Results 1 to 10 of 10
Thread: Help me understand the way the modules all communicate...having several random issues
    Aug 2015
    All,
    I have a 2010 VW CC. Here's the deal...I bought the car as a flood vehicle. The shop that sold me the car put everything together so I'm not completely sure about all that was done.
    Anyway I was originally having (and still am) issues with the DSG. No issues after I first bought the car but then months later it started bucking when I came to a stop. Shortly thereafter I was coming home after the car sat for several hours and I got a transmission overheat warning. I read about the G509 sensor so I changed it out and all was good for a short time. However the problem soon reappeared...bucking when shifting into or out of D, then the overheat warning and being stranded
    I just got VAGCOM and started looking into what the heck was going on. After speaking with one of the techs at Ross-Tech I was advised that the sensor might have been a bad part. I was seeing the G509 sensor go to 200C which was triggering the overheat warning. So, I put another sensor in the car and the overheat is now fixed. However the bucking issue is still there. I have now twice done the adaptation to no avail. While monitoring the Valve Current and Main Pressure-Valve current 1 and 2 I found that when shifting into D the values jump all over the place while it is bucking...the values finally settle down and the bucking stops. This also happens when shifting out of D and into N or P. I'm thinking mechatronic...not sure but I think it might be connected to the other issues.
    The other issues are that I am now getting a lot of other random faults. Here's the scan
    Tuesday,18,August,2015,23:06:36:06166
    VCDS Version: 15.7.0.1 (x64)
    Data version: 20150729
    VIN: WVWMN7AN9AE545401   License Plate:
    Chassis Type: AN (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 53 56 62 65
              72 77
    VIN: WVWMN7AN9AE545401   Mileage: 130720km-81225miles
    65-Tire Pressure -- Status: Not registered 0011
    Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
       Part No SW: 06J 906 026 DA    HW: 06J 906 026 DA
       Component: MED17.5 TFSI 2,0    6987
       Revision: AAH15---    Serial number: VWZCZ000000000
       Coding: 0404010A1C070160
       Shop #: WSC 05666 444 12371
       VCID: 6CF9331F4F93E15E9A-8038
    008801 - Boost Pressure Control Valve (N249)
                   P2261 - 000 - Mechanical Malfunction
                        Mileage: 130708 km
                        Date: 2015.08.18
                        Time: 22:46:34
                        RPM: 1436 /min
                        Load: 11.0 %
                        Speed: 72.0 km/h
                        Temperature: 98.0C
                        Temperature: 43.0C
                        Absolute Pres.: 1010.0 mbar
    Readiness: 0100 0100
    Address 02: Auto Trans        Labels: 02E-927-770.lbl
       Part No SW: 02E 300 053 A    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2106
       Revision:    51112    Serial number: 00001002030119
       Shop #: WSC 05311 000 00000
       VCID: 130B48E3326D9EA6FB-8046
       Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
       Component: J104    C4 440 V2   0015
       Revision: --025---    Serial number: 00000104033482
       Coding: 0000380
       VCID: 62E55D27BD57A72E20-8036
    Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       Shop #: WSC 05311 115 00000
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 75CF167BD4D9209675-8020
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Revision: 00H54000    Serial number: 00000003631607
       Coding: F1848F8B40041A0047970F00170000000028FB475C40017C174000000000
       Shop #: WSC 05124 000 00000
       VCID: 334BE863522D7EA69B-8066
       Subsystem 1 - Part No: 3C8 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 141209 022  0613
       Coding: 00046997
       Shop #: WSC 05124
       Component: RLS     040210 054  0403
       Coding: 00209133
       Shop #: WSC 05124
    02399 - Control Circuit for Terminal 30 for Interior Illumination
                        Fault Status: 00111001
                        Reset counter: 176
                        Mileage: 130664 km
                        Voltage: 12.80 V
    00059 - Terminal 30 for Interior Lighting
                        Fault Status: 00101100
                        Reset counter: 176
                        Mileage: 130664 km
                        Voltage: 13.60 V
       Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
       Component: J234__30S VW10 HI   1918
       Revision: 22014000    Serial number: 003JZP67EMSU
       Coding: 0012371
       VCID: 4BBB90832ADD0666F3-801E
       Subsystem 1 - Part No: 3C8 959 339 A
       Component: BF-Gewichtsens. 003 0001
       Subsystem 2 - Serial number: 00000000003FM7
       Subsystem 3 - Serial number: 0009.03.110000300000660077†63
       Subsystem 4 - Serial number: 660077†6332MTS601363429 †63
       Subsystem 5 - Serial number: 63429 †6342MTS662033439 †63
       Subsystem 6 - Serial number: 33439 †6351HTS6BJQ286KJ †63
       Subsystem 7 - Serial number: 286KJ †6361HTS68BO386KJ †63
       Subsystem 8 - Serial number: 386KJ †63727TS6I1J6U9KR †63
       Subsystem 9 - Serial number: 6U9KR †63827TS6GEU7U9KJ
       Subsystem 10 - Serial number: 7U9KJ
    Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Component: LENKS.MODUL   009 0122
       Revision: FF010035    Serial number: 20100130100119
       Coding: 098A270002
       ASAM Dataset: EV_VW360SteerWheelUDS A03002
       VCID: 6BFB3003829DE66693-803E
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
       Coding: E20000
    Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
       Part No SW: 3C8 920 970 M    HW: 3C8 920 970 M
       Component: KOMBI         H03 0305
       Coding: 240F00
       Shop #: WSC 05314 115 00000
       VCID: 364DD177895F6B8EBC-8062
    Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0172
       Revision:   H13       Serial number: 3620P102020187
       Coding: FD807F06001612009002
       Shop #: WSC 05314 123 12345
       VCID: 2F43E413BE055A46FF-807A
                000 -  -
                        Reset counter: 136
                        Mileage: 130655 km
       Part No SW: 3C8 919 965     HW: 3C8 919 965
       Revision: 00001000    Serial number: 1614128T1J2702
       Shop #: WSC 05314 000 00000
       VCID: 75CF167B1CD9209675-8020
       Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
       Component:    IMMO         052 0383
       Revision: 00052000    Serial number: VWZCZ000000000
       VCID: 78D11F4F0BCB5DFE6E-802C
       Subsystem 1 - Part No: 3C0 905 861 H
       Component:    ELV          028 0380
       3C0905861H     ELV          028 0380
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Revision: A1001003    Serial number: 7667742293
       VCID: 266D013751FF1B0E0C-8072
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0501
       Revision: 12110009    Serial number: 0002610350
       Coding: 0004B7
       ROD: EV_TSGFPQ35BRFVW46X.rod
       VCID: 6DFF3E1BBC89E8568D-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0401
       Serial number: 00000001282294
       Coding: 000490
       Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.141 0703
       Revision: 1AH03726    Serial number: 00093280408002
       Coding: 0000258
       VCID: 3A55C54775478FEE58-806E
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 RDK 052 0412
       Coding: 13910F8001862E521204141FF08A0F0E085801
       Part No SW: 1T0 959 702 AC    HW: 3C0 959 792 A
       Component: TUER-SG BT    002 0307
       Revision: 14101005    Serial number: 0000396309
       Coding: 0004B6
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide.rod
       VCID: 79D71A4BF8C144F611-802C
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0401
       Serial number: 00000001261638
       Coding: 000490
    67330 - Switch for Central Locking
              B122D 29 [008] - Signal Implausible
                        Reset counter: 176
                        Mileage: 130669 km
                        Date: 2015.08.17
                        Time: 18:50:26
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000292046
       Coding: 0021057
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H10 0035
       Revision: -----20S    Serial number: VWZ4Z7K1107818
       Coding: 0100040004
       VCID: 61E7522B7851BC3639-8034
                000 -  -
                        Reset counter: 134
                        Mileage: 130655 km
                        Date: 2015.08.17
                        Time: 04:19:33
       Component:    RDK              0453
       Coding: 0100101
                        Fault Status: 01110100
                        Mileage: 130675 km
                        Date: 2015.08.18
                        Time: 00:43:15
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 5K0 035 730     HW: 5K0 035 730
       Component: TELEFON       H09 1020
       Revision: 1B001001    Serial number: 00007669671225
       Coding: 0A00000000010100
       Shop #: WSC 00015 115 00000
       ASAM Dataset: UHVNA A01009
       ROD: UHVNA.rod
       VCID: 62E55D277557A72E20-8036
    9457427 - Left audio channel for speech/telephone
              B104F 13 [009] - Short to GND
                        Fault Frequency: 20
                        Reset counter: 138
                        Mileage: 130655 km
                        Date: 2015.08.17
                        Time: 04:20:04
    9458195 - Control Module for Cellular Telephone
              B1052 13 [009] - Open Circuit
                        Reset counter: 135
                        Mileage: 130655 km
                        Date: 2015.08.17
                        Time: 04:20:04
    End-------------------------(Elapsed Time: 02:00)--------------------------
    So, I'm thinking there's something going on electrically that is causing all of this. I did just do an LED light install so that might be the reason for the interior light fault but I bought them from a reputable shop and they aren't supposed to trip any codes. The engine fault happened after the G509 install and the rest of the codes did as well. Maybe I bumped something but I noticed the main harness that leads into the cabin from the engine bay is loose and can easily be moved with my hand.
    What I'm trying to figure out is how all of the modules communicate. If the J533 is where everything comes together maybe there is something going on there or maybe it's something completely different. I've checked all the grounds (to include removing the wires, cleaning them and reinstalling) so I don't think that's the issue...
    If anyone has anything to contribute and can maybe get me on the right path I'd appreciate it. I'm not afraid to tear the dash apart if need be but I don't want to do that if there's nothing to be found there...
    Thanks!
    HQ
    Auto-Scan on the your first post!
    The CAN Gateway is not coded for the Tire Pressure Monitoring. You need to add TPMS to the Gateway Installation List. That should resolve the 01044 - Control Module Incorrectly Coded fault code. But this is a minor issue really.
    Maybe the new lights are causing your Terminal 30 fault codes in the J519. They are listed as "Intermittent", so do they clear out and stay out? Or do they keep coming back? If those codes in the J519 keep getting reflagged, then put the original bulbs back in and see if that fixes the issue.
    As for the DSG trans... there are no codes, so from the transmissions point of view, everything is fine. It could be a failing mechatronic unit, but don't $$$ based on my statement alone.
    Jef
    Aug 2015
    Hi Jef,
    I'm still trying to get the system figured out...not sure how to add things to the gateway installation list. I just ran a control module finder with CAN only selected and the TPMS shows up so doesn't that mean that the car already knows it's there since it's finding it?
    Address 01: Engine
       Protocol: CAN
       Part No: 06J 906 026 DA
       Shop #: WSC 05666
       Protocol: CAN
       Part No: 02E 300 053 A
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 3C0 614 109 AF
       Coding: 0000380
       Shop #: WSC 05311
    Address 15: Airbags
       Protocol: CAN
       Part No: 5N0 959 655 Q
       Coding: 0012371
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 3C8 920 970 M
       Coding: 240F00
       Shop #: WSC 05314
       Protocol: CAN
       Part No: 5N1 909 144 K
       Coding: 0000258
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 3C0 959 433 AP
       Shop #: WSC 131071
       Protocol: CAN
       Part No: 3AA 907 801 E
       Coding: 0021057
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 3C0 907 530 Q
       Shop #: WSC 05314
       Protocol: CAN
       Part No: 3C8 937 049 E
       Shop #: WSC 05124
       Protocol: CAN
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 3C8 959 701
       Coding: 0004B7
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 1T0 959 702 AC
       Coding: 0004B6
       Shop #: WSC 05311
       Protocol: CAN
       Component:    RDK              0453
       Coding: 0100101
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 3C5 953 501 BG
       Coding: 098A270002
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 3C8 907 336 AJ
       Coding: 0000001002
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 3C8 919 965
       Shop #: WSC 05314
    Address 56: Radio
       Protocol: CAN
       Part No: 1K0 035 180 AC
       Coding: 0100040004
       Shop #: WSC 05311
       Protocol: CAN
       Part No: 5N0 035 342 B
       Shop #: WSC 05314
       Protocol: CAN
       Part No: 5K0 035 730
       Shop #: WSC 00015
    Sorry for the question, but I've tried to search and everyone just says to add things to the gateway but I can't find anywhere that actually says how to do it.
    Light code was cleared and hasn't reappeared.
    In regards to the DSG, here's an earlier log. The transmission would do it's bucking and then the indicator on the dash would flash. I would be able to engage D but not R and the MIL would activate. Here's what it would show
    19143 - Unexpected / Implausible Mechanical Gear Disengagement
    P2711 - 004 -
    Fault Frequency: 255
    Reset counter: 40
    Mileage: 130657 km
    Date: 2015.08.17
    Time: 00:23:31
    Since the bucking is happening again I think it's only a matter of time before this situation happens again...
    Thanks for the help!
    Aug 2015
    Oh and this was a scan reading from a week ago...
    Component: RDK 0453
    Coding: 0100101
    So I have no idea why it was fine a week ago and now it's not...
    To add your TPMS to the Gateway's installation list (necessary since the Gateway claims it's "unregistered"):
    [Select]
    [19-CAN Gateway]
    [Installation List]
    Scroll down to 65-Tire Pressure
    Put a check-mark in the box.
    [Save Coding]
  6. #6
    Aug 2015
    Uwe,
    Thanks for the reply and have the coding fixed. Now for a new problem...
    The CAN is happy but now I'm getting this
    Component: RDK 0453
    Coding: 0100101
    Mileage: 130720 km
    Date: 2015.08.19
    Time: 22:44:31
    I went into the MEA values and was able to see all four wheels. The problem is none of the tires have an output value for tire pressure. So, for some reason none of the tires are being seen by the system.
    So, looks like I can turn the system on and then get a dash light telling me that there is an error with the TPMS (no input from the wheels) or turn the system off and the CAN will show a fault. I'd like to find out how to fix the system but I guess worst case scenario I'll just turn the system off and the CAN will have an error.
    If anyone can share an idea of how to fix this I'd appreciate it.
    Thanks again!
  7. #7
  8. #8
    Aug 2015
    It no workie...tried all 4 tires and none of the sensors "woke up". I even drove around the block with the tires low. Nada. I checked everything else like last sensor to send the signal (block 16)...that was N/A or blank and finally checked block 25 and wheel 1 was the one indicated. Soooo....looks like nothing is working for some reason.
    The procedure also mentions tho that no fault code should be stored...mine does have a fault code as indicated above and it comes on instantly if cleared. Guess for now I'm just going to go back into the CAN coding and turn the system off so I don't have that friggin light in the dash. Very frustrating tho as I know this system was working previously...
  9. #9
    HQ
    Quote Originally Posted by gasnhaul View Post
    2010 model, so maybe it is time to replace the sensors?
    Jef
  10. Likes Uwe liked this post
  11. #10
    Aug 2015
    Could be, but what are the odds of all 4 failing simultaneously?
