Results 1 to 1 of 1
Thread: Passat ABS woes.
    Mar 2016
    Passat ABS woes.
    Hello folks,
    First time to post so be gentle!
    Got this VW Passat that came in with ESP lamp on and code 00810 Sensor for Brake pressure sensor.
    Tried basic setting procedure but no joy, sent ABS unit off for testing/repair; but was informed that brake pressure sensor is not available for this unit separately. Testing/repair company managed to get a used ABS unit and refurbished it for me. However after refitting and coding pressure sensor basic setting still cannot be accomplished Group 066.3 in the adaption menu states “not OK”! Is the replacement unit faulty or should I be looking for some other problem such as faults in other systems?
    P.S. lost the coding on the ABS unit and had to use the coding helper to work out the coding also parking brake malfunction indicated (although working fine).
    Many thanks for looking
    Mark.
    Tuesday,15,March,2016,10:43:34:34373
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 15.7.3.0
    Data version: 20151216
    VIN: WVWZZZ3CZ7P029714   License Plate: PK07TUY
    Mileage: 101350km-62975mi   Repair Order: ROBI
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 7D
    VIN: WVWZZZ3CZ7P029714   Mileage: 101350km-62975miles
    Address 01: Engine        Labels: 03G-906-016-BKC.lbl
       Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
       Component: R4 1,9L EDC  000SG  9248
       Revision: --H02---    Serial number: VWZCZ000000000
       Coding: 0000071
       Shop #: WSC 00028 028 00001
       VCID: 7AF0195A35591CEE3F-802E
    006215 - Please check DTC Memory of ABS Controller
                   P1847 - 000 -
                        Mileage: 101354 km
                        Time: 19:43:53
                        (no units): 0.00
                        Voltage: 12.46 V
                        (no units): 0.00
                        Bin. Bits: 00000000
                        (no units): 8.15
                   P1653 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 101354 km
                        Time: 19:43:55
                        Load: 0.0 %
                        Voltage: 12.46 V
                        Bin. Bits: 11000010
                        Torque: 0.0 Nm
                        Bin. Bits:  0 01  0
    Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
       Part No SW: 3C0 614 095 P    HW: 3C0 614 095 P
       Component: ESP 440 C2     H015 0003
       Revision:  H015       Serial number: 0658409373
       Coding: 0010000
       VCID: 2F66F80EBE9B0946D8-807A
                000 -  -
                        Mileage: 101354 km
                        Time: 19:44:16
                        Mileage: 101354 km
                        Time: 19:44:16
                        Mileage: 101354 km
                        Time: 19:44:16
                        Mileage: 101354 km
                        Time: 19:44:16
                        Mileage: 101354 km
                        Time: 19:44:16
       Part No: 1K0 820 047 FH
       VCID: 6FE6380E7E1B494698-803A
       Part No SW: 3C0 937 049 H    HW: 3C0 937 049 H
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000004268934
       Coding: 00800F0700041A00000A00000F000000000859435C0000
       Shop #: WSC 38264 001 1048576
       VCID: 2E58E50AB991004ED3-807A
       Subsystem 1 - Part No: 3C2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 38264
       Part No SW: 3C0 909 605 J    HW: 3C0 909 605 J
       Component: 05 AIRBAG VW8   029 2521
       Revision: 09029000    Serial number: 003A2PBQEVSL
       Coding: 0012341
       VCID: 2D5AE206B4977B56EA-8078
       Subsystem 1 - Serial number: 6332MSME10716357
       Subsystem 2 - Serial number: 6342MSME10070D5F
       Subsystem 3 - Serial number: 6351HTS6PLLEPO82
       Subsystem 4 - Serial number: 6361HTS6QLL2FLI2
       Part No SW: 3C0 953 549 A    HW: 3C0 953 549 A
       Component: Lenksäulenmodul 007 0010
       Revision: 00007000    Serial number: 3C5953507A
       Coding: 0000003
       VCID: 2A50E91A85796C6E0F-807E
       Part No SW: 3C0 920 960 K    HW: 3C0 920 960 K
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: X0006000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 00999 067 57207
       VCID: 2B5EEC1E8A837566F4-807E
    Address 19: CAN Gateway        Labels: 3C0-907-530-V1.clb
       Revision: 00007000    Serial number: 0700C0661906CA
       Coding: 3D3D2C04C21003
       VCID: 21420E36F84FAF365E-8074
       Part No SW: 3C0 959 433 M    HW: 3C0 959 433 M
       Component:    IMMO         042 0383
       VCID: 346CF76257BD2A9EA5-8060
       Subsystem 1 - Part No: 3C0 905 861 F
       Component:    ELV          026 0380
       3C0905861F     ELV          026 0380
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
       Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
       Component: J386  TUER-SG FT    1132
       Revision: 31008001    Serial number: 00000014688423
       Coding: 0000565
       Shop #: WSC 61755 001 1048576
       VCID: 3C7CDF427FEDE2DE6D-8068
                        Fault Status: 01100101
                        Reset counter: 185
                        Mileage: 101354 km
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.134 H07 1806
       VCID: 356ACA665CC7339692-8060
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component:    KSG PQ46 ELV 042 0472
       Coding: 01910A0801860E763004941570085BCE103CA0
       Subsystem 1 - Component:   Sounder No Answer
       Subsystem 2 - Part No: 3C0 951 171 A
       Component: Neigungssensor  002 0508
       Subsystem 3 - Part No: 3C0 951 171 A
       Component: Innenraumueberw.002 0508
    01134 - Alarm Horn (H12)
                        Reset counter: 185
                        Mileage: 101354 km
                        Time: 19:41:30
       Component: J387  TUER-SG BT    1124
       Revision: 12006001    Serial number: 00000647168708
       Coding: 0000564
       Revision:   013
       Coding: 0010000
                000 -  -  - MIL ON
                        Reset counter: 185
                        Mileage: 101352 km
                        Time: 18:45:22
                        Voltage: 12.53 V
                        Count: 171
                000 -  -  - MIL ON
                        Reset counter: 185
                        Mileage: 101352 km
                        Time: 18:45:22
                        Voltage: 12.42 V
                        Count: 170
    01316 - ABS Control Module
                        Fault Status: 11101101
                        Reset counter: 185
                        Mileage: 101352 km
                        Time: 22:57:22
                        Voltage: 11.80 V
                        Count: 236
       Part No: 1K0 035 186 R
       Component: Radio GR0       019 0023
       Revision: 0001905S    Serial number: VWZ2Z2F1587685
       Coding: 0020200
                014 - Defective
    End-------------------------(Elapsed Time: 01:49)--------------------------
