Results 1 to 7 of 7
Thread: Boost pressure control valve (n249) fault - leon fr 1pz
    May 2015
    HI ALL,
    KEEP GETTING FOLLOWING FAULT IN ENGINE MANAGEMENT SYSTEM, HAVE REPLACED N249 SOLENOID BUT FAULT RE-APPEARS. HAVE ALSO CHECKED WASTEGATE, PIPES AND HOSES FOR OPERATION/CONDITION - ALL OK.
    MANY THANKS FOR YOUR HELP
    Chassis Type: 1P (1K0)
    VIN: VSSZZZ1PZ7R008061   Mileage: 131310km-81592miles
    Address 01: Engine        Labels: 06F-907-115-AXX.lbl
       Part No SW: 1P0 907 115     HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0040
       Revision: --H14---    Serial number: SEZ7Z0F3505878
       Coding: 0303000318070160
       Shop #: WSC 64018 476 92338
       VCID: 68D5B6C75BAB5E7EFE-803C
    008801 - Boost Pressure Control Valve (N249)
                   P2261 - 008 - Mechanical Malfunction
                        Fault Status: 01101000
                        Mileage: 131308 km
                        Time: 19:02:45
                        RPM: 2737 /min
                        Load: 12.2 %
                        Speed: 86.0 km/h
                        Temperature: 90.0C
                        Temperature: 42.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.970 V
    Readiness: 0010 0001
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 06441 785 00200
       VCID: 73EFD1AB126DADA65B-8026
       Part No: 1P0 907 044
       Component: ClimatronicPQ35 009 0402
       VCID: 69D3B3C340A16776E1-803C
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Revision: 00H37000    Serial number: 00000004162570
       Coding: 818C0F2F00041000001D00000000000000007F075C
       VCID: 2B5F09CB8ADDB566D3-807E
       Subsystem 1 - Part No: 1P0 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer SE350  012  0403
       Coding: 00056272
       Shop #: WSC 06441
       Part No SW: 3C0 909 605 H    HW: 3C0 909 605 H
       Component: R5 AIRBAG VW8   027 2521
       Revision: 09027000    Serial number: 003A1PANTR21
       Coding: 0021045
       Subsystem 1 - Serial number: 6332MSME0E1A1A7F
       Subsystem 2 - Serial number: 6342MSME0F133413
       Subsystem 3 - Serial number: 6351HTS6QLLM0PB3
       Subsystem 4 - Serial number: 6361HTS6QLLILAH2
       Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
       Component: J0527           634 0070
       Coding: 0002042
       VCID: 77F7E5BB0615C18667-8022
       Component: E0221           005 0060
       Part No: 1P0 920 925 B
       Component: KOMBIINSTRUMENT VO3 0422
       Coding: 0002401
       Shop #: WSC 00999 444 64523
       VCID: 2E5900DFB9CFC04EF4-807A
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Revision:   H12       Serial number: 31001065158587
       Coding: 3D3F034007000203
       VCID: 2C5D0AD78FD3B25EDA-8078
       Component: IMMO            VO3 0422
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1124
       Revision: 11006001    Serial number: 00000504768523
       Coding: 0000688
       VCID: 3B7F398B7ABD25E643-806E
    00914 - Window Regulator Switch; Rear Left; Driver (E53)
                        Reset counter: 132
                        Mileage: 131249 km
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.142 H07 1806
       VCID: 356B2FB35C99F396B5-8060
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Component:    KSG PQ35 G2  020 0202
       Coding: 198000005283CC7F0006050560085F86107C80
       VCID: 030F816B42CD9D264B-8056
       Subsystem 5 - Part No: 1P0 951 171
       Component: Innenraumueberw.010 4971
       Coding: 00000000
       Shop #: WSC 06441
       Subsystem 7 - Component:       NGS n.mounted
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1124
       Revision: 11006001    Serial number: 00000509968527
       Coding: 0000688
       VCID: 3C7D3A977FB322DE4A-8068
       Part No: 1P2 035 186 A
       Component: Radio BVX           0006
       Coding: 0042424
       Shop #: WSC 04941 785 00200
       Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
       Component: J388   TUER-SG HL   1103
       Revision: 11004001    Serial number: 00000000098919
       Coding: 0000144
       Part No SW: 1K0 959 704 N    HW: 1K0 959 794 H
       Component: J389   TUER-SG HR   1103
       Revision: 11004001    Serial number: 00000000104092
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:56)--------------------------
    16.4905 S, 151.7375 W
    HAVE YOU had a chance to look at this Ross-Tech wiki page?
    18693/P2261/008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    Wiring/Connectors - ? - maybe?
    Hope that helps,
    drpeter
  3. Likes Uwe, Jack@European_Parts liked this post
    Feb 2016
    Trying to understand this better:
    Are these all the same?
    Parts store: Turbocharger Cut Off Bypass Valve
    Repair manual: Turbocharger Recirculating Valve N249
    Vag-Com: Boost Pressure Control Valve N249
    Forums: DV (Turbo diverter valve)
    Any more names?
    (neme used by parts store ?
    It's unbelievable to
    Have you checked the actual diverter " by pass valve "?
    Quote Originally Posted by elkm36a View Post
    I'm reasonably confident they're all referring to the same thing.
    Any more names?
    Ricers like to call it the "blow off valve".
  7. Likes Jack@European_Parts liked this post
    Also "Secondary boost control valve" or "emergency boost control valve".............
    "Turbo boost pulse protection valve"
  9. Likes Uwe liked this post
  10. #7
    Some others...
    - Pop-off valve
    - "Blow-off valve" - (Like Uwe said) (I hear that a lot, I call it the diverter valve).
    - Just to clarify:
    The diverter valve is the actual part that is doing the diverting of boost pressure back into the intake stream when you let off the throttle,
    this way you do not 'stall the turbo' with backed up boost pressure after the throttle plate closes, because the turbo is still spinning and
    you want this so you do not have to re-spool the turbo each time the throttle closes, like when you are shifting gears.. etc.
    The N249, is an electrical solenoid that the ECM controls to regulate the vacuum to the above diverter valve.
    The ECM can watch the boost pressure with the G31 pressure sensor and when the throttle plate closes,
    the boost pressure should not increase, because the diverter valve is commanded open. If the pressure does increase,
    the ECM suspects the diverter valve has not opened and sets the fault.
    Hope this helps,
    drpeter
  11. Likes Uwe, Jack@European_Parts liked this post
