Results 1 to 9 of 9
Thread: 2013 Touareg trailer hitch install, coding
    Question 2013 Touareg trailer hitch install, coding
    I have recently had a factory trailer hitch installed on a 2013 Touareg, and would like to know how to change the coding to put power on pin 4 to charge trailer batteries, and also how do I disable the rear hatch from opening when trailer is plugged in to the Touareg?
    Full scan below...
    VCDS Version: Release 12.12.2
    Data version: 20140212
    Saturday,19,April,2014,10:03:19:16316
    Chassis Type: BP (7P6)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 55 56 5F 62 65
              69 6C 6D 72
    VIN: WVGEF9BP1DD010341
    Address 01: Engine (J623-CGRA)       Labels: None
       Part No SW: 03H 906 023 BC    HW: 03H 907 309 E
       Component: 3,6 FSI ULEV  H16 3947
       Revision: M7H16---
       Coding: 002A0012433600000000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM36FSI01103H906023BC 002002
       ROD: EV_ECM36FSI01103H906023BC.rod
       VCID: 64CDA3D16F64033E1FF-8031
    Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
       Part No SW: 0C8 927 750 BC    HW: 0C8 927 750 BC
       Component: AL1000 AISIN  001 2264
       Coding: 001368
       ASAM Dataset: EV_TCMAL991031 002114
       ROD: EV_TCMAL991031.rod
       VCID: 6ED9C1F9B1A8B96E79B-803B
    Address 03: ABS Brakes (J104)       Labels: 7P0-907-379.clb
       Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
       Component: MK25A         H36 0446
       Revision: --------    Serial number: 434620010EC815
       Coding: 5B7613C349252553DAF7C89792D3A4407300
       ASAM Dataset: EV_MK25AXT 008001
       ROD: EV_ESPMK25A00800.rod
       VCID: 4A916D69ED80B54E053-801F
       Part No SW: 4H0 907 064 CK    HW: 4H0 907 064 CK
       Component: BCM2 2.0      H33 0433
       Coding: 09860010000000000000
       VCID: 74EDD391D78493BE8FF-8021
       Subsystem 1 - Part No SW: 7P6 959 754 AD    HW: 7P6 959 754 AD
       Component: FBSTOUAREGIDG  H04 0051
    Address 08: Auto HVAC (J255)       Labels: 7P6-907-040.clb
       Part No SW: 7P6 907 040 BK    HW: 7P6 907 040 BK
       Component: Klima 2 Zonen H20 1305
       Coding: 4606200A80
       VCID: 7EF9F1B9E1C8C9EEE9B-802B
    15360256 - Component Protection
              U1101 00 [008] - Active
    Address 09: Cent. Elect. (J519)       Labels: 4H0-907-063.clb
       Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
       Revision: 15012002    Serial number: 00000001487897
       Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
       VCID: 6CDDCBF18FB44B7E57F-8039
       Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-
    119.CLB
       Component: WWS    121113  031 0021
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-
    955-559.CLB
       Component: RLFS  H10 0020
       Coding: 025223
       Component: E1 - LDS  H04 0031
       Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
       Component: USHL4.2  H30 0020
       Part No SW: 7P0 959 655 C    HW: 7P0 959 655 C
       Component: VW10Airbag02F H05 0025
       Revision: --------    Serial number: 003L00061D45
       Coding: 000000000000000000000000000000003246
       ROD: EV_AirbaVW10BPAVW526_VW52.rod
       VCID: 41834A45D0B67616D49-8014
       Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
       Component: BF-Gewichtss.  003 0005
       Serial number: 5850000R1262909XDD
       Serial number: 3575LRB40124UNBC817A
       Serial number: 3585LRB401A4UNBC60T
       Serial number: 3515RRB40064UPDMPGLU
       Serial number: 3525RRB40064UPDMO24%
       Serial number: 3555NRB400E4UPTEDQ4R
       Crash sensor for front airbag; passenger side:
       Serial number: 3565NRB400A4UPTEG1DB
       Part No SW: 4H0 953 568 F    HW: 7P6 953 507 L
       Revision: --------    Serial number: 90815LKU0001N
       Coding: 000015
       VCID: 366929998178C1AE71B-8063
    Address 17: Instruments (J285)       Labels: 7P6-920-xxx-17.clb
       Part No SW: 7P6 920 981 E    HW: 7P6 920 981 E
       Component: Kombi         H13 0318
       Revision: 13240077    Serial number: 658171112592024
       Coding: 8B7732022B00CF05020004
       ASAM Dataset: EV_KombiUDSRBVW526 001017
       ROD: EV_KombiUDSRBVW526.rod
       VCID: 3F874CBDA64200E6A2D-806A
       Part No SW: 7P6 907 530 F    HW: 7P6 907 530 F
       Component: GW-CAN-L-MOST H11 6028
       Revision: --------    Serial number: 00000000778896
       Coding: 0021035600
       ASAM Dataset: EV_GatewVW526UDS 001007
       ROD: EV_GatewUDS_VW52.rod
       VCID: 3B7F38ADB25A1CC68E5-806E
       Serial number: 00000000004190824160
       Revision: AA000000    Serial number: 00000046595309
       Coding: 0058130000004001000001010101202020202121202020
       VCID: 346D13919704D3BE4FF-8061
       Part No SW: 4H0 959 793 N    HW: 4H0 959 793 F
       Component: TSG FA        H07 0166
       Revision: --------    Serial number: 0000132615965
       Coding: 011D07205E00453005080000
       VCID: 448D4351C7A4633EFFF-8011
    Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0188228077
       Coding: 0186123A28B9509480B00620210000000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
       Component: GTO BT  H19 0059
       Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
       Component: J245 PS30.055  H01 0008
       Coding: 191100
       Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
       Component: J394 PS30.055  H01 0008
       Coding: 191100
       Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
       Component: TSG BF        H07 0166
       Revision: --------    Serial number: 0000132695352
       VCID: 3B7F38ADBA5A1CC68E5-806E
    Address 53: Parking Brake (J540-)       Labels: 7P0-907-801.clb
       Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
       Component: EPB           H51 1201
       Revision: 00000000    Serial number: C12B0800034
       Coding: 01040200
       ROD: EV_ParkbA7.rod
       VCID: 366929998978C1AE71B-8063
       Slave 3:
    Address 55: Xenon Range (J745)       Labels: 7P6-907-357.clb
       Part No SW: 7P6 907 357     HW: 7L6 907 357 C
       Component: AFS-ECU       H04 0110
       Coding: 010A00010F000400
       ROD: EV_HeadlRegulVWAFSPt.rod
       VCID: FCFD7BB177D45BFE47F-80A9
       Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Coding: 130000
       Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
       Coding: 130000
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 156LB0C7649466
       Coding: 020007020100000001
       VCID: 2143EAC538F65616B49-8074
       Part No SW: 7P6 035 664 C    HW: 7P6 035 664
       Component: H-BN-NA       H45 0544
       Revision: --------    Serial number: 445L30C7542439
       Coding: 010200050040E1EE41022B0C00000003F0000101
       VCID: 387527A18B6C37DE637-806D
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: DU8 SV Touch  H26 0045
       Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
       Component: CD-Database  1886
       Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
       Component: TSG HL        H09 0167
       Revision: --------    Serial number: 0000132904445
       Coding: 011C07200000253005080000
       VCID: 3A713DA9B56025CE953-806F
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
       Component: RDKBERU25     H09 0008
       Serial number: 20000000006509
       ROD: EV_RDKBERU25_VW52.rod
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
       Component: Anhaenger     H11 0110
       Revision: 5A001001    Serial number: 00000188830750
       Coding: 020D000000000000
       Part No SW: 7P6 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0020
       Revision: 00H06000    Serial number: 525 PA8J2X1316
       Coding: 0110001
       VCID: 3777249D467238A66AD-8062
    Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
       Part No SW: 7P6 959 107 C    HW: 7P6 959 107
       Component: HDSG-Modul    H10 0043
       Revision: 22010001    Serial number: 310200626
       Coding: 0533314003
       ASAM Dataset: EV_HeckkTouar 202142
       ROD: EV_HeckkTouar.rod
       Component: TSG HR        H09 0167
       Revision: --------    Serial number: 0000132904371
    Last edited by Uwe; 04-21-2014 at 09:44 AM. Reason: Wrapped CODE tags aorund Auto-Scan
    United States
    I received your PM but I do not have any personal experience with that retrofit. I suspect those are configured online at the VW dealer using SVM (Software Version Management). If this was a retrofit kit please post the part number so we can see if installation or configuration instructions are available.
    The best place to get help from the greatest variety of different people would be in our Retrofits sub-forum but you aren't a verified user at this time. Please post the short serial number from the part the plugs into the car so the guys can switch you to a VCDS Verified user.
    -Dana
    Ref: C?ID=56963
    On my Hex=CAN 429122?
    It is factory installed and I have seen its possible to change the coding on the slightly earlier Touareg to change the coding to put power on pin 4 to charge trailer batteries, and also how do I disable the rear hatch from opening when trailer is plugged in to the Touareg?
    I believe they were changing the coding from a 1 to a two.
    United States
    Quote Originally Posted by veedabowlu View Post
    Thanks Robert. We found that file, tweaked your forum account to Verified VCDS user and moved this thread to the Retrofits section yesterday.
    Was this a retrofit kit from the VW dealer or did you purchase the parts individually? Any additional information you can provide would be helpful so we can see if VW installation or configuration instructions are available.
  5. Likes Uwe liked this post
    100% factory install...
    Bump, any update for this?
    United States
    OK, per the VIN PR Code 1D6 Trailer hitch is listed so it should have been properly configured from the factory. If you believe it is not when compared to other VW Touareg models I would send this vehicle to the VW dealer so they can dig into that.
    I do not know if the power supply you are after is possible and the 6D: Trunk Elect. controller is coded for Trailer Hitch Installed so I do not have an explanation for the hatch operation. If you don't receive any other replies here you may want to post in one of the Touareg specific forums to see if they have solutions to either one of these concerns.
  9. #8
    Jun 2014
    Newcastle, England
    What type of trailer socket was installed? If it was the Euro 13 pin style (ISO11446) then pin 4 is not used for charging the trailer battery - it's the right turn signal indicator...
    The charging function is on pin 10+ and pin 11- and even for factory installations, you 'enable' it with a small wiring harness that has a relay driven from terminal 15 (ignition switched live).
    You may have 12N/12S sockets and you refer to pin 4 on 12S? Again, you need to add the harness.
  10. Likes Dana liked this post
  11. #9
    Verified VCDS User andreizx12's Avatar
    Nov 2015
    Romania
    In 08 HVAC you must go to long coding and select the trailer hitch byte .
