      9923
       Coding: 0500305
       VCID: 004C41685251813A11-5184
       VCID: 250230FCEDB3841242-5184
       Coding: 0000003
       VCID: 2F2ED2D4BF4FCE42B8-5184
       Coding: 0000173
       Coding: 0012340
       VCID: 281C39C89AA1997A79-5184
       Coding: 0000232
       Coding: 0005221
       Coding: 0000006
       VCID: 70AC11A862F191BAE1-5184
       VCID: 2E10CFD0B845C74AB3-5184
       VCID: 668077F050354F0A8B-5160
       Coding: 0005531
       Coding: 0000004
       VCID: 6FAE12D47FCF8E42F8-5184
       Component:    NAVIGATION       9968
       Coding: 0400000
       VCID: 373EEAB4471F0682E0-5184
       Coding: 0000015
       VCID: 23062EE4E3877A222C-5184
       VCID: 679E7AF4573F5602B0-5184
       Coding: 0000040
       VCID: 3326DEA45367EAA2DC-4B3C
       VCID: 200C21E8F291613A31-5184
       Coding: 0411224
       VCID: 2A18C3C084ADAB6A6F-5184
       VCID: 24042DF8E6897D1A55-5184
       VCID: 2B16C6C48B57B26294-5184
    End-------------------------(Elapsed Time: 04:05)--------------------------
    Scan with HEX-NET using VCDS Desktop/WiFi:
    Wednesday,18,June,2014,18:16:52:21122
    Mileage: 121380km-75422mi   Repair Order: BETA1461-HEXNET-WIFI-4
              46 47 65 68 71 76
       Coding: 0000173
       VCID: ED9288DCF5C3FC524A-5184
       VCID: E89CF9C8DA21D97A39-5184
       Coding: 0008397
       VCID: EB9686C4CBD7F26254-5184
       Coding: 0213228
       VCID: A71EBAF417BF1602F0-5184
       Coding: 0000003
       VCID: F7BEAAB4879F4682A0-5184
       Coding: 0500305
       VCID: 804CC168D251013A91-5184
       VCID: A502B0FC6DB30412C2-5184
       Coding: 0000003
       VCID: AF2E52D43F4F4E4238-5184
       Coding: 0000173
       Coding: 0012340
       VCID: A81CB9C81AA1197AF9-5184
       Coding: 0000232
       Coding: 0005221
       Coding: 0000006
       VCID: F0AC91A8E2F111BA61-5184
       VCID: AE104FD03845474A33-5184
       VCID: E680F7F0D035CF0A0B-5160
       Coding: 0005531
       Coding: 0000004
       VCID: EFAE92D4FFCF0E4278-5184
       Coding: 0400000
       VCID: B73E6AB4C71F868260-5184
       Coding: 0000015
       VCID: A306AEE46387FA22AC-5184
       VCID: E79EFAF4D73FD60230-5184
       Coding: 0000040
       VCID: B3265EA4D3676AA25C-4B3C
       VCID: A00CA1E87291E13AB1-5184
       Coding: 0411224
       VCID: AA1843C004AD2B6AEF-5184
       VCID: A404ADF86689FD1AD5-5184
       VCID: AB1646C40B57326214-5184
    End-------------------------(Elapsed Time: 04:35)--------------------------
    Scan with HEX-NET using VCDS Mobile:
    #hndoc:?docid=00000444&xt=hnh:4353468CFCF76DF43B25353FC3649E6AD6DE63E7286EEECFD72AA01D91A1931B
     VCDS Mobile 0.4107.0.4
    Chassis Type:3D
    Scan:
    	Coding: 0000173
    	VCID: 6D9D5AB724BAEFBAC055B9-5184
    	VCID: 68932BA30B58CA92B30370-5184
    Address 03: ABS Brakes	Labels:3D0-614-517.lbl
    	Part Number SW: 3D0-614-517-AK
    	Coding: 0008397
    	VCID: 6B9954AF1AAEE18ADE2197-5184
    	Part Number SW: 3D0-909-137-C	HW: 5WK48497��
    	Coding: 0213228
    	VCID: 2711689FC6C605EA7A99BB-5184
    	Component: ELV                  XXXX
    	Coding: 0000003
    	VCID: 77B178DF56E6556A2AB92B-5184
    Address 09: Cent. Elect.	Labels:3D0-937-049-V1.clb
    	Part Number SW: 3D0-937-049-H
    	Coding: 0000003
    	VCID: 2F2180BFEE365DAAB2C903-5184
    Address 11: Engine II	Labels:07C-906-018-BAP2.lbl
    	Coding: 0000173
    Address 15: Airbags	Labels:3D0-909-601.lbl
    	Part Number SW: 3D0-909-601-H
    	Revision: BB38727 	Serial Number: 0006635<
    	Coding: 0012340
    	VCID: 28136BA3CBD80A927383B0-5184
    	Subsystem 1 - 	Part Number: 3D0-959-339
    Address 16: Steering wheel	Labels:3D0-953-549.lbl
    	Part Number SW: 3D0-953-549-E
    	Coding: 0000232
    Address 17: Instruments	Labels:3D0-920-xxx-17.lbl
    	Part Number SW: 3D0-920-982-B
    	Coding: 0005221
    Address 19: CAN Gateway	Labels:6N0-909-901-19.lbl
    	Part Number SW: 6N0-909-901
    	Coding: 0000006
    	VCID: F0A3C3C3B38882526B7358-5184
    Address 28: HVAC, Rear	Labels:3D0-919-158.lbl
    	Part Number SW: 3D0-919-158-F
    	VCID: 2E1F9DBBE93C54A2B9DFF6-5184
    Address 29: Left Light	Labels:None
    	Part Number SW:
    	Component:
    	VCID: 55ED1257AC2AC77A1845A1-5160
    Address 34: Level Control	Labels:3D0-907-553.lbl
    	Part Number SW: 3D0-907-553-C
    	Coding: 0005531
    Address 36: Seat Mem. Drvr	Labels:3D0-959-760.lbl
    	Part Number SW: 3D0-959-760-CA
    	Coding: 0000004
    	VCID: 6FA140BF2EB61DAAF249C3-5184
    Address 37: Navigation	Labels:3D0-919-887.lbl
    	Part Number SW: 3D0-919-887-F
    	Coding: 0400000
    	VCID: 3731B8DF1666956AEA396B-5184
    Address 38: Roof Electronics	Labels:3D0-907-135.lbl
    	Part Number SW: 3D0-907-135-C
    	Coding: 0000015
    	VCID: 23097C8FB2FEE9CA26718F-5184
    Address 39: Right Light	Labels:None
    	Part Number SW:
    	Component:
    	VCID: 55ED1257AC2AC77A1845A1-5184
    Address 46: Central Conv.	Labels:3D0-959-933.lbl
    	Part Number SW: 3D0-959-933-F
    	Coding: 0000040
    	VCID: 33298CCF021E794AD6113F-4B3C
    	Subsystem 1 - 	Part Number: 3D1-959-701-L
    	Subsystem 2 - 	Part Number: 3D1-959-702-L
    	Subsystem 3 - 	Part Number: 3D0-959-703-K
    	Subsystem 4 - 	Part Number: 3D0-959-704-K
    	Subsystem 5 - 	Part Number: 3D0-909-610-C
    	Subsystem 6 - 	Part Number: 7L0-907-719-A
    Address 47: Sound System	Labels:7Lx-035-4xx-47.lbl
    	Part Number SW: 3D0-035-466-A
    	VCID: 20037383A3E8F2D23B5368-5184
    Address 65: Tire Pressure	Labels:3D0-907-273.lbl
    	Part Number SW: 3D0-907-273-G
    	Coding: 0411224
    	VCID: 2A1791ABD5D4388265B7DA-5184
    Address 68: Wiper Electr.	Labels:3D1-955-119.lbl
    	Part Number SW: 3D1-955-119-A
    Address 71: Battery Charger	Labels:3D0-915-181.lbl
    	Part Number SW: 3D0-915-181-D
    	VCID: 240B7F93B7F0EEF25F7B84-5184
    Address 76: Park Assist	Labels:3D0-919-283.lbl
    	Part Number SW: 3D0-919-283-D
    	VCID: 2B1994AFDA2E218A9EA1D7-5184
  15. Likes Uwe, Eric, Bruce liked this post
  16. #19
    Cincinnati, OH
    VCDS Mobile only, CB 4108 / FW 0184.
    Looks like Mobile can talk to my headlight leveling controllers now. It did trip over the 12-channel amp (47/Sound System) for some reason, but I've never seen it do that before, and I was successful 3-for-3 attempts on opening it directly, so I'll write that off for a fluke.
    On an unrelated note, my CEL came back on yesterday. My engine is not quite so fixed as I had believed. I'm unbelievably frustrated right now, but that's not Ross-Tech's problem of course. I'm going to start a thread over in the Repair forum because I have no idea what to do from here.
    Jason
    #hndoc:?docid=00000454&xt=hnh:1A29854256D7CBDF13F8318A457AED4ECC65FDF4B22A298C35C0764B283A1097
     VCDS Mobile 0.4108.0.4
    Chassis Type:3D
    Scan:
    	Part No. SW: 07C-906-018-AJ	HW: 00000000000
    	Coding: 0000173
    	VCID: 6D9D5AB724BAEFBAC055BE-5184
    001072 - Catalyst System; Bank 2
    	P0430 - 002 - Efficiency Below Threshold - Intermittent
    		Mileage: 121391 km
    		RPM: 2179 /min
    		Load: 35.3
    		Speed: 117.0 km/h
    		Temperature: 101.0°C
    		Temperature: 36.0°C
    		Absolute Pres.: 990.0 mbar
    		Voltage: 13.462 V
    006435 - Please Check DTC Memory of ECU Number 2
    	P1923 - 008 - Implausible Signal
    		Mileage: 121477 km
    		Load: 0.0
    		Temperature: 87.0°C
    		Temperature: 78.0°C
    		Absolute Pres.: 980.0 mbar
    		Voltage: 12.192 V
    	Part No. SW: 3D0-927-156-AB
    	VCID: 68932BA30B58CA92B30377-5184
    	Part No. SW: 3D0-614-517-AK
    	Coding: 0008397
    	VCID: 6B9954AF1AAEE18ADE2190-5184
    	Part No. SW: 3D0-909-137-C	HW: 5WK48497��
    	Coding: 0213228
    	VCID: 2711689FC6C605EA7A99BC-5184
    	Component: ELV                  XXXX
    	Part No. SW: 3D0-959-759-CA
    	Coding: 0000003
    	VCID: 77B178DF56E6556A2AB92C-5184
    Address 07: Control Head	Labels:3D0-035-00x-07.lbl
    	Part No. SW: 3D0-035-008-QX
    	Coding: 0500305
    	VCID: 80439303832892D29B138F-5184
    Address 08: Auto HVAC	Labels:3D0-907-040.lbl
    	Part No. SW: 3D0-907-040-J
    	VCID: 250D6297BCCA17FA486596-5184
    	Part No. SW: 3D0-937-049-H
    	Coding: 0000003
    	VCID: 2F2180BFEE365DAAB2C904-5184
    	Coding: 0000173
    012953 - Catalyst System; Bank 4
    	P3299 - 002 - Efficiency Below Threshold - Intermittent - MIL ON
    		Fault Status: 10100010
    		Mileage: 121391 km
    		RPM: 2182 /min
    		Load: 29.0
    		Speed: 117.0 km/h
    		Temperature: 35.0°C
    		Voltage: 13.462 V
    012952 - Catalyst System; Bank 3
    	P3298 - 002 - Efficiency Below Threshold - Intermittent
    		Mileage: 121417 km
    		RPM: 1646 /min
    		Load: 23.9
    		Speed: 88.0 km/h
    		Temperature: 93.0°C
    		Temperature: 53.0°C
    		Voltage: 13.081 V
    	Part No. SW: 3D0-909-601-H
    	Coding: 0012340
    	VCID: 28136BA3CBD80A927383B7-5184
    	Part No. SW: 3D0-953-549-E
    	Coding: 0000232
    	Part No. SW: 3D0-920-982-B
    	Coding: 0005221
    	Part No. SW: 6N0-909-901
    	Coding: 0000006
    	VCID: F0A3C3C3B38882526B735F-5184
    	Part No. SW: 3D0-919-158-F
    	VCID: 2E1F9DBBE93C54A2B9DFF1-5184
    Address 29: Left Light	Labels:3D0-909-157.lbl
    	Part No. SW: 3D0-909-157
    	VCID: E68FA59B814C5CE201EFE9-5160
    	Part No. SW: 3D0-907-553-C
    	Coding: 0005531
    	Part No. SW: 3D0-959-760-CA
    	Coding: 0000004
    	VCID: 6FA140BF2EB61DAAF249C4-5184
    	Part No. SW: 3D0-919-887-F
    	Coding: 0400000
    	VCID: 3731B8DF1666956AEA396C-5184
    	Part No. SW: 3D0-907-135-C
    	Coding: 0000015
    	VCID: 23097C8FB2FEE9CA267188-5184
    Address 39: Right Light	Labels:3D0-909-158.lbl
    	Part No. SW: 3D0-909-158
    	VCID: E791A89F864645EA3A19FC-5184
    	Part No. SW: 3D0-959-933-F
    	Coding: 0000040
    	VCID: 33298CCF021E794AD61138-4B3C
    Address 47: Sound System	Labels:None
    	Part No. SW:
    	Component:
    	VCID: 55ED1257AC2AC77A1845A6-5184
    	Part No. SW: 3D0-907-273-G
    	Coding: 0411224
    	VCID: 2A1791ABD5D4388265B7DD-5184
    	Part No. SW: 3D1-955-119-A
    	Part No. SW: 3D0-915-181-D
    	VCID: 240B7F93B7F0EEF25F7B83-5184
    	Part No. SW: 3D0-919-283-D
    	VCID: 2B1994AFDA2E218A9EA1D0-5184
    Follow-up manual scan of 47/Sound System:
    #hndoc:?docid=00000455&xt=hnh:8CD3E5808B1C791FBF89A5CD8536683764D04B471702495FAB08F6A3E8F5E6CA
    Fri,Jun,20,2014,11:02:27  VCDS Mobile 0.4108.0.4
    	VCID: 20037383A3E8F2D23B536F-5184
  17. Likes Eric, Uwe liked this post
  18. #20
    Jun 2014
    You returned my car full of fuel, nicely cleaned, with a new hex net and a bloke to help teach me.
    Class act. Thanks. Very much.
  19. Likes Uwe, Eric, jakematic, jyoung8607 liked this post
