Results 1 to 7 of 7
Thread: Boost pressure control valve (n249) fault - leon fr 1pz
Threaded View
    May 2015
    HI ALL,
    KEEP GETTING FOLLOWING FAULT IN ENGINE MANAGEMENT SYSTEM, HAVE REPLACED N249 SOLENOID BUT FAULT RE-APPEARS. HAVE ALSO CHECKED WASTEGATE, PIPES AND HOSES FOR OPERATION/CONDITION - ALL OK.
    MANY THANKS FOR YOUR HELP
    Chassis Type: 1P (1K0)
    VIN: VSSZZZ1PZ7R008061   Mileage: 131310km-81592miles
    Address 01: Engine        Labels: 06F-907-115-AXX.lbl
       Part No SW: 1P0 907 115     HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0040
       Revision: --H14---    Serial number: SEZ7Z0F3505878
       Coding: 0303000318070160
       Shop #: WSC 64018 476 92338
       VCID: 68D5B6C75BAB5E7EFE-803C
    008801 - Boost Pressure Control Valve (N249)
                   P2261 - 008 - Mechanical Malfunction
                        Fault Status: 01101000
                        Mileage: 131308 km
                        Time: 19:02:45
                        RPM: 2737 /min
                        Load: 12.2 %
                        Speed: 86.0 km/h
                        Temperature: 90.0C
                        Temperature: 42.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.970 V
    Readiness: 0010 0001
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 06441 785 00200
       VCID: 73EFD1AB126DADA65B-8026
       Part No: 1P0 907 044
       Component: ClimatronicPQ35 009 0402
       VCID: 69D3B3C340A16776E1-803C
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Revision: 00H37000    Serial number: 00000004162570
       Coding: 818C0F2F00041000001D00000000000000007F075C
       VCID: 2B5F09CB8ADDB566D3-807E
       Subsystem 1 - Part No: 1P0 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer SE350  012  0403
       Coding: 00056272
       Shop #: WSC 06441
       Part No SW: 3C0 909 605 H    HW: 3C0 909 605 H
       Component: R5 AIRBAG VW8   027 2521
       Revision: 09027000    Serial number: 003A1PANTR21
       Coding: 0021045
       Subsystem 1 - Serial number: 6332MSME0E1A1A7F
       Subsystem 2 - Serial number: 6342MSME0F133413
       Subsystem 3 - Serial number: 6351HTS6QLLM0PB3
       Subsystem 4 - Serial number: 6361HTS6QLLILAH2
       Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
       Component: J0527           634 0070
       Coding: 0002042
       VCID: 77F7E5BB0615C18667-8022
       Component: E0221           005 0060
       Part No: 1P0 920 925 B
       Component: KOMBIINSTRUMENT VO3 0422
       Coding: 0002401
       Shop #: WSC 00999 444 64523
       VCID: 2E5900DFB9CFC04EF4-807A
    Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
       Revision:   H12       Serial number: 31001065158587
       Coding: 3D3F034007000203
       VCID: 2C5D0AD78FD3B25EDA-8078
       Component: IMMO            VO3 0422
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1T0 959 701 G    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1124
       Revision: 11006001    Serial number: 00000504768523
       Coding: 0000688
       VCID: 3B7F398B7ABD25E643-806E
    00914 - Window Regulator Switch; Rear Left; Driver (E53)
                        Reset counter: 132
                        Mileage: 131249 km
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.142 H07 1806
       VCID: 356B2FB35C99F396B5-8060
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Component:    KSG PQ35 G2  020 0202
       Coding: 198000005283CC7F0006050560085F86107C80
       VCID: 030F816B42CD9D264B-8056
       Subsystem 5 - Part No: 1P0 951 171
       Component: Innenraumueberw.010 4971
       Coding: 00000000
       Shop #: WSC 06441
       Subsystem 7 - Component:       NGS n.mounted
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 1T0 959 702 G    HW: 1K0 959 792 M
       Component: J387  TUER-SG BT    1124
       Revision: 11006001    Serial number: 00000509968527
       Coding: 0000688
       VCID: 3C7D3A977FB322DE4A-8068
       Part No: 1P2 035 186 A
       Component: Radio BVX           0006
       Coding: 0042424
       Shop #: WSC 04941 785 00200
       Part No SW: 1K0 959 703 N    HW: 1K0 959 795 H
       Component: J388   TUER-SG HL   1103
       Revision: 11004001    Serial number: 00000000098919
       Coding: 0000144
       Part No SW: 1K0 959 704 N    HW: 1K0 959 794 H
       Component: J389   TUER-SG HR   1103
       Revision: 11004001    Serial number: 00000000104092
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:56)--------------------------
