Results 1 to 10 of 12
Thread: How to actively monitor boost PSI
    Jun 2015
    I have a HEX-NET. How do i setup active monitoring for boost psi, egt, engine temp, etc...?
    Couldn't begin to tell you until you tell us what kind of car you have. The preferred method would be for you to post an Auto-Scan so we can see exactly what ECU your car has.
    Jun 2015
    I have a 2015 VW Passat. I'm looking to use VCDS/VCDS Mobile as a boost gauge.
    Friday,10,July,2015,14:44:37:49139
    VCDS Version: 14.10.2.0
    Data version: 20150311
    VIN: 1VWCV7A37FC009301   License Plate: ADB8823
    Mileage: 34630km-21518mi   Repair Order: 07102015
    Chassis Type: A3 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
              52 56 62 72 75 77
    VIN: 1VWCV7A37FC009301   Mileage: 34630km-21518miles
    Address 01: Engine (J623-CVCA)       Labels: None
       Part No SW: 04L 906 016 AF    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 8417
       Revision: 8AH20---
       Coding: 011D0012032410089000
       Shop #: WSC 41657 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906016AF 001014
       ROD: EV_ECM20TDI01104L906016AE.rod
       VCID: ED9289163C2E8D49359-80B8
       Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
       Component: GSG DSG AG6     521 4509
       Revision: 05652104    Serial number: 00001404052843
       Shop #: WSC 09003 957 00200
       VCID: A502B1366C5E7509BD9-80F0
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: C54BC0F549220003A30E03E4921A0042A1100012
       VCID: FEB0BE5A694806D19C3-80AB
    Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
       Revision: 00092000    Serial number: 0332322625
       Coding: 130C0C
       ROD: EV_KESSYPQ35G_AU21.rod
       VCID: B73E6B7E0EF2F7991F5-80E2
       Part No SW: 561 907 044 AP    HW: 561 907 044 AP
       Component: Climatronic   H03 0707
       Revision: 00001K01
       Coding: 0010019012
       ROD: EV_ACClimaBHBVW411_VW41.rod
       VCID: E582F136E4DEB5097D9-80B0
       Part No SW: 5K0 937 087 AE    HW: 5K0 937 087 AE
       Component: BCM PQ35 H+   122 0174
       Revision: BL122001
       Coding: EF200E3B982B08D4098802013600854800F1A08645A005B064806000BC70
       VCID: F8BCA8424B6C38E1D6F-80AD
       Component: RLS 290514 05  54  0403
       Coding: 02300A
       Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
       Component: AirbagVW10    500 0975
       Serial number: 003LZD018ST9
       Coding: 00004D32
       VCID: F2A89A6A251052B1E8B-80A7
       Serial number: 6940000Y1400016MTW0J
       Coding: 303047
       Serial number: 3572MSME6E6B6A44ZZZB
       Serial number: 3582MSME312C6A44ZZZ-
       Serial number: 3516KSME7B12782EZZZ+
       Serial number: 3526KSME050D572DZZZZ
       Serial number: 3556LSME0703372EZZZU
       Serial number: 3566LSME1D6B352EZZZ7
       Part No SW: 1K5 953 521 BR    HW: 5K0 953 569 AH
       Revision: FF010042    Serial number: 20140530200383
       Coding: 000A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: FEB0BE5A614806D19C3-80AB
       Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
       Component: E221__MFL-YVJ  H07 0022
       Coding: E20000
       Part No SW: 561 920 970 G    HW: 561 920 970 G
       Component: KOMBI         H04 0813
       Coding: 231C01
       VCID: 9E709EDA8108A6D1FC3-80CB
       Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1653
       Revision:   H55       Serial number: 28061403000506
       Coding: 461000
       VCID: 804CC0A213BC7021EEF-80D5
       Component: IMMO          H04 0813
       Coding: 000007
       VCID: EA98820A0DC09A7150B-80BF
    Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
       Revision: 00000000    Serial number: 14000125876005
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: B02C5062EB9C20A15EF-80E5
    Address 2E: Media Player 3
       Part No SW: 561 959 760 B    HW: 561 959 760 B
       Component: MEM-FS        H04 0182
       Revision: AA000000    Serial number: 00000105342645
       Coding: 00581B0000000000000021010100202020202120202020
       VCID: A208AA2ABD708231D8B-80F7
    Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
       Part No SW: 3C0 035 684 N    HW: 3C0 035 684 N
       Component: RNS-MID       H26 5378
       Revision: AB001001    Serial number: VWZ6Z7P3158088
       Coding: 04090042010000A4000B
       VCID: AE104E1AF9A836514C3-80FB
       Subsystem 1 - Part No: 7L6 919 859
       Component: NAR V8  8112
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0525
       Revision: 12110009    Serial number: 0008552180
       Coding: 0405FD
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 9C7494D29714B4C1127-80C9
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630140613191023
       Coding: 800000
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 215    3501
       Revision: 00H22000
       VCID: B93A6D46F0E6E1E9E91-80EC
       Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
       Component: KonzernAmp10K H08 6815
       Revision: --------    Serial number: EAA098A0144697
       VCID: A600B63AD9587E11B43-80F3
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1653
       Coding: 01030108
       VCID: EFAE931E3E227F59075-80BA
       Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
       Component: J245 P05 9BA3  H08 0005
       Coding: 181100
       Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0525
       Revision: 14110009    Serial number: 0008587165
       Coding: 0405FC
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 9D7299D68C0EBDC9E59-80C8
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B
       Component: J389__TSG_HR  006 5470
       Serial number: 14102631140627144210
       Coding: 800000
    Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
    Address 75: Telematics (J949)       Labels: None
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0102
       Serial number: 000003554140523
       Coding: 02140102C2423A007F1606000000
       ROD: EV_OCULow_SE12.rod
       VCID: D3E63FEEBA4A3BB903D-8086
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 159
                        Mileage: 34633 km
                        Date: 2015.07.10
                        Time: 14:41:40
    Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
       Component: TELEFON       H05 0592
       Revision: 1B001001    Serial number: 00007666170901
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: AE104E1AF1A836514C3-80FB
    End-------------------------(Elapsed Time: 02:38)--------------------------
  4. Likes Uwe liked this post
    [Select]
    [Installed]
    [01-Engine]
    [Functions]
    [Live Data HUD]
    [Create New]
    Click on the Gauge gadget.
    On it's configuration pop-up, click [Set Measuring value]
    - For "boost" on your engine, try "Intake manifold pressure"
  6. Likes mabnz liked this post
    HQ
    Your Engine Control Module (ECM) is the UDS type. To that end, click on the [Adv. Meas. Values] button and you will get a list of live data that can be viewed... all 883 of them.
    Note that boost pressure PSI will not be in a PSI scale since this VW/Audi uses the metric system.
    Locations 070 to 084 look to show boost information.
    Location 300 is "Exhaust gas recirculation temperature"
    Location 104 is "Coolant temperature".
    When you go into [Adv. Meas. Values], there is a search box at the top of the list so you can search for key words.
    Jef
    Jun 2015
    Using Uwes method, and selecting gauges, and set the measure value, and set the type as PSI. you can get virtual gauges using VCDS mobile via Web interface or VCDS app. The gauge will convert to PSI I think. It's very handy! I was boosting max about 23 PSI at a WOT pull.
  9. Likes Uwe liked this post
  10. #7
    Jun 2015
    Quote Originally Posted by abishoff View Post
              52 56 62 72 75 77
       Revision: 8AH20---
       Revision: 00H46001
       Coding: 130C0C
       Revision: 00001K01
       Coding: 0010019012
       Revision: BL122001
       Coding: 02300A
       Coding: 00004D32
       Coding: 303047
       Coding: 000A140000
       Coding: E20000
       Coding: 231C01
       Coding: 461000
       Coding: 000007
       Coding: 0405FD
       Slave Driver:
       Coding: 800000
       Revision: 00H22000
       Coding: 01030108
       Coding: 181100
       Coding: 0405FC
       Slave Passenger:
       Coding: 800000
                        Fault Priority: 8
                        Reset counter: 159
                        Mileage: 34633 km
                        Date: 2015.07.10
                        Time: 14:41:40
       ROD: EV_UHVUMI.rod
    [Select]
    [Installed]
    [01-Engine]
    [Functions]
    [Live Data HUD]
    [Create New]
    Uwe what is used for o2 lamda, air intake temp, and Exhaust temp?
  11. #8
    Please browse through the list or try typing in keywords.
  12. #9
    Jun 2015
    Can you please explain the difference between these values?
    Intake manifold press. sensor; act. value calculated [loc 40066]
    Intake manifold pressure; act. value calculated [loc 43297]
  13. #10
    Nope, I don't have more detailed info than what's in VCDS.
