Results 1 to 3 of 3
Thread: Audi 8K _ footwell light dimming
    Romania
    I try to reactivate the foot lights dimming on an A4 8K platformm and it's not reconigzed by the MMI - I also activated on 5F and 09 Centr.Electr. It appears on MMI menu but not working. Any ideeas? Scan listed below:
    Monday,21,April,2014,19:31:08:56830
    VCDS Version: 14.4.0.3
    Data version: 20140411
    Workshop Code: 823 02391 056573
    VIN: WAUZZZ8K6AA184103   License Plate:
    Mileage: 72210km-44869mi   Repair Order:
    Chassis Type: 8K (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 18 19 20 3C 42 46 52 53 55 56
              5F 62 6D 72
    VIN: WAUZZZ8K6AA184103   Mileage: 72210km-44869miles
    Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
       Part No SW: 03L 906 022 MK    HW: 03L 906 022 B
       Component: R4 2,0L EDC   H04 8441
       Revision: 11H04---
       Coding: 0104002C02172018
       Shop #: WSC 20771 142 93681
       ASAM Dataset: EV_ECM20TDI03L906022MK A01009
       ROD: EV_ECM20TDI03L906022C.rod
       VCID: 7AF007C1FD02A7EB0E-802F
    5182 - Particulate Trap Bank 1
              P2002 00 [096] - Efficiency Below Threshold
    5231 - Fuel Rail/System Pressure
              P0087 00 [096] - Too Low
    Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
       Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 H
       Component: 0AW 20TDI RdW H05 0009
       Revision: --H05---    Serial number: 0000000068
       Coding: 000002
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMVL381 A02017
       ROD: EV_TCMVL381.rod
       VCID: 77F61EF5CE10BA8371-8022
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 BD    HW: 8K0 907 379 BD
       Component: ESP8 front    H04 0030
       Coding: 174508
       VCID: 7CFC01D9FF3699DB1C-8029
       Part No SW: 8K0 907 064 DQ    HW: 8K0 907 064 DQ
       Component: BCM2 1.1      H02 0328
       Coding: 010200
       VCID: 02007F219DD2EF2B56-8057
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H50 0070
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01170520101881
       Coding: 34180000
       VCID: 0004752993DEFD3B40-8055
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H29 0380
       Revision: 10029001    Serial number: 00000000669267
       Coding: 260050914074AF010001000300001D0D0F1C470802010141000000
       Shop #: WSC 61904 000 1048576
       VCID: 3C7CC1D9BFB659DB5C-8069
       Component: WWS 150510  H06 0070
       Coding: 00FD11
       Component: RLS  H04 0003
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
    Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
       Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
       Component: PARKHILFE 8K  H06 0070
       Revision: 11001001    Serial number: 50941013003266
       Coding: 100103
       VCID: 4894AD09FB6E057BC8-801D
    Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
       Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GKD0GCAFJ
       Coding: 30343435363030303030554A304C384B3053
       ROD: EV_AirbaECUVWAUDI010_AU48.rod
       VCID: 448CB939CF46211B24-8011
       Serial number: 6334MSME53162D66F
       Serial number: 6344MSME53356B018
       Serial number: 6352QSME225D02067
       Serial number: 6362QSME70611E029
       Serial number: 63732SME60611A04R
       Crash sensor for front airbag; passenger side:
       Serial number: 63832SME3C5F4816B
       Revision: --------    Serial number: 90315JEJ000EG
       Coding: 000013
       VCID: 3D7ACCDDA4AC50D36B-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
       Component: KOMBIINSTR.   H21 0255
       Revision: 00000000    Serial number: CIY58LD5A
       Coding: 0F06100002000008000000
       VCID: 2E58FB9179CABB4BE2-807B
    Address 18: Aux. Heat (J364)       Labels: 8R0-265-105.clb
       Part No SW: 4H0 265 105 A    HW: 4H0 265 105 A
       Component: Standheizung  H20 0230
       Revision: 34003004    Serial number: 20100422102634
       Coding: 5D2000
       VCID: 204415A9331E1D3B60-8075
       Part No SW: 8T0 907 468 AE    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0117
       Revision: FC100058    Serial number: 5800F105020163
       Coding: 00C303
       VCID: 040C793987C6E11B64-8051
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
    Address 20: High Beam Assist. (J844)       Labels: 8K0-857-511.clb
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 02019164747464545425363E
       VCID: 336EEAE592E896A38D-8066
       Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0030
       Revision: 00H01000    Serial number: 6PZ 009 014-82
       Coding: 0000102
       VCID: 3C7CC1D97FB659DB5C-8069
       Subsystem 1 - Part No: 8K0 907 568 H
       Component: J0770_SWA_Slave_H01 0030
       Subsystem 2 - Serial number: 6PZ 009 014-92
       Subsystem 3 - Serial number: 5F19.05.1000H010003C322037˙
       Subsystem 4 - Serial number: 322037˙
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000010674403
       Coding: 011C02205000410001
       VCID: 458AA43DCC7C181333-8010
       Revision: 00002001    Serial number: 0130130245
       Coding: 01000620203934800120023280000000
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000010644337
       VCID: 448CB939C746211B24-8011
       Revision: 00000003    Serial number: 10000000520016
       VCID: 346CE9F997E6919B94-8061
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06334 000 00000
       VCID: 77F61EF50610BA8371-8022
       Part No SW: 4F0 035 056 B    HW: 4F0 035 056
       Component: Radio U STD   H45 0020
       Revision: AB001007    Serial number: 342E60A7809989
       Coding: 010003020100000001
       VCID: 1F4616550E6022C359-804A
       Part No SW: 8T1 035 666 E    HW: 8T1 035 666 E
       Component: H-BN-EU       H47 0047
       Revision: --------    Serial number: 483E10A7626495
       Coding: 01010001010683ED11000B1E000000030001
       Subsystem 1 - Part No: 8R0 060 884 J
       Component: EUR 2010  1005
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
       Component: E0380 Bedient  H08 0100
       Subsystem 4 - Part No: 8R0 906 961 A
       Component:   CD-Database  1293
                        Fault Frequency: 11
                        Reset counter: 134
                        Mileage: 72147 km
                        Date: 2014.04.19
                        Time: 21:20:23
                        Bin. Bits: 10110110 00001010
                        Bin. Bits: 00000100 00001110
                        Bin. Bits: 00000000 00000000
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 134
                        Mileage: 72147 km
                        Date: 2014.04.19
                        Time: 21:20:23
                        Bin. Bits: 00100001 00010000
                        Bin. Bits: 00000000 00001010
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000104585539
       Coding: 010C02204000210001
       VCID: 4280BF21DD522F2B16-8017
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Component: J605  Master  H50 0330
       Revision: --------    Serial number: 8K9827851A
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Component: J756  Slave  H50 0330
    Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000104585540
    Last edited by Uwe; 04-22-2014 at 09:08 AM. Reason: Wrapped CODE tags around Auto-Scan
    United States
    Did you follow David's instructions here?
    http://www.audienthusiasts.com/VagComINLight.html
    Romania
    Sorry for the late replay. Thanks for the link Dana. The dimming works fine until the friend's wife try to stop them. After that operation the dimming won't to come back to the original settings. Now I departured form the Germany where my friend live. I will suggest him to check if the green/hidden menu is activated as listed in the link provided. Thanks you a lot again. Cheers.
