Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Auto-Scan Testing: 2006 VW Phaeton W12
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    I own this car and usually have good access to it, but it happens to be waiting for some engine work at my dealer. Starting Wednesday morning it's going to be in pieces for a couple weeks. I could run another quick test tomorrow if needed, but anything that can't be run by tomorrow would have to wait a while.
    All of my testing was done with Beta 14.4.2/CB 4100. The car was parked with the engine running at idle. You will see a ton of no-communications DTCs because the dealer let the left-side battery go flat a couple times during diagnostics. My experience seems to line up with invisiblewave on his separate Auto-Scan thread.
    Things I noticed:
    • Address 01/11/31: Engine ECUs, Turbo Mode: I only had time to test this on HEX-USB+CAN, but huge progress in Beta 14.4.2! This was almost completely unusable before via any address. It looks like I can reliably switch to Turbo Mode on Address 01 (Engine 1) and Address 31 (Other/Combined). Curiously, I cannot shift to Turbo Mode on Address 11 (Engine 2). Since the car is technically in the dealer's custody right now I only had a little time and I couldn't drive it around and do extensive logging.
    • Address 31: Engine Other, MVB flipping: Looks like this is fixed in Beta 14.4.2! However, as with Turbo Mode above, I was only able to bang on it for a few minutes with my HEX-USB+CAN.
    • Address 07: Control Head: HEX-NET breaks down trying to talk to this device in any mode. It is the driver-facing "radio" in the Phaeton, and as many VW radios do, there's an indication on the screen when a diag session is up. This diag indicator was stuck-on indefinitely after the HEX-NET comms failures. I'm not sure whether Desktop or Mobile first triggered it. It only went away when I manually opened and closed a diag session with my HEX-USB+CAN interface. This module has always had some unique behavior in VCDS and it is very slow to respond to certain requests.
    • Address 37: Navigation: Same deal as address 07, except there is no diag session-in-progress indicator to see. The infotainment and navigation computers are separate physical devices, but made by the same company and share some of the same firmware. A change that fixes address 07 communication seems quite likely to fix address 37 as well.
    • Address 03: ABS Brakes: It looks like HEX-NET in VCDS Mobile mode ran into trouble. Desktop USB and Wifi were okay. I didn't notice that problem until after I got home, so I wasn't able to try replicating it or connecting to that module manually.
    • VCDS Mobile might have given my Phaeton a wedgie: [edit: VCDS Mobile got hung up on address 07 and could not move on, but the other strangeness I experienced was probably unrelated to VCDS Mobile]
    When I have more time with the car, I will try out HEX-NET ECU turbo and address 31 support, as well as Generic OBD2 which I didn't have a chance to try at all today.
    Baseline scan with HEX-USB+CAN:
    Monday,21,April,2014,17:21:51:05280
    VCDS Version: 14.4.2.0 (x64)
    Data version: 20140411
    VIN: WVWAK03D868005728   License Plate: 2006PHAETON
    Mileage: 120650km-74968mi   Repair Order: HEX-USB+CAN
    Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
              34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
    VIN: WVWAK03D868005728   Mileage: 120650km-74968miles
    Address 01: Engine        Labels: 07C-906-018-BAP1.lbl
       Part No SW: 07C 906 018 AJ    HW: 000 000 000 00
       Component: D1-6.0L-AT-LEV2 G  ª6722
       Revision: --H01---    Serial number: VWZ3Z0F7470400
       Coding: 0000173
       Shop #: WSC 01065 000 00000
       VCID: 6DDBB2F477855E538C-5120
    Readiness: 0110 1001
    Address 02: Auto Trans        Labels: 3D0-927-156.lbl
       Part No: 3D0 927 156 AB
       Component: AG5 01L 6.0lW12 USA 1010
       VCID: 68D5C3E058677B7BFF-513C
    Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
       Part No: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H33 0047
       Coding: 0008397
       VCID: 6BDFBCEC4991506392-5120
       Part No SW: 3D0 909 137 C    HW: 5WK 484 97
       Component: G1 Kessy            6700
       Revision: 67006015    Serial number: VWZ3Z0F7470400
       Coding: 0213228
       VCID: 275780DC95F9B40336-5120
    00087 - Terminal 30 for Starting Relevant Consumers
    Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
       Part No: 3D0 959 759 CA
       Component: Sitzmemory D1 BF    1720
       Coding: 0000003
       VCID: 77F7909C05D9E48366-5120
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3D0 035 008 Q
       Component:    ZAB COCKPIT      0253
       Coding: 0500345
       VCID: 285583E098E7BB7B3F-5120
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 J
       Component: Climatronic D1      2031
       VCID: 254B8AD4EFF5A61304-5120
    Address 09: Cent. Elect.        Labels: 3D0-937-049-V1.clb
       Part No: 3D0 937 049 H
       Component: STG.Bordnetz        5101
       Coding: 0000003
       Shop #: WSC 02605 444 64790
       VCID: 2F6768FCBD09EC43FE-5120
    Address 11: Engine II        Labels: 07C-906-018-BAP2.lbl
       Coding: 0000173
       Part No: 3D0 909 601 H
       Component: 04 Airbag 8.4E++H01 0554
       Revision: BB38727     Serial number: 0006635<
       Coding: 0012340
       Subsystem 1 - Part No: 3D0 959 339
       Component: BF-Gewichtsens. 006 0005
                        Date: 2064.00.00
                        Time: 00:00:00
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 E
       Component: Lenksäulenmodul     3401
       Coding: 0000232
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No: 3D0 920 982 B
       Component: KOMBIINSTRUMENT RB8 0521
       Coding: 0005221
    01336 - Data Bus for Comfort System
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70E5AB8060B7B3BBA7-5120
    Address 28: HVAC, Rear        Labels: 3D0-919-158.lbl
       Part No: 3D0 919 158 F
       Component: Klima-Bedienteil D1 0117
       VCID: 2E5975F8BA03E54BF5-5120
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       VCID: 66C9CDD852736D0BCD-5102
    Address 34: Level Control        Labels: 3D0-907-553-V2.clb
       Part No: 3D0 907 553 C
       Component: LUFTFDR.-CDC- 3C3V0 1122
       Coding: 0005531
       Shop #: WSC 53212 053 999999
                013 - Check DTC Memory
    Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
       Part No: 3D0 959 760 CA
       Component: Sitzmemory D1 F     1720
       Coding: 0000004
       VCID: 6FE7A8FC7D89AC43BE-5120
    Address 37: Navigation        Labels: 3D0-919-887.lbl
       Part No: 3D0 919 887 F
       Component:    NAVIGATION       0188
       Coding: 0400000
       VCID: 3777509C45592483A6-5120
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 C
       Component: Dachmodul           0708
       Coding: 0000015
       VCID: 234F94CCE1C158236A-5120
    00220 - Connection to Sunroof
    00926 - Terminal 30
       Part No: 3D0 909 158
       VCID: 67D7C0DC55797403F6-5102
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component: X3 HSG              0102
       Coding: 0000040
       Shop #: WSC 03325 444 13946
       VCID: 336F648C5121C8A39A-4AE6
       Subsystem 1 - Part No: 3D1 959 701 L
       Component: Tuersteuergeraet FS 6001
       Subsystem 2 - Part No: 3D1 959 702 L
       Component: Tuersteuergeraet BF 6001
       Subsystem 3 - Part No: 3D0 959 703 K
       Component: Tuersteuergeraet HL 6001
       Subsystem 4 - Part No: 3D0 959 704 K
       Component: Tuersteuergeraet HR 6001
       Subsystem 5 - Part No: 3D0 909 610 C
       Component: 3L HDSG             2330
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    6 Faults Found:
    01134 - Alarm Horn (H12)
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3D0 035 466 A
       Component: 12K-AUDIOVERST      0118
       VCID: 20459BC0F0D7433B77-5120
    Address 65: Tire Pressure        Labels: None
       Part No: 3D0 907 273 D
       Component: Reifendruckueberw.  0025
       Coding: 0411224
    00003 - Control Module
                014 - Defective - MIL ON
    Address 68: Wiper Electr.        Labels: 3D1-955-119.lbl
       Part No: 3D1 955 119 A
       Component: Front Wiper         2005
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
       VCID: 244D97D0E4CF5F1B13-5120
    Address 76: Park Assist        Labels: 3D0-919-283.lbl
       Part No: 3D0 919 283 D
       Component: 03 Einparkhilfe     0907
       VCID: 2B5F7CEC89119063D2-5120
    00434 - Left Front Inner Parking Aid Sensor (G332)
    Scan with HEX-NET using VCDS Desktop/USB:
    Monday,21,April,2014,17:41:10:21122
    Mileage: 120650km-74968mi   Repair Order: HEX-NET-USB
       Coding: 0000173
       VCID: 6D9208DC77C37C538C-5184
    Readiness: 0110 0001
       VCID: 689C79C85821597BFF-5184
       Coding: 0008397
       VCID: 6B9606C449D7726392-5184
       Coding: 0213228
       VCID: 271E3AF495BF960336-5184
       Coding: 0000003
       VCID: 77BE2AB4059FC68366-5184
    Address 07: Control Head        Labels: None
       VCID: 55E2403CBF53D49354-5184
    No Faults Found
       VCID: 250230FCEFB3841304-5184
       Coding: 0000003
       VCID: 2F2ED2D4BD4FCE43FE-5184
       Coding: 0000173
       Coding: 0012340
       VCID: 281C39C898A1997B3F-5184
                        Date: 2064.00.00
                        Time: 00:00:00
       Coding: 0000232
       Coding: 0005221
       Coding: 0000006
       VCID: 70AC11A860F191BBA7-5184
       VCID: 2E10CFD0BA45C74BF5-5184
       VCID: 668077F052354F0BCD-5160
       Coding: 0005531
       Coding: 0000004
       VCID: 6FAE12D47DCF8E43BE-5184
    Address 37: Navigation        Labels: None
    No Faults Found
       Coding: 0000015
       VCID: 23062EE4E1877A236A-5184
    00926 - Terminal 30
       VCID: 679E7AF4553F5603F6-5160
       Coding: 0000040
       VCID: 3326DEA45167EAA39A-4B3C
    6 Faults Found:
       VCID: 200C21E8F091613B77-5184
       Coding: 0411224
       VCID: 24042DF8E4897D1B13-5184
    No Faults Found
       VCID: 2B16C6C48957B263D2-5184
    Scan with HEX-NET using VCDS Desktop/Wifi:
    Monday,21,April,2014,18:04:11:21122
    Mileage: 120650km-74968mi   Repair Order: HEX-NET-Wifi
       Coding: 0000173
       VCID: ED9288DCF7C3FC530C-5184
    006435 - Please Check DTC Memory of ECU Number 2
                   P1923 - 008 -
                        Mileage: 120658 km
                        RPM: 372 /min
                        Load: 69.8 %
                        Temperature: 103.0°C
                        Temperature: 48.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 11.938 V
    Readiness: 0010 0001
       VCID: E89CF9C8D821D97B7F-5184
       Coding: 0008397
       VCID: EB9686C4C9D7F26312-5184
       Coding: 0213228
       VCID: A71EBAF415BF1603B6-5184
       Coding: 0000003
       VCID: F7BEAAB4859F4683E6-5184
       VCID: D5E2C03C3F535493D4-5184
    No Faults Found
       VCID: A502B0FC6FB3041384-5184
       Coding: 0000003
       VCID: AF2E52D43D4F4E437E-5184
       Coding: 0000173
    049408 - No Communication with Engine Control Module (SAE ECM/PCM)
                   U0100 - 004 -  - Intermittent
                        Mileage: 120658 km
                        RPM: 561 /min
                        Load: 17.2 %
                        Temperature: 104.0°C
                        Temperature: 51.0°C
                        Voltage: 13.208 V
       Coding: 0012340
       VCID: A81CB9C818A1197BBF-5184
                        Date: 2064.00.00
                        Time: 00:00:00
       Coding: 0000232
       Coding: 0005221
       Coding: 0000006
       VCID: F0AC91A8E0F111BB27-5184
       VCID: AE104FD03A45474B75-5184
       VCID: E680F7F0D235CF0B4D-5160
       Coding: 0005531
       Coding: 0000004
       VCID: EFAE92D4FDCF0E433E-5184
    No Faults Found
       Coding: 0000015
       VCID: A306AEE46187FA23EA-5184
    00926 - Terminal 30
       VCID: E79EFAF4D53FD60376-5184
       Coding: 0000040
       VCID: B3265EA4D1676AA31A-4B3C
    6 Faults Found:
       VCID: A00CA1E87091E13BF7-5184
       Coding: 0411224
       VCID: A404ADF86489FD1B93-5184
    No Faults Found
       VCID: AB1646C40957326352-5184
    Scan with HEX-NET using VCDS Mobile - Aborted:
    VCDS Mobile 0.41.0.4
    Chassis Type:3D
    Scan:
    Address 01: Engine	Labels:07C-906-018-BAP1.lbl
    	Part Number SW: 07C-906-018-AJ	HW: 00000000000
    	Revision: --H01---	Serial Number: VWZ3Z0F7470400
    	Coding: 0000173
    	VCID: 6D9D5AB724BAEFBAC06C-5184
    No fault codes found.
    Address 02: Auto Trans	Labels:3D0-927-156.lbl
    	Part Number SW: 3D0-927-156-AB
    	VCID: 68932BA30B58CA92B33A-5184
    Address 03: ABS Brakes	Labels:None
    	Part Number SW:
    	Component:
    	Shop #: WSC 00000 000
    	VCID: 55ED1257AC2AC77A187C-5184
    Address 05: Acc/Start Auth.	Labels:3D0-909-13x-05.lbl
    	Part Number SW: 3D0-909-137-C	HW: 5WK48497ÿ’
    	Revision: 67006015	Serial Number: VWZ3Z0F7470400
    	Coding: 0213228
    	VCID: 2711689FC6C605EA7AA0-5184
    	Subsystem 1 - 	Part Number: XXX-XXX-XXX-XX
    	Component: ELV                  XXXX
    Address 06: Seat Mem. Pass	Labels:3D0-959-759.lbl
    	Part Number SW: 3D0-959-759-CA
    	Coding: 0000003
    	VCID: 77B178DF56E6556A2A80-5184
    Address 07: Control Head	Labels:None
    	Part Number SW:
    	Component:
  2. Likes Santos, Uwe liked this post
  3. #2
    Cincinnati, OH
    VCDS Mobile might have given my Phaeton a wedgie ...
    Following up to myself -- I no longer think VCDS Mobile had anything to do with the ECU/CAN crash.
    When I checked the car again today, I could see the left-side (vehicle power supply) battery was not only flat, but quite thoroughly destroyed. I ran the car for about 10 minutes yesterday, turned it off and got out, and it didn't even take enough charge to support locking the doors with the remote. I brought my multi-meter today and it read about 1.9 volts. The battery is two years old, nothing was left plugged into the lighter sockets, and the car has no historical parasitic-drain problems. That's a $230 AGM battery, so tomorrow I'm going to have some words for the service manager about them running it flat during diagnostics and leaving it flat for weeks.
    Anyway, the ECU/CAN crash could easily be explained by a totally-nuked battery that can't buffer or supplement the alternator's output.
    Jason
  4. Likes Uwe liked this post
  5. #3
    Ouch. Sorry to hear about your battery. "Professionals" really should know better.
    Toronto, Canada
    I ran my first set of scans today with the new HEX-NET device and my 2004 W12 Phaeton.
    My experience was very similar to what Jason reported (note that he has a 2006 W12, mine is older, the engine are a little different). Here's a quick recap, I won't repeat the elaborations that Jason made in the first post at the top of this thread:
    Using VCDS 14.4.2 running on Windows 8.1 (a Microsoft Surface Pro tablet) and the HEX-NET gizmo, everything worked just fine except controllers 07 and 37 were not recognized. I repeated the scan 3 times, never was able to connect to these controllers.
    Using VCDS-Mobile running on my iPhone's Chrome browser and the HEX-NET device, the scan hung up at controller 07 and would not go any further.
    I regret I don't have the same level of savoir-faire as Jason when it comes to formatting posts here in the forum , hence I can't encase my scan log inside a nice scrollable window. So, below you will find the results of the scan.
    Some general comments and suggestions:
    1) For cars that have two engine controllers (W12, V10): It would be awfully nice if, when the user selects "clear all the fault codes", the application goes back and clears controller 01 a second time after doing the first clearing run. Controller 11 (the slave engine controller) has to be free of fault codes before the "go check the other engine controller" message will clear from controller 01. This means that two rinse cycles are needed to clear fault codes on cars with dual engine controllers if there is a fault present in the slave controller. Perhaps an easy way of implementing this would be for the application to take note of whether a controller 11 was recognized, and if so, set a flag so that after completing a "clear fault codes" run, it goes back and makes a second and final attempt to clear codes from controller 01. Note the message still present in controller 01 below - this report was generated immediately after running a "clear all fault codes" function.
    2) For some unknown reason, when VCDS 14.4.2 is running on a laptop computer with the HEX-NET gizmo connected, it shows references to "K-Line" up in the upper right corner of the screen. When VCDS 12.x is running with a conventional USB cable Ross-Tech device attached, it refers to CAN bus in the same place. Not sure if this is significant to you folks, thought I would mention it though.
    3) The first two times I ran a scan with the HEX-NET device, using the autoscan file provided, all the appropriate controllers were scanned, then controllers 01 and 02 were re-scanned and appended at the end (after controller 77). This did not happen on the third and subsequent scans.
    Michael's Phaeton
    VCDS Version: Beta 14.4.2 (x64)
    Tuesday,29,April,2014,19:07:16:33162
    VIN: WVWAH63D648008349   Mileage: 101390km-63000miles
       Part No SW: 07C 906 018 C    HW:
       Component: D1-6.0L-AG-LEV  G  ª5211
       Coding: 0000173
       VCID: A502B7996F600C1384-5184
    18331 - Please Check DTC Memory of ECU Number 2
                P1923 - 008 -
       Part No: 3D0 927 156 N
       Component: AG5 01L 6.0 W12 USA 1114
       Coding: 0000102
       Shop #: WSC 02137 444 53300
       VCID: B32659C1D1B462A31A-5184
       Part No: 3D0 614 517 R
       Component: ESP 5.7 allrad  H33 0043
       Coding: 0008397
       Shop #: WSC 93004 000 00000
       VCID: B12A53C92BA850B368-5184
       Part No SW: 3D0 909 137 A    HW: 5WK 470 19
       Component:    Kessy            6700
       Revision: 67005614    Serial number: VWZ3Z0C7093074
       Coding: 0133356
       Shop #: WSC 91426 999 83920
       Part No: 3D0 959 759 B
       Component: Sitzmemory D1 BF    1520
       Coding: 0000003
       Shop #: WSC 93004 999 52056
       VCID: B52267D9DFC07C9334-5184
       VCID: D5E2C7593F805C93D4-5184
    No Faults Found
       Part No: 3D0 907 040 H
       Component: Climatronic D1      2021
       VCID: A306A9816154F223EA-5184
    00711 - Left Footwell Flap Positioning Motor (V108)
       Part No: 3D0 937 049 G
       Component: STG.Bordnetz        5001
       Coding: 0000003
       Shop #: WSC 03004 999 58851
       VCID: AE1048B53A964F4B75-5184
       Coding: 0000173
       Part No: 3D0 909 601 D
       Component: 0A Airbag 8.4E+ H07 0934
       Coding: 0012353
       VCID: A404AA9D645AF51B93-5184
       Coding: 0000012
       VCID: AF2E55B13D9C46437E-5184
       Part No: 3D0 920 882
       Component: KOMBIINSTRUMENT RB4 0421
       Coding: 0005111
       Shop #: WSC 93004 999 183250
       VCID: E484EA9D24DAB51B53-5184
       Coding: 0000006
       VCID: F0AC96CDE02219BB27-5184
       VCID: E680F095D2E6C70B4D-5184
    Address 34: Level Control        Labels: 3D0-907-553-V1.clb
       Part No: 3D0 907 553 B
       Component: LUFTFDR.-CDC- 3C1V0 1101
       Coding: 0015500
       Shop #: WSC 91426 999 52450
       VCID: A600B0951266070B8D-5184
       Part No: 3D0 959 760 B
       Component: Sitzmemory D1 F     1520
       Coding: 0000004
       VCID: AD124FB9379034534C-5184
    No Faults Found
       Part No: 3D0 907 135 B
       Component: Dachmodul           0605
       Coding: 0000047
       VCID: A208AC857E4EFB2BE1-5184
       Component: EVG GDL+AutoLWR(r)  X012
       VCID: E79EFD91D5ECDE0376-5184
       Component: 1A HSG              0100
       Coding: 0000040
       VCID: B32659C1D1B462A31A-4B3C
       Subsystem 1 - Part No: 3D1 959 701 E
       Component: Tuersteuergeraet FS 0104
       Subsystem 2 - Part No: 3D1 959 702 E
       Component: Tuersteuergeraet BF 0104
       Subsystem 3 - Part No: 3D0 959 703 E
       Component: Tuersteuergeraet HL 0104
       Subsystem 4 - Part No: 3D0 959 704 E
       Component: Tuersteuergeraet HR 0104
       VCID: A00CA68D7042E93BF7-5184
    Address 57: TV Tuner        Labels: 3D0-919-146.lbl
       Part No: 3D0 919 146
       Component: TV Tuner        H07 1205
       Coding: 0000010
       VCID: E582F7992FE0CC1344-5184
       Part No: 3D0 907 273 G
       Component: Reifendruckueberw.  0026
       Coding: 0310224
       VCID: AA1844A5067E236BA9-5184
    Address 66: Seat, Rear        Labels: None
       Part No: 3D0 959 860 C
       Component: Sitzmemory D1 H     1724
       Part No: 3D0 915 181 C
       Component: Batteriemanagement  2700
    No Faults Found
       Part No: 3D0 919 283 C
       Component: 03 Einparkhilfe     0807
       Shop #: WSC 00099 000 00000
  7. Likes jyoung8607, Uwe liked this post
  8. #5
    Toronto, Canada
    Also, I would like to reiterate my offer to drop my Phaeton off at your facility in mid-May and pick it up again in early July. I'll be out of the country during that time, and you are most welcome to use the car for software development during that time. It is fully insured and, except for the one small problem with a HVAC flap motor, it works perfectly. No charge of any kind to you guys, except that maybe you could give me a ride to the local Greyhound bus depot after I drop it off.
    Michael
  9. Likes jyoung8607, Uwe liked this post
  10. #6
    Michael, you just need to stick [ code ] [ /code ] directives around your scan to put it into a scrolling box.
  11. #7
    Cincinnati, OH
    Quote Originally Posted by PanEuropean View Post
    Welcome!
    Use CODE tags to wrap your scan. Similar to how you use QUOTE on vwvortex, use [ CODE ] at the beginning and [ /CODE ] to end (no spaces). Uwe started asking people to do that, and it does make threads easier to scroll through.
    Jason
  12. #8
    Greyhound? No way will I let you suffer that on our behalf. I did one long trip on Greyhound in back in 1977 after which I said: "Never again, I'd rather ride a bicycle or hitch-hike!".
    If we take you up on this, we'll either buy you a ticket back to Toronto on an airliner, or give you a car, or one of my bikes (06 FJR or 07 VFR). However, since the big issues aren't W12 specific, I'm thinking finding the a much more common V8 car locally is what we should shoot for.
  13. Likes jyoung8607 liked this post
  14. #9
    Cincinnati, OH
    I see some more dual-ECU love in Beta 14.5.0/CB 4102. Thanks! I'll give it a try sometime tomorrow.
    Does the other K-line work have anything to do with our address 07/37 issue?
    Jason
  15. #10
    I don't think it specifically addresses that problem but all feedback is welcome.
